I'm using a french configuration with "language=fr, default" for login and password input.
The problem is that the CAPS LOCK does not work for keys other than alphabetic characters
a -> A (OK)
z -> Z (OK)
, -> , (KO, should give ?)
; -> ; (KO, should give .)
& -> & (KO, should give 1)
é -> é (KO, should give 2)
I'm using the last version 5.8.74.
Can you fix this keymapping ?
Keyboard caps lock problem
Re: Keyboard caps lock problem
Try wtware 5.8.76.
Thanks again for your reactivity, problem solved except for the key '*' that don't give 'µ'.
Add to config:
Reboot terminal. Press key '*' several times, with shift and without. Save and show me the log: https://wtware.com/logs.html
keyboard_log=on
In fact, the key is reversed :
'µ' without caps lock (Should be '*')
'*' with caps lock (Should be 'µ')
Yes, all is good.
Many thanks !
Yes, all is good.
Many thanks !
