Can't use smartcard reader with wtware in Raspberry Pi 3B
Posted: Wed Nov 23, 2022 7:03 pm
by andrenoites
Hi all
I can´t use my cardreader (PC USB-TR) with WTware 6.0.86/RPi running in a Pi 3B connected to Windows server 2019.
But the came cardreader works if I use WTware 6.0.86 in a AMD desktop computer connected to the same server.
It seem to be related to the raspberry drivers.
Help
Re: Can't use smartcard reader with wtware in Raspberry Pi 3B
Posted: Wed Nov 23, 2022 8:41 pm
https://wtware.com/logs.html
Show me please both logs. From AMD desktop computer and from Raspberry.
support@wtware.com
Posted: Thu Nov 24, 2022 6:28 pm
by andrenoites
Thanks for the fast response.
Both logs as your request:
https://www.filemail.com/d/mcrneudomqjeqdi
Posted: Thu Nov 24, 2022 9:04 pm
607119 seconds uptime. Seven days. Please, reboot it.
And show me FULL log. From boot to error. Not several last lines.
PS: do you use the same card in both cases?
Posted: Fri Nov 25, 2022 2:52 pm
by andrenoites
Sorry
Here they are, full logs:
https://www.filemail.com/d/svzivzlucglsiul
In both cases we are using the same card and same reader
Posted: Wed Nov 30, 2022 10:46 am
I don't see trivial problem. Both logs look good. We need to go deeper. I'm not sure we'll find something useful there.
Write to config:
smartcard=auto, debug, debug_pcscd
And show me the same log from Raspberry. Log can be large. Please save the log immediately after first wrong behavior.
Btw, did you try this reader with Raspberry OS? If it won't work with Raspberry OS, it's better to google solution for Raspberry first.
Posted: Wed Dec 28, 2022 6:16 pm
by andrenoites
Here it is, the log from the raspberry:
https://www.filemail.com/d/svgxmaiggcuuact
Posted: Fri Dec 30, 2022 10:28 am
It seems to be related to the raspberry drivers. Raspberry USB controller drivers, or Raspberry USB hardware. Sorry, I see no solution at our level
Posted: Wed Jan 04, 2023 2:55 pm
by andrenoites
Ok thanks for the reply.
Can you tell me some other card reader models that is known to work with this setup?
Posted: Thu Jan 05, 2023 4:46 pm
I can not
I have two acr39u. They look the same and have the same stickers on them. One of them works with Raspberry, second does not.
