(RPI3) DISABLE BULT-IN WIFI & USE USB WIFI ADAPTER
Discussions, remarks
estefano.peroza
Post by estefano.peroza » Wed Dec 14, 2016 10:24 pm
Hello there!
My Built-in WIFI in Raspberry PI 3 has really low range (signal starts to decay after 10 meters of distance from the router)
I would like to disable my built-in wifi and install a USB Wifi adapter instead. I've read that Wtware supports most of the newest Realtek Chipset models and i just bought one.
How should i proceed ?
Thank you !!
Re: (RPI3) DISABLE BULT-IN WIFI & USE USB WIFI ADAPTER
Post by aka » Thu Dec 15, 2016 2:00 pm
Connect USB WiFi adapter and run. If wtware has driver for it, it will use usb device instead of built-in.
If it still uses built-in, connect to wifi (usb one should be connected!) and send us a log: http://wtware.com/docs5/logs.html
