"I'm tired" Message
Posted: Thu Nov 16, 2017 8:26 pm
by cody.duncan
We have a Raspberry Pi 3 that runs WTware to connect to an RDP session and use this as digital signage. Every day or so the screen will go blue with a box popped up that says "I'm tired" and an ok button. When you click okay, it reconnects to the session.
What is causing this?
Re: "I'm tired" Message
Posted: Fri Nov 17, 2017 1:38 am
Posted: Tue Nov 21, 2017 1:17 pm
by geefox
we are using the raspberry stuff for aprox. 2 months, and recently the "i'm tired" message popped up.
I've attached the logfile.
best regards
Posted: Tue Nov 21, 2017 3:28 pm
Something strange in RDP we have never seen before. Which server do you use?
Show me please same log from this build:
http://pxe.ru/files/testing/201711211626.zip
Posted: Tue Nov 21, 2017 5:05 pm
by geefox
we are using Server 2016 Datacentre
on first login attempt, the failure "gfx pipe closed" appeared, second time the login was successful
I've attached you the logfile:
Posted: Tue Nov 21, 2017 8:21 pm
by cody.duncan
Sorry for the late reply, we are using Server 2008 R2, the log is attached.
Posted: Wed Nov 22, 2017 7:26 pm
geefox
RDP stream seems corrupted. Or it's any new kind of RDP stream we've never seen before. Old style RDP encryption (not SSL/TLS) is used (it's not a problem itself, but 2016 server uses TLS by default, you change encryption, and TS_STATUS_FINDING_DESTINATION means you connect not to server itself but to virtual machine), but after decryption we receive garbage. The only way to debug it if you tell, what did you reconfigure in server and in virtual machine. Something in RDP security...
Posted: Wed Nov 22, 2017 7:36 pm
cody.duncan
There are no errors in this log. Please, make the same log after you receive error on screen.
Posted: Thu Nov 23, 2017 3:50 pm
by geefox
akatik wrote:geefox
yeah, basically I'm connecting to a session broker, and then passing the credentials to the real terminal server. The only thing which has been modified is the nla option for rdp, which we have switched off.
Posted: Tue Nov 28, 2017 4:26 am
by cody.duncan
aka wrote:cody.duncan
I will do that as soon as we get it again. It has been happening less often now.
Posted: Wed Dec 13, 2017 10:29 am
by dash1982
Met this message several times, after checking the IP conflicts in the same network, it disappeared.
