Page 1 of 2
NFC + SmartCard - only one working on the same time?
Posted: Mon Jan 21, 2019 5:03 pm
by Eskulap
[0] USB ID: 413c:2101, bus ID: 8-1, class: 0x00, subclass: 0x00, Dell Computer Corp. SmartCard Reader Keyboard
[1] USB ID: 072f:2200, bus ID: 6-2, class: 0x00, subclass: 0x00, Advanced Card Systems, Ltd ACR122U
[2] USB ID: 046d:c050, bus ID: 8-2, class: 0x00, subclass: 0x00, Logitech, Inc. RX 250 Optical Mouse
Hello every1.
I have random working USB devices on system start.
Sometimes is SmartCard Reader build-in Dell Keyboard
Sometimes is NFC Card Reader.
And the problem is... NEVER BOTH TOGETHER.
Is there any special trick to make it works?
I'm using SmartCard to authenticate users into domain, and after that NFC to log in to Medical software.
[0] [1] [2] - no matter if I switch devices between USB ports.
It stays random all the time.
Re: NFC + SmartCard - only one working on the same time?
Posted: Mon Jan 21, 2019 7:46 pm
https://wtware.com/logs.html
Make me two logs. First when SmartCard Reader works and second when NFC Card Reader works.
Does keyboard work when SmartCard Reader doesn't work?
Posted: Mon Jan 21, 2019 8:38 pm
by Eskulap
Will do tomorrow @ work.
Positive. I can use mouse and Keybord each time with no problem.
Thanks for response
Posted: Tue Jan 22, 2019 10:34 am
by Eskulap
Got em. nice, fresh and juicy... ;)
Posted: Wed Jan 23, 2019 1:52 pm
It's WTware problem. We can not handle two smartcard devices at once. Sorry :(
Posted: Fri Mar 08, 2019 3:14 pm
by Eskulap
Outch.
And what about CD-ROM?
Some ppl with X-RAY CD? Is it possible to read it on terminal?
Posted: Sat Mar 09, 2019 7:28 am
What is X-RAY CD?
Usual CD-ROM should work. Add to wtware config:
disk = cdrom
Posted: Tue Jan 14, 2020 1:03 pm
by Eskulap
@akatik
I see new version of Wtware from December 2019.
Is there any changes that makes two USB card readers works at once?
Like hardware usb key - token - like self sign use to autentication doctors for prescription drug in online global system.
Or NFC reader for physoterapists like I asked year ago?
Posted: Tue Jan 14, 2020 5:25 pm
No :(
Try this one with usb token: viewtopic.php?f=27&t=49012 This will not work for terminal server, but it may work for VDI scenario, while connecting to console session.
Posted: Wed Feb 26, 2020 3:57 pm
by Eskulap
Thanks.
Another question. Is WTware support Cryptotech Graphite Cards?
I can login to AD using machine with Windows installed on it
But can't login via WTware Client. The same card reader etc.
Just different boot method - Windows and WTware.
After typing PIN as WTware asks Im reciving "no valid certificate" message just like on this picture:
https://d8kaami2d2b7v.cloudfront.net/mo ... 053803.png
I have no idea why...
Posted: Wed Feb 26, 2020 6:23 pm
Posted: Fri Feb 28, 2020 10:56 am
by Eskulap
Thankies.
Log in attachment.
Posted: Fri Feb 28, 2020 11:37 am
Does this reader with this wtware version work with some other cards?
Give me please two more logs. Tool from point 3 in instruction https://wtware.com/docs5/smartcard.html
3. In mstsc.exe terminal session connect to terminal USB-token or reader with inserted card, start this application: http://wtware.com/files/smartcard.zip
First log from mstsc.exe with this card in this reader.
Second log with wtware with this card in this reader. Log in with password.
Posted: Mon Mar 02, 2020 4:06 pm
by Eskulap
Hope I did it right.
Please check is that what You need.
Cheers! :)
Posted: Mon Mar 02, 2020 4:36 pm
by Eskulap
To log in with Graphite Card on Windows, I must install additional driver provided by manufacture.
64bit Driver in Attachment.
And I think this is main problem: WtWAre client don't have Graphic Card driver.
https://drive.google.com/file/d/1Ke0nSK ... sp=sharing
