Boot no sd card - how to undo
HereKittyKitty
Post by HereKittyKitty »
i did the boot without using sd and it worked. but now i have no clue how to revert back to it not doing this.
everytime i plug in the RPi3, it trys to netboot i want to stop it go back to raspberry pi 3 normal factory settings
Re: Boot no sd card - how to undo
Install good, not broken boot SD. It netboots AFTER it fails to boot from SD.
HereKittyKitty
is there away to remove WT from it so it dont even try? or im stuck with it now trying to NetBoot into WT only
After writing this programmable SD Pi will always:
- try to boot from SD
- if fails boot by network.
There is no undo and it's not related to wtware. While programming network boot, we execute this raspberry developer's manual: https://www.raspberrypi.org/documentati ... des/msd.md
If you don't need network boot, insert good working SD with what you want to see on Raspberry.
