rdpclient-vchans.cpp ( 67): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support
Posted: Sat Jan 13, 2018 5:41 pm
by marcostelecom
If user remove the USB speaker (phone) from RPI, they can remote login, but 20 seconds after, the rdp restart, and wtware return to login screen or terminal server name input, without any message to user. :roll:
You know user: you can say: "-never remove the speaker ! " The user will call helpdesk... :lol:
The nontrivial condition is that don't have any USB sound device attached in RPI.
The wtware don't like "sound=on, hw:1:0" wict no HW attached. Maybe put a validation config test, and ajust parameters, before call rdpclient.
I waiting new test version :wink:
When I put the USB sound device, all work (but record device not, yet - other post :mrgreen: )
WTware 5.6.22/RPi supervisor.
[        KERNEL] [    0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  hide_setup quiet
[        KERNEL] [    0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[        KERNEL] [    0.000221] console [tty0] enabled
[        KERNEL] [    0.000251] pid_max: default: 32768 minimum: 301
[        KERNEL] [    0.000383] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[        KERNEL] [    0.000391] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[        KERNEL] [    0.001288] CPU: Testing write buffer coherency: ok
[        KERNEL] [    0.001623] CPU0: update cpu_capacity 1024
[        KERNEL] [    0.001631] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[        KERNEL] [    0.001655] Setting up static identity map for 0x100000 - 0x100034
[        KERNEL] [    0.003168] CPU1: update cpu_capacity 1024
[        KERNEL] [    0.003175] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[        KERNEL] [    0.003725] CPU2: update cpu_capacity 1024
[        KERNEL] [    0.003731] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[        KERNEL] [    0.004276] CPU3: update cpu_capacity 1024
[        KERNEL] [    0.004282] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[        KERNEL] [    0.004359] Brought up 4 CPUs
[        KERNEL] [    0.004369] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[        KERNEL] [    0.004373] CPU: All CPU(s) started in HYP mode.
[        KERNEL] [    0.004376] CPU: Virtualization extensions available.
[        KERNEL] [    0.004913] devtmpfs: initialized
[        KERNEL] [    0.014597] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[        KERNEL] [    0.014978] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[        KERNEL] [    0.014993] futex hash table entries: 1024 (order: 4, 65536 bytes)
[        KERNEL] [    0.015478] pinctrl core: initialized pinctrl subsystem
[        KERNEL] [    0.016010] NET: Registered protocol family 16
[        KERNEL] [    0.017852] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[        KERNEL] [    0.028009] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[        KERNEL] [    0.111166] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb80f000, dmachans=0x1
[        KERNEL] [    0.113500] usbcore: registered new interface driver usbfs
[        KERNEL] [    0.113622] usbcore: registered new interface driver hub
[        KERNEL] [    0.113709] usbcore: registered new device driver usb
[        KERNEL] [    0.120144] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-11-17 15:19
[        KERNEL] [    0.122430] clocksource: Switched to clocksource arch_sys_counter
[        KERNEL] [    0.137346] NET: Registered protocol family 2
[        KERNEL] [    0.137917] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[        KERNEL] [    0.138026] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[        KERNEL] [    0.138210] TCP: Hash tables configured (established 8192 bind 8192)
[        KERNEL] [    0.138296] UDP hash table entries: 512 (order: 2, 16384 bytes)
[        KERNEL] [    0.138337] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[        KERNEL] [    0.138512] NET: Registered protocol family 1
[        KERNEL] [    2.243363] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[        KERNEL] [    2.277660] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[        KERNEL] [    2.277673] io scheduler noop registered
[        KERNEL] [    2.277679] io scheduler deadline registered (default)
[        KERNEL] [    2.287068] BCM2708FB: allocated DMA memory fad10000
[        KERNEL] [    2.287107] BCM2708FB: allocated DMA channel 0 @ bb80f000
[        KERNEL] [    2.318070] Console: switching to colour frame buffer device 240x67
[        KERNEL] [    2.338488] bcm2835-rng 3f104000.rng: hwrng registered
[        KERNEL] [    2.338667] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[        KERNEL] [    2.339592] vc-sm: Videocore shared memory driver
[        KERNEL] [    2.346728] zram: Added device: zram0
[        KERNEL] [    2.346773] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[        KERNEL] [    2.574446] Core Release: 2.80a
[        KERNEL] [    2.574455] Setting default values for core params
[        KERNEL] [    2.574482] Finished setting default values for core params
[        KERNEL] [    2.774830] Using Buffer DMA mode
[        KERNEL] [    2.774836] Periodic Transfer Interrupt Enhancement - disabled
[        KERNEL] [    2.774840] Multiprocessor Interrupt Enhancement - disabled
[        KERNEL] [    2.774845] OTG VER PARAM: 0, OTG VER FLAG: 0
[        KERNEL] [    2.774871] Dedicated Tx FIFOs mode
[        KERNEL] [    2.775415] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xbad04000 dma = 0xfad04000 len=9024
[        KERNEL] [    2.775439] FIQ FSM acceleration enabled for :
[        KERNEL] [    2.775439] Non-periodic Split Transactions
[        KERNEL] [    2.775439] Periodic Split Transactions
[        KERNEL] [    2.775439] High-Speed Isochronous Endpoints
[        KERNEL] [    2.775439] Interrupt/Control Split Transaction hack enabled
[        KERNEL] [    2.775445] dwc_otg: Microframe scheduler enabled
[        KERNEL] [    2.775489] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x80397d28
[        KERNEL] [    2.775498] WARN::hcd_init_fiq:460: FIQ ASM at 0x8039808c length 36
[        KERNEL] [    2.775508] WARN::hcd_init_fiq:486: MPHI regs_base at 0xbb925000
[        KERNEL] [    2.775563] dwc_otg 3f980000.usb: DWC OTG Controller
[        KERNEL] [    2.775594] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[        KERNEL] [    2.775624] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[        KERNEL] [    2.775668] Init: Port Power? op_state=1
[        KERNEL] [    2.775671] Init: Power Port (0)
[        KERNEL] [    2.775847] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[        KERNEL] [    2.775858] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[        KERNEL] [    2.775865] usb usb1: Product: DWC OTG Controller
[        KERNEL] [    2.775872] usb usb1: Manufacturer: Linux 4.9.65 dwc_otg_hcd
[        KERNEL] [    2.775879] usb usb1: SerialNumber: 3f980000.usb
[        KERNEL] [    2.776609] hub 1-0:1.0: USB hub found
[        KERNEL] [    2.776645] hub 1-0:1.0: 1 port detected
[        KERNEL] [    2.777300] dwc_otg: FIQ enabled
[        KERNEL] [    2.777304] dwc_otg: NAK holdoff enabled
[        KERNEL] [    2.777308] dwc_otg: FIQ split-transaction FSM enabled
[        KERNEL] [    2.777321] Module dwc_common_port init
[        KERNEL] [    2.777687] usbcore: registered new interface driver usbtouchscreen
[        KERNEL] [    2.779070] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[        KERNEL] [    2.779542] bcm2835-cpufreq: min=600000 max=1200000
[        KERNEL] [    2.780592] sdhost-bcm2835 3f202000.sdhost: could not get clk, deferring probe
[        KERNEL] [    2.783061] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
[        KERNEL] [    2.785485] ledtrig-cpu: registered to indicate activity on CPUs
[        KERNEL] [    2.785595] hidraw: raw HID events driver (C) Jiri Kosina
[        KERNEL] [    2.786336] usbcore: registered new interface driver usbhid
[        KERNEL] [    2.786341] usbhid: USB HID core driver
[        KERNEL] [    2.788836] vchiq: vchiq_init_state: slot_zero = 0xbad80000, is_master = 0
[        KERNEL] [    2.793693] [vc_sm_connected_init]: start
[        KERNEL] [    2.801008] [vc_sm_connected_init]: end - returning 0
[        KERNEL] [    2.801288] NET: Registered protocol family 17
[        KERNEL] [    2.801428] Registering SWP/SWPB emulation handler
[        KERNEL] [    2.801991] registered taskstats version 1
[        KERNEL] [    2.806201] sdhost: log_buf @ bad07000 (fad07000)
[        KERNEL] [    2.882448] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[        KERNEL] [    2.884561] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[        KERNEL] [    2.884565] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[        KERNEL] [    2.942487] of_cfs_init
[        KERNEL] [    2.942541] of_cfs_init: OK
[        KERNEL] [    2.954440] Freeing unused kernel memory: 5120K
[        KERNEL] [    2.995570] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[        KERNEL] [    2.999565] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[        KERNEL] [    3.001070] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[        KERNEL] [    3.002519] Indeed it is in host mode hprt0 = 00021501
[        KERNEL] [    3.003772] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[        KERNEL] [    3.050972] random: fast init done
[        KERNEL] [    3.114632] mmc1: new high speed SDIO card at address 0001
[        KERNEL] [    3.202472] usb 1-1: new high-speed USB device number 2 using dwc_otg
[        KERNEL] [    3.202616] Indeed it is in host mode hprt0 = 00001101
[       hotplug] [    3.250981] Block device 254:0. No action.
[          pfac] [    3.292186] Run /sbin/initrd.
[          pfac] [    3.292293] Ok, PID 601.
[        initrd] [    3.295332] WTware shell 5.6.22/RPi
[        KERNEL] [    3.432708] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[        KERNEL] [    3.432720] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[        KERNEL] [    3.433524] hub 1-1:1.0: USB hub found
[        KERNEL] [    3.433621] hub 1-1:1.0: 5 ports detected
[        KERNEL] [    3.752467] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[        KERNEL] [    3.882688] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[        KERNEL] [    3.882699] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[        KERNEL] [    3.982466] usb 1-1.2: new low-speed USB device number 4 using dwc_otg
[        KERNEL] [    4.116543] usb 1-1.2: New USB device found, idVendor=2188, idProduct=0ae1
[        KERNEL] [    4.116554] usb 1-1.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[        KERNEL] [    4.116561] usb 1-1.2: Product: USB OPTICAL MOUSE
[        KERNEL] [    4.122021] input: USB OPTICAL MOUSE  as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:2188:0AE1.0001/input/input0
[        KERNEL] [    4.122847] hid-generic 0003:2188:0AE1.0001: input,hidraw0: USB HID v1.11 Mouse [USB OPTICAL MOUSE ] on usb-3f980000.usb-1.2/input0
[        KERNEL] [    4.472466] usb 1-1.3: new low-speed USB device number 5 using dwc_otg
[        KERNEL] [    4.636415] usb 1-1.3: New USB device found, idVendor=1a2c, idProduct=2d23
[        KERNEL] [    4.636426] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[        KERNEL] [    4.636434] usb 1-1.3: Product: USB Keyboard
[        KERNEL] [    4.636441] usb 1-1.3: Manufacturer: USB
[        KERNEL] [    4.647381] input: USB USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:1A2C:2D23.0002/input/input1
[        KERNEL] [    4.713586] hid-generic 0003:1A2C:2D23.0002: input,hidraw1: USB HID v1.10 Keyboard [USB USB Keyboard] on usb-3f980000.usb-1.3/input0
[        KERNEL] [    4.723956] input: USB USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:1A2C:2D23.0003/input/input2
[        KERNEL] [    4.852984] hid-generic 0003:1A2C:2D23.0003: input,hidraw2: USB HID v1.10 Device [USB USB Keyboard] on usb-3f980000.usb-1.3/input1
[        initrd] [    5.280491] Load ethernet drivers.
[        initrd] [    5.284088] modprobe smsc95xx.
[        KERNEL] [    5.293968] smsc95xx v1.0.5
[        KERNEL] [    5.385861] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:aa:fa:2b
[        KERNEL] [    5.386078] usbcore: registered new interface driver smsc95xx
[        KERNEL] [    5.474256] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[        KERNEL] [    7.866307] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
[        initrd] [    9.080162] dhcp: 328 bytes from 10.11.0.30.
[        initrd] [    9.080278] 00000000:0000013400000000001100000A0B001E0A0B00DE004300440134000002010600  ...4...............C.D.4......
[        initrd] [    9.080352] 00000020:67458B6B00000000000000000A0B00DE0A0B001E00000000B827XXXXXXXX0000  gE.k....................'...+..
[        initrd] [    9.080421] 00000040:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [    9.080524] 00000060:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [    9.080595] 00000080:000000000000000073746172742E656C66000000000000000000000000000000  ........start.elf...............
[        initrd] [    9.080664] 000000a0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [    9.080733] 000000c0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [    9.080800] 000000e0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   11.390161] dhcp: 328 bytes from 10.11.0.30.
[        initrd] [   11.390286] 00000000:0000013400000000001100000A0B001E0A0B00DE004300440134000002010600  ...4...............C.D.4......
[        initrd] [   11.390359] 00000020:67458B6B00000000000000000A0B00DE0A0B001E00000000B827XXXXXXXX0000  gE.k....................'...+..
[        initrd] [   11.390428] 00000040:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   11.390500] 00000060:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   11.390569] 00000080:000000000000000073746172742E656C66000000000000000000000000000000  ........start.elf...............
[        initrd] [   11.390640] 000000a0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   11.390707] 000000c0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   11.390780] 000000e0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   11.470085] dhcp: server address 10.11.0.30.
[        initrd] [   11.470162] dhcp: 10.11.0.222/255.255.255.0.
[        initrd] [   11.470234] dhcp: default gateway 10.11.0.30.
[        initrd] [   11.470301] dhcp: DNS 8.8.8.8.
[        initrd] [   11.470368] dhcp: domain test.com.br.
[        initrd] [   11.470433] dhcp: TFTP from 066 10.11.0.30.
[        initrd] [   11.470506] dhcp: TFTP 10.11.0.30.
[        initrd] [   11.470572] Use default TFTP prefix for Raspberry network boot.
[        initrd] [   11.470643] TFTP binary "5.6.22/", configs prefix "", using "/" slash.
[        KERNEL] [   20.752555] random: crng init done
[        initrd] [   21.479258]       diskDevice.cpp (  744): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[        initrd] [   21.479348]          bootWay.cpp (   88): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[        initrd] [   21.479422]          bootWay.cpp (   94): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[        initrd] [   21.479496]           initrd.cpp (  248): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[        initrd] [   21.499522] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
[          pfac] [   21.499952] Run /sbin/httpd.
[          pfac] [   21.500093] Ok, PID 644.
[         httpd] [   21.504767] HTTP Server, WTware 5.6.22/RPi
[        initrd] [   21.610354] USB: 1a2c:2d23 China Resource Semico Co., Ltd.
[        initrd] [   21.610490] USB: 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter.
[        initrd] [   21.610567] USB: 0424:9514 Standard Microsystems Corp. SMC9514 Hub.
[        initrd] [   21.610639] USB: 2188:0ae1 .
[        initrd] [   21.610708] [TFTP] Download config file Everyone/source.wtc from 10.11.0.30.
[        initrd] [   21.613858] [TFTP] It is not WTware5 TFTP server.
[        initrd] [   21.629696] [TFTP] Download config file Everyone/list.wtc from 10.11.0.30.
[        initrd] [   21.639755] [TFTP] Download config file Terminals/B8.27.EB.AA.FA.2B/config.wtc from 10.11.0.30.
| user=usertest
| sound=on, hw:1:0
| skin=Papel
| microphone=on
| server=--new--
| bpp=16
[        initrd] [   21.653251] [TFTP] Download config file Everyone/all.wtc from 10.11.0.30.
| domain=domaintest.local
| keyboard=pt-br
| language=pt-br,default
| skin=sample
| sound=on, hw:1:0
| keyboard=pt-br
| skin=Papel
| sound=on, hw:1:0
| user=usertest
| microphone=on
| server=--new--
| bpp=16
[        initrd] [   21.659738] Hostname: "wtwB827XXXXXXXX".
[         httpd] [   22.004805] Reread settings.
[         httpd] [   22.004945] Everyone can control terminal by HTTP.
[            gm] [   22.009306] WTware session manager 5.6.22/RPi.
[            gm] [   22.010761] Add keyboard event2: USB USB Keyboard.
[            gm] [   22.010851] Add keyboard event1: USB USB Keyboard.
[            gm] [   22.080109] EV_REL flag found. Add mouse event0: USB OPTICAL MOUSE .
[            gm] [   22.080312] Display mode: 1920x1080, 16 bit, landscape, 0 Hz, modeline "", DDC enabled, connector 0.
[            gm] [   22.098838] Framebuffer device found.
[            gm] [   22.098919] LINELENBYTES 3840
[            gm] [   22.098995] VLEN 4147200
[            gm] [   22.118164] Use /lib/ui16.so.
[            gm] [   22.118702] [TFTP] Download config file Graphic/Papel/menu.png from 10.11.0.30.
[            gm] [   22.157209] [TFTP] Download config file Graphic/Papel/popup.png from 10.11.0.30.
[            gm] [   22.165360] [TFTP] Download config file Graphic/Papel/saver.png from 10.11.0.30.
[            gm] [   22.187227] [TFTP] Download config file Graphic/Papel/wait.png from 10.11.0.30.
[            gm] [   22.305303] [TFTP] Download and unpack file 5.6.22/pi2/localboot/packages/pi2-alsa from 10.11.0.30.
[            gm] [   22.904681] modprobe snd-bcm2835.
[            gm] [   22.924626] modprobe snd-usb-audio.
|   0: [ 0]   : control
|  33:        : timer
[        KERNEL] [   22.944947] usbcore: registered new interface driver snd-usb-audio
[            gm] [   22.944432] /dev/snd/pcmC0D1p character device.
[            gm] [   22.944533] /dev/snd/pcmC0D0p character device.
[            gm] [   22.944652] /dev/snd/controlC0 character device.
[            gm] [   22.944761] /dev/snd/timer character device.
[            gm] [   22.944891] Preconfigure ALSA.
[            gm] [   22.944989] Run '/sbin/rdpsnd sndvol 100 100 50', log '', env '', pid ''.
[            gm] [   22.945088] Run sound daemon.
[            gm] [   22.945163] Run '/sbin/rdpsnd 1 0 100 1 0', log '', env '', pid ''.
[            gm] [   22.945239] Run microphone daemon.
[          pfac] [   22.945315] Run /sbin/rdpsnd sndvol 100 100 50.
[            gm] [   22.945360] Run '/sbin/rdpaudin 0 100 1 0', log '', env '', pid ''.
[          pfac] [   22.945519] Ok, PID 672.
[          pfac] [   22.945631] Run /sbin/rdpsnd 1 0 100 1 0.
[          pfac] [   22.945725] Ok, PID 673.
[          pfac] [   22.945800] Run /sbin/rdpaudin 0 100 1 0.
[          pfac] [   22.945919] Ok, PID 674.
[            gm] [   22.949743] Ask server address.
[        sndvol] [   22.956891] Card 'ALSA'/'bcm2835 ALSA'.
[        sndvol] [   22.957019] Mixer name: 'Broadcom Mixer'.
[        sndvol] [   22.957101] Components: ''.
[        sndvol] [   22.957179] Controls: 6.
[        sndvol] [   22.957257] ALSA: control 'PCM Playback Volume'.
[        sndvol] [   22.957340] ALSA: control 'PCM Playback Switch'.
[        sndvol] [   22.957437] ALSA: control 'PCM Playback Route'.
[        sndvol] [   22.957517] ALSA: control 'IEC958 Playback Default'.
[        sndvol] [   22.957595] ALSA: control 'IEC958 Playback Con Mask'.
[        sndvol] [   22.957672] ALSA: control 'IEC958 Playback PCM Stream'.
[        sndvol] [   22.957750] Inactive control IEC958 Playback PCM Stream'.
[          pfac] [   22.958850] Process pid 672 terminated, status 00000000.
[      rdpaudin] [   22.963652] RDP Microphone Redirector, WTware 5.6.22/RPi.
[        rdpsnd] [   22.963971] RDP Sound Redirector, WTware 5.6.22/RPi.
[      rdpaudin] [   22.970201] snd_ctl_open return -2, 'No such file or directory'.
[        rdpsnd] [   22.971946] snd_ctl_open return -2, 'No such file or directory'.
[            gm] [   23.055488] Nobody can control terminal by VNC.
[      rdpaudin] [   23.070536] snd_ctl_open return -2, 'No such file or directory'.
[        rdpsnd] [   23.072419] snd_ctl_open return -2, 'No such file or directory'.
[      rdpaudin] [   23.170701] snd_ctl_open return -2, 'No such file or directory'.
[        rdpsnd] [   23.172667] snd_ctl_open return -2, 'No such file or directory'.
[      rdpaudin] [   23.270813] snd_ctl_open return -2, 'No such file or directory'.
[        rdpsnd] [   23.272866] snd_ctl_open return -2, 'No such file or directory'.
[      rdpaudin] [   23.370949] snd_ctl_open return -2, 'No such file or directory'.
[        rdpsnd] [   23.373065] snd_ctl_open return -2, 'No such file or directory'.
[      rdpaudin] [   23.471083] snd_ctl_open return -2, 'No such file or directory'.
[        rdpsnd] [   23.473263] snd_ctl_open return -2, 'No such file or directory'.
[      rdpaudin] [   23.571326] snd_ctl_open return -2, 'No such file or directory'.
[        rdpsnd] [   23.573564] snd_ctl_open return -2, 'No such file or directory'.
[      rdpaudin] [   23.671544] snd_ctl_open return -2, 'No such file or directory'.
[        rdpsnd] [   23.673909] snd_ctl_open return -2, 'No such file or directory'.
[      rdpaudin] [   23.771775] snd_ctl_open return -2, 'No such file or directory'.
[        rdpsnd] [   23.774266] snd_ctl_open return -2, 'No such file or directory'.
[      rdpaudin] [   23.871984] snd_ctl_open return -2, 'No such file or directory'.
[        rdpsnd] [   23.874619] snd_ctl_open return -2, 'No such file or directory'.
[      rdpaudin] [   23.972208] snd_ctl_open return -2, 'No such file or directory'.
[        rdpsnd] [   23.974969] snd_ctl_open return -2, 'No such file or directory'.
[      rdpaudin] [   24.072427] snd_ctl_open return -2, 'No such file or directory'.
[        rdpsnd] [   24.075320] snd_ctl_open return -2, 'No such file or directory'.
[      rdpaudin] [   24.172644] snd_ctl_open return -2, 'No such file or directory'.
[        rdpsnd] [   24.175670] snd_ctl_open return -2, 'No such file or directory'.
[      rdpaudin] [   24.272866] snd_ctl_open return -2, 'No such file or directory'.
[        rdpsnd] [   24.276022] snd_ctl_open return -2, 'No such file or directory'.
[      rdpaudin] [   24.373078] snd_ctl_open return -2, 'No such file or directory'.
[        rdpsnd] [   24.376376] snd_ctl_open return -2, 'No such file or directory'.
[      rdpaudin] [   24.473309] snd_ctl_open return -2, 'No such file or directory'.
[        rdpsnd] [   24.476730] snd_ctl_open return -2, 'No such file or directory'.
[      rdpaudin] [   24.573527] snd_ctl_open return -2, 'No such file or directory'.
[        rdpsnd] [   24.577081] snd_ctl_open return -2, 'No such file or directory'.
[      rdpaudin] [   24.673746] snd_ctl_open return -2, 'No such file or directory'.
[        rdpsnd] [   24.677429] snd_ctl_open return -2, 'No such file or directory'.
[      rdpaudin] [   24.773975] snd_ctl_open return -2, 'No such file or directory'.
[        rdpsnd] [   24.777785] snd_ctl_open return -2, 'No such file or directory'.
[      rdpaudin] [   24.874198] snd_ctl_open return -2, 'No such file or directory'.
[        rdpsnd] [   24.878140] snd_ctl_open return -2, 'No such file or directory'.
[      rdpaudin] [   24.974412] snd_ctl_open return -2, 'No such file or directory'.
[        rdpsnd] [   24.978528] snd_ctl_open return -2, 'No such file or directory'.
[      rdpaudin] [   25.074627] snd_ctl_open return -2, 'No such file or directory'.
[        rdpsnd] [   25.078876] snd_ctl_open return -2, 'No such file or directory'.
[      rdpaudin] [   25.174851] snd_ctl_open return -2, 'No such file or directory'.
[        rdpsnd] [   25.179222] snd_ctl_open return -2, 'No such file or directory'.
[      rdpaudin] [   25.275063] snd_ctl_open return -2, 'No such file or directory'.
[        rdpsnd] [   25.279565] snd_ctl_open return -2, 'No such file or directory'.
[      rdpaudin] [   25.375303] snd_ctl_open return -2, 'No such file or directory'.
[        rdpsnd] [   25.379912] snd_ctl_open return -2, 'No such file or directory'.
[      rdpaudin] [   25.475517] snd_ctl_open return -2, 'No such file or directory'.
[        rdpsnd] [   25.480242] snd_ctl_open return -2, 'No such file or directory'.
[      rdpaudin] [   25.575735] snd_ctl_open return -2, 'No such file or directory'.
[        rdpsnd] [   25.580583] snd_ctl_open return -2, 'No such file or directory'.
[      rdpaudin] [   25.676049] snd_ctl_open return -2, 'No such file or directory'.
[        rdpsnd] [   25.680978] snd_ctl_open return -2, 'No such file or directory'.
[      rdpaudin] [   25.776274] snd_ctl_open return -2, 'No such file or directory'.
[        rdpsnd] [   25.781204] snd_ctl_open return -2, 'No such file or directory'.
[      rdpaudin] [   25.876493] snd_ctl_open return -2, 'No such file or directory'.
[        rdpsnd] [   25.881428] snd_ctl_open return -2, 'No such file or directory'.
[      rdpaudin] [   25.976626] Caught signal SIGSEGV.
[          pfac] [   25.977328] Process pid 674 terminated, status 00000000.
[        rdpsnd] [   25.982220] Caught signal SIGSEGV.
[          pfac] [   25.982318] Process pid 673 terminated, status 00000000.
[            gm] [   38.257031] Run '/sbin/resolver 0x349d48 dns [192.168.24.74]', log '', env '', pid ''.
[          pfac] [   38.257387] Run /sbin/resolver 0x349d48 dns [192.168.24.74].
[          pfac] [   38.257737] Ok, PID 678.
[          pfac] [   38.261690] Process pid 678 terminated, status 00000000.
[            gm] [   38.263907] 192.168.24.74 => 192.168.24.74.
[            gm] [   38.280382] Free ram before fork terminal client /sbin/rdpclient (session 1): 924688 Kb.
[            gm] [   38.280606] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
[          pfac] [   38.280865] Run /sbin/rdpclient 1.
[          pfac] [   38.281124] Ok, PID 679.
[ rdpclient 679] [   38.288475] RDP Terminal Client, WTware 5.6.22/RPi, pipe 1, pid 679.
[ rdpclient 679] [   38.290142] Use /lib/ui16.so.
[ rdpclient 679] [   38.291341] Redirect sound.
[ rdpclient 679] [   41.292615] rdpclient-rdpsnd.cpp (  572): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ rdpclient 679] [   41.292745] rdpclient-vchans.cpp (   67): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ rdpclient 679] [   41.292829] Make RDP session with 192.168.24.74, port 3389.
[ rdpclient 679] [   41.293030]  Username: "usertest".
[ rdpclient 679] [   41.293114]  No password.
[ rdpclient 679] [   41.293192]  No PIN.
[ rdpclient 679] [   41.293268]  Domain: "domaintest.local".
[ rdpclient 679] [   41.293344]  No shell.
[ rdpclient 679] [   41.293420]  No directory.
[ rdpclient 679] [   41.293495]  Window: 1920x1080@16.
[ rdpclient 679] [   41.293570]  PFlags 0x0000002F.
[ rdpclient 679] [   41.293645]  Keyboard 00000416:00000000.
[ rdpclient 679] [   41.293720]  My hostname "wtwB827XXXXXXXX".
[ rdpclient 679] [   41.293795] TCP: connecting to 192.168.24.74:3389.
[ rdpclient 679] [   41.320032] TCP: connection with 192.168.24.74:3389 established.
[ rdpclient 679] [   41.320124] Turn keepalive on.
[ rdpclient 679] [   41.320903] Free ram after buffers allocation: 924424 KB.
[ rdpclient 679] [   41.564944] Process RDP server certificate.
[ rdpclient 679] [   41.565123] RDP4 encryption.
[ rdpclient 679] [   81.037132] LOGON_EX_LOGONERRORS: ErrorNotificationType 0xfffffffe, ErrorNotificationData 0x00000004.
[ rdpclient 679] [   81.723877] SessionId 0x00000004: DOMAINTEST\administrador.
[ rdpclient 679] [  106.312998] Sound version: 6.
[ rdpclient 679] [  106.313182] ADPCM sound compression.
[ rdpclient 679] [  106.313264] Sound redirection: 44100 frames per second.
[ rdpclient 679] [  106.560656] rdpclient-rdpsnd.cpp (  420): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ rdpclient 679] [  106.560862] Caught signal SIGSEGV.
[          pfac] [  106.563672] Process pid 679 terminated, status 00000000.
[            gm] [  106.563749] Caught signal SIGPIPE.
[            gm] [  106.563829]  TSClientSession.cpp (  346): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[            gm] [  106.564098] Ask server address.
Re: rdpclient-vchans.cpp ( 67): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support
Posted: Sun Jan 14, 2018 11:04 am
Yes!
Mmmm... Yes... Maybe... Sound was written where sound cards were PCI and never disconnected... Sorry, too busy now. That will be done with Bluetooth sound, a bit later.
Posted: Sun Jan 14, 2018 6:53 pm
by marcostelecom
Don't worry. For now, I only test it. I don't have prodution use with sound, until I resolve the audio record remote problem in windows 7. :mrgreen:
If you need beta testing, it will be a pleasure! :)
