Shadow session
villapanama
Shadow session
Post by villapanama » Wed Jul 03, 2019 9:40 pm
Is there a way to start a connection using the "shadow" function?
Here is what I am trying to do. Computer A runs some data acquisition 24/7.
Computer B is usually windows remote to Computer A.
I made a little raspberry touch table so I can remote into Computer A and see the data.
I would like to connect to computer A without disconnecting Computer B.
From doing some reading it looks like the windows shadow option would allow the 2 connections into the 1 terminal.
is there a way to incorporate this to wtware? or a similar feature?
jzholzer
Re: Shadow session
Post by jzholzer » Fri Jul 12, 2019 6:24 pm
VNC is your friend.
Re: Shadow session
Post by aka » Sun Jul 14, 2019 12:35 pm
WTware VNC server only allows one connection.
Shadowing is in every windows server. In early windows servers, it runs from task manager. Now it's harder to run, but it still exists and works for free. Google for remote control of rdp session in your version of windows.
