PXE/netboot on Pi3
Posted: Fri Nov 04, 2016 2:34 pm
by Gnome
Hello!
Pi3 can generally boot over Network without SD-Card. Has anyone tried this for WT-Ware?
Description on the RasPi website didn't help me to get PXE-boot to work.
Any hints or experience on how to configure a Pi3 for netboot to WT-Ware without SD-Card?
Re: PXE/netboot on Pi3
Posted: Sat Nov 05, 2016 9:55 pm
Gnome wrote:Pi3 can generally boot over Network without SD-Card
Really? Give me an instruction. As far as I know, Pi3 can not start without SD.
Posted: Mon Nov 07, 2016 2:47 pm
by J1mbo
Posted: Fri Nov 11, 2016 5:11 am
by Guest
Prepared the Pi3 as described and it seems to access the network for boot information (LAN-leds flashing) but nothing more happens. Screen is black. Any ideas how to get further?
Posted: Fri Nov 11, 2016 12:17 pm
by J1mbo
Did you update the RPi firmware with the net boot settings from Raspbian?
Posted: Fri Nov 11, 2016 1:36 pm
by Gnome
Yes. Updated next_branch firmware and activated netboot option. Had the WTware netboot active before, starting from SD card, and it worked. RPi's netboot may not be working the same way as WTwares netboot...
Think this is more or less a question to the technicians at WTware...
Did anyone try to boot from blank RPi to WTware before?
Posted: Fri Nov 11, 2016 11:56 pm
by Gnome
I cracked the nut !!!
Managed to netboot WTware client without SD card.
There may be certain restrictions...
Let me have some tests done before I tell you more.
Posted: Mon Nov 14, 2016 12:31 pm
by J1mbo
Please do
Posted: Fri Jan 13, 2017 7:46 pm
by Cza
Please send me some instruction about the diskless wtware configuration.
Regards,
Cza
Posted: Fri Feb 24, 2017 1:54 pm
by rodo
@Gnome
How are you?
No longer heard from you.
Best regards
Rolf
Posted: Fri Mar 17, 2017 10:22 pm
by uncle_muddy
My 1st post so please be gentle with me
1st thing to say is what an awesome product this is, and was just what I have been looking for..
I too am trying to get this to work, I have tested that I can get the Pi3 to boot as standard without SD from the network and that works fine (or at least it did after a fashion) But once I get past that bit I'm getting a little (very) lost.
What I'm trying to do now is bend it so I can get wtware to boot in the same fashion, so that I don't need to have an SD card in the Pi to get it to boot to wtware.
If anyone has any useful info or pointers they would be much appreciated
UM
Posted: Sun Mar 19, 2017 6:25 pm
by uncle_muddy
I've made a bunch of progress on this over the last couple of days, but now I'm stuck.
I can get the Pi to boot and load up to the "Press DEL to enter SETUP" screen, thats when we run into problems, I then get the following on the screen
ERROR: INTERNAL ERROR
WTware v.5.4.78/RPi
File: initrd.cpp
Line: 254
Please, report this information to WTware tech support.
Please, correct the error to continue.
WTware v.5.4.78/RPi documentation is avaialble at http://www.wtware.com/doc.html
Techsupport, forum: http://forum.wtware.com
email: support@wtware.com
Skype: wtware
and I'm dumped out to a # prompt on the machine, I'm going to be a little tied for time over the coming days but if anyone has any pointer I can test and report back results
UM
Posted: Mon Mar 20, 2017 12:05 pm
by uncle_muddy
I have over come the problem and managed to get it to work
Posted: Mon Mar 20, 2017 12:15 pm
We'll release wtware with this boot in a few days.
Posted: Tue Mar 21, 2017 12:48 pm
