17-39-38-652| [wtc.exe] Failed to connect to 192.168.1.5:779.
17-39-50-061| [HTTP] WTware v.6.0.26 found at host [], mac DC:A6:32:DA:83:75.
17-39-50-105| [HTTP] '/wtware/Everyone\list.wtc' => 'C:\ProgramData\WTware\Everyone\list.wtc'.
17-39-50-112| [HTTP] '/wtware/Terminals\DC.A6.32.DA.83.75\config.wtc' => 'C:\ProgramData\WTware\Terminals\DC.A6.32.DA.83.75\config.wtc'.
17-39-50-113| [HTTP] '/wtware/Terminals\DC.A6.32.DA.83.75\wtware.lic' => 'C:\ProgramData\WTware\Terminals\DC.A6.32.DA.83.75\wtware.lic'.
17-40-40-952| [HTTP] '/wtware/Graphic\1920x1080\menu.png' => 'C:\ProgramData\WTware\Graphic\1920x1080\menu.png'.
17-40-41-678| [HTTP] '/wtware/Graphic\1920x1080\popup.png' => 'C:\ProgramData\WTware\Graphic\1920x1080\popup.png'.
17-40-41-685| [HTTP] '/wtware/Graphic\1920x1080\saver.png' => 'C:\ProgramData\WTware\Graphic\1920x1080\saver.png'.
17-40-42-266| [HTTP] '/wtware/Graphic\1920x1080\wait.png' => 'C:\ProgramData\WTware\Graphic\1920x1080\wait.png'.
17-41-14-206| WTware 6.0.26/RPi supervisor.
17-41-14-206| [ KERNEL] [ 0.000000] Booting Linux on physical CPU 0x0
17-41-14-206| [ KERNEL] [ 0.000000] Linux version 5.4.75-v7l (aka@c22) (gcc version 8.3.0 (Debian 8.3.0-2)) #19 SMP Fri Nov 27 09:59:20 UTC 2020
17-41-14-206| [ KERNEL] [ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
17-41-14-206| [ KERNEL] [ 0.000000] CPU: div instructions available: patching division code
17-41-14-206| [ KERNEL] [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
17-41-14-206| [ KERNEL] [ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
17-41-14-206| [ KERNEL] [ 0.000000] Memory policy: Data cache writealloc
17-41-14-206| [ KERNEL] [ 0.000000] Reserved memory: created CMA memory pool at 0x000000002ac00000, size 64 MiB
17-41-14-206| [ KERNEL] [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
17-41-14-206| [ KERNEL] [ 0.000000] On node 0 totalpages: 1012736
17-41-14-206| [ KERNEL] [ 0.000000] DMA zone: 1920 pages used for memmap
17-41-14-206| [ KERNEL] [ 0.000000] DMA zone: 0 pages reserved
17-41-14-206| [ KERNEL] [ 0.000000] DMA zone: 196608 pages, LIFO batch:63
17-41-14-206| [ KERNEL] [ 0.000000] HighMem zone: 816128 pages, LIFO batch:63
17-41-14-206| [ KERNEL] [ 0.000000] percpu: Embedded 15 pages/cpu s29324 r8192 d23924 u61440
17-41-14-206| [ KERNEL] [ 0.000000] pcpu-alloc: s29324 r8192 d23924 u61440 alloc=15*4096
17-41-14-206| [ KERNEL] [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
17-41-14-206| [ KERNEL] [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1010816
17-41-14-206| [ KERNEL] [ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbdepth=32 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:DA:83:75 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 quiet wtboot=mmc
17-41-14-206| [ KERNEL] [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
17-41-14-206| [ KERNEL] [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
17-41-14-206| [ KERNEL] [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
17-41-14-206| [ KERNEL] [ 0.000000] software IO TLB: mapped [mem 0x244a0000-0x284a0000] (64MB)
17-41-14-206| [ KERNEL] [ 0.000000] Memory: 3867784K/4050944K available (6144K kernel code, 167K rwdata, 808K rodata, 2048K init, 373K bss, 117624K reserved, 65536K cma-reserved, 3264512K highmem)
17-41-14-206| [ KERNEL] [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
17-41-14-206| [ KERNEL] [ 0.000000] rcu: Hierarchical RCU implementation.
17-41-14-206| [ KERNEL] [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
17-41-14-206| [ KERNEL] [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
17-41-14-206| [ KERNEL] [ 0.000000] GIC: Using split EOI/Deactivate mode
17-41-14-206| [ KERNEL] [ 0.000000] random: get_random_bytes called from 0xc0a00b60 with crng_init=0
17-41-14-206| [ KERNEL] [ 0.000007] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
17-41-14-206| [ KERNEL] [ 0.000021] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
17-41-14-206| [ KERNEL] [ 0.000089] bcm2835: system timer (irq = 17)
17-41-14-206| [ KERNEL] [ 0.000629] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
17-41-14-206| [ KERNEL] [ 0.000643] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
17-41-14-206| [ KERNEL] [ 0.000657] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
17-41-14-206| [ KERNEL] [ 0.000669] Switching to timer-based delay loop, resolution 18ns
17-41-14-206| [ KERNEL] [ 0.000830] Console: colour dummy device 80x30
17-41-14-206| [ KERNEL] [ 0.000846] printk: console [tty0] enabled
17-41-14-206| [ KERNEL] [ 0.000881] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
17-41-14-206| [ KERNEL] [ 0.000893] pid_max: default: 32768 minimum: 301
17-41-14-206| [ KERNEL] [ 0.001020] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
17-41-14-206| [ KERNEL] [ 0.001036] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
17-41-14-206| [ KERNEL] [ 0.001560] CPU: Testing write buffer coherency: ok
17-41-14-206| [ KERNEL] [ 0.001820] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
17-41-14-206| [ KERNEL] [ 0.002198] Setting up static identity map for 0x200000 - 0x20003c
17-41-14-206| [ KERNEL] [ 0.002276] rcu: Hierarchical SRCU implementation.
17-41-14-206| [ KERNEL] [ 0.002539] smp: Bringing up secondary CPUs ...
17-41-14-206| [ KERNEL] [ 0.003119] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
17-41-14-206| [ KERNEL] [ 0.003765] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
17-41-14-206| [ KERNEL] [ 0.004390] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
17-41-14-206| [ KERNEL] [ 0.004467] smp: Brought up 1 node, 4 CPUs
17-41-14-206| [ KERNEL] [ 0.004476] SMP: Total of 4 processors activated (432.00 BogoMIPS).
17-41-14-206| [ KERNEL] [ 0.004483] CPU: All CPU(s) started in HYP mode.
17-41-14-206| [ KERNEL] [ 0.004488] CPU: Virtualization extensions available.
17-41-14-206| [ KERNEL] [ 0.004869] devtmpfs: initialized
17-41-14-206| [ KERNEL] [ 0.013569] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
17-41-14-206| [ KERNEL] [ 0.013850] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
17-41-14-206| [ KERNEL] [ 0.013867] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
17-41-14-206| [ KERNEL] [ 0.015343] pinctrl core: initialized pinctrl subsystem
17-41-14-206| [ KERNEL] [ 0.016252] NET: Registered protocol family 16
17-41-14-206| [ KERNEL] [ 0.018204] DMA: preallocated 1024 KiB pool for atomic coherent allocations
17-41-14-206| [ KERNEL] [ 0.020110] Serial: AMBA PL011 UART driver
17-41-14-206| [ KERNEL] [ 0.022000] bcm2835-mbox fe00b880.mailbox: mailbox enabled
17-41-14-206| [ KERNEL] [ 0.040636] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-08-19 17:38, variant start
17-41-14-206| [ KERNEL] [ 0.050632] raspberrypi-firmware soc:firmware: Firmware hash is e90cba19a98a0d1f2ef086b9cafcbca00778f094
17-41-14-206| [ KERNEL] [ 0.096378] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
17-41-14-206| [ KERNEL] [ 0.099361] vgaarb: loaded
17-41-14-206| [ KERNEL] [ 0.099848] usbcore: registered new interface driver usbfs
17-41-14-206| [ KERNEL] [ 0.099934] usbcore: registered new interface driver hub
17-41-14-206| [ KERNEL] [ 0.100004] usbcore: registered new device driver usb
17-41-14-206| [ KERNEL] [ 0.101537] clocksource: Switched to clocksource arch_sys_counter
17-41-14-206| [ KERNEL] [ 0.111931] thermal_sys: Registered thermal governor 'step_wise'
17-41-14-206| [ KERNEL] [ 0.112297] NET: Registered protocol family 2
17-41-14-206| [ KERNEL] [ 0.112713] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
17-41-14-206| [ KERNEL] [ 0.112737] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
17-41-14-206| [ KERNEL] [ 0.112786] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
17-41-14-206| [ KERNEL] [ 0.112848] TCP: Hash tables configured (established 8192 bind 8192)
17-41-14-206| [ KERNEL] [ 0.112950] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
17-41-14-206| [ KERNEL] [ 0.112978] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
17-41-14-206| [ KERNEL] [ 0.113108] NET: Registered protocol family 1
17-41-14-206| [ KERNEL] [ 0.113137] PCI: CLS 0 bytes, default 64
17-41-14-206| [ KERNEL] [ 0.823558] Initialise system trusted keyrings
17-41-14-206| [ KERNEL] [ 0.823687] workingset: timestamp_bits=30 max_order=20 bucket_order=0
17-41-14-206| [ KERNEL] [ 0.867816] Key type asymmetric registered
17-41-14-206| [ KERNEL] [ 0.867825] Asymmetric key parser 'x509' registered
17-41-14-206| [ KERNEL] [ 0.867888] bounce: pool size: 64 pages
17-41-14-206| [ KERNEL] [ 0.867951] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
17-41-14-206| [ KERNEL] [ 0.870173] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
17-41-14-206| [ KERNEL] [ 0.870188] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
17-41-14-206| [ KERNEL] [ 0.870219] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x0603ffffff -> 0x00f8000000
17-41-14-206| [ KERNEL] [ 0.870248] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x00bfffffff -> 0x0000000000
17-41-14-206| [ KERNEL] [ 0.923629] brcm-pcie fd500000.pcie: link up, 5 GT/s x1 (SSC)
17-41-14-206| [ KERNEL] [ 0.923845] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
17-41-14-206| [ KERNEL] [ 0.923859] pci_bus 0000:00: root bus resource [bus 00-ff]
17-41-14-206| [ KERNEL] [ 0.923873] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
17-41-14-206| [ KERNEL] [ 0.923908] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
17-41-14-206| [ KERNEL] [ 0.924011] pci 0000:00:00.0: PME# supported from D0 D3hot
17-41-14-206| [ KERNEL] [ 0.926753] PCI: bus0: Fast back to back transfers disabled
17-41-14-206| [ KERNEL] [ 0.926924] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
17-41-14-206| [ KERNEL] [ 0.927030] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
17-41-14-206| [ KERNEL] [ 0.927308] pci 0000:01:00.0: PME# supported from D0 D3cold
17-41-14-206| [ KERNEL] [ 0.930039] PCI: bus1: Fast back to back transfers disabled
17-41-14-206| [ KERNEL] [ 0.930077] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
17-41-14-206| [ KERNEL] [ 0.930093] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
17-41-14-206| [ KERNEL] [ 0.930153] pci 0000:00:00.0: PCI bridge to [bus 01]
17-41-14-206| [ KERNEL] [ 0.930164] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
17-41-14-206| [ KERNEL] [ 0.930327] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
17-41-14-206| [ KERNEL] [ 0.930473] pcieport 0000:00:00.0: PME: Signaling with IRQ 53
17-41-14-206| [ KERNEL] [ 0.930717] pcieport 0000:00:00.0: AER: enabled with IRQ 53
17-41-14-206| [ KERNEL] [ 0.930987] pci 0000:01:00.0: enabling device (0140 -> 0142)
17-41-14-206| [ KERNEL] [ 0.931483] bcm2708_fb soc:fb: FB found 1 display(s)
17-41-14-206| [ KERNEL] [ 0.974449] Console: switching to colour frame buffer device 240x67
17-41-14-206| [ KERNEL] [ 0.984956] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 1920x1080
17-41-14-206| [ KERNEL] [ 0.988575] iproc-rng200 fe104000.rng: hwrng registered
17-41-14-206| [ KERNEL] [ 0.988739] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
17-41-14-206| [ KERNEL] [ 0.989248] vc-sm: Videocore shared memory driver
17-41-14-206| [ KERNEL] [ 0.991451] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
17-41-14-206| [ KERNEL] [ 0.992421] zram: Added device: zram0
17-41-14-206| [ KERNEL] [ 0.994329] libphy: Fixed MDIO Bus: probed
17-41-14-206| [ KERNEL] [ 0.994657] xhci_hcd 0000:01:00.0: xHCI Host Controller
17-41-14-206| [ KERNEL] [ 0.994697] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
17-41-14-206| [ KERNEL] [ 1.035263] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000003000000890
17-41-14-206| [ KERNEL] [ 1.035775] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
17-41-14-206| [ KERNEL] [ 1.035786] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
17-41-14-206| [ KERNEL] [ 1.035796] usb usb1: Product: xHCI Host Controller
17-41-14-206| [ KERNEL] [ 1.035805] usb usb1: Manufacturer: Linux 5.4.75-v7l xhci-hcd
17-41-14-206| [ KERNEL] [ 1.035813] usb usb1: SerialNumber: 0000:01:00.0
17-41-14-206| [ KERNEL] [ 1.036282] hub 1-0:1.0: USB hub found
17-41-14-206| [ KERNEL] [ 1.036347] hub 1-0:1.0: 1 port detected
17-41-14-206| [ KERNEL] [ 1.036861] xhci_hcd 0000:01:00.0: xHCI Host Controller
17-41-14-206| [ KERNEL] [ 1.036888] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
17-41-14-206| [ KERNEL] [ 1.036907] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
17-41-14-206| [ KERNEL] [ 1.037179] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
17-41-14-206| [ KERNEL] [ 1.037198] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
17-41-14-206| [ KERNEL] [ 1.037215] usb usb2: Product: xHCI Host Controller
17-41-14-206| [ KERNEL] [ 1.037225] usb usb2: Manufacturer: Linux 5.4.75-v7l xhci-hcd
17-41-14-206| [ KERNEL] [ 1.037233] usb usb2: SerialNumber: 0000:01:00.0
17-41-14-206| [ KERNEL] [ 1.037709] hub 2-0:1.0: USB hub found
17-41-14-206| [ KERNEL] [ 1.037753] hub 2-0:1.0: 4 ports detected
17-41-14-206| [ KERNEL] [ 1.038668] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
17-41-14-206| [ KERNEL] [ 1.038774] dwc_otg: FIQ enabled
17-41-14-206| [ KERNEL] [ 1.038783] dwc_otg: NAK holdoff enabled
17-41-14-206| [ KERNEL] [ 1.038789] dwc_otg: FIQ split-transaction FSM enabled
17-41-14-206| [ KERNEL] [ 1.038798] Module dwc_common_port init
17-41-14-206| [ KERNEL] [ 1.043362] usbcore: registered new interface driver usbtouchscreen
17-41-14-206| [ KERNEL] [ 1.044833] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
17-41-14-206| [ KERNEL] [ 1.046077] sdhci: Secure Digital Host Controller Interface driver
17-41-14-206| [ KERNEL] [ 1.046086] sdhci: Copyright(c) Pierre Ossman
17-41-14-206| [ KERNEL] [ 1.046431] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
17-41-14-206| [ KERNEL] [ 1.046664] sdhci-pltfm: SDHCI platform and OF driver helper
17-41-14-206| [ KERNEL] [ 1.047359] hidraw: raw HID events driver (C) Jiri Kosina
17-41-14-206| [ KERNEL] [ 1.048217] usbcore: registered new interface driver usbhid
17-41-14-206| [ KERNEL] [ 1.048227] usbhid: USB HID core driver
17-41-14-206| [ KERNEL] [ 1.050079] vchiq: vchiq_init_state: slot_zero = (ptrval)
17-41-14-206| [ KERNEL] [ 1.060605] [vc_sm_connected_init]: start
17-41-14-206| [ KERNEL] [ 1.066763] [vc_sm_connected_init]: end - returning 0
17-41-14-206| [ KERNEL] [ 1.067350] NET: Registered protocol family 17
17-41-14-206| [ KERNEL] [ 1.067458] Registering SWP/SWPB emulation handler
17-41-14-206| [ KERNEL] [ 1.067532] Loading compiled-in X.509 certificates
17-41-14-206| [ KERNEL] [ 1.068358] uart-pl011 fe201000.serial: cts_event_workaround enabled
17-41-14-206| [ KERNEL] [ 1.068391] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 29, base_baud = 0) is a PL011 rev2
17-41-14-206| [ KERNEL] [ 1.073649] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
17-41-14-206| [ KERNEL] [ 1.073914] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
17-41-14-206| [ KERNEL] [ 1.073918] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
17-41-14-206| [ KERNEL] [ 1.122228] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
17-41-14-206| [ KERNEL] [ 1.123730] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
17-41-14-206| [ KERNEL] [ 1.125226] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
17-41-14-206| [ KERNEL] [ 1.128015] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
17-41-14-206| [ KERNEL] [ 1.129510] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
17-41-14-206| [ KERNEL] [ 1.138437] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
17-41-14-206| [ KERNEL] [ 1.138568] of_cfs_init
17-41-14-206| [ KERNEL] [ 1.138672] of_cfs_init: OK
17-41-14-206| [ KERNEL] [ 1.141384] Freeing unused kernel memory: 2048K
17-41-14-206| [ KERNEL] [ 1.166397] random: fast init done
17-41-14-206| [ KERNEL] [ 1.191785] Run /init as init process
17-41-14-206| [ KERNEL] [ 1.193685] mmc1: new high speed SDIO card at address 0001
17-41-14-206| [ KERNEL] [ 1.211465] mmc0: new ultra high speed SDR25 SDHC card at address b368
17-41-14-206| [ KERNEL] [ 1.211922] mmcblk0: mmc0:b368 CBADS 30.0 GiB
17-41-14-206| [ KERNEL] [ 1.212878] mmcblk0: p1
17-41-14-206| [ KERNEL] [ 1.401558] usb 1-1: new high-speed USB device number 2 using xhci_hcd
17-41-14-206| [ pfac] [ 1.506731] Run /sbin/initrd.
17-41-14-206| [ pfac] [ 1.506963] Ok, PID 793.
17-41-14-206| [ initrd] [ 1.511281] WTware 6.0.26/RPi shell.
17-41-14-206| [ initrd] [ 1.511759] Load font 'ter-c32b.psf', console 120x33.
17-41-14-206| [ initrd] [ 1.533293] HDD/MMC/SD boot.
17-41-14-206| [ initrd] [ 1.533519] No device '/dev/fb1'.
17-41-14-206| [ KERNEL] [ 1.584146] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
17-41-14-206| [ KERNEL] [ 1.584159] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
17-41-14-206| [ KERNEL] [ 1.584169] usb 1-1: Product: USB2.0 Hub
17-41-14-206| [ KERNEL] [ 1.585797] hub 1-1:1.0: USB hub found
17-41-14-206| [ KERNEL] [ 1.586110] hub 1-1:1.0: 4 ports detected
17-41-14-206| [ initrd] [ 1.596458] Success: /dev/mmcblk0p1 mounted to /bootmedia.
17-41-14-206| /--- FILE "/bootmedia/config.txt" -----------------------
17-41-14-206| | # For more options and information see:
17-41-14-206| | #
17-41-14-206| | # https://www.raspberrypi.org/documentation/configuration/config-txt/README.md
17-41-14-206| | #
17-41-14-206| | # Some settings may impact device functionality. See link above for details.
17-41-14-206| | # Uncomment if you get no picture on HDMI for a default "safe" mode.
17-41-14-206| | #hdmi_safe=1
17-41-14-206| | # Uncomment this if your display has a black border of unused pixels visible
17-41-14-206| | # and your display can output without overscan.
17-41-14-206| | disable_overscan=1
17-41-14-206| | # Uncomment if hdmi display is not detected and composite is being output.
17-41-14-206| | #hdmi_force_hotplug=1
17-41-14-206| | # Uncomment to force a specific HDMI mode (this will force VGA).
17-41-14-206| | #hdmi_group=1
17-41-14-206| | #hdmi_mode=1
17-41-14-206| | # Force the monitor to HDMI mode so that sound will be sent over HDMI cable.
17-41-14-206| | #hdmi_drive=2
17-41-14-206| | # Uncomment to increase signal to HDMI, if you have interference, blanking, or
17-41-14-206| | # no display.
17-41-14-206| | #config_hdmi_boost=4
17-41-14-206| | # Uncomment to overclock the arm. 700 MHz is the default.
17-41-14-206| | #arm_freq=800
17-41-14-206| | disable_splash=1
17-41-14-206| | framebuffer_depth=32
17-41-14-206| | # Uncomment for 16-bit color.
17-41-14-206| | #framebuffer_depth=16
17-41-14-206| | # Enable onboard audio (HDMI or jack).
17-41-14-206| | dtparam=audio=on
17-41-14-206| | # Removes the warning overlay.
17-41-14-206| | #avoid_warnings=1
17-41-14-206| | # Additionally allows turbo when low-voltage is present.
17-41-14-206| | #avoid_warnings=2
17-41-14-206| | [pi4]
17-41-14-206| | max_framebuffers=2
17-41-14-206| | [all]
17-41-14-206| | # Uncomment these two lines to set display resolution:
17-41-14-206| | #hdmi_group=2
17-41-14-206| | #hdmi_mode=58
17-41-14-206| | #
17-41-14-206| | # Specify correct value in hdmi_mode= line from the list of valid values:
17-41-14-206| | # 800x600: hdmi_mode=9
17-41-14-206| | # 1024x768: hdmi_mode=16
17-41-14-206| | # 1280x1024: hdmi_mode=35
17-41-14-206| | # 1360x768: hdmi_mode=39
17-41-14-206| | # 1400x1050: hdmi_mode=42
17-41-14-206| | # 1440x900: hdmi_mode=47
17-41-14-206| | # 1600x1200: hdmi_mode=51
17-41-14-206| | # 1680x1050: hdmi_mode=58
17-41-14-206| | # 1366x768: hdmi_mode=81
17-41-14-206| | # 1920x1080: hdmi_mode=82
17-41-14-206| | # 1920x1200: hdmi_mode=69
17-41-14-206| | #
17-41-14-206| | # Find more resolutions in manual:
17-41-14-206| | # https://www.raspberrypi.org/documentation/configuration/config-txt/video.md
17-41-14-206| | #
17-41-14-206| | # Uncomment six lines with such syntax and right hdmi_mode= values for
17-41-14-206| | # dual displays on Raspberry Pi 4:
17-41-14-206| | #
17-41-14-206| | #[HDMI:0]
17-41-14-206| | # hdmi_group=2
17-41-14-206| | # hdmi_mode=42
17-41-14-206| | #[HDMI:1]
17-41-14-206| | # hdmi_mode=58
17-41-14-206| \----------------------------------------------------
17-41-14-206| [ KERNEL] [ 1.911575] usb 1-1.2: new low-speed USB device number 3 using xhci_hcd
17-41-14-206| [ KERNEL] [ 2.081267] usb 1-1.2: New USB device found, idVendor=03f0, idProduct=034a, bcdDevice= 1.21
17-41-14-206| [ KERNEL] [ 2.081279] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
17-41-14-206| [ KERNEL] [ 2.081288] usb 1-1.2: Product: HP Elite USB Keyboard
17-41-14-206| [ KERNEL] [ 2.081297] usb 1-1.2: Manufacturer: Chicony
17-41-14-206| [ KERNEL] [ 2.104111] input: Chicony HP Elite USB Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2:1.0/0003:03F0:034A.0001/input/input0
17-41-14-206| [ KERNEL] [ 2.172241] hid-generic 0003:03F0:034A.0001: input,hidraw0: USB HID v1.10 Keyboard [Chicony HP Elite USB Keyboard] on usb-0000:01:00.0-1.2/input0
17-41-14-206| [ KERNEL] [ 2.186940] input: Chicony HP Elite USB Keyboard System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2:1.1/0003:03F0:034A.0002/input/input1
17-41-14-206| [ KERNEL] [ 2.261926] input: Chicony HP Elite USB Keyboard Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2:1.1/0003:03F0:034A.0002/input/input2
17-41-14-206| [ KERNEL] [ 2.262220] hid-generic 0003:03F0:034A.0002: input,hidraw1: USB HID v1.10 Device [Chicony HP Elite USB Keyboard] on usb-0000:01:00.0-1.2/input1
17-41-14-206| /--- FILE "/bootmedia/configs/initrd.wtc" -----------------------
17-41-14-206| | clientIP = *
17-41-14-206| | config = http
17-41-14-206| | tftpIP = 172.16.2.73
17-41-14-206| | tftpPrefix = /wtware/
17-41-14-206| | setupPassword = 8ac0fa26aeae79a1084fbf75a8caf048
17-41-14-206| [ initrd] [ 2.311898] Do not cache package files.
17-41-14-206| [ initrd] [ 2.312012] WTpassword present: 8ac0fa26aeae79a1084fbf75a8caf048.
17-41-14-206| [ initrd] [ 2.312063] Unpack /bootmedia/packages/pi2-lib.
17-41-14-206| [ KERNEL] [ 2.361564] usb 1-1.4: new full-speed USB device number 4 using xhci_hcd
17-41-14-206| [ KERNEL] [ 2.506309] usb 1-1.4: New USB device found, idVendor=1b3f, idProduct=2008, bcdDevice= 1.00
17-41-14-206| [ KERNEL] [ 2.506315] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
17-41-14-206| [ KERNEL] [ 2.506319] usb 1-1.4: Product: USB Audio Device
17-41-14-206| [ KERNEL] [ 2.506323] usb 1-1.4: Manufacturer: GeneralPlus
17-41-14-206| [ KERNEL] [ 2.513892] input: GeneralPlus USB Audio Device as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.3/0003:1B3F:2008.0003/input/input3
17-41-14-206| [ KERNEL] [ 2.581720] hid-generic 0003:1B3F:2008.0003: input,hidraw2: USB HID v2.01 Device [GeneralPlus USB Audio Device] on usb-0000:01:00.0-1.4/input3
17-41-14-206| [ initrd] [ 2.962462] USB: 2109:3431 VIA Labs, Inc. Hub.
17-41-14-206| [ initrd] [ 2.962517] USB: 1b3f:2008 Generalplus Technology Inc..
17-41-14-206| [ initrd] [ 2.962550] USB: 03f0:034a HP, Inc Elite Keyboard.
17-41-14-206| [ initrd] [ 4.327447] Load Ethernet drivers.
17-41-14-206| [ initrd] [ 4.327549] modprobe genet.
17-41-14-206| [ KERNEL] [ 4.336173] bcmgenet fd580000.ethernet: failed to get enet clock
17-41-14-206| [ KERNEL] [ 4.336181] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
17-41-14-206| [ KERNEL] [ 4.336186] bcmgenet fd580000.ethernet: failed to get enet-wol clock
17-41-14-206| [ KERNEL] [ 4.336190] bcmgenet fd580000.ethernet: failed to get enet-eee clock
17-41-14-206| [ KERNEL] [ 4.336204] bcmgenet: Skipping UMAC reset
17-41-14-206| [ KERNEL] [ 4.361571] libphy: bcmgenet MII bus: probed
17-41-14-206| [ KERNEL] [ 4.451623] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
17-41-14-206| [ KERNEL] [ 4.453236] bcmgenet: Skipping UMAC reset
17-41-14-206| [ KERNEL] [ 4.455257] bcmgenet fd580000.ethernet: configuring instance for external RGMII
17-41-14-206| [ KERNEL] [ 4.455988] bcmgenet fd580000.ethernet eth0: Link is Down
17-41-14-206| [ KERNEL] [ 9.671648] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
17-41-14-206| [ initrd] [ 9.762336] Download configs from HTTP 172.16.2.73 port 789 prefix '/wtware/'.
17-41-14-206| [ initrd] [ 9.762443] WTpassword present: 8ac0fa26aeae79a1084fbf75a8caf048.
17-41-14-206| [ initrd] [ 10.960133] dhcp: 349 bytes from 192.168.1.254.
17-41-14-206| [ initrd] [ 10.960239] 00000000:000001490000000000110000C0A801FEC0A80105004300440149000002010601 ...I................C.D.I......
17-41-14-206| [ initrd] [ 10.960325] 00000020:67458B6B0000000000000000C0A80105AC100266C0A801FEDCA632DA83750000 gE.k..............f......2..u..
17-41-14-206| [ initrd] [ 10.960409] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
17-41-14-206| [ initrd] [ 10.960491] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
17-41-14-206| [ initrd] [ 10.960572] 00000080:0000000000000000000000000000000000000000000000000000000000000000 ................................
17-41-14-206| [ initrd] [ 10.960653] 000000a0:0000000000000000000000000000000000000000000000000000000000000000 ................................
17-41-14-206| [ initrd] [ 10.960735] 000000c0:0000000000000000000000000000000000000000000000000000000000000000 ................................
17-41-14-206| [ initrd] [ 10.960815] 000000e0:0000000000000000000000000000000000000000000000000000000000000000 ................................
17-41-14-206| [ initrd] [ 10.960897] 00000100:0000000000000000638253633501020104FFFFFF003A040000A8C03B04000127 ........c.Sc5........:.....;...'
17-41-14-206| [ initrd] [ 10.960978] 00000120:503304000151803604AC1002660304C0A801FE0610AC100258AC100259AC1002 P3...Q.6...f.........X..Y..
17-41-14-206| [ initrd] [ 10.961058] dhcp: 349 bytes from 192.168.1.16.
17-41-14-206| [ initrd] [ 10.961136] 00000000:000001490000000000110000C0A80110C0A80105004300440149000002010601 ...I...............C.D.I......
17-41-14-206| [ initrd] [ 10.961217] 00000020:67458B6B0000000000000000C0A80105AC100266C0A80110DCA632DA83750000 gE.k..............f.....2..u..
17-41-14-206| [ initrd] [ 10.961298] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
17-41-14-206| [ initrd] [ 10.961398] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
17-41-14-206| [ initrd] [ 10.961480] 00000080:0000000000000000000000000000000000000000000000000000000000000000 ................................
17-41-14-206| [ initrd] [ 10.961561] 000000a0:0000000000000000000000000000000000000000000000000000000000000000 ................................
17-41-14-206| [ initrd] [ 10.961642] 000000c0:0000000000000000000000000000000000000000000000000000000000000000 ................................
17-41-14-206| [ initrd] [ 10.961722] 000000e0:0000000000000000000000000000000000000000000000000000000000000000 ................................
17-41-14-206| [ initrd] [ 10.961802] 00000100:0000000000000000638253633501020104FFFFFF003A040000A8C03B04000127 ........c.Sc5........:.....;...'
17-41-14-206| [ initrd] [ 10.961883] 00000120:503304000151803604AC1002660304C0A801FE0610AC100258AC100259AC1002 P3...Q.6...f.........X..Y..
17-41-14-206| [ initrd] [ 10.961965] Discard second offer for 192.168.1.5.
17-41-14-206| [ initrd] [ 12.130173] dhcp: 349 bytes from 192.168.1.254.
17-41-14-206| [ initrd] [ 12.130273] 00000000:000001490000000000110000C0A801FEC0A80105004300440149000002010601 ...I................C.D.I......
17-41-14-206| [ initrd] [ 12.130358] 00000020:67458B6B0000000000000000C0A8010500000000C0A801FEDCA632DA83750000 gE.k......................2..u..
17-41-14-206| [ initrd] [ 12.130440] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
17-41-14-206| [ initrd] [ 12.130520] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
17-41-14-206| [ initrd] [ 12.130601] 00000080:0000000000000000000000000000000000000000000000000000000000000000 ................................
17-41-14-206| [ initrd] [ 12.130681] 000000a0:0000000000000000000000000000000000000000000000000000000000000000 ................................
17-41-14-206| [ initrd] [ 12.130762] 000000c0:0000000000000000000000000000000000000000000000000000000000000000 ................................
17-41-14-206| [ initrd] [ 12.130843] 000000e0:0000000000000000000000000000000000000000000000000000000000000000 ................................
17-41-14-206| [ initrd] [ 12.130923] 00000100:0000000000000000638253633501053A040000A8C03B04000127503304000151 ........c.Sc5..:.....;...'P3...Q
17-41-14-206| [ initrd] [ 12.131003] 00000120:803604AC1002660104FFFFFF000304C0A801FE0610AC100258AC100259AC1002 .6...f...............X..Y..
17-41-14-206| [ initrd] [ 12.170089] [DHCP] DHCP server address 172.162.2.102.
17-41-14-206| [ initrd] [ 12.170177] [DHCP] IP 192.168.1.5 mask 255.255.255.0.
17-41-14-206| [ initrd] [ 12.170257] [DHCP] Default gateway 192.168.1.254.
17-41-14-206| [ initrd] [ 12.170337] [DHCP] DNS 172.161.2.188.
17-41-14-206| [ initrd] [ 12.170418] [DHCP] DNS 172.161.2.189.
17-41-14-206| [ initrd] [ 12.170498] [DHCP] DNS 172.161.2.132.
17-41-14-206| [ initrd] [ 12.170576] [DHCP] DNS 192.168.1.49.
17-41-14-206| [ initrd] [ 12.170655] [DHCP] NTP 193.71.14.22.
17-41-14-206| [ initrd] [ 12.170735] [DHCP] Domain eris.local.
17-41-14-206| [ initrd] [ 12.170813] [DHCP] HTTP IP 172.16.2.73 already specified.
17-41-14-206| WTC listener is active.
17-41-14-206| WTC broadcast listener is active.
17-41-14-206| Send broadcast WTCU discover.
17-41-14-206| [ pfac] [ 12.172215] Run /sbin/httpd.
17-41-14-206| [ initrd] [ 12.172284] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
17-41-14-206| [ pfac] [ 12.172418] Ok, PID 853.
17-41-14-206| [ initrd] [ 12.172481] [HTTP] Download config file /wtware/Everyone/list.wtc from 172.16.2.73.
17-41-14-206| [ initrd] [ 12.178805] [HTTP] Download config file /wtware/Terminals/DC.A6.32.DA.83.75/config.wtc from 172.16.2.73.
17-41-14-206| [ initrd] [ 12.180270] [HTTP] Download config file /wtware/Terminals/DC.A6.32.DA.83.75/wtware.lic from 172.16.2.73.
17-41-14-206| [ httpd] [ 12.181415] Internal HTTP Server, WTware 6.0.26/RPi
17-41-14-206| [ initrd] [ 12.181528] [HTTP] File not found.
17-41-14-206| /--- FILE "/tmp/config.wtc" -----------------------
17-41-14-206| | sound=on, hw:2:0
17-41-14-206| | template RDS_Raspberry
17-41-14-206| | connection
17-41-14-206| [ initrd] [ 12.182103] [HTTP] Download config file /wtware/Everyone/all.wtc from 172.16.2.73.
17-41-14-206| /--- FILE "/tmp/all.wtc" -----------------------
17-41-14-206| | [BOM]
17-41-14-206| | server=srvrds99.eris.local
17-41-14-206| | keyboard=it
17-41-14-206| | domain=eris.local
17-41-14-206| | microphone=on
17-41-14-206| | language=it,default
17-41-14-206| | loadbalanceinfo=tsv://MS Terminal Services Plugin.1.RDS_eris
17-41-14-206| | vnc=on
17-41-14-206| | vnc_password=ErViGrSp
17-41-14-206| | clienthostname=TRM*IP1
17-41-14-206| | display=1280x1024
17-41-14-206| | skin=1280x1024
17-41-14-206| Skip 'CLID'.
17-41-14-206| | sleep=5,poweroff
17-41-14-206| [ initrd] [ 12.183668] [HTTP] Download config file /wtware/Everyone/wtware.lic from 172.116.2.73.
17-41-14-206| [ initrd] [ 12.185898] [HTTP] Download config file /wtware/Templates/RDS_Raspberry.wtc from 172.116.2.73.
17-41-14-206| /--- FILE "/tmp/tmp.wtc" -----------------------
17-41-14-206| | server=srvrds99.local
17-41-14-206| | sound=on, hw:1:0
17-41-14-206| | display=1920x1080
17-41-14-206| | sleep=60,poweroff
17-41-14-206| | skin=1920x1080
17-41-14-206| | turnoffmenu=poweroff
17-41-14-206| [ initrd] [ 12.188714] Remount /bootmedia for writing.
17-41-14-206| [ initrd] [ 12.191682] Remount /bootmedia as read-only.
17-41-14-206| /--- FILE "/etc/config.compiled" -----------------------
17-41-14-206| [ initrd] [ 12.232157] Hostname: "TRM-5".
17-41-14-206| [ initrd] [ 12.510304] Run '/bin/sh /tmp/ntpdate', log '/tmp/ntp.out', env '', pid ''.
17-41-14-206| [ pfac] [ 12.510415] Run /bin/sh /tmp/ntpdate.
17-41-14-206| Everyone can control terminal by RSH.
17-41-14-206| RSH: listener is active.
17-41-14-206| [ pfac] [ 12.511661] Ok, PID 854.
17-41-14-206| [ httpd] [ 12.515472] Reread settings.
17-41-14-206| [ httpd] [ 12.515656] Everyone can control terminal by HTTP.
17-41-14-206| [ NTP] [ 12.517768] ntpd: sending query to 193.204.114.232
17-41-14-206| [ initrd] [ 12.537291] Unpack /bootmedia/packages/pi2-f.
17-41-14-206| [ KERNEL] [ 12.707102] random: crng init done
17-41-14-206| [ gm] [ 12.711090] WTware 6.0.26/RPi session manager.
17-41-14-206| [ gm] [ 12.711792] Ignore event3: GeneralPlus USB Audio Device.
17-41-14-206| [ gm] [ 12.711832] Keys found. Add event3: GeneralPlus USB Audio Device.
17-41-14-206| [ gm] [ 12.711867] EV_REL flag found. Add event2: Chicony HP Elite USB Keyboard Consumer Control.
17-41-14-206| [ gm] [ 12.711904] Ignore event1: Chicony HP Elite USB Keyboard System Control.
17-41-14-206| [ gm] [ 12.711941] Keys found. Add event1: Chicony HP Elite USB Keyboard System Control.
17-41-14-206| [ gm] [ 12.711980] Ignore event0: Chicony HP Elite USB Keyboard.
17-41-14-206| [ gm] [ 12.712016] Keys found. Add event0: Chicony HP Elite USB Keyboard.
17-41-14-206| [ gm] [ 12.712053] Display mode: 1920x1080, 32 bit, landscape, 0 Hz, modeline "", DDC enabled, connector 0.
17-41-14-206| [ NTP] [ 22.518264] Alarm clock
17-41-14-206| [ NTP] [ 22.521804] hwclock: can't open '/dev/misc/rtc': No such file or directory
17-41-14-206| [ pfac] [ 22.522625] Process pid 854 terminated, status 00000000.
17-41-14-206| [ gm] [ 62.764267] [ERROR] Lookup for DNS failed, errors 0 -2.
17-41-14-206| [ gm] [ 62.764401] [ERROR] Failed to resolve cl.wtware.com in DNS.
17-41-14-206| [ gm] [ 62.764512] [ERROR] DNS is not configured properly.
17-41-14-206| [ gm] [ 62.764616] [ERROR] Concurrent licenses cannot be applied.
17-41-14-206| [ gm] [ 63.062451] Framebuffer device found.
17-41-14-206| [ gm] [ 63.062495] LINELENBYTES 7680
17-41-14-206| [ gm] [ 63.062530] VLEN 8294400
17-41-14-206| [ gm] [ 63.063597] Use /lib/ui32.so.
17-41-14-206| [ gm] [ 63.063820] [HTTP] Download config file /wtware/Graphic/1920x1080/menu.png from 172.16.2.73.
17-41-14-206| [ gm] [ 63.790104] [HTTP] Download config file /wtware/Graphic/1920x1080/popup.png from 172.16.2.73.
17-41-14-206| [ gm] [ 63.796563] [HTTP] Download config file /wtware/Graphic/1920x1080/saver.png from 172.16.2.73.
17-41-14-206| [ gm] [ 64.379351] [HTTP] Download config file /wtware/Graphic/1920x1080/wait.png from 172.16.2.73.
17-41-14-206| [ gm] [ 65.267742] Use '/tmp/wait.png'.
17-41-14-206| [ gm] [ 65.278825] Unpack /bootmedia/packages/pi2-alsa.
17-41-14-206| [ gm] [ 65.427341] modprobe snd-bcm2835.
17-41-14-206| [ KERNEL] [ 65.435086] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
17-41-14-206| [ KERNEL] [ 65.436510] bcm2835_audio bcm2835_audio: card created with 4 channels
17-41-14-206| [ gm] [ 65.436201] modprobe snd-usb-audio.
17-41-14-206| [ KERNEL] [ 65.437348] bcm2835_audio bcm2835_audio: card created with 4 channels
17-41-14-206| [ KERNEL] [ 65.500233] usbcore: registered new interface driver snd-usb-audio
17-41-14-206| /--- FILE "/proc/asound/devices" -----------------------
17-41-14-206| | 0: [ 0] : control
17-41-14-206| | 16: [ 0- 0]: digital audio playback
17-41-14-206| | 32: [ 1] : control
17-41-14-206| | 33: : timer
17-41-14-206| | 48: [ 1- 0]: digital audio playback
17-41-14-206| | 64: [ 2] : control
17-41-14-206| | 80: [ 2- 0]: digital audio playback
17-41-14-206| | 88: [ 2- 0]: digital audio capture
17-41-14-206| [ gm] [ 66.500054] /dev/snd//controlC2 character device.
17-41-14-206| [ gm] [ 66.500164] /dev/snd//pcmC2D0c character device.
17-41-14-206| [ gm] [ 66.500262] /dev/snd//pcmC2D0p character device.
17-41-14-206| [ gm] [ 66.500350] /dev/snd//controlC1 character device.
17-41-14-206| [ gm] [ 66.500435] /dev/snd//pcmC1D0p character device.
17-41-14-206| [ gm] [ 66.500520] /dev/snd//controlC0 character device.
17-41-14-206| [ gm] [ 66.500604] /dev/snd//pcmC0D0p character device.
17-41-14-206| [ gm] [ 66.500688] /dev/snd//timer character device.
17-41-14-206| [ gm] [ 66.500773] Run '/sbin/rdpsnd sndvol 100 100 50', log '', env '', pid ''.
17-41-14-206| [ pfac] [ 66.501218] Run /sbin/rdpsnd sndvol 100 100 50.
17-41-14-206| [ pfac] [ 66.501346] Ok, PID 884.
17-41-14-206| [ sndvol] [ 66.507418] [ALSA] Sound cards found: 3.
17-41-14-206| [ sndvol] [ 66.510487] Card 'b1'/'bcm2835 HDMI 1'.
17-41-14-206| [ sndvol] [ 66.510600] Mixer name: 'Broadcom Mixer'.
17-41-14-206| [ sndvol] [ 66.510692] Components: ''.
17-41-14-206| [ sndvol] [ 66.510784] Controls: 2.
17-41-14-206| [ sndvol] [ 66.510876] ALSA: control 'HDMI Playback Volume'.
17-41-14-206| [ sndvol] [ 66.510969] ALSA: control 'HDMI Playback Switch'.
17-41-14-206| [ sndvol] [ 66.511061] Card 'Headphones'/'bcm2835 Headphones'.
17-41-14-206| [ sndvol] [ 66.511155] Mixer name: 'Broadcom Mixer'.
17-41-14-206| [ sndvol] [ 66.511247] Components: ''.
17-41-14-206| [ sndvol] [ 66.511339] Controls: 2.
17-41-14-206| [ sndvol] [ 66.511429] ALSA: control 'Headphone Playback Volume'.
17-41-14-206| [ sndvol] [ 66.511519] ALSA: control 'Headphone Playback Switch'.
17-41-14-206| [ sndvol] [ 66.511609] Card 'Device'/'GeneralPlus USB Audio Device at usb-0000:01:00.0-1.4, full speed'.
17-41-14-206| [ sndvol] [ 66.511703] Mixer name: 'USB Mixer'.
17-41-14-206| [ sndvol] [ 66.511794] Components: 'USB1b3f:2008'.
17-41-14-206| [ sndvol] [ 66.511885] Controls: 10.
17-41-14-206| [ sndvol] [ 66.511975] ALSA: control 'Playback Channel Map'.
17-41-14-206| [ sndvol] [ 66.512065] ALSA: control 'Capture Channel Map'.
17-41-14-206| [ sndvol] [ 66.512155] ALSA: control 'Mic Playback Switch'.
17-41-14-206| [ sndvol] [ 66.512808] ALSA: control 'Mic Playback Volume'.
17-41-14-206| [ sndvol] [ 66.512904] ALSA: control 'Speaker Playback Switch'.
17-41-14-206| [ sndvol] [ 66.513517] ALSA: control 'Speaker Playback Volume'.
17-41-14-206| [ sndvol] [ 66.515764] ALSA: control 'Mic Capture Switch'.
17-41-14-206| [ sndvol] [ 66.516524] ALSA: control 'Mic Capture Volume'.
17-41-14-206| [ sndvol] [ 66.517262] ALSA: control 'Auto Gain Control'.
17-41-14-206| [ sndvol] [ 66.518763] ALSA: control 'Keep Interface'.
17-41-14-206| [ pfac] [ 66.520442] Process pid 884 terminated, status 00000000.
17-41-14-206| [ gm] [ 66.600429] Run sound daemon.
17-41-14-206| [ pfac] [ 66.601179] Run /sbin/rdpsnd 1 0 100 card=2,device=0,hw.
17-41-14-206| [ gm] [ 66.601248] Run '/sbin/rdpsnd 1 0 100 card=2,device=0,hw', log '', env '', pid ''.
17-41-14-206| [ pfac] [ 66.601341] Ok, PID 885.
17-41-14-206| [ gm] [ 66.601393] Run microphone daemon.
17-41-14-206| [ pfac] [ 66.601493] Run /sbin/rdpaudin 0 100 card=2,device=0.
17-41-14-206| [ gm] [ 66.601555] Run '/sbin/rdpaudin 0 100 card=2,device=0', log '', env '', pid ''.
17-41-14-206| [ pfac] [ 66.601659] Ok, PID 886.
17-41-14-206| [ rdpsnd] [ 66.606439] RDP Sound Redirector, WTware 6.0.26/RPi.
17-41-14-206| [ rdpaudin] [ 66.607460] RDP Microphone Redirector, WTware 6.0.26/RPi.
17-41-14-206| [ rdpaudin] [ 66.611175] Card 'Device'/'GeneralPlus USB Audio Device at usb-0000:01:00.0-1.4, full speed'.
17-41-14-206| [ rdpaudin] [ 66.611355] Mixer name: 'USB Mixer'.
17-41-14-206| [ rdpaudin] [ 66.611496] Components: 'USB1b3f:2008'.
17-41-14-206| [ rdpaudin] [ 66.611648] Controls: 10.
17-41-14-206| [ rdpaudin] [ 66.611834] ALSA: control 'Playback Channel Map'.
17-41-14-206| [ rdpaudin] [ 66.612001] ALSA: control 'Capture Channel Map'.
17-41-14-206| [ rdpaudin] [ 66.612148] ALSA: control 'Mic Playback Switch'.
17-41-14-206| [ rdpaudin] [ 66.612343] ALSA: control 'Mic Playback Volume'.
17-41-14-206| [ rdpaudin] [ 66.612488] ALSA: control 'Speaker Playback Switch'.
17-41-14-206| [ rdpaudin] [ 66.612631] ALSA: control 'Speaker Playback Volume'.
17-41-14-206| [ rdpaudin] [ 66.612771] ALSA: control 'Mic Capture Switch'.
17-41-14-206| [ rdpaudin] [ 66.612945] ALSA: control 'Mic Capture Volume'.
17-41-14-206| [ rdpaudin] [ 66.613104] ALSA: control 'Auto Gain Control'.
17-41-14-206| [ rdpaudin] [ 66.613256] ALSA: control 'Keep Interface'.
17-41-14-206| [ gm] [ 66.622513] Run '/sbin/resolver 0x1aa3798 dns [srvrds99.eris.local]', log '', env '', pid ''.
17-41-14-206| [ gm] [ 66.622646] Everyone can control terminal by VNC.
17-41-14-206| [ gm] [ 66.622736] [VNC] Listener at port 5900.
17-41-14-206| [ gm] [ 66.622825] Nobody can control terminal by WTRC.
17-41-14-206| [ pfac] [ 66.623561] Run /sbin/resolver 0x1aa3798 dns [srvrds99.eris.local].
17-41-14-206| [ pfac] [ 66.623799] Ok, PID 887.
17-41-14-206| [ gm] [ 66.629490] srvrds99.eris.local => 172.16.2.104.
17-41-14-206| [ pfac] [ 66.629748] Process pid 887 terminated, status 00000000.
17-41-14-206| [ gm] [ 66.636362] Free ram before fork terminal client /sbin/rdpclient (session 1): 3876524 Kb.
17-41-14-206| [ pfac] [ 66.636423] Run /sbin/rdpclient 1.
17-41-14-206| [ gm] [ 66.636441] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
17-41-14-206| [ pfac] [ 66.636557] Ok, PID 888.
17-41-14-206| [ rdpclient 888] [ 66.641682] RDP Terminal Client, WTware 6.0.26/RPi, pipe 1, pid 888.
17-41-14-206| [ rdpclient 888] [ 66.642007] Use /lib/ui32.so.
17-41-14-206| [ rdpclient 888] [ 66.642806] Redirect sound.
17-41-14-206| [ rdpclient 888] [ 66.643136] Make RDP session with 172.16.2.104, port 3389.
17-41-14-206| [ rdpclient 888] [ 66.643237] No username.
17-41-14-206| [ rdpclient 888] [ 66.643287] No password.
17-41-14-206| [ rdpclient 888] [ 66.643330] No PIN.
17-41-14-206| [ rdpclient 888] [ 66.643370] Domain: "eris.local".
17-41-14-206| [ rdpclient 888] [ 66.643413] No shell.
17-41-14-206| [ rdpclient 888] [ 66.643453] No directory.
17-41-14-206| [ rdpclient 888] [ 66.643494] Window: 1856x1080@24.
17-41-14-206| [ rdpclient 888] [ 66.643537] PFlags 0x0000002F.
17-41-14-206| [ rdpclient 888] [ 66.643576] Keyboard 00000410:00000000.
17-41-14-206| [ rdpclient 888] [ 66.643616] My hostname "TRM-5".
17-41-14-206| [ rdpclient 888] [ 66.643659] TCP: connecting to 172.16.2.104:3389.
17-41-14-206| [ rdpclient 888] [ 66.643927] TCP: connection with 172.16.2.104:3389 established.
17-41-14-206| [ rdpclient 888] [ 66.644030] Turn keepalive on.
17-41-14-206| [ rdpclient 888] [ 66.645144] Free ram after buffers allocation: 3876020 KB.
17-41-14-206| [ rdpclient 888] [ 66.645345] Use Balance Info 48 bytes: 'tsv://MS Terminal Services Plugin.1.RDS_eris'.
17-41-14-206| [ gm] [ 66.806125] Use '/tmp/menu.png'.
17-41-14-214| Connection from wtc.exe at 172.16.2.73.
17-44-14-285| [ rdpclient 888] [ 276.336009] Use Balance Info 48 bytes: 'tsv://MS Terminal Services Plugin.1.RDS_eris'.
17-44-14-285| [ rdpclient 888] [ 276.341805] Server supports GFX Pipeline.
17-44-14-292| [ rdpclient 888] [ 276.341854] NLA.
17-44-14-293| [ rdpclient 888] [ 276.341890] SSL/TLS.
17-44-14-323| [ rdpclient 888] [ 276.422084] Enable font smoothing and Desktop Composition.
17-44-14-397| [ rdpclient 888] [ 276.512192] TS_STATUS_FINDING_DESTINATION
17-44-14-447| [ rdpclient 888] [ 276.538452] TS_STATUS_LOADING_DESTINATION
17-44-14-454| [ rdpclient 888] [ 276.538886] TS_STATUS_REDIRECTING_TO_DESTINATION
17-44-14-499| [ rdpclient 888] [ 276.572787] TS_STATUS_BRINGING_SESSION_ONLINE
17-44-14-506| [ rdpclient 888] [ 276.574210] TS_STATUS_VM_LOADING
17-44-14-549| [ rdpclient 888] [ 276.615018] Server Redirection flags 0x00000b0d.
17-44-14-556| [ rdpclient 888] [ 276.615057] Server 172.16.2.98.
17-44-14-557| [ rdpclient 888] [ 276.615085] User "ced".
17-44-14-563| [ rdpclient 888] [ 276.615113] Domain "eris".
17-44-14-564| [ rdpclient 888] [ 276.615141] Send Disconnect Provider Ultimatum.
17-44-18-715| [ gm] [ 280.830881] TSClient (sessionId 1, pid 888) gracefully end.
17-44-18-724| [ gm] [ 280.831113] Free ram before fork terminal client /sbin/rdpclient (session 2): 3870488 Kb.
17-44-18-725| [ gm] [ 280.831145] Run '/sbin/rdpclient 2', log '/tmp/rdpclient.out', env '', pid ''.
17-44-18-732| [ pfac] [ 280.831173] Run /sbin/rdpclient 2.
17-44-18-732| [ pfac] [ 280.831323] Ok, PID 889.
17-44-18-738| [ rdpsnd] [ 280.831643] Link lost.
17-44-18-739| [ pfac] [ 280.831710] Process pid 888 terminated, status 00000009.
17-44-18-745| [ rdpclient 889] [ 280.836497] RDP Terminal Client, WTware 6.0.26/RPi, pipe 2, pid 889.
17-44-18-746| [ rdpclient 889] [ 280.836825] Use /lib/ui32.so.
17-44-18-754| [ rdpclient 889] [ 280.837185] Redirect sound.
17-44-18-764| [ rdpclient 889] [ 280.837281] Make RDP session with 172.16.2.98, port 3389.
17-44-18-764| [ rdpclient 889] [ 280.837316] Username: "ced".
17-44-18-770| [ rdpclient 889] [ 280.837347] Password: present.
17-44-18-771| [ rdpclient 889] [ 280.837375] No PIN.
17-44-18-777| [ rdpclient 889] [ 280.837403] Domain: "eris".
17-44-18-778| [ rdpclient 889] [ 280.837431] No shell.
17-44-18-787| [ rdpclient 889] [ 280.837458] No directory.
17-44-18-796| [ rdpclient 889] [ 280.837486] Window: 1856x1080@24.
17-44-18-797| [ rdpclient 889] [ 280.837513] PFlags 0x0000002F.
17-44-18-805| [ rdpclient 889] [ 280.837541] Keyboard 00000410:00000000.
17-44-18-805| [ rdpclient 889] [ 280.837568] My hostname "TRM-5".
17-44-18-814| [ rdpclient 889] [ 280.837596] TCP: connecting to 172.16.2.98:3389.
17-44-18-821| [ rdpclient 889] [ 280.837822] TCP: connection with 172.16.2.98:3389 established.
17-44-18-822| [ rdpclient 889] [ 280.837852] Turn keepalive on.
17-44-18-828| [ rdpclient 889] [ 280.838365] Free ram after buffers allocation: 3870472 KB.
17-44-18-829| [ rdpclient 889] [ 280.838401] Empty Balance Info.
17-44-18-836| [ rdpclient 889] [ 280.850474] Server supports GFX Pipeline.
17-44-18-837| [ rdpclient 889] [ 280.850505] Redirected Session ID 0x00000000.
17-44-18-844| [ rdpclient 889] [ 280.852845] Process RDP server certificate.
17-44-18-852| [ rdpclient 889] [ 280.852892] RDP5 encryption (X.509).
17-44-18-853| [ rdpclient 889] [ 280.854812] Enable font smoothing and Desktop Composition.
17-44-19-387| [ rdpclient 889] [ 281.502633] GFX codec.
17-44-19-437| [ rdpclient 889] [ 281.545865] Graphics output buffer 1856x1080, 1 monitors.
17-44-19-444| [ rdpclient 889] [ 281.545916] Monitor 0: 0.0-1855.1079 primary.
