USB mouse stops working till reboot
Posted: Fri May 08, 2020 4:34 pm
by jazzldazzl
Dear All,
I´m on Wtware 5.8.72, and have always faced this issue:
I have a logitech keyboard and mouse set connected with a USB dongle, and sometimes - it can take hours - it just stops working. I see no pattern in when it´s happening, and the only cure is to reboot the raspberry. The keyboard continues to work while this is happening.
Any advise?
Thanks in advance!
Re: USB mouse stops working till reboot
Posted: Sun May 10, 2020 10:40 pm
Wired mouse.
Also, google the same issue for Raspbian. Perhaps, google will tell some magic for kernel command line to write into cmdline.txt
Posted: Wed May 20, 2020 2:01 pm
by jazzldazzl
Thank you both!
I´ll try adding the suggested text, as well as maybe swapping the set for a different model.
Posted: Sat May 23, 2020 1:34 am
by jazzldazzl
Ouch, there was a post here by somebody telling which cmdline.txt command that works great for this, but it´s been removed
Any idea what that was? Didn´t have time to test it yet...
Posted: Sun May 24, 2020 5:45 pm
Human factor. I've deleted
Overmind account by mistake and I can not restore it. Very sad
Perhaps, solution was:
One more workaround: add "usbhid.mousepoll=0" before word "quiet" info cmdline.txt on boot SD.
Posted: Mon May 25, 2020 11:47 am
by jazzldazzl
aka wrote: ↑Sun May 24, 2020 5:45 pm
Ouch yes, that sucks
I already have added usbhid command in cmdline.txt, but not quiet.
Should it look like this:
usbhid.mousepoll=0 quiet
or like this:
usbhid.mousepoll=0
quiet
Thanks in advance!
Posted: Mon May 25, 2020 10:13 pm
First is ok. Second is NOT ok. cmdline.txt is single line.
Posted: Tue May 26, 2020 12:36 pm
by jazzldazzl
aka wrote: ↑Mon May 25, 2020 10:13 pm
Thank you, but that resulted in that after 5 mins I could only move the mouse pointer in the upper left 5 % of the screen..
Posted: Thu May 28, 2020 11:35 am
by Overmind
I'm back
no problem, can happen sometimes
Posted: Thu May 28, 2020 12:32 pm
jazzldazzl wrote: ↑Tue May 26, 2020 12:36 pm
...that resulted in that after 5 mins I could only move the mouse pointer in the upper left 5 % of the screen..
Posted: Fri May 29, 2020 11:29 pm
by jazzldazzl
Thanks all. I´ve now swapped the keyboard and mouse with a different Logitech model, and this seems to have resolved my problems!
