Link to firmware is broken
Posted: Wed Sep 09, 2020 2:48 pm
Driver on this terminal needs firmware. In browser
open the page:
https://wtware.com/fw
Find in the list the file:
brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt
Click on it. Will be downloaded zip archive. Do not unpack
or rename it! Archive must be named:
WTFW_brcm_brcmfmac43455-sdio.raspberrypi,4-model-b.txt.zip
This terminal gets configuration files by network.
To make this terminal download firmware file:
1. Save downloaded archive into 'Everyone' directory on
the server, that this terminal gets configuration files
from. Default path:
C:\ProgramData\WTware\Everyone
2. In terminal configuration file specify:
firmware=WTFW_brcm_brcmfmac43455-sdio.raspberrypi,4-model-b.txt.zip
If there are several firmwares, specify all of them comma separated in a single line:
firmware=file1.zip,file2.zip,file3.zip
brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt <<< the link is broken here comes only a blank page.
All other firmware links are working and a zip file is coming.
