How to change IP setting & TFTP server remotely ?
Posted: Tue Aug 23, 2016 12:34 pm
by nicodep
Hi Aka,
I test your wtware solution with PI3 and it's fantastic !
Question : how to change remotely PI3 tcp IP from IP static to DHCP, and modify TFTP server IP ?
I can accces localy via DEL touch ... but remotely ?
Thk
Re: How to change IP setting & TFTP server remotely ?
Posted: Tue Aug 23, 2016 3:52 pm
Sorry, there is no access to these settings.
Posted: Tue Feb 14, 2017 1:40 pm
by nicodep
Hi Aka,
Same question because i have now 80 PI3 in different shop and we change local router
I need to change remotely PI3 IP TCP config from static to DHCP ?
Posted: Tue Feb 14, 2017 3:30 pm
No way
The same problem will be with updating to newer wtware version.
Write 80 new SD cards and ask users to replace.
Posted: Tue Feb 14, 2017 3:36 pm
by J1mbo
Worth noting that network boot is now working, so new SD cards are not needed anymore (once RPi firmware is updated though).
Posted: Tue Feb 14, 2017 7:59 pm
by nicodep
J1mbo wrote:Worth noting that network boot is now working, so new SD cards are not needed anymore (once RPi firmware is updated though).
Hi J1mbo, can you explain your solution ?
for info, i can't add parameter on each shop because the dhcp is inside the router
Posted: Tue Feb 14, 2017 8:55 pm
by J1mbo
I would configure the router for DHCP relay in that case to your central location.
