5.4.90 - remote update using browser
Now WTware 5.4.90, installed on local media (SD and eMMC for Raspberry, USB, IDE, SATA, DiskOnChip and all other local rewritable media) may be updated remotely. You'll be able to try it from the next version, .92.
Update images should be prepared on Windows-computer in graphic configurator.
Update will be loaded to thin client using browser. In web-interface now there's new item Update WTware. Password must be specified in terminal text menu Setup or in DHCP 018 option, update won't work without password.
radicspeter
Re: 5.4.90 - remote update using browser
Post by radicspeter »
akatik wrote:Now WTware 5.4.90, installed on local media (SD and eMMC for Raspberry, USB, IDE, SATA, DiskOnChip and all other local rewritable media) may be updated remotely. You'll be able to try it from the next version, .92.
Amazing good work aka! :D
