NFC + SmartCard - only one working on the same time?
Eskulap
Post by Eskulap » Mon Jan 21, 2019 5:03 pm
[0] USB ID: 413c:2101, bus ID: 8-1, class: 0x00, subclass: 0x00, Dell Computer Corp. SmartCard Reader Keyboard
[1] USB ID: 072f:2200, bus ID: 6-2, class: 0x00, subclass: 0x00, Advanced Card Systems, Ltd ACR122U
[2] USB ID: 046d:c050, bus ID: 8-2, class: 0x00, subclass: 0x00, Logitech, Inc. RX 250 Optical Mouse
Hello every1.
I have random working USB devices on system start.
Sometimes is SmartCard Reader build-in Dell Keyboard
Sometimes is NFC Card Reader.
And the problem is... NEVER BOTH TOGETHER.
Is there any special trick to make it works?
I'm using SmartCard to authenticate users into domain, and after that NFC to log in to Medical software.
[0] [1] [2] - no matter if I switch devices between USB ports.
It stays random all the time.
Re: NFC + SmartCard - only one working on the same time?
Post by akatik » Mon Jan 21, 2019 7:46 pm
https://wtware.com/logs.html
Make me two logs. First when SmartCard Reader works and second when NFC Card Reader works.
Does keyboard work when SmartCard Reader doesn't work?
Eskulap
Post by Eskulap » Mon Jan 21, 2019 8:38 pm
Will do tomorrow @ work.
Positive. I can use mouse and Keybord each time with no problem.
Thanks for response
Eskulap
Post by Eskulap » Tue Jan 22, 2019 10:34 am
Got em. nice, fresh and juicy... ;)
NFC_ON_WTware_00.23.AE.7C.51.DD_2019-01-22_08-29-25.txt
(232.96 KiB) Downloaded 63 times
SMART_ON_WTware_00.23.AE.7C.51.DD_2019-01-22_08-22-33.txt
(232.2 KiB) Downloaded 67 times
Post by akatik » Wed Jan 23, 2019 1:52 pm
It's WTware problem. We can not handle two smartcard devices at once. Sorry :(
Eskulap
Post by Eskulap » Fri Mar 08, 2019 3:14 pm
Outch.
And what about CD-ROM?
Some ppl with X-RAY CD? Is it possible to read it on terminal?
Post by akatik » Sat Mar 09, 2019 7:28 am
What is X-RAY CD?
Usual CD-ROM should work. Add to wtware config:
disk = cdrom
Eskulap
Post by Eskulap » Tue Jan 14, 2020 1:03 pm
@akatik
I see new version of Wtware from December 2019.
Is there any changes that makes two USB card readers works at once?
Like hardware usb key - token - like self sign use to autentication doctors for prescription drug in online global system.
Or NFC reader for physoterapists like I asked year ago?
Post by akatik » Tue Jan 14, 2020 5:25 pm
No :(
Try this one with usb token: viewtopic.php?f=27&t=49012 This will not work for terminal server, but it may work for VDI scenario, while connecting to console session.
