Intel Cherry Trail - Dual Display
Posted: Tue Jan 08, 2019 10:01 pm
Hello all!
I'm attempting to get a Z83 Intel Cherry Trail machine to work with dual displays. It has an HDMI out and a VGA out. When I boot into WTware without specifying monitor configuration, only the Intel(U) driver, I can see in the logs the monitor designations:
However when I attempt to configure The 'display' setting with 'DisplayPort' and 'M2_display' as 'HDMI2' I get black screens. It seems that X is having trouble mapping the monitors:
I have attached the logs from both scenarios for your consideration
[ gm] [ 27.330780] DP1: display 510x290mm.
[ gm] [ 27.331056] DP2: no display found.
[ gm] [ 27.331550] HDMI1: no display found.
[ gm] [ 27.332012] HDMI2: display 510x290mm.
[ gm] [ 27.332924] VIRTUAL1: no display found.Code: Select all
[ X] [ 22.102172] [ 22.102] (==) intel(0): Default visual is TrueColor
[ X] [ 22.102235] [ 22.102] (**) intel(0): Option "ZaphodHeads" "DisplayPort1"
[ X] [ 22.103986] [ 22.103] (--) intel(0): Using a maximum size of 256x256 for hardware cursors
[ X] [ 22.104800] [ 22.104] (II) intel(0): Output VIRTUAL1 using monitor section Monitor0
[ X] [ 22.104837] [ 22.104] (**) intel(0): Option "PreferredMode" "1024x768"
[ X] [ 22.104862] [ 22.104] (II) intel(0): Enabled output VIRTUAL1
[ X] [ 22.104908] [ 22.104] (II) intel(0): EDID for output VIRTUAL1
[ X] [ 22.104935] [ 22.104] (II) intel(0): Output VIRTUAL1 disconnected
[ X] [ 22.104957] [ 22.104] (WW) intel(0): No outputs definitely connected, trying again...
[ X] [ 22.104980] [ 22.104] (II) intel(0): Output VIRTUAL1 disconnected
[ X] [ 22.105001] [ 22.104] (WW) intel(0): Unable to find connected outputs - setting 1024x768 initial framebuffer
[ X] [ 22.105190] [ 22.105] (==) intel(0): TearFree disabled
[ X] [ 22.105248] [ 22.105] (==) intel(0): Using gamma correction (1.0, 1.0, 1.0)
[ X] [ 22.105298] [ 22.105] (==) intel(0): DPI set to (96, 96)Code: Select all
[ X] [ 22.106387] [ 22.106] (**) intel(1): Option "ZaphodHeads" "HDMI2"
[ X] [ 22.107424] [ 22.107] (EE) intel(1): HDMI2 is an invalid output for screen 1
[ X] [ 22.107474] [ 22.107] (EE) intel(1): No outputs and no modes.
