Cisco VPN
mvittek
Cisco VPN
Post by mvittek »
it is great that you support OpenVPN. For our business use i want to ask you, if there is possibility to implement Cisco VPN? Can we be helpful with that in any way?
Thanks, Michal
Re: Cisco VPN
Google tells "The Cisco VPN Client is now obsolete":
https://www.cisco.com/c/en/us/obsolete/ ... lient.html
Am I asking google for wrong question? Does cisco vpn opensource client for Linux exist?
mvittek
Re: Cisco VPN
Post by mvittek »
Hello, sorry, its cisco anyconnect client, here is sample installation. https://faq.oit.gatech.edu/content/how- ... ient-linux
If you need to have developer acces to some cisco vpn, maybe wa can comunicate through email.
Re: Cisco VPN
It's graphic user interface configuration. We have no GUI in WTware. Can it work command line tools and text configs?
mvittek
Re: Cisco VPN
Post by mvittek »
I found out, that it should be possible, if program is installed in linux distro.
http://www.socsci.uci.edu/~jstern/uci_vpn_ubuntu/
Re: Cisco VPN
This manual should also work, is it? It uses opensource tool:
http://www.socsci.uci.edu/~jstern/uci_v ... tions.html
And yes, we need to have developer access to some cisco vpn. Please, mail me to support@wtware.com
