Ability to prevent SIP registration
Posted: Mon Nov 29, 2021 8:27 pm
I have a feature request that I would like to have considered. We have a situation where all of our WTWare clients use the same SIP credentials to register to a SIP proxy. These clients do not receive any phone calls, they only make a single phone call to connect to a call center system.
By default WTWare sends a register command to linphonec when starting up. When all of my WTWare SIP clients have registered the registration response packets from the SIP proxy get rather large due to all SIP client registering using the same credentials, which causes the packets to go outside of the normal MTU boundaries causing UDP fragmentation due to the large number of contacts. There is nothing I can do on the SIP proxy to prevent this behavior, but unregistering the linphonec client allows outbound calls to be made from WTWare.
My request is to add a checkbox to prevent automatic SIP registration on startup of linphonec. This effect of this is that instead of sending a register command as is currently done:
Proxy information would be either added onto the end of the custom linphone configuration (reference: https://alter.org.ua/en/docs/linux/linphonec/ ):
or the proxy information would be added using the 'proxy add' command: https://webhamster.ru/mytetrashare/inde ... 5od5m9ax7x
Please let me know if you need additional information. Thank you!
[ gm] [ 49.778932] [SIP] Command: 'register sip:0000@dialpad.example.com dialpad.example.com **password**'.
[ SIP] [ 49.778993] linphonec> Receiving command 'register sip:0000@dialpad.example.com dialpad.example.com *'
[proxy_0]
reg_proxy=sip:dialpad.example.com
reg_identity=sip:0000@dialpad.example.com
reg_sendregister=0
publish=0
dial_escape_plus=0
[auth_info_0]
username=0000
passwd=**password**
realm="dialpad.example.com"
