Page 1 of 2
keyboard language Problem (Swiss German)
Posted: Wed Feb 21, 2018 4:09 pm
by mga
We have a problem to logon to our terminal servers, when there are specials character in the password.
It seems, that the keymapping from some keys is not correct in the German (Switzerland) keybord layout. This issue is only persent in the login screen from wtware.
Is it possible to fix the keymapping?
Testet on a Raspberry Pi 3
WTware version: 5.6.24
Config:
keyboard=de-ch
language=de-ch,default
You can find the keyboard Layout here http://kbdlayout.info/KBDSG/
Here is the log for the wrong keys:
Character: ¦
13-18-44-589| [            gm] [ 5989.709718] Key WT_KEY_R_ALT (126) pressed.
13-18-44-770| [            gm] [ 5989.891786] Key WT_KEY_1 (48) pressed.
13-18-44-857| [            gm] [ 5989.991772] Key WT_KEY_1 (48) released.
13-18-44-928| [            gm] [ 5990.053660] Key WT_KEY_R_ALT (126) released.
Character: °
13-18-47-088| [            gm] [ 5992.209659] Key WT_KEY_R_ALT (126) pressed.
13-18-47-271| [            gm] [ 5992.391778] Key WT_KEY_4 (51) pressed.
13-18-47-371| [            gm] [ 5992.491777] Key WT_KEY_4 (51) released.
13-18-47-428| [            gm] [ 5992.531655] Key WT_KEY_R_ALT (126) released.
Character: §
13-18-48-595| [            gm] [ 5993.715657] Key WT_KEY_R_ALT (126) pressed.
13-18-48-729| [            gm] [ 5993.857764] Key WT_KEY_5 (52) pressed.
13-18-48-829| [            gm] [ 5993.957787] Key WT_KEY_5 (52) released.
13-18-48-887| [            gm] [ 5993.997650] Key WT_KEY_R_ALT (126) released.
Character: |
13-18-50-310| [            gm] [ 5995.431664] Key WT_KEY_R_ALT (126) pressed.
13-18-50-499| [            gm] [ 5995.620108] Key WT_KEY_7 (54) pressed.
13-18-50-564| [            gm] [ 5995.673831] Key WT_KEY_7 (54) released.
13-18-50-614| [            gm] [ 5995.693649] Key WT_KEY_R_ALT (126) released.
Character: ¨
13-18-55-450| [            gm] [ 6000.581714] Key WT_KEY_SQR_BRACKET_R (80) pressed.
13-18-55-511| [            gm] [ 6000.592081] No glyph for char 0x0308.
13-18-55-520| [            gm] [ 6000.592267]           imgbuf.cpp (  478): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
13-18-55-567| [            gm] [ 6000.683813] Key WT_KEY_SQR_BRACKET_R (80) released.
Character: $
13-19-12-647| [            gm] [ 6017.775707] Key WT_KEY_BACKSLASH (81) pressed.
13-19-12-763| [            gm] [ 6017.857818] Key WT_KEY_BACKSLASH (81) released.
Character: £
13-19-15-149| [            gm] [ 6020.271716] Key WT_KEY_L_SHIFT (105) pressed.
13-19-15-373| [            gm] [ 6020.493701] Key WT_KEY_BACKSLASH (81) pressed.
13-19-15-484| [            gm] [ 6020.593817] Key WT_KEY_BACKSLASH (81) released.
13-19-15-549| [            gm] [ 6020.673676] Key WT_KEY_L_SHIFT (105) released.
Character: }
13-19-16-913| [            gm] [ 6022.033699] Key WT_KEY_R_ALT (126) pressed.
13-19-17-072| [            gm] [ 6022.193819] Key WT_KEY_BACKSLASH (81) pressed.
13-19-17-184| [            gm] [ 6022.295845] Key WT_KEY_BACKSLASH (81) released.
13-19-17-251| [            gm] [ 6022.335696] Key WT_KEY_R_ALT (126) released.
Character: <
13-19-22-923| [            gm] [ 6028.053718] Key WT_KEY_UK_SLASH (140) pressed.
13-19-23-072| [            gm] [ 6028.193810] Key WT_KEY_UK_SLASH (140) released.
Character: >
13-19-24-799| [            gm] [ 6029.919713] Key WT_KEY_L_SHIFT (105) pressed.
13-19-25-001| [            gm] [ 6030.121694] Key WT_KEY_UK_SLASH (140) pressed.
13-19-25-157| [            gm] [ 6030.281802] Key WT_KEY_UK_SLASH (140) released.
13-19-25-241| [            gm] [ 6030.363696] Key WT_KEY_L_SHIFT (105) released.
Character: \
13-19-26-958| [            gm] [ 6032.087697] Key WT_KEY_R_ALT (126) pressed.
13-19-27-157| [            gm] [ 6032.289806] Key WT_KEY_UK_SLASH (140) pressed.
13-19-27-270| [            gm] [ 6032.389874] Key WT_KEY_UK_SLASH (140) released.
13-19-27-325| [            gm] [ 6032.431698] Key WT_KEY_R_ALT (126) released.
Character: /
13-19-33-198| [            gm] [ 6038.319708] Key WT_KEY_KEYPAD_SLASH (65) pressed.
13-19-33-313| [            gm] [ 6038.421828] Key WT_KEY_KEYPAD_SLASH (65) released.
Character: /
13-19-33-915| [            gm] [ 6039.039701] Key WT_KEY_L_SHIFT (105) pressed.
13-19-34-114| [            gm] [ 6039.241696] Key WT_KEY_KEYPAD_SLASH (65) pressed.
13-19-34-230| [            gm] [ 6039.321813] Key WT_KEY_KEYPAD_SLASH (65) released.
13-19-34-331| [            gm] [ 6039.463683] Key WT_KEY_L_SHIFT (105) released.
Character: .
13-19-38-995| [            gm] [ 6044.115708] Key WT_KEY_KEYPAD_PERIOD (134) pressed.
13-19-39-100| [            gm] [ 6044.217815] Key WT_KEY_KEYPAD_PERIOD (134) released.
Character: .
13-19-39-851| [            gm] [ 6044.979716] Key WT_KEY_L_SHIFT (105) pressed.
13-19-40-050| [            gm] [ 6045.181699] Key WT_KEY_KEYPAD_PERIOD (134) pressed.
13-19-40-169| [            gm] [ 6045.261807] Key WT_KEY_KEYPAD_PERIOD (134) released.
13-19-40-220| [            gm] [ 6045.341670] Key WT_KEY_L_SHIFT (105) released.
Regards.
MGA
Re: keyboard language Problem (Swiss German)
Posted: Thu Feb 22, 2018 2:33 am
Please, try 5.8.2: http://winterminal.com
Posted: Thu Feb 22, 2018 1:27 pm
by mga
Thank you for your fast response.
The keyboard layout in the Raspberry Pi version 5.8.2 Build works perfect!
The only problem is that on the right side it displays the Banner "Evaluation Copy"
The Website http://winterminal.com/index.html#raspberry shows
Build does not need license and draws no banner. It's free.
And I also noticed that the size of the previous version 5.6.24 is much smaller then the current version.
How can i get the Raspberry Pi version without a license banner as described on the website?
Kind regards
mga
Posted: Thu Feb 22, 2018 2:18 pm
mga wrote: Thu Feb 22, 2018 1:27 pm
Not anymore, please, update website.
Since 5.8.2 WTware is not free.
mga wrote: Thu Feb 22, 2018 1:27 pmAnd I also noticed that the size of the previous version 5.6.24 is much smaller then the current version.
It was much smaller, now we added chromium and it became much bigger.
Posted: Sun Oct 28, 2018 2:41 pm
by skynet
Hi
I also have problems with the Hungarian keyboard layout. Does not work. The WTware system works with only English keyboard Layout.
Can you fix it in the last free version? It would be a great help to me. Please....
Thank you very much.
Regards
Skynet
Posted: Sun Oct 28, 2018 4:26 pm
1. Photo of the screen where you want to get Hungarian keyboard layout.
2. Your keyboard layout name here: http://kbdlayout.info/
Posted: Sun Oct 28, 2018 5:06 pm
by skynet
HI
The raspberry enters RDP on the Windows server. I'm writing a word document. There are no accented characters á,é,ő,ü,ó, ect...) and the z and y keys are replaced.
I would like to use the Hungarian keyboard layout but only English characters are written in word document.
This is good hungarian keyboard layut:
http://kbdlayout.info/0000040e/
Posted: Sun Oct 28, 2018 6:27 pm
Put into config file:
keyboard=hu
https://wtware.com/docs5/config.html#keyboard
Posted: Sun Oct 28, 2018 7:28 pm
by skynet
which configuration file should i put into it?
config.txt on the SD card?
I set it in template but it does not work. The keyboard layout does not change. It's still English.
Posted: Sun Oct 28, 2018 9:55 pm
config.txt in SD root is Raspberry config. Do not touch it.
For WTware option, you need WTware config file. File with server= and other options from WTware manual: https://wtware.com/docs5/config.html It's configs/config.wtc if stored on SD or on server if downloaded over network.
Posted: Mon Oct 29, 2018 10:30 pm
by skynet
the config file including the keyboard layout but not working. There are no accented characters á,é,ő,ü,ó, ect...) and the z and y keys are replaced.
config file:
server=192.168.5.203
user=RPITC1:\x52\x70\x69\x74\x63\x31\x31\x31\x31
keyboard=hu
graphic=abcdefg
sound=on
microphone=on
timezone=Central Europe Standard Time
clienthostname=RPITC1
vnc=on
vnc_password=patak
resolution=1920x1080
bpp=32
display=1920x1080
language=hu,default
connection
Do you have any idea what's wrong?
Posted: Tue Oct 30, 2018 10:23 am
Posted: Tue Oct 30, 2018 11:26 am
by skynet
09-17-36-335| WTware 5.6.24/RPi supervisor.
09-17-36-335| [        KERNEL] [    0.000000] Booting Linux on physical CPU 0x0
09-17-36-335| [        KERNEL] [    0.000000] Linux version 4.9.75 (aka@c16) (gcc version 7.2.0 (Debian 7.2.0-11) ) #5 SMP Wed Jan 10 12:35:54 EST 2018
09-17-36-335| [        KERNEL] [    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
09-17-36-335| [        KERNEL] [    0.000000] CPU: div instructions available: patching division code
09-17-36-335| [        KERNEL] [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
09-17-36-335| [        KERNEL] [    0.000000] OF: fdt:Machine model: Raspberry Pi 3 Model B Rev 1.2
09-17-36-335| [        KERNEL] [    0.000000] cma: Reserved 8 MiB at 0x3ac00000
09-17-36-335| [        KERNEL] [    0.000000] Memory policy: Data cache writealloc
09-17-36-335| [        KERNEL] [    0.000000] On node 0 totalpages: 242688
09-17-36-335| [        KERNEL] [    0.000000] free_area_init_node: node 0, pgdat 80c22b80, node_mem_map ba3a1000
09-17-36-335| [        KERNEL] [    0.000000]   Normal zone: 2133 pages used for memmap
09-17-36-335| [        KERNEL] [    0.000000]   Normal zone: 0 pages reserved
09-17-36-335| [        KERNEL] [    0.000000]   Normal zone: 242688 pages, LIFO batch:31
09-17-36-335| [        KERNEL] [    0.000000] percpu: Embedded 11 pages/cpu @ba367000 s15948 r8192 d20916 u45056
09-17-36-335| [        KERNEL] [    0.000000] pcpu-alloc: s15948 r8192 d20916 u45056 alloc=11*4096
09-17-36-335| [        KERNEL] [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
09-17-36-335| [        KERNEL] [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 240555
09-17-36-335| [        KERNEL] [    0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbdepth=32 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  quiet wtboot=mmc
09-17-36-335| [        KERNEL] [    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
09-17-36-335| [        KERNEL] [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
09-17-36-335| [        KERNEL] [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
09-17-36-335| [        KERNEL] [    0.000000] Memory: 941160K/970752K available (5120K kernel code, 143K rwdata, 920K rodata, 5120K init, 365K bss, 21400K reserved, 8192K cma-reserved)
09-17-36-335| [        KERNEL] [    0.000000] Virtual kernel memory layout:
09-17-36-335| [        KERNEL] [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
09-17-36-335| [        KERNEL] [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
09-17-36-335| [        KERNEL] [    0.000000]     vmalloc : 0xbb800000 - 0xff800000   (1088 MB)
09-17-36-335| [        KERNEL] [    0.000000]     lowmem  : 0x80000000 - 0xbb400000   ( 948 MB)
09-17-36-335| [        KERNEL] [    0.000000]     modules : 0x7f000000 - 0x80000000   (  16 MB)
09-17-36-335| [        KERNEL] [    0.000000]       .text : 0x80008000 - 0x80600000   (6112 kB)
09-17-36-335| [        KERNEL] [    0.000000]       .init : 0x80700000 - 0x80c00000   (5120 kB)
09-17-36-335| [        KERNEL] [    0.000000]       .data : 0x80c00000 - 0x80c23e38   ( 144 kB)
09-17-36-335| [        KERNEL] [    0.000000]        .bss : 0x80c25000 - 0x80c805e0   ( 366 kB)
09-17-36-335| [        KERNEL] [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
09-17-36-335| [        KERNEL] [    0.000000] Hierarchical RCU implementation.
09-17-36-335| [        KERNEL] [    0.000000] 	Build-time adjustment of leaf fanout to 32.
09-17-36-335| [        KERNEL] [    0.000000] NR_IRQS:16 nr_irqs:16 16
09-17-36-335| [        KERNEL] [    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
09-17-36-335| [        KERNEL] [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
09-17-36-335| [        KERNEL] [    0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
09-17-36-335| [        KERNEL] [    0.000015] Switching to timer-based delay loop, resolution 52ns
09-17-36-335| [        KERNEL] [    0.000218] Console: colour dummy device 80x30
09-17-36-335| [        KERNEL] [    0.000232] console [tty0] enabled
09-17-36-335| [        KERNEL] [    0.000247] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
09-17-36-335| [        KERNEL] [    0.000260] pid_max: default: 32768 minimum: 301
09-17-36-335| [        KERNEL] [    0.000392] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
09-17-36-335| [        KERNEL] [    0.000399] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
09-17-36-335| [        KERNEL] [    0.001241] Disabling memory control group subsystem
09-17-36-335| [        KERNEL] [    0.001292] CPU: Testing write buffer coherency: ok
09-17-36-335| [        KERNEL] [    0.001622] CPU0: update cpu_capacity 1024
09-17-36-335| [        KERNEL] [    0.001629] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
09-17-36-335| [        KERNEL] [    0.001654] Setting up static identity map for 0x100000 - 0x100034
09-17-36-335| [        KERNEL] [    0.003205] CPU1: update cpu_capacity 1024
09-17-36-335| [        KERNEL] [    0.003212] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
09-17-36-335| [        KERNEL] [    0.003782] CPU2: update cpu_capacity 1024
09-17-36-335| [        KERNEL] [    0.003788] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
09-17-36-335| [        KERNEL] [    0.004354] CPU3: update cpu_capacity 1024
09-17-36-335| [        KERNEL] [    0.004360] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
09-17-36-335| [        KERNEL] [    0.004439] Brought up 4 CPUs
09-17-36-335| [        KERNEL] [    0.004447] SMP: Total of 4 processors activated (153.60 BogoMIPS).
09-17-36-335| [        KERNEL] [    0.004452] CPU: All CPU(s) started in HYP mode.
09-17-36-335| [        KERNEL] [    0.004454] CPU: Virtualization extensions available.
09-17-36-335| [        KERNEL] [    0.004992] devtmpfs: initialized
09-17-36-335| [        KERNEL] [    0.014592] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
09-17-36-335| [        KERNEL] [    0.014971] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
09-17-36-335| [        KERNEL] [    0.014986] futex hash table entries: 1024 (order: 4, 65536 bytes)
09-17-36-335| [        KERNEL] [    0.015459] pinctrl core: initialized pinctrl subsystem
09-17-36-335| [        KERNEL] [    0.015986] NET: Registered protocol family 16
09-17-36-335| [        KERNEL] [    0.017821] DMA: preallocated 1024 KiB pool for atomic coherent allocations
09-17-36-335| [        KERNEL] [    0.027941] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
09-17-36-335| [        KERNEL] [    0.111166] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb80f000, dmachans=0x1
09-17-36-335| [        KERNEL] [    0.113497] usbcore: registered new interface driver usbfs
09-17-36-335| [        KERNEL] [    0.113618] usbcore: registered new interface driver hub
09-17-36-335| [        KERNEL] [    0.113703] usbcore: registered new device driver usb
09-17-36-335| [        KERNEL] [    0.120136] raspberrypi-firmware soc:firmware: Attached to firmware from 2018-01-08 14:28
09-17-36-335| [        KERNEL] [    0.122390] clocksource: Switched to clocksource arch_sys_counter
09-17-36-335| [        KERNEL] [    0.137568] NET: Registered protocol family 2
09-17-36-335| [        KERNEL] [    0.138142] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
09-17-36-335| [        KERNEL] [    0.138250] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
09-17-36-335| [        KERNEL] [    0.138433] TCP: Hash tables configured (established 8192 bind 8192)
09-17-36-335| [        KERNEL] [    0.138519] UDP hash table entries: 512 (order: 2, 16384 bytes)
09-17-36-335| [        KERNEL] [    0.138559] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
09-17-36-335| [        KERNEL] [    0.138736] NET: Registered protocol family 1
09-17-36-335| [        KERNEL] [    2.441950] workingset: timestamp_bits=14 max_order=18 bucket_order=4
09-17-36-335| [        KERNEL] [    2.500096] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
09-17-36-335| [        KERNEL] [    2.500110] io scheduler noop registered
09-17-36-335| [        KERNEL] [    2.500115] io scheduler deadline registered (default)
09-17-36-335| [        KERNEL] [    2.514058] BCM2708FB: allocated DMA memory fad10000
09-17-36-335| [        KERNEL] [    2.514091] BCM2708FB: allocated DMA channel 0 @ bb80f000
09-17-36-335| [        KERNEL] [    2.567159] Console: switching to colour frame buffer device 240x67
09-17-36-335| [        KERNEL] [    2.600250] bcm2835-rng 3f104000.rng: hwrng registered
09-17-36-335| [        KERNEL] [    2.600379] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
09-17-36-335| [        KERNEL] [    2.601010] vc-sm: Videocore shared memory driver
09-17-36-335| [        KERNEL] [    2.610608] zram: Added device: zram0
09-17-36-335| [        KERNEL] [    2.610659] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
09-17-36-335| [        KERNEL] [    2.838801] Core Release: 2.80a
09-17-36-335| [        KERNEL] [    2.838815] Setting default values for core params
09-17-36-335| [        KERNEL] [    2.838841] Finished setting default values for core params
09-17-36-335| [        KERNEL] [    3.039203] Using Buffer DMA mode
09-17-36-335| [        KERNEL] [    3.039208] Periodic Transfer Interrupt Enhancement - disabled
09-17-36-335| [        KERNEL] [    3.039212] Multiprocessor Interrupt Enhancement - disabled
09-17-36-335| [        KERNEL] [    3.039219] OTG VER PARAM: 0, OTG VER FLAG: 0
09-17-36-335| [        KERNEL] [    3.039248] Dedicated Tx FIFOs mode
09-17-36-335| [        KERNEL] [    3.039790] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xbad04000 dma = 0xfad04000 len=9024
09-17-36-335| [        KERNEL] [    3.039815] FIQ FSM acceleration enabled for :
09-17-36-335| [        KERNEL] [    3.039815] Non-periodic Split Transactions
09-17-36-335| [        KERNEL] [    3.039815] Periodic Split Transactions
09-17-36-335| [        KERNEL] [    3.039815] High-Speed Isochronous Endpoints
09-17-36-335| [        KERNEL] [    3.039815] Interrupt/Control Split Transaction hack enabled
09-17-36-335| [        KERNEL] [    3.039821] dwc_otg: Microframe scheduler enabled
09-17-36-335| [        KERNEL] [    3.039865] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x80397770
09-17-36-335| [        KERNEL] [    3.039873] WARN::hcd_init_fiq:460: FIQ ASM at 0x80397ad4 length 36
09-17-36-335| [        KERNEL] [    3.039882] WARN::hcd_init_fiq:486: MPHI regs_base at 0xbb925000
09-17-36-335| [        KERNEL] [    3.039935] dwc_otg 3f980000.usb: DWC OTG Controller
09-17-36-335| [        KERNEL] [    3.039970] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
09-17-36-335| [        KERNEL] [    3.040000] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
09-17-36-335| [        KERNEL] [    3.040063] Init: Port Power? op_state=1
09-17-36-335| [        KERNEL] [    3.040067] Init: Power Port (0)
09-17-36-335| [        KERNEL] [    3.040288] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
09-17-36-335| [        KERNEL] [    3.040298] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
09-17-36-335| [        KERNEL] [    3.040305] usb usb1: Product: DWC OTG Controller
09-17-36-335| [        KERNEL] [    3.040312] usb usb1: Manufacturer: Linux 4.9.75 dwc_otg_hcd
09-17-36-335| [        KERNEL] [    3.040319] usb usb1: SerialNumber: 3f980000.usb
09-17-36-335| [        KERNEL] [    3.041071] hub 1-0:1.0: USB hub found
09-17-36-335| [        KERNEL] [    3.041112] hub 1-0:1.0: 1 port detected
09-17-36-335| [        KERNEL] [    3.041786] dwc_otg: FIQ enabled
09-17-36-335| [        KERNEL] [    3.041792] dwc_otg: NAK holdoff enabled
09-17-36-335| [        KERNEL] [    3.041796] dwc_otg: FIQ split-transaction FSM enabled
09-17-36-335| [        KERNEL] [    3.041810] Module dwc_common_port init
09-17-36-335| [        KERNEL] [    3.042202] usbcore: registered new interface driver usbtouchscreen
09-17-36-335| [        KERNEL] [    3.043363] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
09-17-36-335| [        KERNEL] [    3.043763] bcm2835-cpufreq: min=600000 max=1200000
09-17-36-335| [        KERNEL] [    3.044996] sdhost-bcm2835 3f202000.sdhost: could not get clk, deferring probe
09-17-36-335| [        KERNEL] [    3.047528] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
09-17-36-335| [        KERNEL] [    3.052496] ledtrig-cpu: registered to indicate activity on CPUs
09-17-36-335| [        KERNEL] [    3.052773] hidraw: raw HID events driver (C) Jiri Kosina
09-17-36-335| [        KERNEL] [    3.054326] usbcore: registered new interface driver usbhid
09-17-36-335| [        KERNEL] [    3.054333] usbhid: USB HID core driver
09-17-36-335| [        KERNEL] [    3.055259] vchiq: vchiq_init_state: slot_zero = 0xbad80000, is_master = 0
09-17-36-335| [        KERNEL] [    3.064798] [vc_sm_connected_init]: start
09-17-36-335| [        KERNEL] [    3.073395] [vc_sm_connected_init]: end - returning 0
09-17-36-335| [        KERNEL] [    3.073639] NET: Registered protocol family 17
09-17-36-335| [        KERNEL] [    3.073762] Registering SWP/SWPB emulation handler
09-17-36-335| [        KERNEL] [    3.074312] registered taskstats version 1
09-17-36-335| [        KERNEL] [    3.078917] sdhost: log_buf @ bad07000 (fad07000)
09-17-36-335| [        KERNEL] [    3.152404] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
09-17-36-335| [        KERNEL] [    3.154538] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
09-17-36-335| [        KERNEL] [    3.154542] mmc-bcm2835 3f300000.mmc: DMA channel allocated
09-17-36-335| [        KERNEL] [    3.219267] mmc0: host does not support reading read-only switch, assuming write-enable
09-17-36-335| [        KERNEL] [    3.221135] mmc0: new high speed SDHC card at address 59b4
09-17-36-335| [        KERNEL] [    3.221615] mmcblk0: mmc0:59b4 USD   14.9 GiB
09-17-36-335| [        KERNEL] [    3.222964]  mmcblk0: p1
09-17-36-335| [        KERNEL] [    3.232566] of_cfs_init
09-17-36-335| [        KERNEL] [    3.232627] of_cfs_init: OK
09-17-36-335| [        KERNEL] [    3.244749] Freeing unused kernel memory: 5120K
09-17-36-335| [        KERNEL] [    3.253287] Indeed it is in host mode hprt0 = 00021501
09-17-36-335| [        KERNEL] [    3.322552] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
09-17-36-335| [        KERNEL] [    3.324048] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
09-17-36-335| [        KERNEL] [    3.325543] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
09-17-36-335| [        KERNEL] [    3.328230] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
09-17-36-335| [        KERNEL] [    3.331687] random: fast init done
09-17-36-335| [        KERNEL] [    3.419249] mmc1: new high speed SDIO card at address 0001
09-17-36-335| [        KERNEL] [    3.452432] usb 1-1: new high-speed USB device number 2 using dwc_otg
09-17-36-335| [        KERNEL] [    3.452598] Indeed it is in host mode hprt0 = 00001101
09-17-36-335| [       hotplug] [    3.515989] Block device 254:0. No action.
09-17-36-335| [       hotplug] [    3.523654] Block device 179:1. No action.
09-17-36-335| [       hotplug] [    3.523766] Block device 179:0. No action.
09-17-36-335| [          pfac] [    3.574269] Run /sbin/initrd.
09-17-36-335| [          pfac] [    3.574529] Ok, PID 607.
09-17-36-335| [        initrd] [    3.578204] WTware shell 5.6.24/RPi
09-17-36-335| [        initrd] [    3.616531] HDD/MMC/SD boot.
09-17-36-335| [        KERNEL] [    3.692653] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
09-17-36-335| [        KERNEL] [    3.692664] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
09-17-36-335| [        KERNEL] [    3.693395] hub 1-1:1.0: USB hub found
09-17-36-335| [        KERNEL] [    3.693489] hub 1-1:1.0: 5 ports detected
09-17-36-335| [        KERNEL] [    4.012423] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
09-17-36-335| [        KERNEL] [    4.142653] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
09-17-36-335| [        KERNEL] [    4.142663] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
09-17-36-335| [        KERNEL] [    4.242420] usb 1-1.2: new full-speed USB device number 4 using dwc_otg
09-17-36-335| [        KERNEL] [    4.377346] usb 1-1.2: New USB device found, idVendor=046d, idProduct=c534
09-17-36-335| [        KERNEL] [    4.377356] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
09-17-36-335| [        KERNEL] [    4.377363] usb 1-1.2: Product: USB Receiver
09-17-36-335| [        KERNEL] [    4.377370] usb 1-1.2: Manufacturer: Logitech
09-17-36-335| [        KERNEL] [    4.384050] input: Logitech USB Receiver as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:046D:C534.0001/input/input0
09-17-36-335| [        KERNEL] [    4.467343] hid-generic 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-3f980000.usb-1.2/input0
09-17-36-335| [        KERNEL] [    4.476703] input: Logitech USB Receiver as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:046D:C534.0002/input/input1
09-17-36-335| [        KERNEL] [    4.553205] hid-generic 0003:046D:C534.0002: input,hiddev0,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-3f980000.usb-1.2/input1
09-17-36-335| [        initrd] [    4.624443] Success: media /dev/mmcblk0p1 mounted to /bootmedia.
09-17-36-335| /--- FILE "/bootmedia/config.txt" -----------------------
09-17-36-335| | # For more options and information see
09-17-36-335| | # http://www.raspberrypi.org/documentation/configuration/config-txt.md
09-17-36-335| | # Some settings may impact device functionality. See link above for details
09-17-36-335| | # Uncomment if you get no picture on HDMI for a default "safe" mode.
09-17-36-335| | #hdmi_safe=1
09-17-36-335| | # Uncomment this if your display has a black border of unused pixels visible
09-17-36-335| | # and your display can output without overscan.
09-17-36-335| | disable_overscan=1
09-17-36-335| | # Uncomment if hdmi display is not detected and composite is being output.
09-17-36-335| | #hdmi_force_hotplug=1
09-17-36-335| | # Uncomment to force a specific HDMI mode (this will force VGA).
09-17-36-335| | #hdmi_group=1
09-17-36-335| | #hdmi_mode=1
09-17-36-335| | # Force the monitor to HDMI mode so that sound will be sent over HDMI cable.
09-17-36-335| | #hdmi_drive=2
09-17-36-335| | # Uncomment to increase signal to HDMI, if you have interference, blanking, or
09-17-36-335| | # no display.
09-17-36-335| | #config_hdmi_boost=4
09-17-36-335| | # Uncomment to overclock the arm. 700 MHz is the default.
09-17-36-335| | #arm_freq=800
09-17-36-335| | disable_splash=1
09-17-36-335| | #hdmi_group=2
09-17-36-335| | # 800x600:   hdmi_mode=9
09-17-36-335| | # 1024x768:  hdmi_mode=16
09-17-36-335| | # 1280x1024: hdmi_mode=35
09-17-36-335| | # 1360x768:  hdmi_mode=39
09-17-36-335| | # 1400x1050: hdmi_mode=42
09-17-36-335| | # 1440x900:  hdmi_mode=47
09-17-36-335| | # 1600x1200: hdmi_mode=51
09-17-36-335| | # 1680x1050: hdmi_mode=58
09-17-36-335| | # 1366x768:  hdmi_mode=81
09-17-36-335| | # 1920x1080: hdmi_mode=82
09-17-36-335| | # 1920x1200: hdmi_mode=69
09-17-36-335| | framebuffer_depth=32
09-17-36-335| | # Uncomment for 16-bit color. It is up to two
09-17-36-335| | # times faster than default 32-bit.
09-17-36-335| | #framebuffer_depth=16
09-17-36-335| | # Enable onboard audio (HDMI or jack).
09-17-36-335| | dtparam=audio=on
09-17-36-335| | # Removes the warning overlay.
09-17-36-335| | #avoid_warnings=1
09-17-36-335| | # Additionally allows turbo when low-voltage is present.
09-17-36-335| | #avoid_warnings=2
09-17-36-335| \----------------------------------------------------
09-17-36-335| [        initrd] [    4.629300] WTpassword present: e86dbb028b21e7d81abfbea2a873d7a9.
09-17-36-335| /--- FILE "/bootmedia/configs/initrd.wtc" -----------------------
09-17-36-335| | clientIP = *
09-17-36-335| | config = network
09-17-36-335| | setupPassword = e86dbb028b21e7d81abfbea2a873d7a9
09-17-36-335| [        initrd] [    6.654139] Load ethernet drivers.
09-17-36-335| [        initrd] [    6.657420] modprobe smsc95xx.
09-17-36-335| [        KERNEL] [    6.667278] smsc95xx v1.0.5
09-17-36-335| [        KERNEL] [    6.755961] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:bd:31:be
09-17-36-335| [        KERNEL] [    6.756241] usbcore: registered new interface driver smsc95xx
09-17-36-335| [        KERNEL] [    6.844571] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
09-17-36-335| [        KERNEL] [    8.295738] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC1E1
09-17-36-335| [        initrd] [    8.345533] WTpassword present: e86dbb028b21e7d81abfbea2a873d7a9.
09-17-36-335| [        initrd] [    9.540154] dhcp: 335 bytes from 192.168.5.2.
09-17-36-335| [        initrd] [    9.540273] 00000000:0000013B0000000000110000C0A80502C0A806B400430044013B000002010600  ...;................C.D.;......
09-17-36-335| [        initrd] [    9.540344] 00000020:67458B6B0000000000000000C0A806B4C0A805CB00000000B827EBBD31BE0000  gE.k.....................'..1...
09-17-36-335| [        initrd] [    9.540412] 00000040:0000000000000000000000000000000000000000000000000000000000000000  ................................
09-17-36-335| [        initrd] [    9.540478] 00000060:0000000000000000000000000000000000000000000000000000000000000000  ................................
09-17-36-335| [        initrd] [    9.540546] 00000080:00000000000000002F74667470626F6F742F646F732E696D6700000000000000  ......../tftpboot/dos.img.......
09-17-36-335| [        initrd] [    9.540615] 000000a0:0000000000000000000000000000000000000000000000000000000000000000  ................................
09-17-36-335| [        initrd] [    9.540682] 000000c0:0000000000000000000000000000000000000000000000000000000000000000  ................................
09-17-36-335| [        initrd] [    9.540749] 000000e0:0000000000000000000000000000000000000000000000000000000000000000  ................................
09-17-36-335| [        initrd] [   11.780166] dhcp: 335 bytes from 192.168.5.2.
09-17-36-335| [        initrd] [   11.780300] 00000000:0000013B0000000000110000C0A80502C0A806B400430044013B000002010600  ...;................C.D.;......
09-17-36-335| [        initrd] [   11.780373] 00000020:67458B6B0000000000000000C0A806B4C0A805CB00000000B827EBBD31BE0000  gE.k.....................'..1...
09-17-36-335| [        initrd] [   11.780440] 00000040:0000000000000000000000000000000000000000000000000000000000000000  ................................
09-17-36-335| [        initrd] [   11.780508] 00000060:0000000000000000000000000000000000000000000000000000000000000000  ................................
09-17-36-335| [        initrd] [   11.780574] 00000080:00000000000000002F74667470626F6F742F646F732E696D6700000000000000  ......../tftpboot/dos.img.......
09-17-36-335| [        initrd] [   11.780641] 000000a0:0000000000000000000000000000000000000000000000000000000000000000  ................................
09-17-36-335| [        initrd] [   11.780708] 000000c0:0000000000000000000000000000000000000000000000000000000000000000  ................................
09-17-36-335| [        initrd] [   11.780774] 000000e0:0000000000000000000000000000000000000000000000000000000000000000  ................................
09-17-36-335| [        initrd] [   11.820099] [DHCP] DHCP server address 192.168.5.2.
09-17-36-335| [        initrd] [   11.820173] [DHCP] IP 192.168.6.180 mask 255.255.0.0.
09-17-36-335| [        initrd] [   11.820241] [DHCP] Default gateway 192.168.5.1.
09-17-36-335| [        initrd] [   11.820331] [DHCP] DNS 192.168.5.212.
09-17-36-335| [        initrd] [   11.820396] [DHCP] DNS 192.168.5.1.
09-17-36-335| [        initrd] [   11.820462] [DHCP] DNS 192.168.5.23.
09-17-36-335| [        initrd] [   11.820526] [DHCP] DNS 80.244.97.30.
09-17-36-335| [        initrd] [   11.820591] [DHCP] Domain sabinart.hu.
09-17-36-335| [        initrd] [   11.820655] [DHCP] TFTP from siaddr 192.168.5.203.
09-17-36-335| [        initrd] [   11.820720] [DHCP] TFTP 192.168.5.203.
09-17-36-335| [        initrd] [   11.820785] [DHCP] Boot file (header) /tftpboot/dos.img.
09-17-36-335| [        initrd] [   11.820850] [DHCP] TFTP binary "/tftpboot/", configs prefix "/", using "/" slash.
09-17-36-335| WTC listener is active.
09-17-36-335| WTC broadcast listener is active.
09-17-36-335| Send broadcast WTCU discover.
09-17-36-335| [          pfac] [   11.822954] Run /sbin/httpd.
09-17-36-335| [        initrd] [   11.823026] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
09-17-36-335| [          pfac] [   11.823127] Ok, PID 646.
09-17-36-335| [         httpd] [   11.827530] HTTP Server, WTware 5.6.24/RPi
09-17-36-335| [        initrd] [   11.941778] USB: 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter.
09-17-36-335| [        initrd] [   11.941918] USB: 0424:9514 Standard Microsystems Corp. SMC9514 Hub.
09-17-36-335| [        initrd] [   11.941990] USB: 046d:c534 Logitech, Inc. Unifying Receiver.
09-17-36-335| [        initrd] [   11.942060] [TFTP] Download config file /Everyone/list.wtc from 192.168.5.203.
09-17-36-335| [        initrd] [   11.947811] [TFTP] WTware TFTP v.5.6.24.
09-17-36-335| [        initrd] [   11.949453] [TFTP] Download config file /Terminals/B8.27.EB.BD.31.BE/config.wtc from 192.168.5.203.
09-17-36-335| /--- FILE "/tmp/config.wtc" -----------------------
09-17-36-335| | template RPITC11
09-17-36-335| | connection
09-17-36-335| [        initrd] [   11.951051] [TFTP] Download config file /Everyone/all.wtc from 192.168.5.203.
09-17-36-335| /--- FILE "/tmp/all.wtc" -----------------------
09-17-36-335| | server=192.168.5.203
09-17-36-335| [        initrd] [   11.952816] [TFTP] Download config file /Templates/RPITC11.wtc from 192.168.5.203.
09-17-36-335| /--- FILE "/tmp/tmp.wtc" -----------------------
09-17-36-335| | [BOM]
09-17-36-335| | user=RPITC11:\x52\x70\x69\x74\x63\x31\x31\x31\x31
09-17-36-335| | keyboard=hu
09-17-36-335| | graphic=abcdefg
09-17-36-335| | sound=on
09-17-36-335| | microphone=on
09-17-36-335| | timezone=Central Europe Standard Time
09-17-36-335| | clienthostname=RPITC11
09-17-36-335| | vnc=on
09-17-36-335| | vnc_password=patak
09-17-36-335| | resolution=1920x1080
09-17-36-335| | bpp=32
09-17-36-335| | display=1920x1080
09-17-36-335| | chrome_url=192.168.5.23
09-17-36-335| | chrome_proxy=1.1.1.1:3128
09-17-36-335| | language=hu,default
09-17-36-335| [        initrd] [   11.956450] Remount /bootmedia for writing.
09-17-36-335| [        initrd] [   11.959508] Remount /bootmedia as read-only.
09-17-36-335| /--- FILE "/etc/config.compiled" -----------------------
09-17-36-335| [        initrd] [   11.970047] Hostname: "RPITC11".
09-17-36-335| Everyone can control terminal by RSH.
09-17-36-335| RSH: listener is active.
09-17-36-335| [         httpd] [   12.225393] Reread settings.
09-17-36-335| [         httpd] [   12.225569] Everyone can control terminal by HTTP.
09-17-36-335| [            gm] [   12.230802] WTware session manager 5.6.24/RPi.
09-17-36-335| [            gm] [   12.232965] Add keyboard event1: Logitech USB Receiver.
09-17-36-335| [            gm] [   12.233050] Add keyboard event0: Logitech USB Receiver.
09-17-36-335| [            gm] [   12.233228] Display mode: 1920x1080, 32 bit, landscape, 0 Hz, modeline "", DDC enabled, connector 0.
09-17-36-335| [            gm] [   12.262903] Framebuffer device found.
09-17-36-335| [            gm] [   12.262981] LINELENBYTES 7680
09-17-36-335| [            gm] [   12.263054] VLEN 8294400
09-17-36-335| [            gm] [   12.294035] Use /lib/ui32.so.
09-17-36-335| [            gm] [   12.347179] Unpack /bootmedia/packages/pi2-alsa.
09-17-36-335| [            gm] [   12.640632] modprobe snd-bcm2835.
09-17-36-335| [            gm] [   12.659715] modprobe snd-usb-audio.
09-17-36-335| /--- FILE "/proc/asound/devices" -----------------------
09-17-36-335| |   0: [ 0]   : control
09-17-36-335| |  16: [ 0- 0]: digital audio playback
09-17-36-335| |  17: [ 0- 1]: digital audio playback
09-17-36-335| |  33:        : timer
09-17-36-335| [        KERNEL] [   12.685936] usbcore: registered new interface driver snd-usb-audio
09-17-36-335| [            gm] [   12.685689] /dev/snd/pcmC0D1p character device.
09-17-36-335| [            gm] [   12.685799] /dev/snd/pcmC0D0p character device.
09-17-36-335| [            gm] [   12.685880] /dev/snd/controlC0 character device.
09-17-36-335| [            gm] [   12.685955] /dev/snd/timer character device.
09-17-36-335| [            gm] [   12.686029] Preconfigure ALSA.
09-17-36-335| [            gm] [   12.686108] Run '/sbin/rdpsnd sndvol 100 100 50', log '', env '', pid ''.
09-17-36-335| [            gm] [   12.686194] Run sound daemon.
09-17-36-335| [            gm] [   12.686265] Run '/sbin/rdpsnd 1 0 100 0 -1', log '', env '', pid ''.
09-17-36-335| [            gm] [   12.686352] Run microphone daemon.
09-17-36-335| [            gm] [   12.686446] Run '/sbin/rdpaudin 0 100 0 -1', log '', env '', pid ''.
09-17-36-335| [          pfac] [   12.686654] Run /sbin/rdpsnd sndvol 100 100 50.
09-17-36-335| [          pfac] [   12.686946] Ok, PID 673.
09-17-36-335| [          pfac] [   12.687065] Run /sbin/rdpsnd 1 0 100 0 -1.
09-17-36-335| [          pfac] [   12.687153] Ok, PID 674.
09-17-36-335| [          pfac] [   12.687232] Run /sbin/rdpaudin 0 100 0 -1.
09-17-36-335| [          pfac] [   12.687365] Ok, PID 675.
09-17-36-335| [      rdpaudin] [   12.695807] RDP Microphone Redirector, WTware 5.6.24/RPi.
09-17-36-335| [          pfac] [   12.704083] Process pid 673 terminated, status 00000000.
09-17-36-335| [        sndvol] [   12.704162] Card 'ALSA'/'bcm2835 ALSA'.
09-17-36-335| [      rdpaudin] [   12.704211] Card 'ALSA'/'bcm2835 ALSA'.
09-17-36-335| [        sndvol] [   12.704325] Mixer name: 'Broadcom Mixer'.
09-17-36-335| [      rdpaudin] [   12.704369] Mixer name: 'Broadcom Mixer'.
09-17-36-335| [        rdpsnd] [   12.704413] RDP Sound Redirector, WTware 5.6.24/RPi.
09-17-36-335| [        sndvol] [   12.704492] Components: ''.
09-17-36-335| [      rdpaudin] [   12.704536] Components: ''.
09-17-36-335| [        sndvol] [   12.704612] Controls: 6.
09-17-36-335| [      rdpaudin] [   12.704655] Controls: 6.
09-17-36-335| [        sndvol] [   12.704730] ALSA: control 'PCM Playback Volume'.
09-17-36-335| [      rdpaudin] [   12.704774] ALSA: control 'PCM Playback Volume'.
09-17-36-335| [        sndvol] [   12.704852] ALSA: control 'PCM Playback Switch'.
09-17-36-335| [      rdpaudin] [   12.704894] ALSA: control 'PCM Playback Switch'.
09-17-36-335| [        sndvol] [   12.704970] ALSA: control 'PCM Playback Route'.
09-17-36-335| [      rdpaudin] [   12.705013] ALSA: control 'PCM Playback Route'.
09-17-36-335| [        sndvol] [   12.705088] ALSA: control 'IEC958 Playback Default'.
09-17-36-335| [      rdpaudin] [   12.705131] ALSA: control 'IEC958 Playback Default'.
09-17-36-335| [        sndvol] [   12.705206] ALSA: control 'IEC958 Playback Con Mask'.
09-17-36-335| [      rdpaudin] [   12.705249] ALSA: control 'IEC958 Playback Con Mask'.
09-17-36-335| [        sndvol] [   12.705326] ALSA: control 'IEC958 Playback PCM Stream'.
09-17-36-335| [      rdpaudin] [   12.705369] ALSA: control 'IEC958 Playback PCM Stream'.
09-17-36-335| [        sndvol] [   12.705445] Inactive control IEC958 Playback PCM Stream'.
09-17-36-335| [      rdpaudin] [   12.705487] Inactive control IEC958 Playback PCM Stream'.
09-17-36-335| [        rdpsnd] [   12.709935] Card 'ALSA'/'bcm2835 ALSA'.
09-17-36-335| [        rdpsnd] [   12.710070] Mixer name: 'Broadcom Mixer'.
09-17-36-335| [        rdpsnd] [   12.710153] Components: ''.
09-17-36-335| [        rdpsnd] [   12.710232] Controls: 6.
09-17-36-335| [        rdpsnd] [   12.710307] ALSA: control 'PCM Playback Volume'.
09-17-36-335| [        rdpsnd] [   12.710718] ALSA: control 'PCM Playback Switch'.
09-17-36-335| [        rdpsnd] [   12.710800] ALSA: control 'PCM Playback Route'.
09-17-36-335| [        rdpsnd] [   12.710879] ALSA: control 'IEC958 Playback Default'.
09-17-36-335| [        rdpsnd] [   12.710956] ALSA: control 'IEC958 Playback Con Mask'.
09-17-36-335| [        rdpsnd] [   12.711033] ALSA: control 'IEC958 Playback PCM Stream'.
09-17-36-335| [        rdpsnd] [   12.711111] Inactive control IEC958 Playback PCM Stream'.
09-17-36-335| [            gm] [   12.749041] Run '/sbin/resolver 0x10cefe8 dns [192.168.5.203]', log '', env '', pid ''.
09-17-36-335| [            gm] [   12.749148] Everyone can control terminal by VNC.
09-17-36-335| [            gm] [   12.749190] [VNC] Listener at port 5900.
09-17-36-335| [          pfac] [   12.749320] Run /sbin/resolver 0x10cefe8 dns [192.168.5.203].
09-17-36-335| [          pfac] [   12.749731] Ok, PID 676.
09-17-36-335| [          pfac] [   12.753308] Process pid 676 terminated, status 00000000.
09-17-36-335| [            gm] [   12.759008] 192.168.5.203 => 192.168.5.203.
09-17-36-335| [            gm] [   12.765114] Free ram before fork terminal client /sbin/rdpclient (session 1): 920760 Kb.
09-17-36-335| [            gm] [   12.765218] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
09-17-36-335| [          pfac] [   12.765261] Run /sbin/rdpclient 1.
09-17-36-335| [          pfac] [   12.765457] Ok, PID 677.
09-17-36-335| [ rdpclient 677] [   12.770074] RDP Terminal Client, WTware 5.6.24/RPi, pipe 1, pid 677.
09-17-36-335| [ rdpclient 677] [   12.770582] Use /lib/ui32.so.
09-17-36-335| [ rdpclient 677] [   12.771163] Redirect sound.
09-17-36-335| [ rdpclient 677] [   12.771414] Make RDP session with 192.168.5.203, port 3389.
09-17-36-335| [ rdpclient 677] [   12.771469]  Username: "RPITC11".
09-17-36-335| [ rdpclient 677] [   12.771546]  Password: present.
09-17-36-335| [ rdpclient 677] [   12.771590]  No PIN.
09-17-36-335| [ rdpclient 677] [   12.771633]  No domain.
09-17-36-335| [ rdpclient 677] [   12.771674]  No shell.
09-17-36-335| [ rdpclient 677] [   12.771716]  No directory.
09-17-36-335| [ rdpclient 677] [   12.771754]  Window: 1920x1080@24.
09-17-36-335| [ rdpclient 677] [   12.771793]  PFlags 0x00000180.
09-17-36-335| [ rdpclient 677] [   12.771833]  Keyboard 0000040E:00000000.
09-17-36-335| [ rdpclient 677] [   12.771873]  My hostname "RPITC11".
09-17-36-335| [ rdpclient 677] [   12.771916] TCP: connecting to 192.168.5.203:3389.
09-17-36-335| [ rdpclient 677] [   12.772468] TCP: connection with 192.168.5.203:3389 established.
09-17-36-335| [ rdpclient 677] [   12.772530] Turn keepalive on.
09-17-36-335| [ rdpclient 677] [   12.773483] Free ram after buffers allocation: 920164 KB.
09-17-36-335| [ rdpclient 677] [   12.776713] Server supports GFX Pipeline.
09-17-36-335| [ rdpclient 677] [   12.778301] Process RDP server certificate.
09-17-36-335| [ rdpclient 677] [   12.778521] RDP4 encryption.
09-17-36-335| [ rdpclient 677] [   12.782948] Timezone '(UTC+01:00) Belgrade, Bratislava, Budapest, Ljubljana, Prague'.
09-17-36-335| [ rdpclient 677] [   12.783031] Enable font smoothing and Desktop Composition.
09-17-36-335| [ rdpclient 677] [   12.827986] GFX codec.
09-17-36-335| [ rdpclient 677] [   13.111932] errorInfo 0x00000000.
09-17-36-335| [ rdpclient 677] [   13.348076] SessionId 0x00000013: WIN2012TS\RPITC11.
09-17-36-335| [ rdpclient 677] [   13.408584] Run 4 tile threads.
09-17-36-335| [        KERNEL] [   15.954124] random: crng init done
09-17-36-335| [            gm] [   16.457190] [VNC] Connection from 10.14.0.2.
09-17-36-335| [            gm] [   16.492721] [VNC] Client VNC version 8 (RFB 003.008).
09-17-36-335| [            gm] [   85.652967] [VNC] Ignore new connection. Session is already active.
09-17-36-335| [            gm] [   90.767594] [VNC] Password ok.
09-17-36-335| [            gm] [   90.980233] [VNC] 11 encodings: 7 1 16 5 2 0 -26 -223 -224 -232 -239.
09-17-36-335| [ rdpclient 677] [  100.521084] errorInfo 0x0000000c.
09-17-36-335| [ rdpclient 677] [  100.521247] ERRINFO_LOGOFF_BY_USER
09-17-36-335| [ rdpclient 677] [  100.623905] Receive Disconnect Provider Ultimatum.
09-17-36-335| [            gm] [  100.721629] TSClient (sessionId 1, pid 677) gracefully end.
09-17-36-335| [          pfac] [  100.728363] Run /sbin/resolver 0x10cefe8 dns [192.168.5.203].
09-17-36-335| [            gm] [  100.728443] Run '/sbin/resolver 0x10cefe8 dns [192.168.5.203]', log '', env '', pid ''.
09-17-36-335| [          pfac] [  100.728564] Ok, PID 691.
09-17-36-335| [          pfac] [  100.729170] Process pid 677 terminated, status 00000009.
09-17-36-335| [        rdpsnd] [  100.730663] Link lost.
09-17-36-335| [          pfac] [  100.730744] Process pid 691 terminated, status 00000000.
09-17-36-335| [            gm] [  100.885304] 192.168.5.203 => 192.168.5.203.
09-17-36-335| [            gm] [  100.891408] Free ram before fork terminal client /sbin/rdpclient (session 2): 919864 Kb.
09-17-36-335| [          pfac] [  100.891532] Run /sbin/rdpclient 2.
09-17-36-335| [            gm] [  100.891589] Run '/sbin/rdpclient 2', log '/tmp/rdpclient.out', env '', pid ''.
09-17-36-335| [          pfac] [  100.891737] Ok, PID 692.
09-17-36-335| [ rdpclient 692] [  100.896007] RDP Terminal Client, WTware 5.6.24/RPi, pipe 2, pid 692.
09-17-36-335| [ rdpclient 692] [  100.896491] Use /lib/ui32.so.
09-17-36-335| [ rdpclient 692] [  100.896943] Redirect sound.
09-17-36-335| [ rdpclient 692] [  100.897119] Make RDP session with 192.168.5.203, port 3389.
09-17-36-335| [ rdpclient 692] [  100.897170]  Username: "RPITC11".
09-17-36-335| [ rdpclient 692] [  100.897215]  Password: present.
09-17-36-335| [ rdpclient 692] [  100.897254]  No PIN.
09-17-36-335| [ rdpclient 692] [  100.897293]  No domain.
09-17-36-335| [ rdpclient 692] [  100.897419]  No shell.
09-17-36-335| [ rdpclient 692] [  100.897459]  No directory.
09-17-36-335| [ rdpclient 692] [  100.897497]  Window: 1920x1080@24.
09-17-36-335| [ rdpclient 692] [  100.897536]  PFlags 0x00000180.
09-17-36-335| [ rdpclient 692] [  100.897574]  Keyboard 0000040E:00000000.
09-17-36-335| [ rdpclient 692] [  100.897612]  My hostname "RPITC11".
09-17-36-335| [ rdpclient 692] [  100.897651] TCP: connecting to 192.168.5.203:3389.
09-17-36-335| [ rdpclient 692] [  100.897835] TCP: connection with 192.168.5.203:3389 established.
09-17-36-335| [ rdpclient 692] [  100.897879] Turn keepalive on.
09-17-36-335| [ rdpclient 692] [  100.898458] Free ram after buffers allocation: 919136 KB.
09-17-36-335| [ rdpclient 692] [  100.901045] Server supports GFX Pipeline.
09-17-36-335| [ rdpclient 692] [  100.902336] Process RDP server certificate.
09-17-36-335| [ rdpclient 692] [  100.902482] RDP4 encryption.
09-17-36-335| [ rdpclient 692] [  100.906785] Timezone '(UTC+01:00) Belgrade, Bratislava, Budapest, Ljubljana, Prague'.
09-17-36-335| [ rdpclient 692] [  100.906904] Enable font smoothing and Desktop Composition.
09-17-36-335| [ rdpclient 692] [  100.949186] GFX codec.
09-17-36-335| [ rdpclient 692] [  101.262215] LOGON_EX_LOGONERRORS: ErrorNotificationType 0xfffffffe, ErrorNotificationData 0x00000011.
09-17-36-335| [ rdpclient 692] [  101.302533] SessionId 0x00000011: WIN2012TS\RPITC11.
09-17-36-335| [ rdpclient 692] [  101.400223] Run 4 tile threads.
09-17-36-335| [            gm] [  126.502698] [VNC] Unknown keysym 0x1fb.
09-17-36-335| [            gm] [  126.557288] [VNC] Unknown keysym 0x1fb.
09-17-36-335| [            gm] [  126.620424] [VNC] Unknown keysym 0x1fb.
09-17-36-335| [            gm] [  126.728797] [VNC] Unknown keysym 0x1fb.
09-17-36-335| [            gm] [  133.607720] [VNC] Close connection.
09-17-36-335| [        KERNEL] [38718.832551] usb 1-1.4: new high-speed USB device number 5 using dwc_otg
09-17-36-335| [        KERNEL] [38718.964898] usb 1-1.4: New USB device found, idVendor=0424, idProduct=2734
09-17-36-335| [        KERNEL] [38718.964909] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
09-17-36-335| [        KERNEL] [38718.964916] usb 1-1.4: Product: USB2734
09-17-36-335| [        KERNEL] [38718.964923] usb 1-1.4: Manufacturer: Microchip Tech
09-17-36-335| [        KERNEL] [38718.965738] hub 1-1.4:1.0: USB hub found
09-17-36-335| [        KERNEL] [38718.965891] hub 1-1.4:1.0: 5 ports detected
09-17-36-335| [        KERNEL] [38719.692554] usb 1-1.4.2: new high-speed USB device number 6 using dwc_otg
09-17-36-335| [        KERNEL] [38719.822880] usb 1-1.4.2: New USB device found, idVendor=0424, idProduct=2412
09-17-36-335| [        KERNEL] [38719.822891] usb 1-1.4.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
09-17-36-335| [        KERNEL] [38719.823716] hub 1-1.4.2:1.0: USB hub found
09-17-36-335| [        KERNEL] [38719.823873] hub 1-1.4.2:1.0: 2 ports detected
09-17-36-335| [        KERNEL] [38719.922564] usb 1-1.4.5: new high-speed USB device number 7 using dwc_otg
09-17-36-335| [        KERNEL] [38720.056295] usb 1-1.4.5: New USB device found, idVendor=0424, idProduct=274c
09-17-36-335| [        KERNEL] [38720.056308] usb 1-1.4.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
09-17-36-335| [        KERNEL] [38720.056316] usb 1-1.4.5: Product: Hub Controller
09-17-36-335| [        KERNEL] [38720.056323] usb 1-1.4.5: Manufacturer: Microchip Tech
09-17-36-335| [        KERNEL] [38720.061974] hid-generic 0003:0424:274C.0003: hiddev0,hidraw2: USB HID v1.10 Device [Microchip Tech Hub Controller] on usb-3f980000.usb-1.4.5/input1
09-17-36-335| [        KERNEL] [38720.152554] usb 1-1.4.2.1: new full-speed USB device number 8 using dwc_otg
09-17-36-335| [        KERNEL] [38720.286973] usb 1-1.4.2.1: New USB device found, idVendor=1fd2, idProduct=6103
09-17-36-335| [        KERNEL] [38720.286984] usb 1-1.4.2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
09-17-36-335| [        KERNEL] [38720.286992] usb 1-1.4.2.1: Product: LGD AIT Touch Controller
09-17-36-335| [        KERNEL] [38720.286999] usb 1-1.4.2.1: Manufacturer: Melfas
09-17-36-335| [        KERNEL] [38720.299824] input: Melfas LGD AIT Touch Controller as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4.2/1-1.4.2.1/1-1.4.2.1:1.0/0003:1FD2:6103.0004/input/input2
09-17-36-335| [        KERNEL] [38720.300646] hid-multitouch 0003:1FD2:6103.0004: input,hiddev0,hidraw3: USB HID v2.00 Device [Melfas LGD AIT Touch Controller] on usb-3f980000.usb-1.4.2.1/input0
09-17-36-335| [        KERNEL] [38720.304998] hid-generic 0003:1FD2:6103.0005: hiddev0,hidraw4: USB HID v2.00 Device [Melfas LGD AIT Touch Controller] on usb-3f980000.usb-1.4.2.1/input1
09-17-36-335| [            gm] [38720.370296] EV_ABS flag found. Add mouse event2: Melfas LGD AIT Touch Controller.
09-17-36-335| [        KERNEL] [38720.402558] usb 1-1.4.2.2: new full-speed USB device number 9 using dwc_otg
09-17-36-335| [        KERNEL] [38720.538599] usb 1-1.4.2.2: New USB device found, idVendor=05e0, idProduct=1200
09-17-36-335| [        KERNEL] [38720.538609] usb 1-1.4.2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
09-17-36-335| [        KERNEL] [38720.538618] usb 1-1.4.2.2: Product: Symbol Bar Code Scanner
09-17-36-335| [        KERNEL] [38720.538625] usb 1-1.4.2.2: Manufacturer: Symbol Technologies, Inc, 2008
09-17-36-335| [        KERNEL] [38720.538634] usb 1-1.4.2.2: SerialNumber: S/N:E1E2D78698974D82B101572CCEC66E8F Rev:PAACFS00-002-R003
09-17-36-335| [        KERNEL] [38720.545309] input: Symbol Technologies, Inc, 2008 Symbol Bar Code Scanner as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4.2/1-1.4.2.2/1-1.4.2.2:1.0/0003:05E0:1200.0006/input/input3
09-17-36-335| [        KERNEL] [38720.614164] hid-generic 0003:05E0:1200.0006: input,hidraw5: USB HID v1.10 Keyboard [Symbol Technologies, Inc, 2008 Symbol Bar Code Scanner] on usb-3f980000.usb-1.4.2.2/input0
09-17-36-335| [            gm] [38720.621622] Add keyboard event3: Symbol Technologies, Inc, 2008 Symbol Bar Code Scanner.
09-17-36-335| [            gm] [38725.179357] [TOUCHSCREEN] ==================================================
09-17-36-335| [            gm] [38725.179495] [TOUCHSCREEN] Hardware configuration:
09-17-36-335| [            gm] [38725.179594] [TOUCHSCREEN]      touchscreen = 0..4095,0..4095
09-17-36-335| [            gm] [38725.179698] [TOUCHSCREEN] ==================================================
09-17-36-335| [            gm] [96260.414054] Close input device 'Melfas LGD AIT Touch Controller', errno 19.
09-17-36-335| [        KERNEL] [96260.412916] hub 1-1.4.2:1.0: hub_ext_port_status failed (err = -71)
09-17-36-335| [        KERNEL] [96260.413061] usb 1-1.4.2-port1: cannot reset (err = -71)
09-17-36-335| [        KERNEL] [96260.413202] usb 1-1.4.2-port1: cannot reset (err = -71)
09-17-36-335| [        KERNEL] [96260.413340] usb 1-1.4.2-port1: cannot reset (err = -71)
09-17-36-335| [        KERNEL] [96260.413468] usb 1-1.4.2-port1: cannot reset (err = -71)
09-17-36-335| [        KERNEL] [96260.413473] usb 1-1.4.2-port1: Cannot enable. Maybe the USB cable is bad?
09-17-36-335| [        KERNEL] [96260.413605] usb 1-1.4.2-port1: cannot disable (err = -71)
09-17-36-335| [        KERNEL] [96260.413753] usb 1-1.4.2-port1: cannot reset (err = -71)
09-17-36-335| [        KERNEL] [96260.413897] usb 1-1.4.2-port1: cannot reset (err = -71)
09-17-36-335| [        KERNEL] [96260.414039] usb 1-1.4.2-port1: cannot reset (err = -71)
09-17-36-335| [        KERNEL] [96260.414181] usb 1-1.4.2-port1: cannot reset (err = -71)
09-17-36-335| [        KERNEL] [96260.414326] usb 1-1.4.2-port1: cannot reset (err = -71)
09-17-36-335| [        KERNEL] [96260.414331] usb 1-1.4.2-port1: Cannot enable. Maybe the USB cable is bad?
09-17-36-335| [        KERNEL] [96260.414464] usb 1-1.4.2-port1: cannot disable (err = -71)
09-17-36-335| [        KERNEL] [96260.414595] usb 1-1.4.2-port1: cannot reset (err = -71)
09-17-36-335| [        KERNEL] [96260.414725] usb 1-1.4.2-port1: cannot reset (err = -71)
09-17-36-335| [        KERNEL] [96260.414853] usb 1-1.4.2-port1: cannot reset (err = -71)
09-17-36-335| [        KERNEL] [96260.414981] usb 1-1.4.2-port1: cannot reset (err = -71)
09-17-36-335| [        KERNEL] [96260.415108] usb 1-1.4.2-port1: cannot reset (err = -71)
09-17-36-335| [        KERNEL] [96260.415113] usb 1-1.4.2-port1: Cannot enable. Maybe the USB cable is bad?
09-17-36-335| [        KERNEL] [96260.415255] usb 1-1.4.2-port1: cannot disable (err = -71)
09-17-36-335| [        KERNEL] [96260.415397] usb 1-1.4.2-port1: cannot reset (err = -71)
09-17-36-335| [        KERNEL] [96260.415540] usb 1-1.4.2-port1: cannot reset (err = -71)
09-17-36-335| [        KERNEL] [96260.415680] usb 1-1.4.2-port1: cannot reset (err = -71)
09-17-36-335| [        KERNEL] [96260.415822] usb 1-1.4.2-port1: cannot reset (err = -71)
09-17-36-335| [        KERNEL] [96260.415965] usb 1-1.4.2-port1: cannot reset (err = -71)
09-17-36-335| [        KERNEL] [96260.415970] usb 1-1.4.2-port1: Cannot enable. Maybe the USB cable is bad?
09-17-36-335| [        KERNEL] [96260.416098] usb 1-1.4.2-port1: cannot disable (err = -71)
09-17-36-335| [        KERNEL] [96260.416228] usb 1-1.4.2-port1: cannot disable (err = -71)
09-17-36-335| [        KERNEL] [96260.416790] hub 1-1.4.2:1.0: hub_ext_port_status failed (err = -71)
09-17-36-335| [        KERNEL] [96260.426652] usb 1-1.4: USB disconnect, device number 5
09-17-36-335| [        KERNEL] [96260.426666] usb 1-1.4.2: USB disconnect, device number 6
09-17-36-335| [        KERNEL] [96260.426675] usb 1-1.4.2.1: USB disconnect, device number 8
09-17-36-335| [        KERNEL] [96260.465421] usb 1-1.4.2.2: USB disconnect, device number 9
09-17-36-335| [            gm] [96260.670669] Close input device 'Symbol Technologies, Inc, 2008 Symbol Bar Code Scanner', errno 19.
09-17-36-335| [        KERNEL] [96260.754801] usb 1-1.4.5: USB disconnect, device number 7
09-17-36-335| [        KERNEL] [126862.452859] usb 1-1.4: new high-speed USB device number 10 using dwc_otg
09-17-36-335| [        KERNEL] [126862.585132] usb 1-1.4: New USB device found, idVendor=0424, idProduct=2734
09-17-36-335| [        KERNEL] [126862.585143] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
09-17-36-335| [        KERNEL] [126862.585151] usb 1-1.4: Product: USB2734
09-17-36-335| [        KERNEL] [126862.585158] usb 1-1.4: Manufacturer: Microchip Tech
09-17-36-335| [        KERNEL] [126862.585942] hub 1-1.4:1.0: USB hub found
09-17-36-335| [        KERNEL] [126862.586088] hub 1-1.4:1.0: 5 ports detected
09-17-36-335| [        KERNEL] [126863.312870] usb 1-1.4.2: new high-speed USB device number 11 using dwc_otg
09-17-36-335| [        KERNEL] [126863.443176] usb 1-1.4.2: New USB device found, idVendor=0424, idProduct=2412
09-17-36-335| [        KERNEL] [126863.443187] usb 1-1.4.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
09-17-36-335| [        KERNEL] [126863.443964] hub 1-1.4.2:1.0: USB hub found
09-17-36-335| [        KERNEL] [126863.444127] hub 1-1.4.2:1.0: 2 ports detected
09-17-36-335| [        KERNEL] [126863.542866] usb 1-1.4.5: new high-speed USB device number 12 using dwc_otg
09-17-36-335| [        KERNEL] [126863.676563] usb 1-1.4.5: New USB device found, idVendor=0424, idProduct=274c
09-17-36-335| [        KERNEL] [126863.676575] usb 1-1.4.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
09-17-36-335| [        KERNEL] [126863.676583] usb 1-1.4.5: Product: Hub Controller
09-17-36-335| [        KERNEL] [126863.676591] usb 1-1.4.5: Manufacturer: Microchip Tech
09-17-36-335| [        KERNEL] [126863.681932] hid-generic 0003:0424:274C.0007: hiddev0,hidraw2: USB HID v1.10 Device [Microchip Tech Hub Controller] on usb-3f980000.usb-1.4.5/input1
09-17-36-335| [        KERNEL] [126863.772855] usb 1-1.4.2.2: new full-speed USB device number 13 using dwc_otg
09-17-36-335| [        KERNEL] [126863.907619] usb 1-1.4.2.2: New USB device found, idVendor=05e0, idProduct=1200
09-17-36-335| [        KERNEL] [126863.907631] usb 1-1.4.2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
09-17-36-335| [        KERNEL] [126863.907639] usb 1-1.4.2.2: Product: Symbol Bar Code Scanner
09-17-36-335| [        KERNEL] [126863.907646] usb 1-1.4.2.2: Manufacturer: Symbol Technologies, Inc, 2008
09-17-36-335| [        KERNEL] [126863.907654] usb 1-1.4.2.2: SerialNumber: S/N:E1E2D78698974D82B101572CCEC66E8F Rev:PAACFS00-002-R003
09-17-36-335| [        KERNEL] [126863.913949] input: Symbol Technologies, Inc, 2008 Symbol Bar Code Scanner as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4.2/1-1.4.2.2/1-1.4.2.2:1.0/0003:05E0:1200.0008/input/input4
09-17-36-335| [        KERNEL] [126863.984431] hid-generic 0003:05E0:1200.0008: input,hidraw3: USB HID v1.10 Keyboard [Symbol Technologies, Inc, 2008 Symbol Bar Code Scanner] on usb-3f980000.usb-1.4.2.2/input0
09-17-36-335| [        KERNEL] [126864.282862] usb 1-1.4.2.1: new full-speed USB device number 14 using dwc_otg
09-17-36-335| [        KERNEL] [126864.417245] usb 1-1.4.2.1: New USB device found, idVendor=1fd2, idProduct=6103
09-17-36-335| [        KERNEL] [126864.417256] usb 1-1.4.2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
09-17-36-335| [        KERNEL] [126864.417265] usb 1-1.4.2.1: Product: LGD AIT Touch Controller
09-17-36-335| [        KERNEL] [126864.417272] usb 1-1.4.2.1: Manufacturer: Melfas
09-17-36-335| [        KERNEL] [126864.429971] input: Melfas LGD AIT Touch Controller as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4.2/1-1.4.2.1/1-1.4.2.1:1.0/0003:1FD2:6103.0009/input/input5
09-17-36-335| [        KERNEL] [126864.430780] hid-multitouch 0003:1FD2:6103.0009: input,hiddev0,hidraw4: USB HID v2.00 Device [Melfas LGD AIT Touch Controller] on usb-3f980000.usb-1.4.2.1/input0
09-17-36-335| [        KERNEL] [126864.434985] hid-generic 0003:1FD2:6103.000A: hiddev0,hidraw5: USB HID v2.00 Device [Melfas LGD AIT Touch Controller] on usb-3f980000.usb-1.4.2.1/input1
09-17-36-335| [            gm] [126877.662952] [TOUCHSCREEN] ==================================================
09-17-36-335| [            gm] [126877.663120] [TOUCHSCREEN] Hardware configuration:
09-17-36-335| [            gm] [126877.663208] [TOUCHSCREEN]      touchscreen = 0..4095,0..4095
09-17-36-335| [            gm] [126877.663287] [TOUCHSCREEN] ==================================================
09-17-36-335| Send WTCU discover to 192.168.5.203.
09-17-36-341| Connection from wtc.exe at 192.168.5.203.
Posted: Tue Oct 30, 2018 3:14 pm
You ignore all four points in manual https://wtware.com/logs.html
5.6.24 is ok, keyboard= here for many years. All other is not ok. Here is my screen, two lines in config:
server=10.1.1.85
keyboard=hu
Posted: Tue Oct 30, 2018 3:31 pm
by skynet
I don't understand. So what's the problem?
Unfortunately, it does not work.
do you have an idea?
This is my template:
keyboard=hu
graphic=abcdefg
sound=on
microphone=on
vnc=on
vnc_password=patak
bpp=32
display=1920x1080
language=hu,default
