default error prompt on RDP disconnect
Posted: Mon Jun 04, 2018 4:25 am
by Fraal
Hi team,
When disconnecting a session from a Windows 2016 Session Collection, upon reconnecting the session we are greeted with the below prompt,
wtware default error.PNG (3.15 KiB) Viewed 8987 times
Hitting OK simply removes the prompt, not sure whats causing this?
Cheers!
Re: default error prompt on RDP disconnect
Posted: Mon Jun 04, 2018 11:05 am
Connect to the same server with the same username using mstsc.exe. If prompt appear, it's not related to wtware. Then ask google for solution for mstsc. Looks like some weird application in startup. Never saw this before.
Posted: Tue Jun 05, 2018 4:33 am
by Fraal
Hi akatik,
Thanks for that, it seems it's a mstsc.exe thing and some application, does not occur on clean windows 10 VM's.
Cheers for the clarification!
