				Chanege network interface via web...?
				Posted: Thu Aug 08, 2019 2:33 am
				by mixtype
				Hello
I have to change network interface  (from wifi to Ethernet) but unfortunately i haven't locally access to Rpi3
Is there any way to change under web ?
Thx for your help
				Re: Chanege network interface via web...?
				Posted: Thu Aug 08, 2019 8:03 am
				No. Network options are only configured locally.
				Posted: Thu Aug 08, 2019 9:09 am
				by mixtype
				Thank you
Are you consider to enable this possibility in the future upgrades ?
				Posted: Sat Aug 10, 2019 9:45 am
				I'm not sure we should enable so easy way to shoot yourself in the foot. Device will not be able to run web interface after reboot in case of any mistake in network configuration and will be unusable until you come to RPi physically.
