remote desktop from anywhere
Posted: Sat Mar 28, 2020 4:05 pm
by Yaxlei
I'v installed wtware on my rpi 3b it works perfectly when connected on my home network
for a few days i try to connect from any wifi , 4g sharing, school wifi, so i change the config file to connect to my public ip , i redirect the 3389 port to my pc on my network provider page, i had the firwall rule to this port , i enabled rdp on windows etc...
when i try to connect i set server:XX.XX.XX.XX:3389 i have a tcp/ip connection lost:Network failure ? error , and i don't kow what to do
ty for your answers
Re: remote desktop from anywhere
Posted: Sat Mar 28, 2020 5:03 pm
Posted: Sat Mar 28, 2020 6:04 pm
by Yaxlei
i can't access log through configurator due to the connection problem so i tried to access them directly from my rpi but how can i access command line after the error ? because i can only give you the boot logs not the connection error logs
Posted: Sat Mar 28, 2020 6:05 pm
by Yaxlei
Heres what i got
WTware 5.8.90/RPi supervisor.
[ KERNEL] [ 0.000000] Linux version 4.19.102-v7 (aka@c22) (gcc version 8.3.0 (Debian 8.3.0-2)) #18 SMP Mon Feb 17 08:55:24 UTC 2020
[ KERNEL] [ 0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Rev 1.2
[ KERNEL] [ 0.000000] Normal zone: 1896 pages used for memmap
[ KERNEL] [ 0.000000] Normal zone: 242688 pages, LIFO batch:63
[ KERNEL] [ 0.000000] random: get_random_bytes called from 0x807009cc with crng_init=0
[ KERNEL] [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 240792
[ KERNEL] [ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbdepth=32 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:3B:C5:18 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 quiet wtboot=mmc
[ KERNEL] [ 0.000000] Memory: 942060K/970752K available (5120K kernel code, 134K rwdata, 600K rodata, 5120K init, 349K bss, 20500K reserved, 8192K cma-reserved)
[ KERNEL] [ 0.000000] .text : 0x(ptrval) - 0x(ptrval) (6112 kB)
[ KERNEL] [ 0.000000] .init : 0x(ptrval) - 0x(ptrval) (5120 kB)
[ KERNEL] [ 0.000000] .data : 0x(ptrval) - 0x(ptrval) ( 135 kB)
[ KERNEL] [ 0.000000] .bss : 0x(ptrval) - 0x(ptrval) ( 350 kB)
[ KERNEL] [ 0.000194] Console: colour dummy device 80x30
[ KERNEL] [ 0.000208] console [tty0] enabled
[ KERNEL] [ 0.000245] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ KERNEL] [ 0.000257] pid_max: default: 32768 minimum: 301
[ KERNEL] [ 0.000408] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ KERNEL] [ 0.000421] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ KERNEL] [ 0.001026] CPU: Testing write buffer coherency: ok
[ KERNEL] [ 0.001403] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ KERNEL] [ 0.001856] Setting up static identity map for 0x100000 - 0x10003c
[ KERNEL] [ 0.001965] rcu: Hierarchical SRCU implementation.
[ KERNEL] [ 0.002515] smp: Bringing up secondary CPUs ...
[ KERNEL] [ 0.003133] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ KERNEL] [ 0.003822] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ KERNEL] [ 0.004456] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ KERNEL] [ 0.004546] smp: Brought up 1 node, 4 CPUs
[ KERNEL] [ 0.004555] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ KERNEL] [ 0.004559] CPU: All CPU(s) started in HYP mode.
[ KERNEL] [ 0.004563] CPU: Virtualization extensions available.
[ KERNEL] [ 0.005196] devtmpfs: initialized
[ KERNEL] [ 0.016275] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ KERNEL] [ 0.016610] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ KERNEL] [ 0.016627] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ KERNEL] [ 0.017052] pinctrl core: initialized pinctrl subsystem
[ KERNEL] [ 0.018067] NET: Registered protocol family 16
[ KERNEL] [ 0.020333] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ KERNEL] [ 0.027884] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ KERNEL] [ 0.050038] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-12-11 15:14, variant start
[ KERNEL] [ 0.060043] raspberrypi-firmware soc:firmware: Firmware hash is 44e6357b14365c3029d973dc32956fc5730dc334
[ KERNEL] [ 0.108396] bcm2835-dma 3f007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
[ KERNEL] [ 0.110912] usbcore: registered new interface driver usbfs
[ KERNEL] [ 0.111016] usbcore: registered new interface driver hub
[ KERNEL] [ 0.111103] usbcore: registered new device driver usb
[ KERNEL] [ 0.112846] clocksource: Switched to clocksource arch_sys_counter
[ KERNEL] [ 0.125800] NET: Registered protocol family 2
[ KERNEL] [ 0.126356] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ KERNEL] [ 0.126387] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ KERNEL] [ 0.126495] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ KERNEL] [ 0.126679] TCP: Hash tables configured (established 8192 bind 8192)
[ KERNEL] [ 0.126805] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ KERNEL] [ 0.126850] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ KERNEL] [ 0.127022] NET: Registered protocol family 1
[ KERNEL] [ 2.334820] Initialise system trusted keyrings
[ KERNEL] [ 2.335024] workingset: timestamp_bits=30 max_order=18 bucket_order=0
[ KERNEL] [ 2.392399] Key type asymmetric registered
[ KERNEL] [ 2.392409] Asymmetric key parser 'x509' registered
[ KERNEL] [ 2.392520] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ KERNEL] [ 2.392536] io scheduler noop registered
[ KERNEL] [ 2.392773] io scheduler cfq registered (default)
[ KERNEL] [ 2.397252] bcm2708_fb soc:fb: FB found 1 display(s)
[ KERNEL] [ 2.457890] Console: switching to colour frame buffer device 240x67
[ KERNEL] [ 2.493462] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 1920x1080
[ KERNEL] [ 2.495682] bcm2835-rng 3f104000.rng: hwrng registered
[ KERNEL] [ 2.496107] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ KERNEL] [ 2.496904] vc-sm: Videocore shared memory driver
[ KERNEL] [ 2.497520] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ KERNEL] [ 2.498670] zram: Added device: zram0
[ KERNEL] [ 2.499700] libphy: Fixed MDIO Bus: probed
[ KERNEL] [ 2.499786] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ KERNEL] [ 2.527740] dwc_otg 3f980000.usb: base=(ptrval)
[ KERNEL] [ 2.727959] Core Release: 2.80a
[ KERNEL] [ 2.727971] Setting default values for core params
[ KERNEL] [ 2.727995] Finished setting default values for core params
[ KERNEL] [ 2.928293] Using Buffer DMA mode
[ KERNEL] [ 2.928299] Periodic Transfer Interrupt Enhancement - disabled
[ KERNEL] [ 2.928303] Multiprocessor Interrupt Enhancement - disabled
[ KERNEL] [ 2.928311] OTG VER PARAM: 0, OTG VER FLAG: 0
[ KERNEL] [ 2.928346] Dedicated Tx FIFOs mode
[ KERNEL] [ 2.928925] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = bad04000 dma = 0xfad04000 len=9024
[ KERNEL] [ 2.928951] FIQ FSM acceleration enabled for :
[ KERNEL] [ 2.928951] Non-periodic Split Transactions
[ KERNEL] [ 2.928951] Periodic Split Transactions
[ KERNEL] [ 2.928951] High-Speed Isochronous Endpoints
[ KERNEL] [ 2.928951] Interrupt/Control Split Transaction hack enabled
[ KERNEL] [ 2.928958] dwc_otg: Microframe scheduler enabled
[ KERNEL] [ 2.929008] WARN::hcd_init_fiq:457: FIQ on core 1
[ KERNEL] [ 2.929016] WARN::hcd_init_fiq:458: FIQ ASM at 803b2300 length 36
[ KERNEL] [ 2.929026] WARN::hcd_init_fiq:497: MPHI regs_base at bb810000
[ KERNEL] [ 2.929046] dwc_otg 3f980000.usb: DWC OTG Controller
[ KERNEL] [ 2.929080] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ KERNEL] [ 2.929112] dwc_otg 3f980000.usb: irq 56, io mem 0x00000000
[ KERNEL] [ 2.929160] Init: Port Power? op_state=1
[ KERNEL] [ 2.929165] Init: Power Port (0)
[ KERNEL] [ 2.929357] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ KERNEL] [ 2.929367] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ KERNEL] [ 2.929374] usb usb1: Product: DWC OTG Controller
[ KERNEL] [ 2.929381] usb usb1: Manufacturer: Linux 4.19.102-v7 dwc_otg_hcd
[ KERNEL] [ 2.929389] usb usb1: SerialNumber: 3f980000.usb
[ KERNEL] [ 2.930029] hub 1-0:1.0: USB hub found
[ KERNEL] [ 2.930067] hub 1-0:1.0: 1 port detected
[ KERNEL] [ 2.930780] dwc_otg: FIQ enabled
[ KERNEL] [ 2.930792] dwc_otg: NAK holdoff enabled
[ KERNEL] [ 2.930796] dwc_otg: FIQ split-transaction FSM enabled
[ KERNEL] [ 2.930813] Module dwc_common_port init
[ KERNEL] [ 2.931192] usbcore: registered new interface driver usbtouchscreen
[ KERNEL] [ 2.932263] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ KERNEL] [ 2.932558] bcm2835-cpufreq: min=600000 max=1200000
[ KERNEL] [ 2.933406] sdhci: Secure Digital Host Controller Interface driver
[ KERNEL] [ 2.933414] sdhci: Copyright(c) Pierre Ossman
[ KERNEL] [ 2.934013] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
[ KERNEL] [ 2.934637] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[ KERNEL] [ 2.934779] sdhci-pltfm: SDHCI platform and OF driver helper
[ KERNEL] [ 2.934870] hidraw: raw HID events driver (C) Jiri Kosina
[ KERNEL] [ 2.935493] usbcore: registered new interface driver usbhid
[ KERNEL] [ 2.935498] usbhid: USB HID core driver
[ KERNEL] [ 2.936313] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
[ KERNEL] [ 2.941606] [vc_sm_connected_init]: start
[ KERNEL] [ 2.953177] [vc_sm_connected_init]: end - returning 0
[ KERNEL] [ 2.954075] NET: Registered protocol family 17
[ KERNEL] [ 2.954273] Registering SWP/SWPB emulation handler
[ KERNEL] [ 2.954661] Loading compiled-in X.509 certificates
[ KERNEL] [ 2.957523] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ KERNEL] [ 2.957532] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
[ KERNEL] [ 2.983564] sdhost: log_buf @ (ptrval) (fad07000)
[ KERNEL] [ 3.018996] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ KERNEL] [ 3.020528] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ KERNEL] [ 3.022053] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ KERNEL] [ 3.025124] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ KERNEL] [ 3.030643] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ KERNEL] [ 3.030793] of_cfs_init
[ KERNEL] [ 3.030941] of_cfs_init: OK
[ KERNEL] [ 3.054874] Freeing unused kernel memory: 5120K
[ KERNEL] [ 3.109853] mmc0: host does not support reading read-only switch, assuming write-enable
[ KERNEL] [ 3.111635] mmc0: Problem switching card into high-speed mode!
[ KERNEL] [ 3.112520] mmc0: new SDHC card at address 0001
[ KERNEL] [ 3.113418] mmcblk0: mmc0:0001 00000 14.9 GiB
[ KERNEL] [ 3.115874] mmcblk0: p1
[ KERNEL] [ 3.120640] random: fast init done
[ KERNEL] [ 3.150033] Run /init as init process
[ KERNEL] [ 3.176058] mmc1: new high speed SDIO card at address 0001
[ KERNEL] [ 3.182984] Indeed it is in host mode hprt0 = 00021501
[ KERNEL] [ 3.402895] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ KERNEL] [ 3.403066] Indeed it is in host mode hprt0 = 00001101
[ hotplug] [ 3.412269] Block device 254:0. No action.
[ hotplug] [ 3.417593] Block device 179:0. No action.
[ hotplug] [ 3.417987] Block device 179:1. No action.
[ pfac] [ 3.476179] Run /sbin/initrd.
[ pfac] [ 3.476375] Ok, PID 651.
[ initrd] [ 3.481219] WTware 5.8.90/RPi shell.
[ initrd] [ 3.481627] Load font 'ter-c32b.psf', console 120x33.
[ initrd] [ 3.525044] HDD/MMC/SD boot.
[ initrd] [ 3.525172] No device '/dev/fb1'.
[ KERNEL] [ 3.653127] usb 1-1: New USB device found, idVendor=0424, idProduct=9514, bcdDevice= 2.00
[ KERNEL] [ 3.653141] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ KERNEL] [ 3.653805] hub 1-1:1.0: USB hub found
[ KERNEL] [ 3.653906] hub 1-1:1.0: 5 ports detected
[ KERNEL] [ 3.972884] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ KERNEL] [ 4.103089] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
[ KERNEL] [ 4.103099] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ KERNEL] [ 4.402882] usb 1-1.2: new low-speed USB device number 4 using dwc_otg
[ KERNEL] [ 4.544792] usb 1-1.2: New USB device found, idVendor=1bcf, idProduct=0007, bcdDevice= 0.10
[ KERNEL] [ 4.544802] usb 1-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ KERNEL] [ 4.544810] usb 1-1.2: Product: USB Optical Mouse
[ KERNEL] [ 4.560130] input: USB Optical Mouse Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:1BCF:0007.0001/input/input0
[ KERNEL] [ 4.560651] input: USB Optical Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:1BCF:0007.0001/input/input1
[ KERNEL] [ 4.561433] hid-generic 0003:1BCF:0007.0001: input,hiddev96,hidraw0: USB HID v1.10 Mouse [USB Optical Mouse] on usb-3f980000.usb-1.2/input0
[ KERNEL] [ 4.672875] usb 1-1.3: new full-speed USB device number 5 using dwc_otg
[ KERNEL] [ 4.814541] usb 1-1.3: New USB device found, idVendor=1ea7, idProduct=2002, bcdDevice= 1.03
[ KERNEL] [ 4.814552] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ KERNEL] [ 4.814559] usb 1-1.3: Product: Gaming Keyboard
[ KERNEL] [ 4.814567] usb 1-1.3: Manufacturer: WFDZ
[ KERNEL] [ 4.821168] input: WFDZ Gaming Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:1EA7:2002.0002/input/input2
[ KERNEL] [ 4.883807] hid-generic 0003:1EA7:2002.0002: input,hidraw1: USB HID v1.10 Keyboard [WFDZ Gaming Keyboard] on usb-3f980000.usb-1.3/input0
[ KERNEL] [ 4.913299] input: WFDZ Gaming Keyboard Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:1EA7:2002.0003/input/input3
[ KERNEL] [ 4.913816] input: WFDZ Gaming Keyboard Consumer Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:1EA7:2002.0003/input/input4
[ KERNEL] [ 4.983321] input: WFDZ Gaming Keyboard System Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:1EA7:2002.0003/input/input5
[ KERNEL] [ 4.983965] hid-generic 0003:1EA7:2002.0003: input,hiddev97,hidraw2: USB HID v1.10 Mouse [WFDZ Gaming Keyboard] on usb-3f980000.usb-1.3/input1
[ KERNEL] [ 5.092876] usb 1-1.4: new high-speed USB device number 6 using dwc_otg
[ KERNEL] [ 5.224163] usb 1-1.4: New USB device found, idVendor=1609, idProduct=3a04, bcdDevice= 0.00
[ KERNEL] [ 5.224173] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ KERNEL] [ 5.224181] usb 1-1.4: Product: USB Disk
[ KERNEL] [ 5.224189] usb 1-1.4: Manufacturer: Flash
[ KERNEL] [ 5.224197] usb 1-1.4: SerialNumber: 37271106B481573912681
[ initrd] [ 5.684929] Success: /dev/mmcblk0p1 mounted to /bootmedia.
| #hdmi_safe=1
| disable_overscan=1
| #hdmi_force_hotplug=1
| #hdmi_group=1
| #hdmi_mode=1
| #hdmi_drive=2
| # no display.
| #config_hdmi_boost=4
| #arm_freq=800
| disable_splash=1
| framebuffer_depth=32
| #framebuffer_depth=16
| dtparam=audio=on
| #avoid_warnings=1
| #avoid_warnings=2
| [pi4]
| max_framebuffers=2
| [all]
| #hdmi_group=2
| #hdmi_mode=58
| # 800x600: hdmi_mode=9
| # 1024x768: hdmi_mode=16
| # 1280x1024: hdmi_mode=35
| # 1360x768: hdmi_mode=39
| # 1400x1050: hdmi_mode=42
| # 1440x900: hdmi_mode=47
| # 1600x1200: hdmi_mode=51
| # 1680x1050: hdmi_mode=58
| # 1366x768: hdmi_mode=81
| # 1920x1080: hdmi_mode=82
| # 1920x1200: hdmi_mode=69
| #[HDMI:0]
| # hdmi_group=2
| # hdmi_mode=42
| #[HDMI:1]
| # hdmi_group=2
| # hdmi_mode=58
[ initrd] [ 5.756429] Do not cache package files.
[ initrd] [ 5.756942] WTpassword empty.
[ initrd] [ 5.823830] USB: 1ea7:2002 SHARKOON Technologies GmbH.
[ initrd] [ 5.823967] USB: 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter.
[ initrd] [ 5.824031] USB: 0424:9514 Standard Microsystems Corp. SMC9514 Hub.
[ initrd] [ 5.824088] USB: 1609:3a04 .
[ initrd] [ 5.824159] USB: 1bcf:0007 Sunplus Innovation Technology Inc. Optical Mouse.
[ initrd] [ 5.879411] Start Setup.
[ KERNEL] [ 7.275564] random: crng init done
[ KERNEL] [ 363.612284] SCSI subsystem initialized
[ KERNEL] [ 363.624479] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[ KERNEL] [ 363.624836] scsi host0: usb-storage 1-1.4:1.0
[ KERNEL] [ 363.625471] usbcore: registered new interface driver usb-storage
[ KERNEL] [ 364.633623] scsi 0:0:0:0: Direct-Access Flash USB Disk 6.80 PQ: 0 ANSI: 2
[ KERNEL] [ 364.635239] sd 0:0:0:0: [sda] 7864320 512-byte logical blocks: (4.03 GB/3.75 GiB)
[ KERNEL] [ 364.635569] sd 0:0:0:0: [sda] Write Protect is off
[ KERNEL] [ 364.635585] sd 0:0:0:0: [sda] Mode Sense: 0b 00 00 08
[ KERNEL] [ 364.635837] sd 0:0:0:0: [sda] No Caching mode page found
[ KERNEL] [ 364.635847] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ KERNEL] [ 364.639002] sda: sda1
[ KERNEL] [ 364.641158] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ KERNEL] [ 368.746028] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Posted: Sat Mar 28, 2020 8:26 pm
It's small part of log. Not the full log.
Posted: Sat Mar 28, 2020 9:07 pm
by Yaxlei
Yaxlei wrote: Sat Mar 28, 2020 6:04 pm i can't access log through configurator due to the connection problem so i tried to access them directly from my rpi but how can i access command line after the error ? because i can only give you the boot logs not the connection error logs
Posted: Sun Mar 29, 2020 10:29 am
Command line needed when there is no network. When terminal connected to network, you can read log in web browser from another computer in the same network as Pi.
Posted: Tue Apr 14, 2020 12:40 pm
by Yaxlei
I know where the error comes from, my ip is dynamic this is why i couldn't connect :/ here's another question is it possible to connect through a dns like no-ip ?
Posted: Tue Apr 14, 2020 2:44 pm
The server must have static IP. Client can use dynamic IP. We have never tried a dns like no-ip, but I see no problems with this.
