About WTware login screen using Japanese keyboard layout.
Guest
Post by Guest »
I'd like to use the Japanese keyboard layout in WTware login screen.
Currently, it seems the 'language' parameter can NOT support JA.
If so, please add/support it?
Re: About WTware login screen using Japanese keyboard layout.
Find your keyboard layout here: http://ascii-table.com/keyboards.php
And here: http://kbdlayout.info/
Is Japanese keyboard works like Latin keyboard (one key pressed - one char printed) or more complicated method needed?
