digital audio capture, aka remote recording
Posted: Tue Jan 09, 2018 5:41 pm
by marcostelecom
I have successful raspberry Pi 3 network boot with linux isc-dhcpd + linux tftp server, using RDP on VM server (vmware).
I use wtware configuration software in windows 10, and sync the wtc config files to tftpboot dir.
I ran the update firmware in raspberry pi, using raspian
But I can't see microphone in wtware rdp - device record.
I already config registry in windows 7, as ref: https://docs.microsoft.com/en-us/vsts/f ... io-capture
The logs say that the audio device is detect OK.
The sound in phone and volume control works well.
I try other sound= and microphone= combinations, without success.
One question: is this correct?
[ gm] [ 11.011491] Add keyboard event1: C-Media Electronics Inc. USB PnP Sound Device.
Keyboard event ? Are there volume control reference?
Well.... help me, please !
My full logs:
WTware 5.6.22/RPi supervisor.
[        KERNEL] [    0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbdepth=32 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  hide_setup quiet
[        KERNEL] [    0.000222] console [tty0] enabled
[        KERNEL] [    0.000252] pid_max: default: 32768 minimum: 301
[        KERNEL] [    0.000384] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[        KERNEL] [    0.000391] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[        KERNEL] [    0.001288] CPU: Testing write buffer coherency: ok
[        KERNEL] [    0.001624] CPU0: update cpu_capacity 1024
[        KERNEL] [    0.001632] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[        KERNEL] [    0.001656] Setting up static identity map for 0x100000 - 0x100034
[        KERNEL] [    0.003169] CPU1: update cpu_capacity 1024
[        KERNEL] [    0.003175] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[        KERNEL] [    0.003726] CPU2: update cpu_capacity 1024
[        KERNEL] [    0.003733] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[        KERNEL] [    0.004278] CPU3: update cpu_capacity 1024
[        KERNEL] [    0.004284] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[        KERNEL] [    0.004362] Brought up 4 CPUs
[        KERNEL] [    0.004371] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[        KERNEL] [    0.004375] CPU: All CPU(s) started in HYP mode.
[        KERNEL] [    0.004378] CPU: Virtualization extensions available.
[        KERNEL] [    0.004915] devtmpfs: initialized
[        KERNEL] [    0.014605] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[        KERNEL] [    0.014986] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[        KERNEL] [    0.015001] futex hash table entries: 1024 (order: 4, 65536 bytes)
[        KERNEL] [    0.015483] pinctrl core: initialized pinctrl subsystem
[        KERNEL] [    0.016015] NET: Registered protocol family 16
[        KERNEL] [    0.017856] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[        KERNEL] [    0.028015] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[        KERNEL] [    0.111144] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb80f000, dmachans=0x1
[        KERNEL] [    0.113478] usbcore: registered new interface driver usbfs
[        KERNEL] [    0.113599] usbcore: registered new interface driver hub
[        KERNEL] [    0.113686] usbcore: registered new device driver usb
[        KERNEL] [    0.120149] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-11-17 15:19
[        KERNEL] [    0.122437] clocksource: Switched to clocksource arch_sys_counter
[        KERNEL] [    0.137418] NET: Registered protocol family 2
[        KERNEL] [    0.137991] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[        KERNEL] [    0.138099] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[        KERNEL] [    0.138283] TCP: Hash tables configured (established 8192 bind 8192)
[        KERNEL] [    0.138367] UDP hash table entries: 512 (order: 2, 16384 bytes)
[        KERNEL] [    0.138408] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[        KERNEL] [    0.138582] NET: Registered protocol family 1
[        KERNEL] [    2.246586] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[        KERNEL] [    2.282384] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[        KERNEL] [    2.282398] io scheduler noop registered
[        KERNEL] [    2.282403] io scheduler deadline registered (default)
[        KERNEL] [    2.293307] BCM2708FB: allocated DMA memory fad10000
[        KERNEL] [    2.293349] BCM2708FB: allocated DMA channel 0 @ bb80f000
[        KERNEL] [    2.352041] Console: switching to colour frame buffer device 240x67
[        KERNEL] [    2.389698] bcm2835-rng 3f104000.rng: hwrng registered
[        KERNEL] [    2.389900] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[        KERNEL] [    2.390780] vc-sm: Videocore shared memory driver
[        KERNEL] [    2.396632] zram: Added device: zram0
[        KERNEL] [    2.396671] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[        KERNEL] [    2.624417] Core Release: 2.80a
[        KERNEL] [    2.624427] Setting default values for core params
[        KERNEL] [    2.624455] Finished setting default values for core params
[        KERNEL] [    2.824822] Using Buffer DMA mode
[        KERNEL] [    2.824828] Periodic Transfer Interrupt Enhancement - disabled
[        KERNEL] [    2.824831] Multiprocessor Interrupt Enhancement - disabled
[        KERNEL] [    2.824839] OTG VER PARAM: 0, OTG VER FLAG: 0
[        KERNEL] [    2.824866] Dedicated Tx FIFOs mode
[        KERNEL] [    2.825333] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xbad04000 dma = 0xfad04000 len=9024
[        KERNEL] [    2.825361] FIQ FSM acceleration enabled for :
[        KERNEL] [    2.825361] Non-periodic Split Transactions
[        KERNEL] [    2.825361] Periodic Split Transactions
[        KERNEL] [    2.825361] High-Speed Isochronous Endpoints
[        KERNEL] [    2.825361] Interrupt/Control Split Transaction hack enabled
[        KERNEL] [    2.825367] dwc_otg: Microframe scheduler enabled
[        KERNEL] [    2.825411] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x80397d28
[        KERNEL] [    2.825420] WARN::hcd_init_fiq:460: FIQ ASM at 0x8039808c length 36
[        KERNEL] [    2.825429] WARN::hcd_init_fiq:486: MPHI regs_base at 0xbb925000
[        KERNEL] [    2.825485] dwc_otg 3f980000.usb: DWC OTG Controller
[        KERNEL] [    2.825519] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[        KERNEL] [    2.825548] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[        KERNEL] [    2.825594] Init: Port Power? op_state=1
[        KERNEL] [    2.825598] Init: Power Port (0)
[        KERNEL] [    2.825784] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[        KERNEL] [    2.825794] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[        KERNEL] [    2.825802] usb usb1: Product: DWC OTG Controller
[        KERNEL] [    2.825809] usb usb1: Manufacturer: Linux 4.9.65 dwc_otg_hcd
[        KERNEL] [    2.825816] usb usb1: SerialNumber: 3f980000.usb
[        KERNEL] [    2.826568] hub 1-0:1.0: USB hub found
[        KERNEL] [    2.826606] hub 1-0:1.0: 1 port detected
[        KERNEL] [    2.827316] dwc_otg: FIQ enabled
[        KERNEL] [    2.827320] dwc_otg: NAK holdoff enabled
[        KERNEL] [    2.827325] dwc_otg: FIQ split-transaction FSM enabled
[        KERNEL] [    2.827340] Module dwc_common_port init
[        KERNEL] [    2.827722] usbcore: registered new interface driver usbtouchscreen
[        KERNEL] [    2.829081] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[        KERNEL] [    2.829587] bcm2835-cpufreq: min=600000 max=1200000
[        KERNEL] [    2.830668] sdhost-bcm2835 3f202000.sdhost: could not get clk, deferring probe
[        KERNEL] [    2.833133] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
[        KERNEL] [    2.835648] ledtrig-cpu: registered to indicate activity on CPUs
[        KERNEL] [    2.835826] hidraw: raw HID events driver (C) Jiri Kosina
[        KERNEL] [    2.836593] usbcore: registered new interface driver usbhid
[        KERNEL] [    2.836601] usbhid: USB HID core driver
[        KERNEL] [    2.837775] vchiq: vchiq_init_state: slot_zero = 0xbad80000, is_master = 0
[        KERNEL] [    2.844890] [vc_sm_connected_init]: start
[        KERNEL] [    2.852742] [vc_sm_connected_init]: end - returning 0
[        KERNEL] [    2.852996] NET: Registered protocol family 17
[        KERNEL] [    2.853159] Registering SWP/SWPB emulation handler
[        KERNEL] [    2.853744] registered taskstats version 1
[        KERNEL] [    2.857874] sdhost: log_buf @ bad07000 (fad07000)
[        KERNEL] [    2.932453] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[        KERNEL] [    2.934573] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[        KERNEL] [    2.934577] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[        KERNEL] [    2.992496] of_cfs_init
[        KERNEL] [    2.992554] of_cfs_init: OK
[        KERNEL] [    3.004816] Freeing unused kernel memory: 5120K
[        KERNEL] [    3.041855] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[        KERNEL] [    3.042552] Indeed it is in host mode hprt0 = 00021501
[        KERNEL] [    3.103532] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[        KERNEL] [    3.105037] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[        KERNEL] [    3.107724] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[        KERNEL] [    3.112617] mmc0: host does not support reading read-only switch, assuming write-enable
[        KERNEL] [    3.116064] mmc0: new high speed SDHC card at address aaaa
[        KERNEL] [    3.116504] mmcblk0: mmc0:aaaa SB32G 29.7 GiB
[        KERNEL] [    3.119033]  mmcblk0: p1 p2
[       hotplug] [    3.118577] Block device 179:2. No action.
[       hotplug] [    3.118745] Block device 179:0. No action.
[        KERNEL] [    3.120961] random: fast init done
[       hotplug] [    3.118908] Block device 179:1. No action.
[        KERNEL] [    3.197306] mmc1: new high speed SDIO card at address 0001
[        KERNEL] [    3.262508] usb 1-1: new high-speed USB device number 2 using dwc_otg
[        KERNEL] [    3.262607] Indeed it is in host mode hprt0 = 00001101
[       hotplug] [    3.299476] Block device 254:0. No action.
[          pfac] [    3.337701] Run /sbin/initrd.
[          pfac] [    3.337757] Ok, PID 609.
[        initrd] [    3.339436] WTware shell 5.6.22/RPi
[        KERNEL] [    3.492592] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[        KERNEL] [    3.492604] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[        KERNEL] [    3.493069] hub 1-1:1.0: USB hub found
[        KERNEL] [    3.493142] hub 1-1:1.0: 5 ports detected
[        KERNEL] [    3.812470] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[        KERNEL] [    3.942711] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[        KERNEL] [    3.942722] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[        KERNEL] [    4.042476] usb 1-1.2: new low-speed USB device number 4 using dwc_otg
[        KERNEL] [    4.176516] usb 1-1.2: New USB device found, idVendor=2188, idProduct=0ae1
[        KERNEL] [    4.176528] usb 1-1.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[        KERNEL] [    4.176535] usb 1-1.2: Product: USB OPTICAL MOUSE
[        KERNEL] [    4.182056] input: USB OPTICAL MOUSE  as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:2188:0AE1.0001/input/input0
[        KERNEL] [    4.182684] hid-generic 0003:2188:0AE1.0001: input,hidraw0: USB HID v1.11 Mouse [USB OPTICAL MOUSE ] on usb-3f980000.usb-1.2/input0
[        KERNEL] [    4.282469] usb 1-1.4: new full-speed USB device number 5 using dwc_otg
[        KERNEL] [    4.420259] usb 1-1.4: New USB device found, idVendor=8086, idProduct=0808
[        KERNEL] [    4.420270] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[        KERNEL] [    4.420278] usb 1-1.4: Product: USB PnP Sound Device
[        KERNEL] [    4.420285] usb 1-1.4: Manufacturer: C-Media Electronics Inc.
[        KERNEL] [    4.425818] input: C-Media Electronics Inc.       USB PnP Sound Device as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.3/0003:8086:0808.0002/input/input1
[        KERNEL] [    4.493006] hid-generic 0003:8086:0808.0002: input,hidraw1: USB HID v1.00 Device [C-Media Electronics Inc.       USB PnP Sound Device] on usb-3f980000.usb-1.4/input3
[        KERNEL] [    4.792467] usb 1-1.5: new low-speed USB device number 6 using dwc_otg
[        KERNEL] [    4.938885] usb 1-1.5: New USB device found, idVendor=1a2c, idProduct=2d23
[        KERNEL] [    4.938896] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[        KERNEL] [    4.938903] usb 1-1.5: Product: USB Keyboard
[        KERNEL] [    4.938910] usb 1-1.5: Manufacturer: USB
[        KERNEL] [    4.949041] input: USB USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.0/0003:1A2C:2D23.0003/input/input2
[        KERNEL] [    5.013736] hid-generic 0003:1A2C:2D23.0003: input,hidraw2: USB HID v1.10 Keyboard [USB USB Keyboard] on usb-3f980000.usb-1.5/input0
[        KERNEL] [    5.023636] input: USB USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.1/0003:1A2C:2D23.0004/input/input3
[        KERNEL] [    5.093073] hid-generic 0003:1A2C:2D23.0004: input,hidraw3: USB HID v1.10 Device [USB USB Keyboard] on usb-3f980000.usb-1.5/input1
[        initrd] [    5.370524] Load ethernet drivers.
[        initrd] [    5.375475] modprobe smsc95xx.
[        KERNEL] [    5.385566] smsc95xx v1.0.5
[        KERNEL] [    5.476902] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:2a:5f:a3
[        KERNEL] [    5.477306] usbcore: registered new interface driver smsc95xx
[        KERNEL] [    5.564335] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[        KERNEL] [    7.007692] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
[        initrd] [    8.260183] dhcp: 328 bytes from 10.11.0.30.
[        initrd] [    8.260303] 00000000:0000013400000000001100000A0B001E0A0B00DD004300440134000002010600  ...4...............C.D.4......
[        initrd] [    8.260377] 00000020:67458B6B00000000000000000A0B00DD0A0B001E00000000B827EB2A5FA30000  gE.k....................'.*_...
[        initrd] [    8.260446] 00000040:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [    8.260514] 00000060:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [    8.260582] 00000080:000000000000000073746172742E656C66000000000000000000000000000000  ........start.elf...............
[        initrd] [    8.260650] 000000a0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [    8.260717] 000000c0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [    8.260785] 000000e0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        KERNEL] [    9.680903] random: crng init done
[        initrd] [   10.520171] dhcp: 328 bytes from 10.11.0.30.
[        initrd] [   10.520298] 00000000:0000013400000000001100000A0B001E0A0B00DD004300440134000002010600  ...4...............C.D.4......
[        initrd] [   10.520370] 00000020:67458B6B00000000000000000A0B00DD0A0B001E00000000B827EB2A5FA30000  gE.k....................'.*_...
[        initrd] [   10.520438] 00000040:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   10.520506] 00000060:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   10.520573] 00000080:000000000000000073746172742E656C66000000000000000000000000000000  ........start.elf...............
[        initrd] [   10.520641] 000000a0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   10.520707] 000000c0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   10.520774] 000000e0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   10.560093] dhcp: server address 10.11.0.30.
[        initrd] [   10.560167] dhcp: 10.11.0.221/255.255.255.0.
[        initrd] [   10.560238] dhcp: default gateway 10.11.0.30.
[        initrd] [   10.560304] dhcp: DNS 8.8.8.8.
[        initrd] [   10.560369] dhcp: domain teste.com.br.
[        initrd] [   10.560434] dhcp: TFTP from 066 10.11.0.30.
[        initrd] [   10.560499] dhcp: TFTP 10.11.0.30.
[        initrd] [   10.560563] Use default TFTP prefix for Raspberry network boot.
[        initrd] [   10.560629] TFTP binary "5.6.22/", configs prefix "", using "/" slash.
[        initrd] [   10.572868] Success: media /dev/mmcblk0p1 mounted to /bootmedia.
[        initrd] [   10.574927] WTpassword present: 4fdd7b466ab915c50d6ab85f.
[        initrd] [   10.612815] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
[          pfac] [   10.613275] Run /sbin/httpd.
[          pfac] [   10.613378] Ok, PID 657.
[         httpd] [   10.618209] HTTP Server, WTware 5.6.22/RPi
[        initrd] [   10.727871] USB: 1a2c:2d23 China Resource Semico Co., Ltd.
[        initrd] [   10.728015] USB: 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter.
[        initrd] [   10.728093] USB: 0424:9514 Standard Microsystems Corp. SMC9514 Hub.
[        initrd] [   10.728165] USB: 8086:0808 Intel Corp..
[        initrd] [   10.728234] USB: 2188:0ae1 .
[        initrd] [   10.728302] [TFTP] Download config file Everyone/source.wtc from 10.11.0.30.
[        initrd] [   10.731582] [TFTP] It is not WTware5 TFTP server.
[        initrd] [   10.735597] [TFTP] Download config file Everyone/list.wtc from 10.11.0.30.
[        initrd] [   10.738504] [TFTP] Download config file Terminals/B8.27.EB.2A.5F.A3/config.wtc from 10.11.0.30.
| user=testuser
| server=192.168.24.96
| sound=on, hw:1:0
| skin=Papel
[        initrd] [   10.741106] [TFTP] Download config file Everyone/all.wtc from 10.11.0.30.
| domain=domaintest.local
| keyboard=pt-br
| language=pt-br,default
| skin=sample
| sound=on, hw:1:0
| keyboard=pt-br
| skin=Papel
| sound=on, hw:1:0
| user=testuser
[        initrd] [   10.744558] Hostname: "wtwB827EBXXXXXX".
[            gm] [   11.009890] WTware session manager 5.6.22/RPi.
[            gm] [   11.011279] Add keyboard event3: USB USB Keyboard.
[            gm] [   11.011371] Add keyboard event2: USB USB Keyboard.
[         httpd] [   11.011448] Reread settings.
[         httpd] [   11.011627] Everyone can control terminal by HTTP.
[            gm] [   11.080116] EV_REL flag found. Add mouse event0: USB OPTICAL MOUSE .
[            gm] [   11.080344] Display mode: 1920x1080, 32 bit, landscape, 0 Hz, modeline "", DDC enabled, connector 0.
[            gm] [   11.115881] Framebuffer device found.
[            gm] [   11.115959] LINELENBYTES 7680
[            gm] [   11.116032] VLEN 8294400
[            gm] [   11.152511] Use /lib/ui32.so.
[            gm] [   11.153149] [TFTP] Download config file Graphic/Papel/menu.png from 10.11.0.30.
[            gm] [   11.166406] [TFTP] Download config file Graphic/Papel/popup.png from 10.11.0.30.
[            gm] [   11.172068] [TFTP] Download config file Graphic/Papel/saver.png from 10.11.0.30.
[            gm] [   11.176756] [TFTP] Download config file Graphic/Papel/wait.png from 10.11.0.30.
[            gm] [   11.303200] [TFTP] Download and unpack file 5.6.22/pi2/localboot/packages/pi2-alsa from 10.11.0.30.
[            gm] [   11.929192] modprobe snd-bcm2835.
[            gm] [   11.948068] modprobe snd-usb-audio.
|   0: [ 0]   : control
|  32: [ 1]   : control
|  33:        : timer
[        KERNEL] [   11.989617] usbcore: registered new interface driver snd-usb-audio
[            gm] [   11.989661] /dev/snd/pcmC1D0c character device.
[            gm] [   11.989808] /dev/snd/pcmC1D0p character device.
[            gm] [   11.989925] /dev/snd/controlC1 character device.
[            gm] [   11.990098] /dev/snd/pcmC0D1p character device.
[          pfac] [   11.990182] Run /sbin/rdpsnd sndvol 100 100 50.
[            gm] [   11.990228] /dev/snd/pcmC0D0p character device.
[            gm] [   11.990301] /dev/snd/controlC0 character device.
[          pfac] [   11.990376] Ok, PID 688.
[            gm] [   11.990423] /dev/snd/timer character device.
[          pfac] [   11.990658] Run /sbin/rdpsnd 1 0 100 1 0.
[            gm] [   11.990762] Preconfigure ALSA.
[          pfac] [   11.990893] Ok, PID 689.
[            gm] [   11.990944] Run '/sbin/rdpsnd sndvol 100 100 50', log '', env '', pid ''.
[            gm] [   11.991047] Run sound daemon.
[            gm] [   11.991154] Run '/sbin/rdpsnd 1 0 100 1 0', log '', env '', pid ''.
[        rdpsnd] [   11.997332] RDP Sound Redirector, WTware 5.6.22/RPi.
[        rdpsnd] [   12.003988] Card 'Device'/'C-Media Electronics Inc. USB PnP Sound Device at usb-3f980000.usb-1.4, full spe'.
[        rdpsnd] [   12.004193] Mixer name: 'USB Mixer'.
[        sndvol] [   12.004279] Card 'ALSA'/'bcm2835 ALSA'.
[        sndvol] [   12.004360] Mixer name: 'Broadcom Mixer'.
[        sndvol] [   12.004473] Components: ''.
[        sndvol] [   12.004553] Controls: 6.
[        sndvol] [   12.004650] ALSA: control 'PCM Playback Volume'.
[        sndvol] [   12.004748] ALSA: control 'PCM Playback Switch'.
[        sndvol] [   12.004829] ALSA: control 'PCM Playback Route'.
[        sndvol] [   12.004907] ALSA: control 'IEC958 Playback Default'.
[        sndvol] [   12.005009] ALSA: control 'IEC958 Playback Con Mask'.
[        sndvol] [   12.005110] ALSA: control 'IEC958 Playback PCM Stream'.
[        sndvol] [   12.005226] Inactive control IEC958 Playback PCM Stream'.
[        sndvol] [   12.005307] Card 'Device'/'C-Media Electronics Inc. USB PnP Sound Device at usb-3f980000.usb-1.4, full spe'.
[        sndvol] [   12.005386] Mixer name: 'USB Mixer'.
[        sndvol] [   12.005484] Components: 'USB8086:0808'.
[        sndvol] [   12.005582] Controls: 7.
[        sndvol] [   12.005668] ALSA: control 'Playback Channel Map'.
[        sndvol] [   12.005770] ALSA: control 'Capture Channel Map'.
[        sndvol] [   12.005867] ALSA: control 'PCM Playback Switch'.
[        sndvol] [   12.005964] ALSA: control 'PCM Playback Volume'.
[        rdpsnd] [   12.006135] Components: 'USB8086:0808'.
[        rdpsnd] [   12.006300] Controls: 7.
[        rdpsnd] [   12.006532] ALSA: control 'Playback Channel Map'.
[        sndvol] [   12.006594] ALSA: control 'Mic Capture Switch'.
[        sndvol] [   12.007029] ALSA: control 'Mic Capture Volume'.
[        rdpsnd] [   12.007221] ALSA: control 'Capture Channel Map'.
[        sndvol] [   12.007403] ALSA: control 'Auto Gain Control'.
[        rdpsnd] [   12.007535] ALSA: control 'PCM Playback Switch'.
[        rdpsnd] [   12.007704] ALSA: control 'PCM Playback Volume'.
[        rdpsnd] [   12.008781] ALSA: control 'Mic Capture Switch'.
[        rdpsnd] [   12.008925] ALSA: control 'Mic Capture Volume'.
[          pfac] [   12.009064] Process pid 688 terminated, status 00000000.
[        rdpsnd] [   12.009111] ALSA: control 'Auto Gain Control'.
[            gm] [   12.056243] Run '/sbin/resolver 0xa37ca0 dns [192.168.24.96]', log '', env '', pid ''.
[          pfac] [   12.056408] Run /sbin/resolver 0xa37ca0 dns [192.168.24.96].
[            gm] [   12.056520] Nobody can control terminal by VNC.
[          pfac] [   12.056694] Ok, PID 690.
[          pfac] [   12.062680] Process pid 690 terminated, status 00000000.
[            gm] [   12.069260] 192.168.24.96 => 192.168.24.96.
[            gm] [   12.081255] Free ram before fork terminal client /sbin/rdpclient (session 1): 920648 Kb.
[          pfac] [   12.081420] Run /sbin/rdpclient 1.
[            gm] [   12.081466] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
[          pfac] [   12.081629] Ok, PID 691.
[ rdpclient 691] [   12.089422] RDP Terminal Client, WTware 5.6.22/RPi, pipe 1, pid 691.
[ rdpclient 691] [   12.091953] Use /lib/ui32.so.
[ rdpclient 691] [   12.092228] Redirect sound.
[ rdpclient 691] [   12.093720] Make RDP session with 192.168.24.96, port 3389.
[ rdpclient 691] [   12.093936]  Username: "testuser".
[ rdpclient 691] [   12.094024]  No password.
[ rdpclient 691] [   12.094109]  No PIN.
[ rdpclient 691] [   12.094190]  Domain: "domaintest.local".
[ rdpclient 691] [   12.094272]  No shell.
[ rdpclient 691] [   12.094353]  No directory.
[ rdpclient 691] [   12.094518]  Window: 1920x1080@24.
[ rdpclient 691] [   12.094640]  PFlags 0x0000002F.
[ rdpclient 691] [   12.094753]  Keyboard 00000416:00000000.
[ rdpclient 691] [   12.094839]  My hostname "wtwB827EBXXXXXX".
[ rdpclient 691] [   12.094919] TCP: connecting to 192.168.24.96:3389.
[ rdpclient 691] [   12.139400] TCP: connection with 192.168.24.96:3389 established.
[ rdpclient 691] [   12.139586] Turn keepalive on.
[ rdpclient 691] [   12.139670] Free ram after buffers allocation: 919840 KB.
[ rdpclient 691] [   12.246202] Process RDP server certificate.
[ rdpclient 691] [   12.246302] RDP4 encryption.
[ rdpclient 691] [   12.613582] Enable font smoothing.
[ rdpclient 691] [   13.493917] 32-bit color.
[ rdpclient 691] [   29.066959] errorInfo 0x00000000.
[ rdpclient 691] [   30.028849] SessionId 0x00000038: DOMAINTEST\testuser.
Re: digital audio capture, aka remote recording
Posted: Tue Jan 09, 2018 7:03 pm
There is no "microphone=on" in this log. Show me log with "microphone=on" after you try to capture sound.
Posted: Tue Jan 09, 2018 11:00 pm
by marcostelecom
The log with "microphone=on" :
play audio in phone, OK; play volume control: OK
I search all "DisableAudioCapture" keys in register, and set to 0 (zero);
see no record devices in windows.
[        KERNEL] [    0.000209] Console: colour dummy device 80x30
[        KERNEL] [    0.000223] console [tty0] enabled
[        KERNEL] [    0.000239] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[        KERNEL] [    0.000253] pid_max: default: 32768 minimum: 301
[        KERNEL] [    0.000392] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[        KERNEL] [    0.001233] Disabling memory control group subsystem
[        KERNEL] [    0.001287] CPU: Testing write buffer coherency: ok
[        KERNEL] [    0.001622] CPU0: update cpu_capacity 1024
[        KERNEL] [    0.001630] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[        KERNEL] [    0.001655] Setting up static identity map for 0x100000 - 0x100034
[        KERNEL] [    0.003164] CPU1: update cpu_capacity 1024
[        KERNEL] [    0.003171] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[        KERNEL] [    0.003720] CPU2: update cpu_capacity 1024
[        KERNEL] [    0.003727] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[        KERNEL] [    0.004272] CPU3: update cpu_capacity 1024
[        KERNEL] [    0.004279] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[        KERNEL] [    0.004357] Brought up 4 CPUs
[        KERNEL] [    0.004367] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[        KERNEL] [    0.004371] CPU: All CPU(s) started in HYP mode.
[        KERNEL] [    0.004374] CPU: Virtualization extensions available.
[        KERNEL] [    0.004911] devtmpfs: initialized
[        KERNEL] [    0.015484] pinctrl core: initialized pinctrl subsystem
[        KERNEL] [    0.016011] NET: Registered protocol family 16
[        KERNEL] [    0.017852] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[        KERNEL] [    0.027999] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[        KERNEL] [    0.111155] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb80f000, dmachans=0x1
[        KERNEL] [    0.113489] usbcore: registered new interface driver usbfs
[        KERNEL] [    0.113611] usbcore: registered new interface driver hub
[        KERNEL] [    0.113697] usbcore: registered new device driver usb
[        KERNEL] [    0.120155] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-11-17 15:19
[        KERNEL] [    0.122457] clocksource: Switched to clocksource arch_sys_counter
[        KERNEL] [    0.137350] NET: Registered protocol family 2
[        KERNEL] [    0.137920] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[        KERNEL] [    0.138028] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[        KERNEL] [    0.138212] TCP: Hash tables configured (established 8192 bind 8192)
[        KERNEL] [    0.138297] UDP hash table entries: 512 (order: 2, 16384 bytes)
[        KERNEL] [    0.138338] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[        KERNEL] [    0.138512] NET: Registered protocol family 1
[        KERNEL] [    2.243585] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[        KERNEL] [    2.279128] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[        KERNEL] [    2.279141] io scheduler noop registered
[        KERNEL] [    2.279146] io scheduler deadline registered (default)
[        KERNEL] [    2.286802] BCM2708FB: allocated DMA memory fad10000
[        KERNEL] [    2.286839] BCM2708FB: allocated DMA channel 0 @ bb80f000
[        KERNEL] [    2.345957] Console: switching to colour frame buffer device 240x67
[        KERNEL] [    2.383435] bcm2835-rng 3f104000.rng: hwrng registered
[        KERNEL] [    2.383641] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[        KERNEL] [    2.384506] vc-sm: Videocore shared memory driver
[        KERNEL] [    2.390542] zram: Added device: zram0
[        KERNEL] [    2.390606] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[        KERNEL] [    2.618373] Core Release: 2.80a
[        KERNEL] [    2.618383] Setting default values for core params
[        KERNEL] [    2.618412] Finished setting default values for core params
[        KERNEL] [    2.818780] Using Buffer DMA mode
[        KERNEL] [    2.818785] Periodic Transfer Interrupt Enhancement - disabled
[        KERNEL] [    2.818788] Multiprocessor Interrupt Enhancement - disabled
[        KERNEL] [    2.818796] OTG VER PARAM: 0, OTG VER FLAG: 0
[        KERNEL] [    2.818825] Dedicated Tx FIFOs mode
[        KERNEL] [    2.819431] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xbad04000 dma = 0xfad04000 len=9024
[        KERNEL] [    2.819456] FIQ FSM acceleration enabled for :
[        KERNEL] [    2.819456] Non-periodic Split Transactions
[        KERNEL] [    2.819456] Periodic Split Transactions
[        KERNEL] [    2.819456] High-Speed Isochronous Endpoints
[        KERNEL] [    2.819456] Interrupt/Control Split Transaction hack enabled
[        KERNEL] [    2.819462] dwc_otg: Microframe scheduler enabled
[        KERNEL] [    2.819508] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x80397d28
[        KERNEL] [    2.819518] WARN::hcd_init_fiq:460: FIQ ASM at 0x8039808c length 36
[        KERNEL] [    2.819528] WARN::hcd_init_fiq:486: MPHI regs_base at 0xbb925000
[        KERNEL] [    2.819584] dwc_otg 3f980000.usb: DWC OTG Controller
[        KERNEL] [    2.819619] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[        KERNEL] [    2.819648] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[        KERNEL] [    2.819695] Init: Port Power? op_state=1
[        KERNEL] [    2.819699] Init: Power Port (0)
[        KERNEL] [    2.819878] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[        KERNEL] [    2.819888] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[        KERNEL] [    2.819896] usb usb1: Product: DWC OTG Controller
[        KERNEL] [    2.819903] usb usb1: Manufacturer: Linux 4.9.65 dwc_otg_hcd
[        KERNEL] [    2.819910] usb usb1: SerialNumber: 3f980000.usb
[        KERNEL] [    2.820654] hub 1-0:1.0: USB hub found
[        KERNEL] [    2.820696] hub 1-0:1.0: 1 port detected
[        KERNEL] [    2.821388] dwc_otg: FIQ enabled
[        KERNEL] [    2.821393] dwc_otg: NAK holdoff enabled
[        KERNEL] [    2.821396] dwc_otg: FIQ split-transaction FSM enabled
[        KERNEL] [    2.821409] Module dwc_common_port init
[        KERNEL] [    2.821807] usbcore: registered new interface driver usbtouchscreen
[        KERNEL] [    2.823352] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[        KERNEL] [    2.823816] bcm2835-cpufreq: min=600000 max=1200000
[        KERNEL] [    2.824898] sdhost-bcm2835 3f202000.sdhost: could not get clk, deferring probe
[        KERNEL] [    2.827314] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
[        KERNEL] [    2.829806] ledtrig-cpu: registered to indicate activity on CPUs
[        KERNEL] [    2.829965] hidraw: raw HID events driver (C) Jiri Kosina
[        KERNEL] [    2.830759] usbcore: registered new interface driver usbhid
[        KERNEL] [    2.830769] usbhid: USB HID core driver
[        KERNEL] [    2.831952] vchiq: vchiq_init_state: slot_zero = 0xbad80000, is_master = 0
[        KERNEL] [    2.839796] [vc_sm_connected_init]: start
[        KERNEL] [    2.847633] [vc_sm_connected_init]: end - returning 0
[        KERNEL] [    2.847925] NET: Registered protocol family 17
[        KERNEL] [    2.848070] Registering SWP/SWPB emulation handler
[        KERNEL] [    2.848588] registered taskstats version 1
[        KERNEL] [    2.853162] sdhost: log_buf @ bad07000 (fad07000)
[        KERNEL] [    2.932482] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[        KERNEL] [    2.934587] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[        KERNEL] [    2.934591] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[        KERNEL] [    3.012535] of_cfs_init
[        KERNEL] [    3.012593] of_cfs_init: OK
[        KERNEL] [    3.026816] Freeing unused kernel memory: 5120K
[        KERNEL] [    3.033833] Indeed it is in host mode hprt0 = 00021501
[        KERNEL] [    3.046363] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[        KERNEL] [    3.047860] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[        KERNEL] [    3.049353] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[        KERNEL] [    3.052044] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[        KERNEL] [    3.062740] mmc0: host does not support reading read-only switch, assuming write-enable
[        KERNEL] [    3.065721] mmc0: new high speed SDHC card at address aaaa
[        KERNEL] [    3.066128] mmcblk0: mmc0:aaaa SC32G 29.7 GiB
[        KERNEL] [    3.096483] random: fast init done
[        KERNEL] [    3.097549]  mmcblk0: p1 p2
[       hotplug] [    3.097101] Block device 179:0. No action.
[       hotplug] [    3.097189] Block device 179:2. No action.
[       hotplug] [    3.097335] Block device 179:1. No action.
[        KERNEL] [    3.142295] mmc1: new high speed SDIO card at address 0001
[        KERNEL] [    3.252500] usb 1-1: new high-speed USB device number 2 using dwc_otg
[        KERNEL] [    3.252646] Indeed it is in host mode hprt0 = 00001101
[       hotplug] [    3.291144] Block device 254:0. No action.
[          pfac] [    3.358099] Run /sbin/initrd.
[          pfac] [    3.358640] Ok, PID 609.
[        initrd] [    3.362061] WTware shell 5.6.22/RPi
[        KERNEL] [    3.492751] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[        KERNEL] [    3.492763] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[        KERNEL] [    3.493523] hub 1-1:1.0: USB hub found
[        KERNEL] [    3.494000] hub 1-1:1.0: 5 ports detected
[        KERNEL] [    3.812486] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[        KERNEL] [    3.942712] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[        KERNEL] [    4.042487] usb 1-1.2: new low-speed USB device number 4 using dwc_otg
[        KERNEL] [    4.176520] usb 1-1.2: New USB device found, idVendor=2188, idProduct=0ae1
[        KERNEL] [    4.176530] usb 1-1.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[        KERNEL] [    4.176538] usb 1-1.2: Product: USB OPTICAL MOUSE
[        KERNEL] [    4.183794] input: USB OPTICAL MOUSE  as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:2188:0AE1.0001/input/input0
[        KERNEL] [    4.184342] hid-generic 0003:2188:0AE1.0001: input,hidraw0: USB HID v1.11 Mouse [USB OPTICAL MOUSE ] on usb-3f980000.usb-1.2/input0
[        KERNEL] [    4.282495] usb 1-1.3: new full-speed USB device number 5 using dwc_otg
[        KERNEL] [    4.420268] usb 1-1.3: New USB device found, idVendor=8086, idProduct=0808
[        KERNEL] [    4.420279] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[        KERNEL] [    4.420287] usb 1-1.3: Product: USB PnP Sound Device
[        KERNEL] [    4.420294] usb 1-1.3: Manufacturer: C-Media Electronics Inc.
[        KERNEL] [    4.425765] input: C-Media Electronics Inc.       USB PnP Sound Device as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.3/0003:8086:0808.0002/input/input1
[        KERNEL] [    4.493001] hid-generic 0003:8086:0808.0002: input,hidraw1: USB HID v1.00 Device [C-Media Electronics Inc.       USB PnP Sound Device] on usb-3f980000.usb-1.3/input3
[        KERNEL] [    4.792492] usb 1-1.4: new low-speed USB device number 6 using dwc_otg
[        KERNEL] [    4.938014] usb 1-1.4: New USB device found, idVendor=1a2c, idProduct=2124
[        KERNEL] [    4.938025] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[        KERNEL] [    4.938032] usb 1-1.4: Product: USB Keyboard
[        KERNEL] [    4.938041] usb 1-1.4: Manufacturer: SEM
[        KERNEL] [    4.949034] input: SEM USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:1A2C:2124.0003/input/input2
[        KERNEL] [    5.073612] hid-generic 0003:1A2C:2124.0003: input,hidraw2: USB HID v1.10 Keyboard [SEM USB Keyboard] on usb-3f980000.usb-1.4/input0
[        KERNEL] [    5.085692] input: SEM USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:1A2C:2124.0004/input/input3
[        KERNEL] [    5.153125] hid-generic 0003:1A2C:2124.0004: input,hidraw3: USB HID v1.10 Device [SEM USB Keyboard] on usb-3f980000.usb-1.4/input1
[        initrd] [    5.510509] Load ethernet drivers.
[        initrd] [    5.515500] modprobe smsc95xx.
[        KERNEL] [    5.525711] smsc95xx v1.0.5
[        KERNEL] [    5.616260] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:aa:fa:2b
[        KERNEL] [    5.616451] usbcore: registered new interface driver smsc95xx
[        KERNEL] [    5.704692] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[        KERNEL] [    7.163892] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
[        initrd] [    8.410179] dhcp: 328 bytes from 10.11.0.30.
[        initrd] [    8.410299] 00000000:0000013400000000001100000A0B001E0A0B00DE004300440134000002010600  ...4...............C.D.4......
[        initrd] [    8.410376] 00000020:67458B6B00000000000000000A0B00DE0A0B001E00000000B827XXXXXXXX0000  gE.k....................'...+..
[        initrd] [    8.410445] 00000040:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [    8.410516] 00000060:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [    8.410584] 00000080:000000000000000073746172742E656C66000000000000000000000000000000  ........start.elf...............
[        initrd] [    8.410653] 000000a0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [    8.410721] 000000c0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [    8.410789] 000000e0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        KERNEL] [    9.671035] random: crng init done
[        initrd] [   10.650170] dhcp: 328 bytes from 10.11.0.30.
[        initrd] [   10.650293] 00000000:0000013400000000001100000A0B001E0A0B00DE004300440134000002010600  ...4...............C.D.4......
[        initrd] [   10.650364] 00000020:67458B6B00000000000000000A0B00DE0A0B001E00000000B827XXXXXXXX0000  gE.k....................'...+..
[        initrd] [   10.650433] 00000040:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   10.650500] 00000060:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   10.650568] 00000080:000000000000000073746172742E656C66000000000000000000000000000000  ........start.elf...............
[        initrd] [   10.650635] 000000a0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   10.650703] 000000c0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   10.650770] 000000e0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   10.700089] dhcp: server address 10.11.0.30.
[        initrd] [   10.700164] dhcp: 10.11.0.222/255.255.255.0.
[        initrd] [   10.700234] dhcp: default gateway 10.11.0.30.
[        initrd] [   10.700301] dhcp: DNS 8.8.8.8.
[        initrd] [   10.700367] dhcp: domain test.com.br.
[        initrd] [   10.700433] dhcp: TFTP from 066 10.11.0.30.
[        initrd] [   10.700499] dhcp: TFTP 10.11.0.30.
[        initrd] [   10.700566] Use default TFTP prefix for Raspberry network boot.
[        initrd] [   10.700633] TFTP binary "5.6.22/", configs prefix "", using "/" slash.
[        initrd] [   10.712359] Success: media /dev/mmcblk0p1 mounted to /bootmedia.
[        initrd] [   10.714249] WTpassword present: 4fdd7b466ab915c50d6ab85f84efab8e.
[        initrd] [   10.752151] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
[          pfac] [   10.752287] Run /sbin/httpd.
[          pfac] [   10.752564] Ok, PID 658.
[         httpd] [   10.757625] HTTP Server, WTware 5.6.22/RPi
[        initrd] [   10.867307] USB: 8086:0808 Intel Corp..
[        initrd] [   10.867461] USB: 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter.
[        initrd] [   10.867540] USB: 0424:9514 Standard Microsystems Corp. SMC9514 Hub.
[        initrd] [   10.867616] USB: 1a2c:2124 China Resource Semico Co., Ltd.
[        initrd] [   10.867687] USB: 2188:0ae1 .
[        initrd] [   10.867757] [TFTP] Download config file Everyone/source.wtc from 10.11.0.30.
[        initrd] [   10.870395] [TFTP] It is not WTware5 TFTP server.
[        initrd] [   10.873867] [TFTP] Download config file Everyone/list.wtc from 10.11.0.30.
[        initrd] [   10.876540] [TFTP] Download config file Terminals/B8.27.EB.AA.FA.2B/config.wtc from 10.11.0.30.
| user=usertest
| sound=on, hw:1:0
| skin=Papel
| microphone=on
[        initrd] [   10.878569] [TFTP] Download config file Everyone/all.wtc from 10.11.0.30.
| keyboard=pt-br
| skin=sample
| sound=on, hw:1:0
| keyboard=pt-br
| skin=Papel
| sound=on, hw:1:0
| user=usertest
| microphone=on
[        initrd] [   10.881922] Hostname: "wtwB827XXXXXXXX".
[         httpd] [   11.155242] Reread settings.
[         httpd] [   11.155545] Everyone can control terminal by HTTP.
[            gm] [   11.159907] WTware session manager 5.6.22/RPi.
[            gm] [   11.161344] Add keyboard event3: SEM USB Keyboard.
[            gm] [   11.161436] Add keyboard event2: SEM USB Keyboard.
[            gm] [   11.161514] Add keyboard event1: C-Media Electronics Inc.       USB PnP Sound Device.
[            gm] [   11.230103] EV_REL flag found. Add mouse event0: USB OPTICAL MOUSE .
[            gm] [   11.230301] Display mode: 1920x1080, 32 bit, landscape, 0 Hz, modeline "", DDC enabled, connector 0.
[            gm] [   11.265782] Framebuffer device found.
[            gm] [   11.265863] LINELENBYTES 7680
[            gm] [   11.265936] VLEN 8294400
[            gm] [   11.302357] Use /lib/ui32.so.
[            gm] [   11.302990] [TFTP] Download config file Graphic/Papel/menu.png from 10.11.0.30.
[            gm] [   11.317306] [TFTP] Download config file Graphic/Papel/popup.png from 10.11.0.30.
[            gm] [   11.322970] [TFTP] Download config file Graphic/Papel/saver.png from 10.11.0.30.
[            gm] [   11.327582] [TFTP] Download config file Graphic/Papel/wait.png from 10.11.0.30.
[            gm] [   11.459963] [TFTP] Download and unpack file 5.6.22/pi2/localboot/packages/pi2-alsa from 10.11.0.30.
[            gm] [   12.082994] modprobe snd-bcm2835.
[            gm] [   12.103544] modprobe snd-usb-audio.
[        KERNEL] [   12.143559] usbcore: registered new interface driver snd-usb-audio
|   0: [ 0]   : control
|  32: [ 1]   : control
|  33:        : timer
[            gm] [   12.143898] /dev/snd/pcmC1D0c character device.
[            gm] [   12.143992] /dev/snd/pcmC1D0p character device.
[            gm] [   12.144089] /dev/snd/controlC1 character device.
[            gm] [   12.144174] /dev/snd/pcmC0D1p character device.
[            gm] [   12.144275] /dev/snd/pcmC0D0p character device.
[            gm] [   12.144359] /dev/snd/controlC0 character device.
[            gm] [   12.144435] /dev/snd/timer character device.
[            gm] [   12.144512] Preconfigure ALSA.
[            gm] [   12.144596] Run '/sbin/rdpsnd sndvol 100 100 50', log '', env '', pid ''.
[          pfac] [   12.144673] Run /sbin/rdpsnd sndvol 100 100 50.
[            gm] [   12.144718] Run sound daemon.
[            gm] [   12.144792] Run '/sbin/rdpsnd 1 0 100 1 0', log '', env '', pid ''.
[            gm] [   12.144876] Run microphone daemon.
[          pfac] [   12.144996] Ok, PID 689.
[            gm] [   12.145068] Run '/sbin/rdpaudin 0 100 1 0', log '', env '', pid ''.
[          pfac] [   12.145171] Run /sbin/rdpsnd 1 0 100 1 0.
[          pfac] [   12.145254] Ok, PID 690.
[          pfac] [   12.145354] Run /sbin/rdpaudin 0 100 1 0.
[          pfac] [   12.145432] Ok, PID 691.
[        sndvol] [   12.160391] Card 'ALSA'/'bcm2835 ALSA'.
[        sndvol] [   12.160549] Mixer name: 'Broadcom Mixer'.
[        rdpsnd] [   12.160594] RDP Sound Redirector, WTware 5.6.22/RPi.
[        sndvol] [   12.160676] Components: ''.
[        sndvol] [   12.160756] Controls: 6.
[        sndvol] [   12.160836] ALSA: control 'PCM Playback Volume'.
[        sndvol] [   12.160915] ALSA: control 'PCM Playback Switch'.
[        sndvol] [   12.160997] ALSA: control 'PCM Playback Route'.
[        sndvol] [   12.161077] ALSA: control 'IEC958 Playback Default'.
[        sndvol] [   12.161156] ALSA: control 'IEC958 Playback Con Mask'.
[        sndvol] [   12.161237] ALSA: control 'IEC958 Playback PCM Stream'.
[        sndvol] [   12.161316] Inactive control IEC958 Playback PCM Stream'.
[        sndvol] [   12.161397] Card 'Device'/'C-Media Electronics Inc. USB PnP Sound Device at usb-3f980000.usb-1.3, full spe'.
[        sndvol] [   12.161480] Mixer name: 'USB Mixer'.
[        sndvol] [   12.161557] Components: 'USB8086:0808'.
[        sndvol] [   12.161637] Controls: 7.
[        sndvol] [   12.161714] ALSA: control 'Playback Channel Map'.
[        sndvol] [   12.161792] ALSA: control 'Capture Channel Map'.
[        sndvol] [   12.161871] ALSA: control 'PCM Playback Switch'.
[        sndvol] [   12.161950] ALSA: control 'PCM Playback Volume'.
[        sndvol] [   12.162030] ALSA: control 'Mic Capture Switch'.
[        sndvol] [   12.162127] ALSA: control 'Mic Capture Volume'.
[        sndvol] [   12.162206] ALSA: control 'Auto Gain Control'.
[      rdpaudin] [   12.162489] RDP Microphone Redirector, WTware 5.6.22/RPi.
[          pfac] [   12.169603] Process pid 689 terminated, status 00000000.
[      rdpaudin] [   12.169693] Card 'Device'/'C-Media Electronics Inc. USB PnP Sound Device at usb-3f980000.usb-1.3, full spe'.
[        rdpsnd] [   12.169741] Card 'Device'/'C-Media Electronics Inc. USB PnP Sound Device at usb-3f980000.usb-1.3, full spe'.
[      rdpaudin] [   12.169838] Mixer name: 'USB Mixer'.
[        rdpsnd] [   12.169882] Mixer name: 'USB Mixer'.
[      rdpaudin] [   12.169962] Components: 'USB8086:0808'.
[        rdpsnd] [   12.170047] Components: 'USB8086:0808'.
[      rdpaudin] [   12.170140] Controls: 7.
[        rdpsnd] [   12.170183] Controls: 7.
[      rdpaudin] [   12.170271] ALSA: control 'Playback Channel Map'.
[        rdpsnd] [   12.170315] ALSA: control 'Playback Channel Map'.
[      rdpaudin] [   12.170395] ALSA: control 'Capture Channel Map'.
[        rdpsnd] [   12.170438] ALSA: control 'Capture Channel Map'.
[      rdpaudin] [   12.170515] ALSA: control 'PCM Playback Switch'.
[        rdpsnd] [   12.170559] ALSA: control 'PCM Playback Switch'.
[      rdpaudin] [   12.170635] ALSA: control 'PCM Playback Volume'.
[        rdpsnd] [   12.170677] ALSA: control 'PCM Playback Volume'.
[      rdpaudin] [   12.170754] ALSA: control 'Mic Capture Switch'.
[        rdpsnd] [   12.170798] ALSA: control 'Mic Capture Switch'.
[      rdpaudin] [   12.170884] ALSA: control 'Mic Capture Volume'.
[        rdpsnd] [   12.170945] ALSA: control 'Mic Capture Volume'.
[      rdpaudin] [   12.171023] ALSA: control 'Auto Gain Control'.
[        rdpsnd] [   12.171065] ALSA: control 'Auto Gain Control'.
[            gm] [   12.226440] Run '/sbin/resolver 0x16efce0 dns [192.168.24.96]', log '', env '', pid ''.
[          pfac] [   12.226605] Run /sbin/resolver 0x16efce0 dns [192.168.24.96].
[          pfac] [   12.226898] Ok, PID 692.
[            gm] [   12.227009] Nobody can control terminal by VNC.
[          pfac] [   12.232343] Process pid 692 terminated, status 00000000.
[            gm] [   12.238797] 192.168.24.96 => 192.168.24.96.
[            gm] [   12.250599] Free ram before fork terminal client /sbin/rdpclient (session 1): 920060 Kb.
[          pfac] [   12.250765] Run /sbin/rdpclient 1.
[            gm] [   12.250810] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
[          pfac] [   12.251019] Ok, PID 693.
[ rdpclient 693] [   12.258424] RDP Terminal Client, WTware 5.6.22/RPi, pipe 1, pid 693.
[ rdpclient 693] [   12.259867] Use /lib/ui32.so.
[ rdpclient 693] [   12.261280] Redirect sound.
[ rdpclient 693] [   12.261543] Make RDP session with 192.168.24.96, port 3389.
[ rdpclient 693] [   12.261643]  Username: "usertest".
[ rdpclient 693] [   12.261728]  No password.
[ rdpclient 693] [   12.261805]  No PIN.
[ rdpclient 693] [   12.261883]  Domain: "domaintest.local".
[ rdpclient 693] [   12.262044]  No shell.
[ rdpclient 693] [   12.262129]  No directory.
[ rdpclient 693] [   12.262207]  Window: 1920x1080@24.
[ rdpclient 693] [   12.262291]  PFlags 0x0000002F.
[ rdpclient 693] [   12.262370]  Keyboard 00000416:00000000.
[ rdpclient 693] [   12.262453]  My hostname "wtwB827XXXXXXXX".
[ rdpclient 693] [   12.262537] TCP: connecting to 192.168.24.96:3389.
[ rdpclient 693] [   12.312214] TCP: connection with 192.168.24.96:3389 established.
[ rdpclient 693] [   12.312359] Turn keepalive on.
[ rdpclient 693] [   12.313157] Free ram after buffers allocation: 919672 KB.
[ rdpclient 693] [   12.489928] Process RDP server certificate.
[ rdpclient 693] [   12.490125] RDP4 encryption.
[ rdpclient 693] [   12.959870] Enable font smoothing.
[ rdpclient 693] [   13.996242] 32-bit color.
[ rdpclient 693] [   45.106272] errorInfo 0x00000000.
[ rdpclient 693] [   45.251234] SessionId 0x00000042: DOMAINTEST\usertest.
Posted: Wed Jan 10, 2018 1:37 pm
The logs say that the audio device is detected OK.
Have you got microphone redirection connecting with mstsc.exe from another windows machine to the same server 192.168.24.96?
Posted: Wed Jan 10, 2018 9:06 pm
by marcostelecom
HUmmm... Don't work...
How can I access the log /tmp/rdpclient.out
ssh access ?
I see that
rsh ... reboot
works;
But not
rsh ... cat /tmp/rdpclient.out
Any idea to log search in windows ?
Posted: Thu Jan 11, 2018 10:40 am
All log messages are in log. /tmp/rdpcient.out is just a pipe.
Sound problem is on server side. On server Windows. If microphone won't be redirected with mstsc.exe from one windows to windows server, it will not be redirected in wtware too.
