set bpp=16; wtware try bpp 24 [SOLVED]
Posted: Thu Jan 11, 2018 12:00 am
by marcostelecom
I have server with limit bpp=16; set bpp=16; but rdpclient try 24, and don't fallback to 16
[ rdpclient 702] [ 41.197995] Window: 1920x1080@24.
WTware 5.6.22/RPi supervisor.
[        KERNEL] [    0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbdepth=32 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  hide_setup quiet
[        KERNEL] [    0.000221] console [tty0] enabled
[        KERNEL] [    0.000237] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[        KERNEL] [    0.000250] pid_max: default: 32768 minimum: 301
[        KERNEL] [    0.000381] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[        KERNEL] [    0.000389] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[        KERNEL] [    0.001231] Disabling memory control group subsystem
[        KERNEL] [    0.001283] CPU: Testing write buffer coherency: ok
[        KERNEL] [    0.001614] CPU0: update cpu_capacity 1024
[        KERNEL] [    0.001622] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[        KERNEL] [    0.001647] Setting up static identity map for 0x100000 - 0x100034
[        KERNEL] [    0.003151] CPU1: update cpu_capacity 1024
[        KERNEL] [    0.003158] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[        KERNEL] [    0.003710] CPU2: update cpu_capacity 1024
[        KERNEL] [    0.003717] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[        KERNEL] [    0.004263] CPU3: update cpu_capacity 1024
[        KERNEL] [    0.004270] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[        KERNEL] [    0.004347] Brought up 4 CPUs
[        KERNEL] [    0.004356] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[        KERNEL] [    0.004360] CPU: All CPU(s) started in HYP mode.
[        KERNEL] [    0.004363] CPU: Virtualization extensions available.
[        KERNEL] [    0.004900] devtmpfs: initialized
[        KERNEL] [    0.014577] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[        KERNEL] [    0.014955] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[        KERNEL] [    0.014971] futex hash table entries: 1024 (order: 4, 65536 bytes)
[        KERNEL] [    0.015455] pinctrl core: initialized pinctrl subsystem
[        KERNEL] [    0.015986] NET: Registered protocol family 16
[        KERNEL] [    0.017825] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[        KERNEL] [    0.027995] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[        KERNEL] [    0.111168] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb80f000, dmachans=0x1
[        KERNEL] [    0.113509] usbcore: registered new interface driver usbfs
[        KERNEL] [    0.113631] usbcore: registered new interface driver hub
[        KERNEL] [    0.113718] usbcore: registered new device driver usb
[        KERNEL] [    0.120147] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-11-17 15:19
[        KERNEL] [    0.122433] clocksource: Switched to clocksource arch_sys_counter
[        KERNEL] [    0.137383] NET: Registered protocol family 2
[        KERNEL] [    0.137957] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[        KERNEL] [    0.138065] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[        KERNEL] [    0.138249] TCP: Hash tables configured (established 8192 bind 8192)
[        KERNEL] [    0.138333] UDP hash table entries: 512 (order: 2, 16384 bytes)
[        KERNEL] [    0.138374] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[        KERNEL] [    0.138549] NET: Registered protocol family 1
[        KERNEL] [    2.243879] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[        KERNEL] [    2.279584] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[        KERNEL] [    2.279595] io scheduler noop registered
[        KERNEL] [    2.279600] io scheduler deadline registered (default)
[        KERNEL] [    2.287644] BCM2708FB: allocated DMA memory fad10000
[        KERNEL] [    2.287692] BCM2708FB: allocated DMA channel 0 @ bb80f000
[        KERNEL] [    2.346745] Console: switching to colour frame buffer device 240x67
[        KERNEL] [    2.384352] bcm2835-rng 3f104000.rng: hwrng registered
[        KERNEL] [    2.384538] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[        KERNEL] [    2.385508] vc-sm: Videocore shared memory driver
[        KERNEL] [    2.391127] zram: Added device: zram0
[        KERNEL] [    2.391184] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[        KERNEL] [    2.618937] Core Release: 2.80a
[        KERNEL] [    2.618946] Setting default values for core params
[        KERNEL] [    2.618975] Finished setting default values for core params
[        KERNEL] [    2.819336] Using Buffer DMA mode
[        KERNEL] [    2.819342] Periodic Transfer Interrupt Enhancement - disabled
[        KERNEL] [    2.819346] Multiprocessor Interrupt Enhancement - disabled
[        KERNEL] [    2.819351] OTG VER PARAM: 0, OTG VER FLAG: 0
[        KERNEL] [    2.819379] Dedicated Tx FIFOs mode
[        KERNEL] [    2.819906] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xbad04000 dma = 0xfad04000 len=9024
[        KERNEL] [    2.819931] FIQ FSM acceleration enabled for :
[        KERNEL] [    2.819931] Non-periodic Split Transactions
[        KERNEL] [    2.819931] Periodic Split Transactions
[        KERNEL] [    2.819931] High-Speed Isochronous Endpoints
[        KERNEL] [    2.819931] Interrupt/Control Split Transaction hack enabled
[        KERNEL] [    2.819938] dwc_otg: Microframe scheduler enabled
[        KERNEL] [    2.819979] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x80397d28
[        KERNEL] [    2.819988] WARN::hcd_init_fiq:460: FIQ ASM at 0x8039808c length 36
[        KERNEL] [    2.819997] WARN::hcd_init_fiq:486: MPHI regs_base at 0xbb925000
[        KERNEL] [    2.820047] dwc_otg 3f980000.usb: DWC OTG Controller
[        KERNEL] [    2.820081] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[        KERNEL] [    2.820110] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[        KERNEL] [    2.820157] Init: Port Power? op_state=1
[        KERNEL] [    2.820161] Init: Power Port (0)
[        KERNEL] [    2.820344] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[        KERNEL] [    2.820354] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[        KERNEL] [    2.820361] usb usb1: Product: DWC OTG Controller
[        KERNEL] [    2.820368] usb usb1: Manufacturer: Linux 4.9.65 dwc_otg_hcd
[        KERNEL] [    2.820375] usb usb1: SerialNumber: 3f980000.usb
[        KERNEL] [    2.821125] hub 1-0:1.0: USB hub found
[        KERNEL] [    2.821172] hub 1-0:1.0: 1 port detected
[        KERNEL] [    2.821874] dwc_otg: FIQ enabled
[        KERNEL] [    2.821880] dwc_otg: NAK holdoff enabled
[        KERNEL] [    2.821884] dwc_otg: FIQ split-transaction FSM enabled
[        KERNEL] [    2.821897] Module dwc_common_port init
[        KERNEL] [    2.822353] usbcore: registered new interface driver usbtouchscreen
[        KERNEL] [    2.823847] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[        KERNEL] [    2.824299] bcm2835-cpufreq: min=600000 max=1200000
[        KERNEL] [    2.825421] sdhost-bcm2835 3f202000.sdhost: could not get clk, deferring probe
[        KERNEL] [    2.827977] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
[        KERNEL] [    2.831352] ledtrig-cpu: registered to indicate activity on CPUs
[        KERNEL] [    2.831589] hidraw: raw HID events driver (C) Jiri Kosina
[        KERNEL] [    2.833257] usbcore: registered new interface driver usbhid
[        KERNEL] [    2.833264] usbhid: USB HID core driver
[        KERNEL] [    2.836702] vchiq: vchiq_init_state: slot_zero = 0xbad80000, is_master = 0
[        KERNEL] [    2.850119] [vc_sm_connected_init]: start
[        KERNEL] [    2.859972] [vc_sm_connected_init]: end - returning 0
[        KERNEL] [    2.860460] NET: Registered protocol family 17
[        KERNEL] [    2.860710] Registering SWP/SWPB emulation handler
[        KERNEL] [    2.861708] registered taskstats version 1
[        KERNEL] [    2.869530] sdhost: log_buf @ bad07000 (fad07000)
[        KERNEL] [    2.942466] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[        KERNEL] [    2.944802] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[        KERNEL] [    2.944811] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[        KERNEL] [    3.022567] of_cfs_init
[        KERNEL] [    3.022661] of_cfs_init: OK
[        KERNEL] [    3.042685] Indeed it is in host mode hprt0 = 00021501
[        KERNEL] [    3.047164] Freeing unused kernel memory: 5120K
[        KERNEL] [    3.131738] mmc0: host does not support reading read-only switch, assuming write-enable
[        KERNEL] [    3.132028] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[        KERNEL] [    3.133573] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[        KERNEL] [    3.135762] mmc0: new high speed SDHC card at address aaaa
[        KERNEL] [    3.136529] mmcblk0: mmc0:aaaa SC32G 29.7 GiB
[        KERNEL] [    3.137314] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[        KERNEL] [    3.140182] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[        KERNEL] [    3.140335] random: fast init done
[        KERNEL] [    3.157969]  mmcblk0: p1 p2
[        KERNEL] [    3.232031] mmc1: new high speed SDIO card at address 0001
[        KERNEL] [    3.252484] usb 1-1: new high-speed USB device number 2 using dwc_otg
[        KERNEL] [    3.252622] Indeed it is in host mode hprt0 = 00001101
[       hotplug] [    3.292719] Block device 254:0. No action.
[       hotplug] [    3.459450] Block device 179:1. No action.
[       hotplug] [    3.459611] Block device 179:0. No action.
[       hotplug] [    3.461898] Block device 179:2. No action.
[          pfac] [    3.465335] Run /sbin/initrd.
[          pfac] [    3.465517] Ok, PID 608.
[        initrd] [    3.468919] WTware shell 5.6.22/RPi
[        KERNEL] [    3.482818] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[        KERNEL] [    3.482828] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[        KERNEL] [    3.503117] hub 1-1:1.0: USB hub found
[        KERNEL] [    3.503242] hub 1-1:1.0: 5 ports detected
[        KERNEL] [    3.822462] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[        KERNEL] [    3.952686] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[        KERNEL] [    3.952697] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[        KERNEL] [    4.052470] usb 1-1.2: new low-speed USB device number 4 using dwc_otg
[        KERNEL] [    4.186494] usb 1-1.2: New USB device found, idVendor=2188, idProduct=0ae1
[        KERNEL] [    4.186505] usb 1-1.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[        KERNEL] [    4.186513] usb 1-1.2: Product: USB OPTICAL MOUSE
[        KERNEL] [    4.192162] input: USB OPTICAL MOUSE  as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:2188:0AE1.0001/input/input0
[        KERNEL] [    4.195220] hid-generic 0003:2188:0AE1.0001: input,hidraw0: USB HID v1.11 Mouse [USB OPTICAL MOUSE ] on usb-3f980000.usb-1.2/input0
[        KERNEL] [    4.292463] usb 1-1.3: new full-speed USB device number 5 using dwc_otg
[        KERNEL] [    4.430241] usb 1-1.3: New USB device found, idVendor=8086, idProduct=0808
[        KERNEL] [    4.430252] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[        KERNEL] [    4.430261] usb 1-1.3: Product: USB PnP Sound Device
[        KERNEL] [    4.430268] usb 1-1.3: Manufacturer: C-Media Electronics Inc.
[        KERNEL] [    4.436702] input: C-Media Electronics Inc.       USB PnP Sound Device as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.3/0003:8086:0808.0002/input/input1
[        KERNEL] [    4.503129] hid-generic 0003:8086:0808.0002: input,hidraw1: USB HID v1.00 Device [C-Media Electronics Inc.       USB PnP Sound Device] on usb-3f980000.usb-1.3/input3
[        KERNEL] [    4.802462] usb 1-1.4: new low-speed USB device number 6 using dwc_otg
[        KERNEL] [    4.947990] usb 1-1.4: New USB device found, idVendor=1a2c, idProduct=2124
[        KERNEL] [    4.948000] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[        KERNEL] [    4.948009] usb 1-1.4: Product: USB Keyboard
[        KERNEL] [    4.948016] usb 1-1.4: Manufacturer: SEM
[        KERNEL] [    4.958306] input: SEM USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:1A2C:2124.0003/input/input2
[        KERNEL] [    5.024028] hid-generic 0003:1A2C:2124.0003: input,hidraw2: USB HID v1.10 Keyboard [SEM USB Keyboard] on usb-3f980000.usb-1.4/input0
[        KERNEL] [    5.034095] input: SEM USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:1A2C:2124.0004/input/input3
[        KERNEL] [    5.113140] hid-generic 0003:1A2C:2124.0004: input,hidraw3: USB HID v1.10 Device [SEM USB Keyboard] on usb-3f980000.usb-1.4/input1
[        initrd] [    5.650516] Load ethernet drivers.
[        initrd] [    5.655420] modprobe smsc95xx.
[        KERNEL] [    5.665602] smsc95xx v1.0.5
[        KERNEL] [    5.758134] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:aa:fa:2b
[        KERNEL] [    5.758444] usbcore: registered new interface driver smsc95xx
[        KERNEL] [    5.844293] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[        KERNEL] [    7.263773] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
[        initrd] [    8.570181] dhcp: 328 bytes from 10.11.0.30.
[        initrd] [    8.570298] 00000000:0000013400000000001100000A0B001E0A0B00DE004300440134000002010600  ...4...............C.D.4......
[        initrd] [    8.570372] 00000020:67458B6B00000000000000000A0B00DE0A0B001E00000000B827XXXXXXXX0000  gE.k....................'...+..
[        initrd] [    8.570442] 00000040:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [    8.570510] 00000060:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [    8.570577] 00000080:000000000000000073746172742E656C66000000000000000000000000000000  ........start.elf...............
[        initrd] [    8.570644] 000000a0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [    8.570712] 000000c0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [    8.570779] 000000e0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        KERNEL] [    9.405006] random: crng init done
[        initrd] [   10.820162] dhcp: 328 bytes from 10.11.0.30.
[        initrd] [   10.820286] 00000000:0000013400000000001100000A0B001E0A0B00DE004300440134000002010600  ...4...............C.D.4......
[        initrd] [   10.820359] 00000020:67458B6B00000000000000000A0B00DE0A0B001E00000000B827XXXXXXXX0000  gE.k....................'...+..
[        initrd] [   10.820428] 00000040:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   10.820496] 00000060:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   10.820563] 00000080:000000000000000073746172742E656C66000000000000000000000000000000  ........start.elf...............
[        initrd] [   10.820630] 000000a0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   10.820697] 000000c0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   10.820764] 000000e0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   10.870091] dhcp: server address 10.11.0.30.
[        initrd] [   10.870165] dhcp: 10.11.0.222/255.255.255.0.
[        initrd] [   10.870233] dhcp: default gateway 10.11.0.30.
[        initrd] [   10.870299] dhcp: DNS 8.8.8.8.
[        initrd] [   10.870365] dhcp: domain test.com.br.
[        initrd] [   10.870430] dhcp: TFTP from 066 10.11.0.30.
[        initrd] [   10.870495] dhcp: TFTP 10.11.0.30.
[        initrd] [   10.870561] Use default TFTP prefix for Raspberry network boot.
[        initrd] [   10.870628] TFTP binary "5.6.22/", configs prefix "", using "/" slash.
[        initrd] [   10.882112] Success: media /dev/mmcblk0p1 mounted to /bootmedia.
[        initrd] [   10.883620] WTpassword present: 4fdd7b466ab915c50d6ab85f84efab8e.
[        initrd] [   10.921280] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
[          pfac] [   10.921411] Run /sbin/httpd.
[          pfac] [   10.922094] Ok, PID 657.
[         httpd] [   10.926703] HTTP Server, WTware 5.6.22/RPi
[        initrd] [   11.035698] USB: 8086:0808 Intel Corp..
[        initrd] [   11.035838] USB: 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter.
[        initrd] [   11.035917] USB: 0424:9514 Standard Microsystems Corp. SMC9514 Hub.
[        initrd] [   11.035989] USB: 1a2c:2124 China Resource Semico Co., Ltd.
[        initrd] [   11.036060] USB: 2188:0ae1 .
[        initrd] [   11.036128] [TFTP] Download config file Everyone/source.wtc from 10.11.0.30.
[        initrd] [   11.039503] [TFTP] It is not WTware5 TFTP server.
[        initrd] [   11.089558] [TFTP] Download config file Everyone/list.wtc from 10.11.0.30.
[        initrd] [   11.095539] [TFTP] Download config file Terminals/B8.27.EB.AA.FA.2B/config.wtc from 10.11.0.30.
| user=usertest
| sound=on, hw:1:0
| skin=Papel
| microphone=on
| server=--new--
| bpp=16
[        initrd] [   11.169050] [TFTP] Download config file Everyone/all.wtc from 10.11.0.30.
| domain=domaintest.local
| keyboard=pt-br
| language=pt-br,default
| skin=sample
| sound=on, hw:1:0
| keyboard=pt-br
| skin=Papel
| sound=on, hw:1:0
| user=usertest
| microphone=on
| server=--new--
| bpp=16
[        initrd] [   11.172087] Hostname: "wtwB827XXXXXXXX".
[         httpd] [   11.451412] Reread settings.
[         httpd] [   11.451541] Everyone can control terminal by HTTP.
[            gm] [   11.451587] WTware session manager 5.6.22/RPi.
[            gm] [   11.451664] Add keyboard event3: SEM USB Keyboard.
[            gm] [   11.451741] Add keyboard event2: SEM USB Keyboard.
[            gm] [   11.451816] Add keyboard event1: C-Media Electronics Inc.       USB PnP Sound Device.
[            gm] [   11.555458] EV_REL flag found. Add mouse event0: USB OPTICAL MOUSE .
[            gm] [   11.555559] Display mode: 1920x1080, 32 bit, landscape, 0 Hz, modeline "", DDC enabled, connector 0.
[            gm] [   11.555716] Framebuffer device found.
[            gm] [   11.555844] LINELENBYTES 7680
[            gm] [   11.555962] VLEN 8294400
[            gm] [   11.592325] Use /lib/ui32.so.
[            gm] [   11.593104] [TFTP] Download config file Graphic/Papel/menu.png from 10.11.0.30.
[            gm] [   11.616624] [TFTP] Download config file Graphic/Papel/popup.png from 10.11.0.30.
[            gm] [   11.622568] [TFTP] Download config file Graphic/Papel/saver.png from 10.11.0.30.
[            gm] [   11.628133] [TFTP] Download config file Graphic/Papel/wait.png from 10.11.0.30.
[            gm] [   11.752769] [TFTP] Download and unpack file 5.6.22/pi2/localboot/packages/pi2-alsa from 10.11.0.30.
[            gm] [   12.383924] modprobe snd-bcm2835.
[            gm] [   12.408452] modprobe snd-usb-audio.
[        KERNEL] [   12.445627] usbcore: registered new interface driver snd-usb-audio
|   0: [ 0]   : control
|  32: [ 1]   : control
|  33:        : timer
[            gm] [   12.445857] /dev/snd/pcmC1D0c character device.
[            gm] [   12.446013] /dev/snd/pcmC1D0p character device.
[            gm] [   12.446128] /dev/snd/controlC1 character device.
[            gm] [   12.446250] /dev/snd/pcmC0D1p character device.
[          pfac] [   12.446356] Run /sbin/rdpsnd sndvol 100 100 50.
[            gm] [   12.446427] /dev/snd/pcmC0D0p character device.
[            gm] [   12.446550] /dev/snd/controlC0 character device.
[          pfac] [   12.446645] Ok, PID 690.
[            gm] [   12.446695] /dev/snd/timer character device.
[          pfac] [   12.446829] Run /sbin/rdpsnd 1 0 100 1 0.
[            gm] [   12.446892] Preconfigure ALSA.
[          pfac] [   12.447008] Ok, PID 691.
[            gm] [   12.447053] Run '/sbin/rdpsnd sndvol 100 100 50', log '', env '', pid ''.
[          pfac] [   12.447131] Run /sbin/rdpaudin 0 100 1 0.
[            gm] [   12.447201] Run sound daemon.
[          pfac] [   12.447307] Ok, PID 692.
[            gm] [   12.447377] Run '/sbin/rdpsnd 1 0 100 1 0', log '', env '', pid ''.
[            gm] [   12.447496] Run microphone daemon.
[            gm] [   12.447607] Run '/sbin/rdpaudin 0 100 1 0', log '', env '', pid ''.
[        rdpsnd] [   12.452059] RDP Sound Redirector, WTware 5.6.22/RPi.
[      rdpaudin] [   12.452353] RDP Microphone Redirector, WTware 5.6.22/RPi.
[        sndvol] [   12.459312] Card 'ALSA'/'bcm2835 ALSA'.
[      rdpaudin] [   12.459409] Card 'Device'/'C-Media Electronics Inc. USB PnP Sound Device at usb-3f980000.usb-1.3, full spe'.
[        sndvol] [   12.459518] Mixer name: 'Broadcom Mixer'.
[      rdpaudin] [   12.459565] Mixer name: 'USB Mixer'.
[        sndvol] [   12.459640] Components: ''.
[      rdpaudin] [   12.459684] Components: 'USB8086:0808'.
[        sndvol] [   12.459758] Controls: 6.
[      rdpaudin] [   12.459799] Controls: 7.
[        sndvol] [   12.459871] ALSA: control 'PCM Playback Volume'.
[      rdpaudin] [   12.459913] ALSA: control 'Playback Channel Map'.
[        sndvol] [   12.459988] ALSA: control 'PCM Playback Switch'.
[      rdpaudin] [   12.460126] ALSA: control 'Capture Channel Map'.
[        sndvol] [   12.460210] ALSA: control 'PCM Playback Route'.
[      rdpaudin] [   12.460288] ALSA: control 'PCM Playback Switch'.
[        sndvol] [   12.460367] ALSA: control 'IEC958 Playback Default'.
[      rdpaudin] [   12.460415] ALSA: control 'PCM Playback Volume'.
[        sndvol] [   12.460490] ALSA: control 'IEC958 Playback Con Mask'.
[      rdpaudin] [   12.460535] ALSA: control 'Mic Capture Switch'.
[        sndvol] [   12.460610] ALSA: control 'IEC958 Playback PCM Stream'.
[      rdpaudin] [   12.460651] ALSA: control 'Mic Capture Volume'.
[        sndvol] [   12.460727] Inactive control IEC958 Playback PCM Stream'.
[        rdpsnd] [   12.460770] Card 'Device'/'C-Media Electronics Inc. USB PnP Sound Device at usb-3f980000.usb-1.3, full spe'.
[        sndvol] [   12.460848] Card 'Device'/'C-Media Electronics Inc. USB PnP Sound Device at usb-3f980000.usb-1.3, full spe'.
[        rdpsnd] [   12.460890] Mixer name: 'USB Mixer'.
[        sndvol] [   12.460964] Mixer name: 'USB Mixer'.
[        rdpsnd] [   12.461006] Components: 'USB8086:0808'.
[        sndvol] [   12.461081] Components: 'USB8086:0808'.
[        rdpsnd] [   12.461123] Controls: 7.
[      rdpaudin] [   12.461163] ALSA: control 'Auto Gain Control'.
[        sndvol] [   12.461236] Controls: 7.
[        rdpsnd] [   12.461277] ALSA: control 'Playback Channel Map'.
[        sndvol] [   12.461351] ALSA: control 'Playback Channel Map'.
[        rdpsnd] [   12.461394] ALSA: control 'Capture Channel Map'.
[        sndvol] [   12.461468] ALSA: control 'Capture Channel Map'.
[        rdpsnd] [   12.461510] ALSA: control 'PCM Playback Switch'.
[        sndvol] [   12.461585] ALSA: control 'PCM Playback Switch'.
[        sndvol] [   12.461660] ALSA: control 'PCM Playback Volume'.
[        sndvol] [   12.462635] ALSA: control 'Mic Capture Switch'.
[        rdpsnd] [   12.462681] ALSA: control 'PCM Playback Volume'.
[        sndvol] [   12.462756] ALSA: control 'Mic Capture Volume'.
[        sndvol] [   12.462831] ALSA: control 'Auto Gain Control'.
[        rdpsnd] [   12.463506] ALSA: control 'Mic Capture Switch'.
[        rdpsnd] [   12.463610] ALSA: control 'Mic Capture Volume'.
[        rdpsnd] [   12.463689] ALSA: control 'Auto Gain Control'.
[          pfac] [   12.465179] Process pid 690 terminated, status 00000000.
[            gm] [   12.504471] Ask server address.
[            gm] [   12.586355] Nobody can control terminal by VNC.
[            gm] [   41.161663] Run '/sbin/resolver 0xa86d48 dns [192.168.24.64]', log '', env '', pid ''.
[          pfac] [   41.161868] Run /sbin/resolver 0xa86d48 dns [192.168.24.64].
[          pfac] [   41.162204] Ok, PID 701.
[          pfac] [   41.167591] Process pid 701 terminated, status 00000000.
[            gm] [   41.174251] 192.168.24.64 => 192.168.24.64.
[            gm] [   41.185796] Free ram before fork terminal client /sbin/rdpclient (session 1): 917740 Kb.
[          pfac] [   41.185952] Run /sbin/rdpclient 1.
[            gm] [   41.185999] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
[          pfac] [   41.186188] Ok, PID 702.
[ rdpclient 702] [   41.194044] RDP Terminal Client, WTware 5.6.22/RPi, pipe 1, pid 702.
[ rdpclient 702] [   41.196307] Use /lib/ui32.so.
[ rdpclient 702] [   41.196493] Redirect sound.
[ rdpclient 702] [   41.197393] Make RDP session with 192.168.24.64, port 3389.
[ rdpclient 702] [   41.197529]  Username: "usertest".
[ rdpclient 702] [   41.197611]  No password.
[ rdpclient 702] [   41.197691]  No PIN.
[ rdpclient 702] [   41.197768]  Domain: "domaintest.local".
[ rdpclient 702] [   41.197846]  No shell.
[ rdpclient 702] [   41.197921]  No directory.
[ rdpclient 702] [   41.198070]  PFlags 0x0000002F.
[ rdpclient 702] [   41.198145]  Keyboard 00000416:00000000.
[ rdpclient 702] [   41.198220]  My hostname "wtwB827XXXXXXXX".
[ rdpclient 702] [   41.198298] TCP: connecting to 192.168.24.64:3389.
[ rdpclient 702] [   42.143405] TCP: connection with 192.168.24.64:3389 established.
[ rdpclient 702] [   42.143556] Turn keepalive on.
[ rdpclient 702] [   42.143636] Free ram after buffers allocation: 916972 KB.
[ rdpclient 702] [   54.045770] Process RDP server certificate.
[ rdpclient 702] [   54.045924] RDP4 encryption.
[            gm] [   54.795966] Kill session 702.
[            gm] [   54.796100] Session terminated.
[            gm] [   54.797674] Final message: Session terminated.
[        rdpsnd] [   54.797785] Link lost.
[          pfac] [   54.798012] Process pid 702 terminated, status 00000009.
[            gm] [   56.796088] Ask server address.
[            gm] [   62.537458] Run '/sbin/resolver 0xa86d48 dns [192.168.20.101]', log '', env '', pid ''.
[          pfac] [   62.537642] Run /sbin/resolver 0xa86d48 dns [192.168.20.101].
[          pfac] [   62.538008] Ok, PID 703.
[          pfac] [   62.543579] Process pid 703 terminated, status 00000000.
[            gm] [   62.549984] 192.168.20.101 => 192.168.20.101.
[            gm] [   62.561678] Free ram before fork terminal client /sbin/rdpclient (session 2): 917236 Kb.
[          pfac] [   62.561840] Run /sbin/rdpclient 2.
[            gm] [   62.561887] Run '/sbin/rdpclient 2', log '/tmp/rdpclient.out', env '', pid ''.
[          pfac] [   62.562072] Ok, PID 704.
[ rdpclient 704] [   62.569686] RDP Terminal Client, WTware 5.6.22/RPi, pipe 2, pid 704.
[ rdpclient 704] [   62.571983] Use /lib/ui32.so.
[ rdpclient 704] [   62.572207] Redirect sound.
[ rdpclient 704] [   62.573230] Make RDP session with 192.168.20.101, port 3389.
[ rdpclient 704] [   62.573379]  Username: "usertest".
[ rdpclient 704] [   62.573462]  No password.
[ rdpclient 704] [   62.573543]  No PIN.
[ rdpclient 704] [   62.573622]  Domain: "domaintest.local".
[ rdpclient 704] [   62.573699]  No shell.
[ rdpclient 704] [   62.573775]  No directory.
[ rdpclient 704] [   62.573853]  Window: 1920x1080@24.
[ rdpclient 704] [   62.573932]  PFlags 0x0000002F.
[ rdpclient 704] [   62.574006]  Keyboard 00000416:00000000.
[ rdpclient 704] [   62.574081]  My hostname "wtwB827XXXXXXXX".
[ rdpclient 704] [   62.574156] TCP: connecting to 192.168.20.101:3389.
[ rdpclient 704] [   63.579174] TCP: connection with 192.168.20.101:3389 established.
[ rdpclient 704] [   63.579324] Turn keepalive on.
[ rdpclient 704] [   63.579405] Free ram after buffers allocation: 916988 KB.
[ rdpclient 704] [   81.402838] Process RDP server certificate.
[ rdpclient 704] [   81.402965] RDP4 encryption.
[ rdpclient 704] [   87.998157] Enable font smoothing.
[ rdpclient 704] [   88.684534] rdpclient-connect.cpp ( 2309): -- ERROR -- 16 24
[ rdpclient 704] [   88.684740]             Server requires 16 bit color depth.
Windows Server is able to work with up to 32 bit color.
But color depth can be limited by this parameter:
 Control Panel => Administrative tools =>
     => Terminal services configuration => RDP-Tcp =>
         => Client Settings => Maximum color depth
Server allows to connect with any color depth only
if this checkbox is turned off.
cmd.exe with Administrator rights =>
  gpedit.msc =>
    Computer Configuration =>
      Administrative Templates =>
        Windows Components =>
          Remote Desktop Services =>
            Remote Desktop Session Host =>
              Remote Session Environment =>
                Limit maximum color depth =>
                  set to Enabled, Color Depth 32 bit.
[            gm] [   88.685305] Final message:             Server requires 16 bit color depth.
  gpedit.msc =>
[        rdpsnd] [   88.686541] Link lost.
[          pfac] [   88.687160] Process pid 704 terminated, status 00000009.
Re: set bpp=16; wtware try bpp 24
Posted: Thu Jan 11, 2018 10:39 am
marcostelecom wrote: Thu Jan 11, 2018 12:00 am I have server with limit bpp=16; set bpp=16; but rdpclient try 24, and don't fallback to 16
Raspberry firmware configures screen resolution and color depth. Read comments in Raspberry firmware config file config.txt on SD.
Re: set bpp=16; wtware try bpp 24 [SOLVED]
Posted: Sat Jan 13, 2018 4:54 pm
by marcostelecom
Yep!
Solved. Thanks ! :D
For information to other users, my SD has only bootload.bin. When using Linux isc-dhcpd + Linux tftp server tftp boot, the config.txt may be in tftpboot dir 8)
Posted: Sat Jan 13, 2018 6:48 pm
marcostelecom wrote: Sat Jan 13, 2018 4:54 pm For information to other users, my SD has only bootload.bin. When unising tftp boot, the config.txt is in tftpboot dir 8)
Only for WTware TFTP:
http://wtware.com/docs5/pinetboot.html
config.txt file
To edit config.txt file, copy it from directory (instead of 5.4.84 specify WTware version you are working with):
C:\Program Files (x86)\WTware\TFTPDROOT\5.4.84\pi2\localboot\
to directory:
C:\ProgramData\WTware\Terminals\{your Pi MAC-address}\
And in terminal directory make changes, needed only for this terminal.
Posted: Sun Jan 14, 2018 7:02 pm
by marcostelecom
Perfect. I edit the information, due use Linux DHCP server + TFTP server
