Page 1 of 2
Cant set dual 4k monitors Raspberry Pi 4
Posted: Sat Aug 17, 2019 3:22 am
by jeremy
I can set a single monitor to 4k60 with hdmi_enable_4kp60=1 but this mode doesnt work for dual monitors. The pi 4 can only support 4k30 for dual monitors.
On raspian it auto detects the 4k monitors and sets it to 4k30, I cant for the life of me find a way to set it in the config file for this mode using WTware.
Re: Cant set dual 4k monitors Raspberry Pi 4
Posted: Sat Aug 17, 2019 10:13 am
Hello,Send me your terminal log to
support@wtware.com
Here's the manual about making logs:
http://wtware.com/logs.html
Posted: Sat Aug 17, 2019 6:28 pm
by jeremy
Log sent.
Posted: Wed Aug 21, 2019 9:44 am
by cwt
I have a similar problem with 2x DELL 24" monitors running at 1920x1200px. Only one monitor shows a picture, the second one has a signal (backlight is enabled and the status LED is "white") but shows nothing.
Raspberry Pi4B, 1GB RAM
RPi config entry:
[HDMI:0]
hdmi_group=2
hdmi_mode=69
[HDMI:1]
hdmi_group=2
hdmi_mode=69
Posted: Wed Aug 21, 2019 1:37 pm
The same question: do these two monitors run in Raspbian? If so, send me your config.txt from Raspbian SD.
Also, run in Raspbian command line:
dmesg > /tmp/dmesg.txt
and send me file /tmp/dmesg.txt
Posted: Wed Oct 16, 2019 11:13 am
by cwt
I found a solution for my problem.
Added this entry within WTWARE config menu to my Raspberry config.txt:
Save the file and reboot. When the login to RDP window appears both monitors are used correctly.
Posted: Mon Dec 02, 2019 1:05 pm
by ysammy8
Hi cwt
What model monitor do you use?
Posted: Fri Dec 06, 2019 7:47 pm
by cwt
ysammy8 wrote: Mon Dec 02, 2019 1:05 pm
Hi cwt
I use DELL U2415 monitors with direct HDMI connections.
Posted: Tue Dec 10, 2019 3:31 pm
by frujo
we have an similar problem and no way runs as described before.
We use Raspberry Pi4 1GB RAM with WTware current version 5.8.88 and tried to connect 2 equal monitors (iiyama 27" ProLite XB2783HSU) via HDMI connector. Only 1 monitor (HDMI:0) shows picture, second monitor (HDMI:1) has a signal but shows nothing.
In Raspbian both monitors shows pictures.
The steps before my post we have done but no success. We tried different resolutions and connectors, the problem still resits.
Can anyone help us please?
Posted: Tue Dec 10, 2019 10:40 pm
Manufacturer site:
https://iiyama.com/gl_en/products/prolite-XB2783HSU-B3/
Native resolution 1920 x 1080
It's not 4k monitors.
Posted: Wed Dec 11, 2019 10:28 am
by frujo
Good morning,
yes, it´s not 4k monitors (I should have opened a new topic?)
But it doesn´t work and I can´t find the problem to send the picture on both monitors.
Posted: Wed Dec 11, 2019 12:46 pm
frujo wrote: Wed Dec 11, 2019 10:28 am
Good morning,
Yes. For 1920x1080, you do not need 4k magic. It should just work with default settings.
https://wtware.com/logs.html
Posted: Wed Dec 11, 2019 1:59 pm
by frujo
thx for your answer, the log files I have sent to
support@wtware.com
Posted: Wed Dec 11, 2019 5:36 pm
frujo
Two regular 1920x1080 displays should work out of box if user does not prevent them from working. Format SD card and install wtware on SD again. It will restore config.txt you broke. Also, remove all lines from config as logging manual says:
2. Remove all lines from terminal configuration file. Absolutely all.
And write config with only two simple lines:
You should get menu on first monitor and blue fill on second.
Posted: Thu Dec 12, 2019 11:30 am
by frujo
Good morning akatik,
thank you for your answer.
I have format the SD card, install new wtware version on it and remove all lines from config.txt.
Now the Raspberry Pi doesn´t boot wtware. I tried different SD cards, different wtware versions, but no variant run ...
If I start with Raspian the Raspberry Pi start normal, also with two monitors.
I will looking for the issue next day.
