I would like to tell you, that the ADF scanner Fujitsu ScanSnap S1500 works perfectly in a RemoteDesktop scenario:
- The Server is a Hyper-V Windows 10 Education, installed is the current driver (WinS1500ManagerV55L10WW.exe).
- The client is a Raspberry Pi 3B+ with WTware v5.8.26.
Computer Configuration > Administrative Templates > Windows Components > Remote Desktop Services > Remote Desktop Session Host > Device and Resource Redirection > Do not allow supported Plug and Play device redirection
On WTware I added the following parameter in the configuration file:
usb=04c5:11a2
I did not enable the parameter scanner.
The ScanSnap manager detects the ScanSnap once you open the cover, no additional required.
Congratulation, WTware works as expected!
