I am using a RPI keyboard without separate number-keys. But there is a NumLock Key to activate the number keys instead of letters in the right area.
https://www.raspberrypi.org/products/ra ... d-and-hub/
I do not want to use that number-keys. Instead I have connected a bluetooth number pad. It is working, but as soon as I press a number key on it, the NumLock on the RPI keyboard is activated.
Do you have any idea how I could prevent this?
Thank you
Bluetooth Number Pad always activates Num-Lock
Re: Bluetooth Number Pad always activates Num-Lock
1. Install the latest wtware version.
2. Write to wtware config:
3. Reboot.
4. Press a number key on bluetooth number pad.
5. Press a number/letters key in the right area of keyboard.
6. Save log: https://wtware.com/logs.html
connection
connection
numlock off
keyboard_log on
sorry for the looong delay. Log attached
15-22-59-953| WTware 6.0.32/RPi supervisor.
15-22-59-953| [ KERNEL] [ 0.000000] Booting Linux on physical CPU 0x0
15-22-59-953| [ KERNEL] [ 0.000000] Linux version 5.4.83-v7l (aka@c22) (gcc version 8.3.0 (Debian 8.3.0-2)) #14 SMP Thu Jan 21 10:11:43 UTC 2021
15-22-59-953| [ KERNEL] [ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
15-22-59-953| [ KERNEL] [ 0.000000] CPU: div instructions available: patching division code
15-22-59-953| [ KERNEL] [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
15-22-59-953| [ KERNEL] [ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
15-22-59-953| [ KERNEL] [ 0.000000] Memory policy: Data cache writealloc
15-22-59-953| [ KERNEL] [ 0.000000] Reserved memory: created CMA memory pool at 0x000000002ac00000, size 64 MiB
15-22-59-953| [ KERNEL] [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
15-22-59-953| [ KERNEL] [ 0.000000] On node 0 totalpages: 504832
15-22-59-953| [ KERNEL] [ 0.000000] DMA zone: 1920 pages used for memmap
15-22-59-953| [ KERNEL] [ 0.000000] DMA zone: 0 pages reserved
15-22-59-953| [ KERNEL] [ 0.000000] DMA zone: 196608 pages, LIFO batch:63
15-22-59-953| [ KERNEL] [ 0.000000] HighMem zone: 308224 pages, LIFO batch:63
15-22-59-953| [ KERNEL] [ 0.000000] percpu: Embedded 15 pages/cpu s29324 r8192 d23924 u61440
15-22-59-953| [ KERNEL] [ 0.000000] pcpu-alloc: s29324 r8192 d23924 u61440 alloc=15*4096
15-22-59-953| [ KERNEL] [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
15-22-59-953| [ KERNEL] [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 502912
15-22-59-953| [ KERNEL] [ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbdepth=32 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:26:EA:07 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 usbhid.mousepoll=0 quiet wtboot=mmc
15-22-59-953| [ KERNEL] [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
15-22-59-953| [ KERNEL] [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
15-22-59-953| [ KERNEL] [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
15-22-59-953| [ KERNEL] [ 0.000000] software IO TLB: mapped [mem 0x25800000-0x29800000] (64MB)
15-22-59-953| [ KERNEL] [ 0.000000] Memory: 1856012K/2019328K available (6144K kernel code, 161K rwdata, 812K rodata, 2048K init, 375K bss, 97780K reserved, 65536K cma-reserved, 1232896K highmem)
15-22-59-953| [ KERNEL] [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
15-22-59-953| [ KERNEL] [ 0.000000] rcu: Hierarchical RCU implementation.
15-22-59-953| [ KERNEL] [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
15-22-59-953| [ KERNEL] [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
15-22-59-953| [ KERNEL] [ 0.000000] GIC: Using split EOI/Deactivate mode
15-22-59-953| [ KERNEL] [ 0.000000] random: get_random_bytes called from 0xc0a00b60 with crng_init=0
15-22-59-953| [ KERNEL] [ 0.000007] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
15-22-59-953| [ KERNEL] [ 0.000021] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
15-22-59-953| [ KERNEL] [ 0.000088] bcm2835: system timer (irq = 17)
15-22-59-953| [ KERNEL] [ 0.000624] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
15-22-59-953| [ KERNEL] [ 0.000638] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
15-22-59-953| [ KERNEL] [ 0.000653] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
15-22-59-953| [ KERNEL] [ 0.000664] Switching to timer-based delay loop, resolution 18ns
15-22-59-953| [ KERNEL] [ 0.000824] Console: colour dummy device 80x30
15-22-59-953| [ KERNEL] [ 0.000842] printk: console [tty0] enabled
15-22-59-953| [ KERNEL] [ 0.000876] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
15-22-59-953| [ KERNEL] [ 0.000888] pid_max: default: 32768 minimum: 301
15-22-59-953| [ KERNEL] [ 0.001017] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
15-22-59-953| [ KERNEL] [ 0.001033] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
15-22-59-953| [ KERNEL] [ 0.001569] CPU: Testing write buffer coherency: ok
15-22-59-953| [ KERNEL] [ 0.001830] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
15-22-59-953| [ KERNEL] [ 0.002209] Setting up static identity map for 0x200000 - 0x20003c
15-22-59-953| [ KERNEL] [ 0.002286] rcu: Hierarchical SRCU implementation.
15-22-59-953| [ KERNEL] [ 0.002546] smp: Bringing up secondary CPUs ...
15-22-59-953| [ KERNEL] [ 0.003124] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
15-22-59-953| [ KERNEL] [ 0.003771] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
15-22-59-953| [ KERNEL] [ 0.004398] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
15-22-59-953| [ KERNEL] [ 0.004472] smp: Brought up 1 node, 4 CPUs
15-22-59-953| [ KERNEL] [ 0.004481] SMP: Total of 4 processors activated (432.00 BogoMIPS).
15-22-59-953| [ KERNEL] [ 0.004488] CPU: All CPU(s) started in HYP mode.
15-22-59-953| [ KERNEL] [ 0.004493] CPU: Virtualization extensions available.
15-22-59-953| [ KERNEL] [ 0.004883] devtmpfs: initialized
15-22-59-953| [ KERNEL] [ 0.013730] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
15-22-59-953| [ KERNEL] [ 0.014011] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
15-22-59-953| [ KERNEL] [ 0.014028] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
15-22-59-953| [ KERNEL] [ 0.015411] pinctrl core: initialized pinctrl subsystem
15-22-59-953| [ KERNEL] [ 0.016311] NET: Registered protocol family 16
15-22-59-953| [ KERNEL] [ 0.018287] DMA: preallocated 1024 KiB pool for atomic coherent allocations
15-22-59-953| [ KERNEL] [ 0.020213] Serial: AMBA PL011 UART driver
15-22-59-953| [ KERNEL] [ 0.022092] bcm2835-mbox fe00b880.mailbox: mailbox enabled
15-22-59-953| [ KERNEL] [ 0.040677] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-08-19 17:38, variant start
15-22-59-953| [ KERNEL] [ 0.050673] raspberrypi-firmware soc:firmware: Firmware hash is e90cba19a98a0d1f2ef086b9cafcbca00778f094
15-22-59-953| [ KERNEL] [ 0.096236] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
15-22-59-953| [ KERNEL] [ 0.099214] vgaarb: loaded
15-22-59-953| [ KERNEL] [ 0.099703] usbcore: registered new interface driver usbfs
15-22-59-953| [ KERNEL] [ 0.099788] usbcore: registered new interface driver hub
15-22-59-953| [ KERNEL] [ 0.099859] usbcore: registered new device driver usb
15-22-59-953| [ KERNEL] [ 0.101436] clocksource: Switched to clocksource arch_sys_counter
15-22-59-953| [ KERNEL] [ 0.111990] thermal_sys: Registered thermal governor 'step_wise'
15-22-59-953| [ KERNEL] [ 0.112365] NET: Registered protocol family 2
15-22-59-953| [ KERNEL] [ 0.112782] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
15-22-59-953| [ KERNEL] [ 0.112806] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
15-22-59-953| [ KERNEL] [ 0.112854] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
15-22-59-953| [ KERNEL] [ 0.112915] TCP: Hash tables configured (established 8192 bind 8192)
15-22-59-953| [ KERNEL] [ 0.113017] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
15-22-59-953| [ KERNEL] [ 0.113046] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
15-22-59-953| [ KERNEL] [ 0.113174] NET: Registered protocol family 1
15-22-59-953| [ KERNEL] [ 0.113201] PCI: CLS 0 bytes, default 64
15-22-59-953| [ KERNEL] [ 0.824601] Initialise system trusted keyrings
15-22-59-953| [ KERNEL] [ 0.824731] workingset: timestamp_bits=30 max_order=19 bucket_order=0
15-22-59-953| [ KERNEL] [ 0.867675] Key type asymmetric registered
15-22-59-953| [ KERNEL] [ 0.867683] Asymmetric key parser 'x509' registered
15-22-59-953| [ KERNEL] [ 0.867747] bounce: pool size: 64 pages
15-22-59-953| [ KERNEL] [ 0.867803] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
15-22-59-953| [ KERNEL] [ 0.870142] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
15-22-59-953| [ KERNEL] [ 0.870163] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
15-22-59-953| [ KERNEL] [ 0.870198] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x0603ffffff -> 0x00f8000000
15-22-59-953| [ KERNEL] [ 0.870229] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x007fffffff -> 0x0000000000
15-22-59-953| [ KERNEL] [ 0.923566] brcm-pcie fd500000.pcie: link up, 5 GT/s x1 (SSC)
15-22-59-953| [ KERNEL] [ 0.923791] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
15-22-59-953| [ KERNEL] [ 0.923805] pci_bus 0000:00: root bus resource [bus 00-ff]
15-22-59-953| [ KERNEL] [ 0.923819] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
15-22-59-953| [ KERNEL] [ 0.923855] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
15-22-59-953| [ KERNEL] [ 0.923960] pci 0000:00:00.0: PME# supported from D0 D3hot
15-22-59-953| [ KERNEL] [ 0.926709] PCI: bus0: Fast back to back transfers disabled
15-22-59-953| [ KERNEL] [ 0.926723] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
15-22-59-953| [ KERNEL] [ 0.926900] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
15-22-59-953| [ KERNEL] [ 0.927007] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
15-22-59-953| [ KERNEL] [ 0.927287] pci 0000:01:00.0: PME# supported from D0 D3cold
15-22-59-953| [ KERNEL] [ 0.930016] PCI: bus1: Fast back to back transfers disabled
15-22-59-953| [ KERNEL] [ 0.930031] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
15-22-59-953| [ KERNEL] [ 0.930061] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
15-22-59-953| [ KERNEL] [ 0.930076] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
15-22-59-953| [ KERNEL] [ 0.930136] pci 0000:00:00.0: PCI bridge to [bus 01]
15-22-59-953| [ KERNEL] [ 0.930148] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
15-22-59-953| [ KERNEL] [ 0.930312] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
15-22-59-953| [ KERNEL] [ 0.930461] pcieport 0000:00:00.0: PME: Signaling with IRQ 53
15-22-59-953| [ KERNEL] [ 0.930706] pcieport 0000:00:00.0: AER: enabled with IRQ 53
15-22-59-953| [ KERNEL] [ 0.930994] pci 0000:01:00.0: enabling device (0140 -> 0142)
15-22-59-953| [ KERNEL] [ 0.931556] bcm2708_fb soc:fb: FB found 1 display(s)
15-22-59-953| [ KERNEL] [ 0.973182] Console: switching to colour frame buffer device 240x67
15-22-59-953| [ KERNEL] [ 0.983620] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 1920x1080
15-22-59-953| [ KERNEL] [ 0.987257] iproc-rng200 fe104000.rng: hwrng registered
15-22-59-953| [ KERNEL] [ 0.987443] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
15-22-59-953| [ KERNEL] [ 0.987963] vc-sm: Videocore shared memory driver
15-22-59-953| [ KERNEL] [ 0.988405] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
15-22-59-953| [ KERNEL] [ 0.989210] zram: Added device: zram0
15-22-59-953| [ KERNEL] [ 0.990995] libphy: Fixed MDIO Bus: probed
15-22-59-953| [ KERNEL] [ 0.991348] xhci_hcd 0000:01:00.0: xHCI Host Controller
15-22-59-953| [ KERNEL] [ 0.991398] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
15-22-59-953| [ KERNEL] [ 0.996277] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000003000000890
15-22-59-953| [ KERNEL] [ 0.996847] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
15-22-59-953| [ KERNEL] [ 0.996871] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
15-22-59-953| [ KERNEL] [ 0.996884] usb usb1: Product: xHCI Host Controller
15-22-59-953| [ KERNEL] [ 0.996896] usb usb1: Manufacturer: Linux 5.4.83-v7l xhci-hcd
15-22-59-953| [ KERNEL] [ 0.996912] usb usb1: SerialNumber: 0000:01:00.0
15-22-59-953| [ KERNEL] [ 0.997431] hub 1-0:1.0: USB hub found
15-22-59-953| [ KERNEL] [ 0.997494] hub 1-0:1.0: 1 port detected
15-22-59-953| [ KERNEL] [ 0.997901] xhci_hcd 0000:01:00.0: xHCI Host Controller
15-22-59-953| [ KERNEL] [ 0.997923] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
15-22-59-953| [ KERNEL] [ 0.997950] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
15-22-59-953| [ KERNEL] [ 0.998214] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
15-22-59-953| [ KERNEL] [ 0.998225] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
15-22-59-953| [ KERNEL] [ 0.998234] usb usb2: Product: xHCI Host Controller
15-22-59-953| [ KERNEL] [ 0.998242] usb usb2: Manufacturer: Linux 5.4.83-v7l xhci-hcd
15-22-59-953| [ KERNEL] [ 0.998250] usb usb2: SerialNumber: 0000:01:00.0
15-22-59-953| [ KERNEL] [ 0.998726] hub 2-0:1.0: USB hub found
15-22-59-953| [ KERNEL] [ 0.998769] hub 2-0:1.0: 4 ports detected
15-22-59-953| [ KERNEL] [ 0.999792] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
15-22-59-953| [ KERNEL] [ 0.999896] dwc_otg: FIQ enabled
15-22-59-953| [ KERNEL] [ 0.999902] dwc_otg: NAK holdoff enabled
15-22-59-953| [ KERNEL] [ 0.999909] dwc_otg: FIQ split-transaction FSM enabled
15-22-59-953| [ KERNEL] [ 0.999917] Module dwc_common_port init
15-22-59-953| [ KERNEL] [ 1.005254] usbcore: registered new interface driver usbtouchscreen
15-22-59-953| [ KERNEL] [ 1.006846] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
15-22-59-953| [ KERNEL] [ 1.007893] sdhci: Secure Digital Host Controller Interface driver
15-22-59-953| [ KERNEL] [ 1.007900] sdhci: Copyright(c) Pierre Ossman
15-22-59-953| [ KERNEL] [ 1.008274] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
15-22-59-953| [ KERNEL] [ 1.008615] sdhci-pltfm: SDHCI platform and OF driver helper
15-22-59-953| [ KERNEL] [ 1.009395] hidraw: raw HID events driver (C) Jiri Kosina
15-22-59-953| [ KERNEL] [ 1.010171] usbcore: registered new interface driver usbhid
15-22-59-953| [ KERNEL] [ 1.010177] usbhid: USB HID core driver
15-22-59-953| [ KERNEL] [ 1.011938] vchiq: vchiq_init_state: slot_zero = (ptrval)
15-22-59-953| [ KERNEL] [ 1.019823] [vc_sm_connected_init]: start
15-22-59-953| [ KERNEL] [ 1.037455] [vc_sm_connected_init]: end - returning 0
15-22-59-953| [ KERNEL] [ 1.038046] NET: Registered protocol family 17
15-22-59-953| [ KERNEL] [ 1.038172] Registering SWP/SWPB emulation handler
15-22-59-953| [ KERNEL] [ 1.038252] Loading compiled-in X.509 certificates
15-22-59-953| [ KERNEL] [ 1.039084] uart-pl011 fe201000.serial: cts_event_workaround enabled
15-22-59-953| [ KERNEL] [ 1.039115] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 29, base_baud = 0) is a PL011 rev2
15-22-59-953| [ KERNEL] [ 1.042854] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
15-22-59-953| [ KERNEL] [ 1.043169] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
15-22-59-953| [ KERNEL] [ 1.043175] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
15-22-59-953| [ KERNEL] [ 1.090742] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
15-22-59-953| [ KERNEL] [ 1.092243] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
15-22-59-953| [ KERNEL] [ 1.093740] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
15-22-59-953| [ KERNEL] [ 1.096428] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
15-22-59-953| [ KERNEL] [ 1.097931] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
15-22-59-953| [ KERNEL] [ 1.104126] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
15-22-59-953| [ KERNEL] [ 1.104257] of_cfs_init
15-22-59-953| [ KERNEL] [ 1.104358] of_cfs_init: OK
15-22-59-953| [ KERNEL] [ 1.107021] Freeing unused kernel memory: 2048K
15-22-59-953| [ KERNEL] [ 1.133045] random: fast init done
15-22-59-953| [ KERNEL] [ 1.159297] mmc1: new high speed SDIO card at address 0001
15-22-59-953| [ KERNEL] [ 1.161843] Run /init as init process
15-22-59-953| [ KERNEL] [ 1.203051] mmc0: new ultra high speed DDR50 SDHC card at address 5048
15-22-59-953| [ KERNEL] [ 1.203446] mmcblk0: mmc0:5048 SD16G 14.4 GiB
15-22-59-953| [ KERNEL] [ 1.204406] mmcblk0: p1
15-22-59-953| [ KERNEL] [ 1.361482] usb 1-1: new high-speed USB device number 2 using xhci_hcd
15-22-59-953| [ pfac] [ 1.475641] Run /sbin/initrd.
15-22-59-953| [ pfac] [ 1.475841] Ok, PID 793.
15-22-59-953| [ initrd] [ 1.480086] WTware 6.0.32/RPi shell.
15-22-59-953| [ initrd] [ 1.480523] Load font 'ter-c32b.psf', console 120x33.
15-22-59-953| [ initrd] [ 1.494967] HDD/MMC/SD boot.
15-22-59-953| [ initrd] [ 1.495053] No device '/dev/fb1'.
15-22-59-953| [ KERNEL] [ 1.544133] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.20
15-22-59-953| [ KERNEL] [ 1.544146] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
15-22-59-953| [ KERNEL] [ 1.544156] usb 1-1: Product: USB2.0 Hub
15-22-59-953| [ KERNEL] [ 1.545774] hub 1-1:1.0: USB hub found
15-22-59-953| [ KERNEL] [ 1.546119] hub 1-1:1.0: 4 ports detected
15-22-59-953| [ initrd] [ 1.559565] Success: /dev/mmcblk0p1 mounted to /bootmedia.
15-22-59-953| /--- FILE "/bootmedia/config.txt" -----------------------
15-22-59-953| | # For more options and information see:
15-22-59-953| | #
15-22-59-953| | # https://www.raspberrypi.org/documentation/configuration/config-txt/README.md
15-22-59-953| | #
15-22-59-953| | # Some settings may impact device functionality. See link above for details.
15-22-59-953| | # Uncomment if you get no picture on HDMI for a default "safe" mode.
15-22-59-953| | #hdmi_safe=1
15-22-59-953| | # Uncomment this if your display has a black border of unused pixels visible
15-22-59-953| | # and your display can output without overscan.
15-22-59-953| | disable_overscan=1
15-22-59-953| | # Uncomment if hdmi display is not detected and composite is being output.
15-22-59-953| | #hdmi_force_hotplug=1
15-22-59-953| | # Uncomment to force a specific HDMI mode (this will force VGA).
15-22-59-953| | #hdmi_group=1
15-22-59-953| | #hdmi_mode=1
15-22-59-953| | # Force the monitor to HDMI mode so that sound will be sent over HDMI cable.
15-22-59-953| | #hdmi_drive=2
15-22-59-953| | # Uncomment to increase signal to HDMI, if you have interference, blanking, or
15-22-59-953| | # no display.
15-22-59-953| | #config_hdmi_boost=4
15-22-59-953| | # Uncomment to overclock the arm. 700 MHz is the default.
15-22-59-953| | #arm_freq=800
15-22-59-953| | disable_splash=1
15-22-59-953| | framebuffer_depth=32
15-22-59-953| | # Uncomment for 16-bit color.
15-22-59-953| | #framebuffer_depth=16
15-22-59-953| | # Enable onboard audio (HDMI or jack).
15-22-59-953| | dtparam=audio=on
15-22-59-953| | # Removes the warning overlay.
15-22-59-953| | #avoid_warnings=1
15-22-59-953| | # Additionally allows turbo when low-voltage is present.
15-22-59-953| | #avoid_warnings=2
15-22-59-953| | [pi4]
15-22-59-953| | max_framebuffers=2
15-22-59-953| | [all]
15-22-59-953| | # Uncomment these two lines to set display resolution:
15-22-59-953| | #hdmi_group=2
15-22-59-953| | #hdmi_mode=58
15-22-59-953| | #
15-22-59-953| | # Specify correct value in hdmi_mode= line from the list of valid values:
15-22-59-953| | # 800x600: hdmi_mode=9
15-22-59-953| | # 1024x768: hdmi_mode=16
15-22-59-953| | # 1280x1024: hdmi_mode=35
15-22-59-953| | # 1360x768: hdmi_mode=39
15-22-59-953| | # 1400x1050: hdmi_mode=42
15-22-59-953| | # 1440x900: hdmi_mode=47
15-22-59-953| | # 1600x1200: hdmi_mode=51
15-22-59-953| | # 1680x1050: hdmi_mode=58
15-22-59-953| | # 1366x768: hdmi_mode=81
15-22-59-953| | # 1920x1080: hdmi_mode=82
15-22-59-953| | # 1920x1200: hdmi_mode=69
15-22-59-953| | #
15-22-59-953| | # Find more resolutions in manual:
15-22-59-953| | # https://www.raspberrypi.org/documentation/configuration/config-txt/video.md
15-22-59-953| | #
15-22-59-953| | # Uncomment six lines with such syntax and right hdmi_mode= values for
15-22-59-953| | # dual displays on Raspberry Pi 4:
15-22-59-953| | #
15-22-59-953| | #[HDMI:0]
15-22-59-953| | # hdmi_group=2
15-22-59-953| | # hdmi_mode=42
15-22-59-953| | #[HDMI:1]
15-22-59-953| | # hdmi_mode=58
15-22-59-953| \----------------------------------------------------
15-22-59-953| [ KERNEL] [ 1.871471] usb 1-1.3: new high-speed USB device number 3 using xhci_hcd
15-22-59-953| [ KERNEL] [ 2.003085] usb 1-1.3: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=32.98
15-22-59-953| [ KERNEL] [ 2.003096] usb 1-1.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
15-22-59-953| [ KERNEL] [ 2.003106] usb 1-1.3: Product: USB2.0 Hub
15-22-59-953| [ KERNEL] [ 2.004799] hub 1-1.3:1.0: USB hub found
15-22-59-953| [ KERNEL] [ 2.005183] hub 1-1.3:1.0: 4 ports detected
15-22-59-953| [ KERNEL] [ 2.321472] usb 1-1.3.1: new low-speed USB device number 4 using xhci_hcd
15-22-59-953| [ KERNEL] [ 2.494727] usb 1-1.3.1: New USB device found, idVendor=04d9, idProduct=0006, bcdDevice= 1.10
15-22-59-953| [ KERNEL] [ 2.494740] usb 1-1.3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
15-22-59-953| [ KERNEL] [ 2.494750] usb 1-1.3.1: Product: RPI Wired Keyboard 5
15-22-59-953| [ KERNEL] [ 2.494759] usb 1-1.3.1: Manufacturer:
15-22-59-953| [ KERNEL] [ 2.520445] input: RPI Wired Keyboard 5 as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3.1/1-1.3.1:1.0/0003:04D9:0006.0001/input/input0
15-22-59-953| [ KERNEL] [ 2.582093] hid-generic 0003:04D9:0006.0001: input,hidraw0: USB HID v1.11 Keyboard [ RPI Wired Keyboard 5] on usb-0000:01:00.0-1.3.1/input0
15-22-59-953| [ KERNEL] [ 2.602178] input: RPI Wired Keyboard 5 as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3.1/1-1.3.1:1.1/0003:04D9:0006.0002/input/input1
15-22-59-953| [ KERNEL] [ 2.671753] hid-generic 0003:04D9:0006.0002: input,hidraw1: USB HID v1.11 Device [ RPI Wired Keyboard 5] on usb-0000:01:00.0-1.3.1/input1
15-22-59-953| [ KERNEL] [ 2.771465] usb 1-1.3.3: new low-speed USB device number 5 using xhci_hcd
15-22-59-953| [ KERNEL] [ 2.909040] usb 1-1.3.3: New USB device found, idVendor=093a, idProduct=2510, bcdDevice= 1.00
15-22-59-953| [ KERNEL] [ 2.909052] usb 1-1.3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
15-22-59-953| [ KERNEL] [ 2.909063] usb 1-1.3.3: Product: USB Optical Mouse
15-22-59-953| [ KERNEL] [ 2.909072] usb 1-1.3.3: Manufacturer: PixArt
15-22-59-953| [ KERNEL] [ 2.918326] input: PixArt USB Optical Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3.3/1-1.3.3:1.0/0003:093A:2510.0003/input/input2
15-22-59-953| [ KERNEL] [ 2.918611] hid-generic 0003:093A:2510.0003: input,hidraw2: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-0000:01:00.0-1.3.3/input0
15-22-59-953| /--- FILE "/bootmedia/configs/initrd.wtc" -----------------------
15-22-59-953| | [BOM]
15-22-59-953| | clientIP=*
15-22-59-953| | config=local
15-22-59-953| | setupPassword=6f9e847d96986e6a0a2882a660da08b3
15-22-59-953| | netmedia=ethernet
15-22-59-953| | routerIP=192.168.0.1
15-22-59-953| | nameserverIP=9.9.9.9
15-22-59-953| [ initrd] [ 3.012334] Do not cache package files.
15-22-59-953| [ initrd] [ 3.012436] WTpassword present: 6f9e847d96986e6a0a2882a660da08b3.
15-22-59-953| [ initrd] [ 3.012544] Unpack /bootmedia/packages/pi2-lib.
15-22-59-953| [ initrd] [ 3.602267] USB: 04d9:0006 Holtek Semiconductor, Inc. Wired Keyboard (78/79 key) [RPI Wired Keyboard 5].
15-22-59-953| [ initrd] [ 3.602326] USB: 05e3:0610 Genesys Logic, Inc. Hub.
15-22-59-953| [ initrd] [ 3.602359] USB: 2109:3431 VIA Labs, Inc. Hub.
15-22-59-953| [ initrd] [ 3.602391] USB: 093a:2510 Pixart Imaging, Inc. Optical Mouse.
15-22-59-953| [ initrd] [ 5.027627] Load Ethernet drivers.
15-22-59-953| [ initrd] [ 5.027725] modprobe genet.
15-22-59-953| [ KERNEL] [ 5.036904] bcmgenet fd580000.ethernet: failed to get enet clock
15-22-59-953| [ KERNEL] [ 5.036919] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
15-22-59-953| [ KERNEL] [ 5.036932] bcmgenet fd580000.ethernet: failed to get enet-wol clock
15-22-59-953| [ KERNEL] [ 5.036942] bcmgenet fd580000.ethernet: failed to get enet-eee clock
15-22-59-953| [ KERNEL] [ 5.036962] bcmgenet: Skipping UMAC reset
15-22-59-953| [ KERNEL] [ 5.051435] libphy: bcmgenet MII bus: probed
15-22-59-953| [ KERNEL] [ 5.151529] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
15-22-59-953| [ KERNEL] [ 5.153102] bcmgenet: Skipping UMAC reset
15-22-59-953| [ KERNEL] [ 5.155136] bcmgenet fd580000.ethernet: configuring instance for external RGMII
15-22-59-953| [ KERNEL] [ 5.155831] bcmgenet fd580000.ethernet eth0: Link is Down
15-22-59-953| [ KERNEL] [ 10.391545] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
15-22-59-953| [ initrd] [ 10.461950] WTpassword present: 6f9e847d96986e6a0a2882a660da08b3.
15-22-59-953| [ initrd] [ 11.781201] dhcp: 328 bytes from 192.168.0.2.
15-22-59-953| [ initrd] [ 11.781310] 00000000:000001340000000000110000C0A80002FFFFFFFF004300440134000002010600 ...4................C.D.4......
15-22-59-953| [ initrd] [ 11.781398] 00000020:67458B6B0000800000000000C0A800F10000000000000000DCA63226EA070000 gE.k......................2&....
15-22-59-953| [ initrd] [ 11.781482] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
15-22-59-953| [ initrd] [ 11.781565] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
15-22-59-953| [ initrd] [ 11.781648] 00000080:0000000000000000000000000000000000000000000000000000000000000000 ................................
15-22-59-953| [ initrd] [ 11.781730] 000000a0:0000000000000000000000000000000000000000000000000000000000000000 ................................
15-22-59-953| [ initrd] [ 11.781812] 000000c0:0000000000000000000000000000000000000000000000000000000000000000 ................................
15-22-59-953| [ initrd] [ 11.781894] 000000e0:0000000000000000000000000000000000000000000000000000000000000000 ................................
15-22-59-953| [ initrd] [ 11.781975] 00000100:0000000000000000638253633501023604C0A80002330400000E100104FFFFFF ........c.Sc5..6.....3.........
15-22-59-953| [ initrd] [ 11.782057] 00000120:000304C0A800010608C0A80005C0A800020F056C6F63616CFF00000000000000 ...................local........
15-22-59-953| [ initrd] [ 11.785543] dhcp: 328 bytes from 192.168.0.2.
15-22-59-953| [ initrd] [ 11.785628] 00000000:000001340000000000110000C0A80002FFFFFFFF004300440134000002010600 ...4................C.D.4......
15-22-59-953| [ initrd] [ 11.785712] 00000020:67458B6B0000800000000000C0A800F10000000000000000DCA63226EA070000 gE.k......................2&....
15-22-59-953| [ initrd] [ 11.785794] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
15-22-59-953| [ initrd] [ 11.785876] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
15-22-59-953| [ initrd] [ 11.785958] 00000080:0000000000000000000000000000000000000000000000000000000000000000 ................................
15-22-59-953| [ initrd] [ 11.786040] 000000a0:0000000000000000000000000000000000000000000000000000000000000000 ................................
15-22-59-953| [ initrd] [ 11.786121] 000000c0:0000000000000000000000000000000000000000000000000000000000000000 ................................
15-22-59-953| [ initrd] [ 11.786203] 000000e0:0000000000000000000000000000000000000000000000000000000000000000 ................................
15-22-59-953| [ initrd] [ 11.786285] 00000100:0000000000000000638253633501023604C0A80002330400000E100104FFFFFF ........c.Sc5..6.....3.........
15-22-59-953| [ initrd] [ 11.786367] 00000120:000304C0A800010608C0A80005C0A800020F056C6F63616CFF00000000000000 ...................local........
15-22-59-953| [ initrd] [ 11.786448] Discard second offer for 192.168.0.241.
15-22-59-953| [ initrd] [ 13.015545] dhcp: 328 bytes from 192.168.0.2.
15-22-59-953| [ initrd] [ 13.015646] 00000000:000001340000000000110000C0A80002FFFFFFFF004300440134000002010600 ...4................C.D.4......
15-22-59-953| [ initrd] [ 13.015731] 00000020:67458B6B0000800000000000C0A800F10000000000000000DCA63226EA070000 gE.k......................2&....
15-22-59-953| [ initrd] [ 13.015816] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
15-22-59-953| [ initrd] [ 13.015899] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
15-22-59-953| [ initrd] [ 13.015981] 00000080:0000000000000000000000000000000000000000000000000000000000000000 ................................
15-22-59-953| [ initrd] [ 13.016063] 000000a0:0000000000000000000000000000000000000000000000000000000000000000 ................................
15-22-59-953| [ initrd] [ 13.016144] 000000c0:0000000000000000000000000000000000000000000000000000000000000000 ................................
15-22-59-953| [ initrd] [ 13.016227] 000000e0:0000000000000000000000000000000000000000000000000000000000000000 ................................
15-22-59-953| [ initrd] [ 13.016308] 00000100:0000000000000000638253633501053604C0A80002330400000E100104FFFFFF ........c.Sc5..6.....3.........
15-22-59-953| [ initrd] [ 13.016390] 00000120:000304C0A800010608C0A80005C0A800020F056C6F63616CFF00000000000000 ...................local........
15-22-59-953| [ initrd] [ 13.050083] [DHCP] DHCP server address 192.168.0.2.
15-22-59-953| [ initrd] [ 13.050171] [DHCP] IP 192.168.0.241 mask 255.255.255.0.
15-22-59-953| [ initrd] [ 13.050252] [DHCP] Default gateway 192.168.0.1.
15-22-59-953| [ initrd] [ 13.050333] [DHCP] DNS 192.168.0.5.
15-22-59-953| [ initrd] [ 13.050414] [DHCP] DNS 192.168.0.2.
15-22-59-953| [ initrd] [ 13.050494] [DHCP] Domain local.
15-22-59-953| [ initrd] [ 13.050574] [DHCP] TFTP = DHCP 192.168.0.2.
15-22-59-953| [ initrd] [ 13.050655] [DHCP] TFTP 192.168.0.2.
15-22-59-953| [ initrd] [ 13.050734] [DHCP] No boot file from DHCP.
15-22-59-953| [ initrd] [ 13.050814] [DHCP] TFTP binary "", configs prefix "", using "/" slash.
15-22-59-953| WTC listener is active.
15-22-59-953| WTC broadcast listener is active.
15-22-59-953| Send broadcast WTCU discover.
15-22-59-953| [ pfac] [ 13.052239] Run /sbin/httpd.
15-22-59-953| [ initrd] [ 13.052314] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
15-22-59-953| [ pfac] [ 13.052442] Ok, PID 853.
15-22-59-953| [ initrd] [ 13.052495] Copy /bootmedia/configs/config.wtc to /tmp/config.wtc.
15-22-59-953| [ initrd] [ 13.052676] /bootmedia/configs/config.wtc -> /tmp/config.wtc, 1102 bytes copied.
15-22-59-953| [ initrd] [ 13.052773] Common local disk config:
15-22-59-953| /--- FILE "/tmp/config.wtc" -----------------------
15-22-59-953| | server=srv.local
15-22-59-953| | language=de,default
15-22-59-953| | sound = on, amixer:cset numid=3 1
15-22-59-953| | keyboard = de
15-22-59-953| | numlock = off
15-22-59-953| | sleep=10,poweroff
15-22-59-953| | infobox=always, shutdown
15-22-59-953| | bluetooth=on
15-22-59-953| | connection
15-22-59-953| | numlock off
15-22-59-953| | keyboard_log on
15-22-59-953| | license_dc:a6:32:26:ea:07_full = \
15-22-59-953| | 7943a95096fdaa6ddb26c5f784dc9a0ac98ece6ac350718908c190b4aaf425b1 \
15-22-59-953| | c9f16220c3d84372ea6ab32a44acee0b1162d64560977d1adb1f32c6be3900e1 \
15-22-59-953| | 1b3598e413e53ebbb32299a411bf7f9714a4e54f8a6bfbbba6b0c999a1ee8ade \
15-22-59-953| | f33f62c94380928faf0145b24a0b1e6f409aaea64a8aa0133775eaefa1cf41e9
15-22-59-953| /--- FILE "/etc/config.compiled" -----------------------
15-22-59-953| | sound=on, amixer:cset numid=3 1
15-22-59-953| | keyboard=de
15-22-59-953| | numlock=off
15-22-59-953| | keyboard_log=on
15-22-59-953| [ initrd] [ 13.055039] Hostname: "wtwDCA63226EA07".
15-22-59-953| [ httpd] [ 13.061281] Internal HTTP Server, WTware 6.0.32/RPi
15-22-59-953| [ initrd] [ 13.300284] [NTP] 42 DHCP option is not set.
15-22-59-953| Everyone can control terminal by RSH.
15-22-59-953| RSH: listener is active.
15-22-59-953| [ httpd] [ 13.304700] Reread settings.
15-22-59-953| [ initrd] [ 13.304821] Unpack /bootmedia/packages/pi2-f.
15-22-59-953| [ httpd] [ 13.304917] Everyone can control terminal by HTTP.
15-22-59-953| [ KERNEL] [ 13.460698] random: crng init done
15-22-59-953| [ gm] [ 13.464917] WTware 6.0.32/RPi session manager.
15-22-59-953| [ gm] [ 13.465555] EV_REL flag found. Add event2: PixArt USB Optical Mouse.
15-22-59-953| [ gm] [ 13.465596] Ignore event1: RPI Wired Keyboard 5.
15-22-59-953| [ gm] [ 13.465639] Keys found. Add event1: RPI Wired Keyboard 5.
15-22-59-953| [ gm] [ 13.465674] Ignore event0: RPI Wired Keyboard 5.
15-22-59-953| [ gm] [ 13.465714] Keys found. Add event0: RPI Wired Keyboard 5.
15-22-59-953| [ gm] [ 13.465757] Display mode: 1920x1080, 32 bit, landscape, 0 Hz, modeline "", DDC enabled, connector 0.
15-22-59-953| [ gm] [ 13.789018] Framebuffer device found.
15-22-59-953| [ gm] [ 13.789067] LINELENBYTES 7680
15-22-59-953| [ gm] [ 13.789103] VLEN 8294400
15-22-59-953| [ gm] [ 13.790192] Use /lib/ui32.so.
15-22-59-953| [ gm] [ 13.815794] Copy /bootmedia/configs/bluetooth.DC.A6.32.26.EA.07.zip to /tmp/bluetooth.zip.
15-22-59-953| [ gm] [ 13.816386] /bootmedia/configs/bluetooth.DC.A6.32.26.EA.07.zip -> /tmp/bluetooth.zip, 5274 bytes copied.
15-22-59-953| [ gm] [ 13.816425] [unzip] Unpack '/tmp/bluetooth.zip' to '/'.
15-22-59-953| [ gm] [ 13.816601] [unzip] Unpack '/var/lib/bluetooth/DC:A6:32:26:EA:0B/D3:D5:2F:F6:27:8D/info', 456 bytes.
15-22-59-953| [ gm] [ 13.816680] [unzip] Unpack '/var/lib/bluetooth/DC:A6:32:26:EA:0B/D3:D5:2F:F6:27:8D/attributes', 490 bytes.
15-22-59-953| [ gm] [ 13.816760] [unzip] Unpack '/var/lib/bluetooth/DC:A6:32:26:EA:0B/D3:D5:2F:F2:28:8D/info', 282 bytes.
15-22-59-953| [ gm] [ 13.816842] [unzip] Unpack '/var/lib/bluetooth/DC:A6:32:26:EA:0B/D3:D5:2F:F2:28:8D/attributes', 490 bytes.
15-22-59-953| [ gm] [ 13.816957] [unzip] Unpack '/var/lib/bluetooth/DC:A6:32:26:EA:0B/cache/D3:D5:2F:F6:27:8D', 3104 bytes.
15-22-59-953| [ gm] [ 13.817016] [unzip] Unpack '/var/lib/bluetooth/DC:A6:32:26:EA:0B/cache/E8:22:58:FF:E1:B5', 21 bytes.
15-22-59-953| [ gm] [ 13.817081] [unzip] Unpack '/var/lib/bluetooth/DC:A6:32:26:EA:0B/cache/D3:D5:2F:F2:28:8D', 36 bytes.
15-22-59-953| [ gm] [ 13.817137] [unzip] Unpack '/var/lib/bluetooth/DC:A6:32:26:EA:0B/cache/D3:D5:2F:F2:29:8D', 36 bytes.
15-22-59-953| [ gm] [ 13.817243] [unzip] Unpack '/var/lib/bluetooth/DC:A6:32:26:EA:0B/cache/D3:D5:2F:F4:27:8D', 3104 bytes.
15-22-59-953| [ gm] [ 13.817345] [unzip] Unpack '/var/lib/bluetooth/DC:A6:32:26:EA:0B/cache/20:75:50:06:35:FE', 1812 bytes.
15-22-59-953| [ gm] [ 13.817396] [unzip] Unpack '/var/lib/bluetooth/DC:A6:32:26:EA:0B/settings', 0 bytes.
15-22-59-953| [ gm] [ 13.817469] [unzip] Unpack '/var/lib/bluetooth/DC:A6:32:26:EA:0B/20:75:50:06:35:FE/info', 349 bytes.
15-22-59-953| [ gm] [ 13.817551] Unpack /bootmedia/packages/pi2-dbus.
15-22-59-953| [ gm] [ 13.946694] +--- Executing "/usr/bin/dbus-uuidgen --ensure"
15-22-59-953| [ gm] [ 13.950841] +- Errorlevel: 0, output:
15-22-59-953| | <No output>
15-22-59-953| [ gm] [ 13.950967] +------------------------
15-22-59-953| [ gm] [ 13.951005] +--- Executing "/usr/bin/dbus-daemon --system "
15-22-59-953| [ gm] [ 13.965957] +- Errorlevel: 0, output:
15-22-59-953| [ gm] [ 13.966146] +------------------------
15-22-59-953| [ gm] [ 13.966219] Run '/usr/bin/dbus-daemon --session --address=unix:path=/run/user/1007/bus', log '', env '', pid ''.
15-22-59-953| [ pfac] [ 13.966284] Run /usr/bin/dbus-daemon --session --address=unix:path=/run/user/1007/bus.
15-22-59-953| [ pfac] [ 13.966429] Ok, PID 858.
15-22-59-953| [ gm] [ 13.966597] Unpack /bootmedia/packages/pi2-bt.
15-22-59-953| [ gm] [ 14.295462] Load bluetooth driver.
15-22-59-953| [ gm] [ 14.295534] modprobe hci_uart.
15-22-59-953| [ gm] [ 14.304196] modprobe hidp.
15-22-59-953| [ KERNEL] [ 14.304044] Bluetooth: Core ver 2.22
15-22-59-953| [ KERNEL] [ 14.304068] NET: Registered protocol family 31
15-22-59-953| [ KERNEL] [ 14.304071] Bluetooth: HCI device and connection manager initialized
15-22-59-953| [ KERNEL] [ 14.304084] Bluetooth: HCI socket layer initialized
15-22-59-953| [ KERNEL] [ 14.304088] Bluetooth: L2CAP socket layer initialized
15-22-59-953| [ KERNEL] [ 14.304093] Bluetooth: SCO socket layer initialized
15-22-59-953| [ KERNEL] [ 14.305153] Bluetooth: HCI UART driver ver 2.3
15-22-59-953| [ KERNEL] [ 14.305160] Bluetooth: HCI UART protocol H4 registered
15-22-59-953| [ KERNEL] [ 14.305276] Bluetooth: HCI UART protocol Broadcom registered
15-22-59-953| [ gm] [ 14.308911] +--- Executing "/usr/bin/btuart"
15-22-59-953| [ KERNEL] [ 14.310082] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
15-22-59-953| [ KERNEL] [ 14.310097] Bluetooth: HIDP socket layer initialized
15-22-59-953| [ KERNEL] [ 14.321418] uart-pl011 fe201000.serial: no DMA platform data
15-22-59-953| [ gm] [ 20.928728] +- Errorlevel: 0, output:
15-22-59-953| | bcm43xx_init
15-22-59-953| | Flash firmware /lib/firmware/brcm/BCM4345C0.hcd
15-22-59-953| | Set Controller UART speed to 3000000 bit/s
15-22-59-953| | Device setup complete
15-22-59-953| [ gm] [ 20.929170] +------------------------
15-22-59-953| [ gm] [ 20.929271] Run '/usr/sbin/bluetoothd', log '', env '', pid ''.
15-22-59-953| [ pfac] [ 20.929361] Run /usr/sbin/bluetoothd.
15-22-59-953| [ pfac] [ 20.929565] Ok, PID 881.
15-22-59-953| [ SYSLOG] [ 20.947229] <30>Jan 21 00:00:19 bluetoothd[881]: Bluetooth daemon 5.50
15-22-59-953| [ SYSLOG] [ 20.949202] <30>Jan 21 00:00:19 bluetoothd[881]: Starting SDP server
15-22-59-953| [ SYSLOG] [ 20.950943] <28>Jan 21 00:00:19 bluetoothd[881]: kernel lacks bnep-protocol support
15-22-59-953| [ SYSLOG] [ 20.950989] <28>Jan 21 00:00:19 bluetoothd[881]: System does not support network plugin
15-22-59-953| [ SYSLOG] [ 20.953314] <30>Jan 21 00:00:19 dbus-daemon[856]: [system] Activating service name='org.freedesktop.hostname1' requested by ':1.0' (uid=0 pid=881 comm="/usr/sbin/bluetoothd ") (using servicehelper)
15-22-59-953| [ SYSLOG] [ 20.954002] <27>Jan 21 00:00:19 bluetoothd[881]: Failed to open RFKILL control device
15-22-59-953| [ SYSLOG] [ 20.954095] <30>Jan 21 00:00:19 bluetoothd[881]: Bluetooth management interface 1.14 initialized
15-22-59-953| [ SYSLOG] [ 20.954791] <27>Jan 21 00:00:19 bluetoothd[881]: Sap driver initialization failed.
15-22-59-953| [ SYSLOG] [ 20.954838] <27>Jan 21 00:00:19 bluetoothd[881]: sap-server: Operation not permitted (1)
15-22-59-953| [ SYSLOG] [ 20.956873] <30>Jan 21 00:00:19 dbus-daemon[856]: [system] Activated service 'org.freedesktop.hostname1' failed: Failed to execute program org.freedesktop.hostname1: No such file or directory
15-22-59-953| [ gm] [ 21.929756] Unpack /bootmedia/packages/pi2-alsa.
15-22-59-953| [ gm] [ 21.992145] /usr/lib/arm-linux-gnueabihf/libasound.so.2.0.0 already exists. Do not overwrite.
15-22-59-953| [ gm] [ 22.085538] modprobe snd-bcm2835.
15-22-59-953| [ KERNEL] [ 22.093054] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
15-22-59-953| [ KERNEL] [ 22.094623] bcm2835_audio bcm2835_audio: card created with 4 channels
15-22-59-953| [ KERNEL] [ 22.095571] bcm2835_audio bcm2835_audio: card created with 4 channels
15-22-59-953| [ gm] [ 22.094716] modprobe snd-usb-audio.
15-22-59-953| [ KERNEL] [ 22.104386] usbcore: registered new interface driver snd-usb-audio
15-22-59-953| /--- FILE "/proc/asound/devices" -----------------------
15-22-59-953| | 0: [ 0] : control
15-22-59-953| | 16: [ 0- 0]: digital audio playback
15-22-59-953| | 32: [ 1] : control
15-22-59-953| | 33: : timer
15-22-59-953| | 48: [ 1- 0]: digital audio playback
15-22-59-953| [ gm] [ 23.104175] /dev/snd//controlC1 character device.
15-22-59-953| [ gm] [ 23.104284] /dev/snd//pcmC1D0p character device.
15-22-59-953| [ gm] [ 23.104375] /dev/snd//controlC0 character device.
15-22-59-953| [ gm] [ 23.104463] /dev/snd//pcmC0D0p character device.
15-22-59-953| [ gm] [ 23.104550] /dev/snd//timer character device.
15-22-59-953| [ gm] [ 23.104637] +--- Executing "/usr/bin/amixer cset numid=3 1"
15-22-59-953| [ gm] [ 23.115307] +- Errorlevel: 1, output:
15-22-59-953| | amixer: Cannot find the given element from control default
15-22-59-953| [ gm] [ 23.115646] +------------------------
15-22-59-953| [ gm] [ 23.115743] globalConfig.cpp ( 2231): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
15-22-59-953| [ pfac] [ 23.115836] Run /sbin/snd_start 100 100 50.
15-22-59-953| [ gm] [ 23.115882] Run '/sbin/snd_start 100 100 50', log '', env '', pid ''.
15-22-59-953| [ pfac] [ 23.116051] Ok, PID 910.
15-22-59-953| [ snd_start] [ 23.122416] Onboard sound, level 100: bcm2835 HDMI 1.
15-22-59-953| [ snd_start] [ 23.125186] Card 'b1'/'bcm2835 HDMI 1'.
15-22-59-953| [ snd_start] [ 23.125294] Mixer name: 'Broadcom Mixer'.
15-22-59-953| [ snd_start] [ 23.125389] Components: ''.
15-22-59-953| [ snd_start] [ 23.125483] HDMI Playback Volume: integer, skip.
15-22-59-953| [ snd_start] [ 23.125576] HDMI Playback Switch: boolean, skip.
15-22-59-953| [ snd_start] [ 23.125668] Onboard sound, level 100: bcm2835 Headphones.
15-22-59-953| [ snd_start] [ 23.125762] Card 'Headphones'/'bcm2835 Headphones'.
15-22-59-953| [ snd_start] [ 23.125855] Mixer name: 'Broadcom Mixer'.
15-22-59-953| [ snd_start] [ 23.125947] Components: ''.
15-22-59-953| [ snd_start] [ 23.126039] Headphone Playback Volume: integer -10239..400 step 0, Volume 100% -> 400.
15-22-59-953| [ snd_start] [ 23.126135] Headphone Playback Switch: boolean, turn ON.
15-22-59-953| [ pfac] [ 23.127044] Process pid 910 terminated, status 00000000.
15-22-59-953| [ gm] [ 23.365933] Run sound daemon.
15-22-59-953| [ gm] [ 23.366041] Run '/sbin/rdpsnd 1 0 100 card=0,device=-1,hw', log '', env '', pid ''.
15-22-59-953| [ pfac] [ 23.366251] Run /sbin/rdpsnd 1 0 100 card=0,device=-1,hw.
15-22-59-953| [ pfac] [ 23.366500] Ok, PID 911.
15-22-59-953| [ rdpsnd] [ 23.371808] RDP Sound Redirector, WTware 6.0.32/RPi.
15-22-59-953| [ gm] [ 23.385690] Nobody can control terminal by VNC.
15-22-59-953| [ gm] [ 23.385816] Nobody can control terminal by WTRC.
15-22-59-953| [ gm] [ 24.291256] Key WT_KEY_ENTER (101) pressed.
15-22-59-953| [ gm] [ 24.298931] Run '/sbin/resolver 0x879a58 dns [srv.local]', log '', env '', pid ''.
15-22-59-953| [ pfac] [ 24.299036] Run /sbin/resolver 0x879a58 dns [srv.local].
15-22-59-953| [ pfac] [ 24.299320] Ok, PID 912.
15-22-59-953| [ gm] [ 24.312609] srv.local => 192.168.0.55.
15-22-59-953| [ pfac] [ 24.313030] Process pid 912 terminated, status 00000000.
15-22-59-953| [ gm] [ 24.317928] Free ram before fork terminal client /sbin/rdpclient (session 1): 1873204 Kb.
15-22-59-953| [ pfac] [ 24.317985] Run /sbin/rdpclient 1.
15-22-59-953| [ gm] [ 24.318004] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
15-22-59-953| [ pfac] [ 24.318098] Ok, PID 913.
15-22-59-953| [ rdpclient 913] [ 24.323681] RDP Terminal Client, WTware 6.0.32/RPi, pipe 1, pid 913.
15-22-59-953| [ rdpclient 913] [ 24.323914] Use /lib/ui32.so.
15-22-59-953| [ rdpclient 913] [ 24.324859] Redirect sound.
15-22-59-953| [ rdpclient 913] [ 24.328270] Make RDP session with 192.168.0.55, port 3389.
15-22-59-953| [ rdpclient 913] [ 24.328518] No username.
15-22-59-953| [ rdpclient 913] [ 24.328608] No password.
15-22-59-953| [ rdpclient 913] [ 24.328657] No PIN.
15-22-59-953| [ rdpclient 913] [ 24.328743] No domain.
15-22-59-953| [ rdpclient 913] [ 24.328794] No shell.
15-22-59-953| [ rdpclient 913] [ 24.328841] No directory.
15-22-59-953| [ rdpclient 913] [ 24.328884] Window: 1920x1080@24.
15-22-59-953| [ rdpclient 913] [ 24.329100] PFlags 0x0000002F.
15-22-59-953| [ rdpclient 913] [ 24.329194] Keyboard 00000407:00000000.
15-22-59-953| [ rdpclient 913] [ 24.329256] My hostname "wtwDCA63226EA07".
15-22-59-953| [ rdpclient 913] [ 24.329301] TCP: connecting to 192.168.0.55:3389.
15-22-59-953| [ rdpclient 913] [ 24.330028] TCP: connection with 192.168.0.55:3389 established.
15-22-59-953| [ rdpclient 913] [ 24.330089] Turn keepalive on.
15-22-59-953| [ rdpclient 913] [ 24.330554] Free ram after buffers allocation: 1872448 KB.
...user and password ....
15-22-59-953| [ rdpclient 913] [ 31.563886] Reconnect with NLA enabled.
15-22-59-953| [ rdpclient 913] [ 31.564327] TCP: reconnecting to 192.168.0.55:3389.
15-22-59-953| [ rdpclient 913] [ 31.564635] TCP: connection with 192.168.0.55:3389 established.
15-22-59-953| [ rdpclient 913] [ 31.564787] Turn keepalive on.
15-22-59-953| [ rdpclient 913] [ 31.573898] Server supports GFX Pipeline.
15-22-59-953| [ rdpclient 913] [ 31.574060] NLA.
15-22-59-953| [ rdpclient 913] [ 31.574170] SSL/TLS.
15-22-59-953| [ rdpclient 913] [ 31.595544] Enable font smoothing and Desktop Composition.
15-22-59-953| [ rdpclient 913] [ 31.596816] License: STATUS_VALID_CLIENT.
15-22-59-953| [ rdpclient 913] [ 31.687688] GFX codec.
15-22-59-953| [ rdpclient 913] [ 31.729684] Graphics output buffer 1920x1080, 1 monitors.
15-22-59-953| [ rdpclient 913] [ 31.729793] Monitor 0: 0.0-1919.1079 primary.
15-22-59-953| [ rdpclient 913] [ 33.134210] Run 4 tile threads.
15-22-59-953| [ rdpclient 913] [ 33.746151] SessionId 0x00000008: SRV\praktikant.
15-22-59-953| [ SYSLOG] [ 43.935608] <14>Jan 21 00:00:42 modprobe: -q -- net-pf-38
15-22-59-953| [ SYSLOG] [ 48.077916] <27>Jan 21 00:00:46 bluetoothd[881]: Failed to connection details: getpeername: Transport endpoint is not connected (107)
15-22-59-953| [ SYSLOG] [ 48.280755] <14>Jan 21 00:00:47 modprobe: -q -- net-pf-38
15-22-59-953| [ KERNEL] [ 53.356918] input: Microsoft Number Pad Keyboard as /devices/virtual/misc/uhid/0005:045E:0836.0004/input/input3
15-22-59-953| [ KERNEL] [ 53.357977] input: Microsoft Number Pad Consumer Control as /devices/virtual/misc/uhid/0005:045E:0836.0004/input/input4
15-22-59-953| [ KERNEL] [ 53.358261] input: Microsoft Number Pad Mouse as /devices/virtual/misc/uhid/0005:045E:0836.0004/input/input5
15-22-59-953| [ KERNEL] [ 53.358549] input: Microsoft Number Pad as /devices/virtual/misc/uhid/0005:045E:0836.0004/input/input6
15-22-59-953| [ KERNEL] [ 53.358869] input: Microsoft Number Pad as /devices/virtual/misc/uhid/0005:045E:0836.0004/input/input8
15-22-59-953| [ KERNEL] [ 53.359190] hid-generic 0005:045E:0836.0004: input,hidraw3: BLUETOOTH HID v1.25 Keyboard [Microsoft Number Pad] on DC:A6:32:26:EA:0B
15-22-59-953| [ gm] [ 53.366155] EV_ABS flag found. Add event6: Microsoft Number Pad.
15-22-59-953| [ gm] [ 53.366443] EV_REL flag found. Add event4: Microsoft Number Pad Consumer Control.
15-22-59-953| [ gm] [ 53.368417] Ignore event3: Microsoft Number Pad Keyboard.
15-22-59-953| [ gm] [ 53.368574] Keys found. Add event3: Microsoft Number Pad Keyboard.
15-22-59-953| [ gm] [ 53.370092] EV_ABS flag found. Add event7: Microsoft Number Pad.
15-22-59-953| [ gm] [ 53.372881] EV_REL flag found. Add event5: Microsoft Number Pad Mouse.
15-22-59-953| Send WTCU discover to 192.168.0.55.
15-22-59-967| Connection from wtc.exe at 192.168.0.55.
