I'm Tired.
SkyWalker3200
I'm Tired.
Post by SkyWalker3200 »
So, after several hours my virtual machine WTWare thin client, and my 2 Raspberry Pi's shows "I'm Tired."
The logs are as follows:
Virtual Machine: https://pastebin.com/taBXSD2h
Raspberry Pi 2: https://pastebin.com/gYyqL2tK
Any help would be appreciated.
Thanks in advance!
Re: I'm Tired.
Something is wrong with our VNC client. Is it easy to reproduce? Which VNC server do you use?
PS: we recommend avoiding VNC if possible. RDP is better.
SkyWalker3200
Re: I'm Tired.
Unfortunately RDP is not an option with our limited resources. I am using UltraVNC Server, as far as the client goes, whatever is built into WTWare.
Re: I'm Tired.
Is it easy to reproduce this error?
SkyWalker3200
Re: I'm Tired.
yes, in my opinion
Re: I'm Tired.
Please, try to reproduce error with this build: http://wtware.com/testing/202004110525.zip
And send me new log.
SkyWalker3200
Re: I'm Tired.
Whenever I go to update WTWare, I get this error... I also get this error when I go to install on a fresh machine.
https://i.imgur.com/vTUKDNM.png
Re: I'm Tired.
I tried to install the build from the link above on virtualbox booting by network and then booting from CD. Both methods work. Please, tell more details: what do you do to get this error?
Also, show me the log. The latest method is in manual, where there is no network on terminal: https://wtware.com/logs.html
SkyWalker3200
Re: I'm Tired.
This is erroring out when I go to install on Virtualbox.
https://i.imgur.com/rA3Q6CQ.png
I've removed the virtual hard drive and attempted it again.
