Unable save terminal config file
Posted: Thu Oct 20, 2011 10:20 am
Hi to all and sorry for my english,
i have tried for many time wtware 4.6.8 installed on Wxp Pro workstation and with terminal boot via cdrom. All work fine and fast. I can connect to my RDP server without any problem.
In my new test scenario i have:
Windows 2003 R2 with Microsoft DHCP server
Wtware 5.01 installed on this server with all default value (dir, connection server, etc) except that i have not installed builtin DHCP.
I would boot via PXE
In DHCP i have make a reservation for test client and i have set only 067 parameter with value 5.0.1\wtware.pxe
Workstation start, receive configuration file from tftp server and show me an alert that say that configuration file not exist. I run without any problem the wizard, complete successfully the configuration, press F10 to save config file and connect to my rdp server. All work fine.
Here the problem!
When i restart my workstation, wtware wizard restart because not found any configuration file...
If i look in server terminals dir, i found dir named with mac address but i can't find any configuration file inside it.
Where my mistake?
I hope to be clear in my explanation.
Thanks in advanced for any help.
Kind regards.
Massimo
Here the problem!
Where my mistake?
Kind regards.
Massimo
