Template for writing SD Card
Posted: Mon Jul 27, 2020 10:57 am
by WtWareJunky
Since Network Boot is not too reliable, it would be great to have the possibility to save the parameters that are defined while running through the write on SD-Card Dialog. It would be much quicker if you could choose this saved setting on the first page of the dialog and than just click write on SD-Card.
Re: Template for writing SD Card
Posted: Wed Jul 29, 2020 1:35 pm
Just mark: on Raspberry is not too reliable. On x86, in safe network, it's reliable.
...if you could choose this saved setting on the first page of the dialog and than just click write on SD-Card.
"settings" is in configs/initrd.wtc on SD. There is no boot magic on Raspberry boot SD. It's just SD with files. You may copy all files and folders from Raspberry boot SD to new formatted SD in Windows Explorer.
