"I'm tired" Message
"I'm tired" Message
We have a Raspberry Pi 3 that runs WTware to connect to an RDP session and use this as digital signage. Every day or so the screen will go blue with a box popped up that says "I'm tired" and an ok button. When you click okay, it reconnects to the session.
What is causing this?
Re: "I'm tired" Message
we are using the raspberry stuff for aprox. 2 months, and recently the "i'm tired" message popped up.
I've attached the logfile.
best regards
best regards
- log.zip
- (68.31 KiB) Downloaded 416 times
Something strange in RDP we have never seen before. Which server do you use?
Show me please same log from this build:
http://pxe.ru/files/testing/201711211626.zip
we are using Server 2016 Datacentre
on first login attempt, the failure "gfx pipe closed" appeared, second time the login was successful
I've attached you the logfile:
- log.zip
- (10.85 KiB) Downloaded 380 times
Sorry for the late reply, we are using Server 2008 R2, the log is attached.
- WTware_B8.27.EB.0A.64.76_2017-11-21_09-19-29.txt
- (105.73 KiB) Downloaded 550 times
geefox
RDP stream seems corrupted. Or it's any new kind of RDP stream we've never seen before. Old style RDP encryption (not SSL/TLS) is used (it's not a problem itself, but 2016 server uses TLS by default, you change encryption, and TS_STATUS_FINDING_DESTINATION means you connect not to server itself but to virtual machine), but after decryption we receive garbage. The only way to debug it if you tell, what did you reconfigure in server and in virtual machine. Something in RDP security...
cody.duncan
There are no errors in this log. Please, make the same log after you receive error on screen.
yeah, basically I'm connecting to a session broker, and then passing the credentials to the real terminal server. The only thing which has been modified is the nla option for rdp, which we have switched off.akatik wrote:geefox
I will do that as soon as we get it again. It has been happening less often now.aka wrote:cody.duncan
Met this message several times, after checking the IP conflicts in the same network, it disappeared.
