DHCP Option 18 ignored?
twister5800
Post by twister5800 »
Have tried setting hash password in DHCP parameter 18 extensions-path option, but no matter what, you can access setup (Press DEL for setup), without entering password.
Does this not work for Rpi?
best regards
Martin
Re: DHCP Option 18 ignored?
It should work. Show me a log, please: https://wtware.com/logs.html
naves
Post by naves »
Hi, thanks for the great software.
I have the same problem with option 18 on WTware 5.6.24/RPi
Log:
WTware 5.6.24
WTware 5.6.24/RPi supervisor.
[        KERNEL] [    0.000000] Booting Linux on physical CPU 0xf00
[        KERNEL] [    0.000000] Linux version 4.9.75 (aka@c16) (gcc version 7.2.0 (Debian 7.2.0-11) ) #4 SMP Wed Jan 10 10:39:31 EST 2018
[        KERNEL] [    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[        KERNEL] [    0.000000] OF: fdt:Machine model: Raspberry Pi 2 Model B Rev 1.1
[        KERNEL] [    0.000000] free_area_init_node: node 0, pgdat 80c22b80, node_mem_map ba3a1000
[        KERNEL] [    0.000000] Kernel command line: bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbdepth=32 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait
[        KERNEL] [    0.000000]       .data : 0x80c00000 - 0x80c23e38   ( 144 kB)
[        KERNEL] [    0.000000]        .bss : 0x80c25000 - 0x80c805e0   ( 366 kB)
[        KERNEL] [    0.000000] 	Build-time adjustment of leaf fanout to 32.
[        KERNEL] [    0.000009] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[        KERNEL] [    0.000027] Switching to timer-based delay loop, resolution 52ns
[        KERNEL] [    0.000262] Console: colour dummy device 80x30
[        KERNEL] [    0.001024] console [tty1] enabled
[        KERNEL] [    0.001069] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[        KERNEL] [    0.001141] pid_max: default: 32768 minimum: 301
[        KERNEL] [    0.001348] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[        KERNEL] [    0.001392] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[        KERNEL] [    0.002452] Disabling memory control group subsystem
[        KERNEL] [    0.002577] CPU: Testing write buffer coherency: ok
[        KERNEL] [    0.003107] CPU0: update cpu_capacity 1024
[        KERNEL] [    0.003152] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[        KERNEL] [    0.003218] Setting up static identity map for 0x100000 - 0x100034
[        KERNEL] [    0.005601] CPU1: update cpu_capacity 1024
[        KERNEL] [    0.005612] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[        KERNEL] [    0.006477] CPU2: update cpu_capacity 1024
[        KERNEL] [    0.006485] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[        KERNEL] [    0.007343] CPU3: update cpu_capacity 1024
[        KERNEL] [    0.007353] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[        KERNEL] [    0.007461] Brought up 4 CPUs
[        KERNEL] [    0.007677] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[        KERNEL] [    0.007712] CPU: All CPU(s) started in HYP mode.
[        KERNEL] [    0.007744] CPU: Virtualization extensions available.
[        KERNEL] [    0.008616] devtmpfs: initialized
[        KERNEL] [    0.020569] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[        KERNEL] [    0.021215] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[        KERNEL] [    0.021297] futex hash table entries: 1024 (order: 4, 65536 bytes)
[        KERNEL] [    0.022043] pinctrl core: initialized pinctrl subsystem
[        KERNEL] [    0.022927] NET: Registered protocol family 16
[        KERNEL] [    0.025225] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[        KERNEL] [    0.037942] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[        KERNEL] [    0.121885] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb80f000, dmachans=0x1
[        KERNEL] [    0.125187] usbcore: registered new interface driver usbfs
[        KERNEL] [    0.125422] usbcore: registered new interface driver hub
[        KERNEL] [    0.125590] usbcore: registered new device driver usb
[        KERNEL] [    0.130326] raspberrypi-firmware soc:firmware: Attached to firmware from 2018-01-08 14:28
[        KERNEL] [    0.133703] clocksource: Switched to clocksource arch_sys_counter
[        KERNEL] [    0.155759] NET: Registered protocol family 2
[        KERNEL] [    0.156589] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[        KERNEL] [    0.156755] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[        KERNEL] [    0.156976] TCP: Hash tables configured (established 8192 bind 8192)
[        KERNEL] [    0.157116] UDP hash table entries: 512 (order: 2, 16384 bytes)
[        KERNEL] [    0.157207] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[        KERNEL] [    0.157509] NET: Registered protocol family 1
[        KERNEL] [    3.009265] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[        KERNEL] [    3.096360] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[        KERNEL] [    3.096449] io scheduler noop registered
[        KERNEL] [    3.096486] io scheduler deadline registered (default)
[        KERNEL] [    3.112395] BCM2708FB: allocated DMA memory fad00000
[        KERNEL] [    3.112499] BCM2708FB: allocated DMA channel 0 @ bb80f000
[        KERNEL] [    3.170092] Console: switching to colour frame buffer device 240x67
[        KERNEL] [    3.206428] bcm2835-rng 3f104000.rng: hwrng registered
[        KERNEL] [    3.206781] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[        KERNEL] [    3.208162] vc-sm: Videocore shared memory driver
[        KERNEL] [    3.220768] zram: Added device: zram0
[        KERNEL] [    3.221078] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[        KERNEL] [    3.449660] Core Release: 2.80a
[        KERNEL] [    3.449834] Setting default values for core params
[        KERNEL] [    3.450009] Finished setting default values for core params
[        KERNEL] [    3.650592] Using Buffer DMA mode
[        KERNEL] [    3.650734] Periodic Transfer Interrupt Enhancement - disabled
[        KERNEL] [    3.650899] Multiprocessor Interrupt Enhancement - disabled
[        KERNEL] [    3.651057] OTG VER PARAM: 0, OTG VER FLAG: 0
[        KERNEL] [    3.651349] Dedicated Tx FIFOs mode
[        KERNEL] [    3.652333] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xbad14000 dma = 0xfad14000 len=9024
[        KERNEL] [    3.652635] FIQ FSM acceleration enabled for :
[        KERNEL] [    3.652635] Non-periodic Split Transactions
[        KERNEL] [    3.652635] Periodic Split Transactions
[        KERNEL] [    3.652635] High-Speed Isochronous Endpoints
[        KERNEL] [    3.652635] Interrupt/Control Split Transaction hack enabled
[        KERNEL] [    3.653215] dwc_otg: Microframe scheduler enabled
[        KERNEL] [    3.653284] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x80397770
[        KERNEL] [    3.653467] WARN::hcd_init_fiq:460: FIQ ASM at 0x80397ad4 length 36
[        KERNEL] [    3.653653] WARN::hcd_init_fiq:486: MPHI regs_base at 0xbb925000
[        KERNEL] [    3.653934] dwc_otg 3f980000.usb: DWC OTG Controller
[        KERNEL] [    3.654136] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[        KERNEL] [    3.654385] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[        KERNEL] [    3.654592] Init: Port Power? op_state=1
[        KERNEL] [    3.654707] Init: Power Port (0)
[        KERNEL] [    3.655080] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[        KERNEL] [    3.655280] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[        KERNEL] [    3.655484] usb usb1: Product: DWC OTG Controller
[        KERNEL] [    3.655622] usb usb1: Manufacturer: Linux 4.9.75 dwc_otg_hcd
[        KERNEL] [    3.655785] usb usb1: SerialNumber: 3f980000.usb
[        KERNEL] [    3.656955] hub 1-0:1.0: USB hub found
[        KERNEL] [    3.657181] hub 1-0:1.0: 1 port detected
[        KERNEL] [    3.658328] dwc_otg: FIQ enabled
[        KERNEL] [    3.658339] dwc_otg: NAK holdoff enabled
[        KERNEL] [    3.658344] dwc_otg: FIQ split-transaction FSM enabled
[        KERNEL] [    3.658365] Module dwc_common_port init
[        KERNEL] [    3.659163] usbcore: registered new interface driver usbtouchscreen
[        KERNEL] [    3.661093] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[        KERNEL] [    3.661945] bcm2835-cpufreq: min=600000 max=900000
[        KERNEL] [    3.675745] sdhost-bcm2835 3f202000.sdhost: could not get clk, deferring probe
[        KERNEL] [    3.683913] ledtrig-cpu: registered to indicate activity on CPUs
[        KERNEL] [    3.693113] hidraw: raw HID events driver (C) Jiri Kosina
[        KERNEL] [    3.704581] usbcore: registered new interface driver usbhid
[        KERNEL] [    3.711505] usbhid: USB HID core driver
[        KERNEL] [    3.729922] vchiq: vchiq_init_state: slot_zero = 0xbad80000, is_master = 0
[        KERNEL] [    3.737799] [vc_sm_connected_init]: start
[        KERNEL] [    3.747722] [vc_sm_connected_init]: end - returning 0
[        KERNEL] [    3.754516] NET: Registered protocol family 17
[        KERNEL] [    3.760690] Registering SWP/SWPB emulation handler
[        KERNEL] [    3.768293] registered taskstats version 1
[        KERNEL] [    3.780890] sdhost: log_buf @ bad13000 (fad13000)
[        KERNEL] [    3.863730] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[        KERNEL] [    3.863869] of_cfs_init
[        KERNEL] [    3.863988] of_cfs_init: OK
[        KERNEL] [    3.895399] Indeed it is in host mode hprt0 = 00021501
[        KERNEL] [    3.897858] Freeing unused kernel memory: 5120K
[        KERNEL] [    4.002403] random: fast init done
[        KERNEL] [    4.021492] mmc0: host does not support reading read-only switch, assuming write-enable
[        KERNEL] [    4.023495] mmc0: new high speed SDHC card at address 0001
[        KERNEL] [    4.024675] mmcblk0: mmc0:0001 TEAM 14.8 GiB
[        KERNEL] [    4.028193]  mmcblk0: p1 p2
[       hotplug] [    4.030801] Block device 179:1. No action.
[       hotplug] [    4.031375] Block device 179:0. No action.
[       hotplug] [    4.032495] Block device 179:2. No action.
[        KERNEL] [    4.123763] usb 1-1: new high-speed USB device number 2 using dwc_otg
[        KERNEL] [    4.123940] Indeed it is in host mode hprt0 = 00001101
[       hotplug] [    4.130807] Block device 254:0. No action.
[          pfac] [    4.310808] Run /sbin/initrd.
[          pfac] [    4.311146] Ok, PID 596.
[        initrd] [    4.315813] WTware shell 5.6.24/RPi
[        KERNEL] [    4.375037] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[        KERNEL] [    4.375045] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[        KERNEL] [    4.375874] hub 1-1:1.0: USB hub found
[        KERNEL] [    4.376006] hub 1-1:1.0: 5 ports detected
[        KERNEL] [    4.693741] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[        KERNEL] [    4.824060] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[        KERNEL] [    4.824077] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[        KERNEL] [    4.923760] usb 1-1.2: new low-speed USB device number 4 using dwc_otg
[        KERNEL] [    5.058682] usb 1-1.2: New USB device found, idVendor=03f0, idProduct=094a
[        KERNEL] [    5.058698] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[        KERNEL] [    5.058707] usb 1-1.2: Product: HP USB Optical Mouse
[        KERNEL] [    5.058716] usb 1-1.2: Manufacturer: PixArt
[        KERNEL] [    5.071417] input: PixArt HP USB Optical Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:03F0:094A.0001/input/input0
[        KERNEL] [    5.072706] hid-generic 0003:03F0:094A.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt HP USB Optical Mouse] on usb-3f980000.usb-1.2/input0
[        KERNEL] [    5.173748] usb 1-1.3: new low-speed USB device number 5 using dwc_otg
[        KERNEL] [    5.323193] usb 1-1.3: New USB device found, idVendor=04b3, idProduct=3025
[        KERNEL] [    5.323211] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[        KERNEL] [    5.323221] usb 1-1.3: Product: USB NetVista Full Width Keyboard
[        KERNEL] [    5.323229] usb 1-1.3: Manufacturer: CHICONY
[        KERNEL] [    5.337031] input: CHICONY USB NetVista Full Width Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:04B3:3025.0002/input/input1
[        KERNEL] [    5.415465] hid-generic 0003:04B3:3025.0002: input,hidraw1: USB HID v1.10 Keyboard [CHICONY USB NetVista Full Width Keyboard] on usb-3f980000.usb-1.3/input0
[        initrd] [    5.856664] Load ethernet drivers.
[        initrd] [    5.856917] modprobe smsc95xx.
[        KERNEL] [    5.870905] smsc95xx v1.0.5
[        KERNEL] [    5.968398] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:3a:5a:b9
[        KERNEL] [    5.968809] usbcore: registered new interface driver smsc95xx
[        KERNEL] [    6.076453] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[        KERNEL] [    7.512677] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC1E1
[        initrd] [   10.960237] dhcp: 401 bytes from 192.168.3.254.
[        initrd] [   10.960443] 00000000:0000017D0000000000110000C0A803FEFFFFFFFF00430044017D000002010600  ...}................C.D.}......
[        initrd] [   10.960559] 00000020:67458B6B0000000000000000C0A801BAC0A8036F00000000B827EB3A5AB90000  gE.k...............o.....'.:Z...
[        initrd] [   10.960658] 00000040:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   10.960760] 00000060:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   10.960857] 00000080:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   10.960980] 000000a0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   10.961076] 000000c0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   10.961171] 000000e0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   13.250249] dhcp: 401 bytes from 192.168.3.254.
[        initrd] [   13.250442] 00000000:0000017D0000000000110000C0A803FEFFFFFFFF00430044017D000002010600  ...}................C.D.}......
[        initrd] [   13.250558] 00000020:67458B6B0000000000000000C0A801BAC0A8036F00000000B827EB3A5AB90000  gE.k...............o.....'.:Z...
[        initrd] [   13.250662] 00000040:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   13.250761] 00000060:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   13.250858] 00000080:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   13.250954] 000000a0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   13.251049] 000000c0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   13.251144] 000000e0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   13.300166] [DHCP] DHCP server address 192.168.3.254.
[        initrd] [   13.300288] [DHCP] IP 192.168.1.186 mask 255.255.252.0.
[        initrd] [   13.300394] [DHCP] Default gateway 192.168.0.1.
[        initrd] [   13.300496] [DHCP] DNS 192.168.3.254.
[        initrd] [   13.300593] [DHCP] DNS 192.168.3.253.
[        initrd] [   13.300687] [DHCP] NTP 192.168.0.1.
[        initrd] [   13.300782] [DHCP] Domain local.xxxxx.ru.
[        initrd] [   13.300885] [DHCP] TFTP from 066 192.168.3.111.
[        initrd] [   13.300988] [DHCP] TFTP 192.168.3.111.
[        initrd] [   13.301091] [DHCP] Use default TFTP prefix for Raspberry network boot.
[        initrd] [   13.301191] [DHCP] TFTP binary "5.6.24/", configs prefix "", using "/" slash.
[        initrd] [   13.301294] [DHCP] WTPassword hash 3f9f2ea8e36aaeecfe82b1ba0e353683.
[        initrd] [   13.309249] Success: media /dev/mmcblk0p1 mounted to /bootmedia.
| # http://www.raspberrypi.org/documentation/configuration/config-txt.md
| #hdmi_safe=1
| disable_overscan=1
| #hdmi_force_hotplug=1
| #hdmi_group=1
| #hdmi_mode=1
| #hdmi_drive=2
| # no display.
| #config_hdmi_boost=4
| #arm_freq=800
| disable_splash=1
| #hdmi_group=2
| # 800x600:   hdmi_mode=9
| # 1024x768:  hdmi_mode=16
| # 1280x1024: hdmi_mode=35
| # 1360x768:  hdmi_mode=39
| # 1400x1050: hdmi_mode=42
| # 1440x900:  hdmi_mode=47
| # 1600x1200: hdmi_mode=51
| # 1680x1050: hdmi_mode=58
| # 1366x768:  hdmi_mode=81
| # 1920x1080: hdmi_mode=82
| # 1920x1200: hdmi_mode=69
| framebuffer_depth=32
| #framebuffer_depth=16
| dtparam=audio=on
| #avoid_warnings=1
| #avoid_warnings=2
| hdmi_blanking=1
[        initrd] [   13.315126] WTpassword empty.
[        initrd] [   13.351037] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
[          pfac] [   13.351246] Run /sbin/httpd.
[          pfac] [   13.351635] Ok, PID 634.
[         httpd] [   13.360393] HTTP Server, WTware 5.6.24/RPi
[        initrd] [   13.486826] USB: 04b3:3025 IBM Corp. NetVista Full Width Keyboard.
[        initrd] [   13.487047] USB: 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter.
[        initrd] [   13.487178] USB: 0424:9514 Standard Microsystems Corp. SMC9514 Hub.
[        initrd] [   13.487298] USB: 03f0:094a Hewlett-Packard Optical Mouse [672662-001].
[        initrd] [   13.487410] [TFTP] Download config file Everyone/source.wtc from 192.168.3.111.
[        initrd] [   13.497594] [TFTP] WTware TFTP v.5.6.24.
[        initrd] [   13.511871] [TFTP] Download config file Everyone/list.wtc from 192.168.3.111.
[        initrd] [   13.524639] [TFTP] Download config file Terminals/B8.27.EB.3A.5A.B9/config.wtc from 192.168.3.111.
[        initrd] [   13.525468] [TFTP] Error code 1: File not found..
[        initrd] [   13.525591] [TFTP] Download config file Terminals/B8.27.EB.3A.5A.B9.wtc from 192.168.3.111.
[        initrd] [   13.526374] [TFTP] Error code 1: File not found..
[        initrd] [   13.526489] [TFTP] Download config file Everyone/default.wtc from 192.168.3.111.
/--- FILE "/tmp/default.wtc" -----------------------
| # Список групп терминалов по подсетям.
| # Если терминал загружается по сети и не находит индивидуальный конфигурационный
| # файл на сервере, то он останавливает работу, сообщает, что терминал не настроен, и требует
| # создать конфигурационный файл для этого терминала.
| # Это поведение можно изменить. Для группы терминалов в выбранной подсети либо вообще для всех
| # терминалов можно создать конфигурационный файл по умолчанию. Создайте группу интересующих вас
| # терминалов, а затем в списке терминалов найдите соответствующую строку и создайте
| # конфигурацию по умолчанию.
| # После этого новый терминал из этой группы будет считаться автоматически настроенным:
| # не будет показывать предупреждений, а скачает созданную вами конфигурацию.
| # Формат строки в этом файле:
| # 03 10.1.1.0/24 Удаленный филиал
| # Первым идет номер группы в 16-ричном формате - 03. Допустимы номера от 01 до ff.
| # Тогда конфигурация группы 03 будет в папке FF.FF.FF.FF.FF.03 в каталоге Terminals.
| # Далее идут параметры подсети - IP и маска - 10.1.1.0/24.
| # "Удаленный филиал" - название группы, по которому вы найдете эту группу в конфигураторе
| # в списке терминалов.
| # Эта конфигурация будет скачиваться TFTP-сервером как индивидуальный конфигурационный
| # файл по умолчанию для терминалов из подсети 10.1.1.0/24, у которых нет собственного
| # конфигурационного файла.
| # Еще пример:
| # 0d 192.168.1.0/16 Подсеть бухгалтерии
| # Группа для подсети 192.168.1.0/16. Конфигурация хранится в каталоге FF.FF.FF.FF.FF.0d.
| # В списке терминалов в конфигураторе находится под названием "Подсеть бухгалтерии".
| # В конце файла можно добавить группу для всех остальных терминалов в сети, не попавших
| # в указанные подсети. Эта группа должна быть единственной. Эта группа должна быть последней
| # строкой в default.wtc. Все группы, указанные после нее, будут проигнорированы при считывании.
| # Формат строки группы для всех терминалов:
|  1f all ZOOOOOO
[        initrd] [   13.541421] Default config group FF:FF:FF:FF:FF:1F.
[        initrd] [   13.541553] [TFTP] Download config file Terminals/FF.FF.FF.FF.FF.1F/config.wtc from 192.168.3.111.
[        initrd] [   13.551101] [TFTP] Download config file Everyone/all.wtc from 192.168.3.111.
| server=rdp
| disk=cdrom; usb
| graphic=af
| onerror=30
| sleep=10,poweroff
| sound=on
| vnc=on
| vnc_password=hex:797593216c9c954ea74e400d2dd28133
| clienthostname=wt*IP3
| mouse_accel_mult=2.5
| server=rdp
| disk=cdrom; usb
| graphic=af
| onerror=30
| sleep=10,poweroff
| sound=on
| vnc=on
| vnc_password=off
[        initrd] [   13.572739] Hostname: "wt-168-1-186".
[        initrd] [   13.860309] Run '/usr/sbin/ntpdate -bs 192.168.0.1', log '', env '', pid ''.
[          pfac] [   13.860435] Run /usr/sbin/ntpdate -bs 192.168.0.1.
[          pfac] [   13.862249] Ok, PID 635.
[         httpd] [   13.868434] Reread settings.
[         httpd] [   13.868670] Everyone can control terminal by HTTP.
[            gm] [   13.874596] WTware session manager 5.6.24/RPi.
[            gm] [   13.874744] Add keyboard event1: CHICONY USB NetVista Full Width Keyboard.
[            gm] [   13.940243] EV_REL flag found. Add mouse event0: PixArt HP USB Optical Mouse.
[            gm] [   13.940590] Display mode: 1920x1080, 32 bit, landscape, 0 Hz, modeline "", DDC enabled, connector 0.
[            gm] [   13.974219] Framebuffer device found.
[            gm] [   13.974804] LINELENBYTES 7680
[            gm] [   13.974949] VLEN 8294400
[            gm] [   14.009942] Use /lib/ui32.so.
[            gm] [   14.069162] [WARNING] 'disk = cdrom' does not work on Raspberry.
[            gm] [   14.069375] [WARNING] 'disk = cdrom' does not work on Raspberry.
[            gm] [   14.069507] [TFTP] Download and unpack file 5.6.24/pi2/localboot/packages/pi2-alsa from 192.168.3.111.
[            gm] [   14.747900] modprobe snd-bcm2835.
[            gm] [   14.780504] modprobe snd-usb-audio.
[        KERNEL] [   14.817123] usbcore: registered new interface driver snd-usb-audio
|   0: [ 0]   : control
|  33:        : timer
[            gm] [   14.816674] /dev/snd/pcmC0D1p character device.
[            gm] [   14.816889] /dev/snd/pcmC0D0p character device.
[            gm] [   14.817080] /dev/snd/controlC0 character device.
[          pfac] [   14.817289] Run /sbin/rdpsnd sndvol 100 100 50.
[            gm] [   14.817406] /dev/snd/timer character device.
[            gm] [   14.817578] Preconfigure ALSA.
[          pfac] [   14.817767] Ok, PID 663.
[            gm] [   14.817874] Run '/sbin/rdpsnd sndvol 100 100 50', log '', env '', pid ''.
[          pfac] [   14.818090] Run /sbin/rdpsnd 1 0 100 0 -1.
[            gm] [   14.818217] Run sound daemon.
[          pfac] [   14.818421] Ok, PID 664.
[            gm] [   14.818531] Run '/sbin/rdpsnd 1 0 100 0 -1', log '', env '', pid ''.
[            gm] [   14.818750] Load usb storage driver.
[            gm] [   14.818968] modprobe scsi_mod.
[        rdpsnd] [   14.828541] RDP Sound Redirector, WTware 5.6.24/RPi.
[            gm] [   14.843762] modprobe usb-storage.
[        KERNEL] [   14.845582] SCSI subsystem initialized
[        rdpsnd] [   14.844870] Card 'ALSA'/'bcm2835 ALSA'.
[        rdpsnd] [   14.845084] Mixer name: 'Broadcom Mixer'.
[        rdpsnd] [   14.845284] Components: ''.
[        rdpsnd] [   14.845444] Controls: 6.
[        rdpsnd] [   14.845613] ALSA: control 'PCM Playback Volume'.
[        rdpsnd] [   14.845783] ALSA: control 'PCM Playback Switch'.
[        rdpsnd] [   14.845947] ALSA: control 'PCM Playback Route'.
[        rdpsnd] [   14.846131] ALSA: control 'IEC958 Playback Default'.
[        rdpsnd] [   14.846313] ALSA: control 'IEC958 Playback Con Mask'.
[        rdpsnd] [   14.846516] ALSA: control 'IEC958 Playback PCM Stream'.
[        rdpsnd] [   14.846706] Inactive control IEC958 Playback PCM Stream'.
[        sndvol] [   14.849170] Card 'ALSA'/'bcm2835 ALSA'.
[        sndvol] [   14.849437] Mixer name: 'Broadcom Mixer'.
[        sndvol] [   14.849659] Components: ''.
[        sndvol] [   14.849859] Controls: 6.
[        sndvol] [   14.850256] ALSA: control 'PCM Playback Volume'.
[        sndvol] [   14.850466] ALSA: control 'PCM Playback Switch'.
[        sndvol] [   14.850649] ALSA: control 'PCM Playback Route'.
[        sndvol] [   14.850835] ALSA: control 'IEC958 Playback Default'.
[        sndvol] [   14.850983] ALSA: control 'IEC958 Playback Con Mask'.
[        sndvol] [   14.851179] ALSA: control 'IEC958 Playback PCM Stream'.
[        sndvol] [   14.851368] Inactive control IEC958 Playback PCM Stream'.
[          pfac] [   14.853511] Process pid 663 terminated, status 00000000.
[            gm] [   14.868171] modprobe sd_mod.
[        KERNEL] [   14.870268] usbcore: registered new interface driver usb-storage
[            gm] [   14.882935] Load EXFAT filesystem driver.
[            gm] [   14.883183] modprobe fuse.
[        KERNEL] [   14.901921] fuse init (API version 7.26)
[            gm] [   14.901134] modprobe exfat.
[        KERNEL] [   14.918586] exFAT: Version 1.2.9
[            gm] [   14.969357] Run '/sbin/resolver 0x1c59d70 dns [rdp]', log '', env '', pid ''.
[          pfac] [   14.969671] Run /sbin/resolver 0x1c59d70 dns [rdp].
[            gm] [   14.969778] Everyone can control terminal by VNC.
[            gm] [   14.969945] [VNC] Listener at port 5900.
[          pfac] [   14.970311] Ok, PID 690.
[          pfac] [   14.987095] Process pid 690 terminated, status 00000000.
[            gm] [   14.987276] rdp => 192.168.3.111.
[            gm] [   14.999603] Free ram before fork terminal client /sbin/rdpclient (session 1): 920068 Kb.
[          pfac] [   14.999898] Run /sbin/rdpclient 1.
[            gm] [   15.000145] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
[          pfac] [   15.000394] Ok, PID 691.
[ rdpclient 691] [   15.011836] RDP Terminal Client, WTware 5.6.24/RPi, pipe 1, pid 691.
[ rdpclient 691] [   15.012762] Use /lib/ui32.so.
[ rdpclient 691] [   15.014916] Redirect sound.
[ rdpclient 691] [   15.015552] Make RDP session with 192.168.3.111, port 3389.
[ rdpclient 691] [   15.015894]  No username.
[ rdpclient 691] [   15.016249]  No password.
[ rdpclient 691] [   15.016532]  No PIN.
[ rdpclient 691] [   15.016790]  No domain.
[ rdpclient 691] [   15.017007]  No shell.
[ rdpclient 691] [   15.017244]  No directory.
[ rdpclient 691] [   15.017577]  Window: 1920x1080@24.
[ rdpclient 691] [   15.017899]  PFlags 0x000000AE.
[ rdpclient 691] [   15.018192]  Keyboard 00000409:00000000.
[ rdpclient 691] [   15.018457]  My hostname "wt-168-1-186".
[ rdpclient 691] [   15.018778] TCP: connecting to 192.168.3.111:3389.
[ rdpclient 691] [   15.019056] TCP: connection with 192.168.3.111:3389 established.
[ rdpclient 691] [   15.019319] Turn keepalive on.
[ rdpclient 691] [   15.020214] Free ram after buffers allocation: 919276 KB.
[ rdpclient 691] [   15.025187] Reconnect with TLS/SSL enabled.
[ rdpclient 691] [   15.025678] TCP: reconnecting to 192.168.3.111:3389.
[ rdpclient 691] [   15.026698] TCP: connection with 192.168.3.111:3389 established.
[ rdpclient 691] [   15.027095] Turn keepalive on.
[ rdpclient 691] [   15.030674] Server supports GFX Pipeline.
[ rdpclient 691] [   15.031088] TLS.
[ rdpclient 691] [   15.031260] SSL/TLS.
[ rdpclient 691] [   15.079503] Enable font smoothing and Desktop Composition.
[ rdpclient 691] [   15.081262] RDP4 encryption.
[ rdpclient 691] [   15.229110] GFX codec.
[ rdpclient 691] [   15.692472] Run 4 tile threads.
[        KERNEL] [   16.839438] random: crng init done
[SYSLOG] <29>Feb 21 17:20:58 ntpdate[635]: step time server 192.168.0.1 offset -27844757.261463 sec
[          pfac] [   19.977199] Process pid 635 terminated, status 00000000.
look at this rows:
[        initrd] [   13.231323] [DHCP] WTPassword hash 3f9f2ea8e36aaeecfe82b1ba0e353683.
naves
Something strange on SD. Reformat and reinstall wtware.
naves
Post by naves »
Thanks for answer.
I found the cause of the problem
I took the distribution ZIP (no Windows-utilities)
and copied files from the directory zip\wtware on the SD card
wtware\cmdline.txt file contains only the string
quiet
without a parameter
wtboot=mmc
With the new cmdline.txt file from setup distr everything works
