Does WTware support Power-Button for Raspberri Pi?
Posted: Thu Oct 05, 2017 5:30 pm
by CKoewing
Does WTware for Raspberry Pi support any Power-Button-PCB including the script?
Like OnOff SHIM from Pimoroni? Or it is possible to integrate one of the scripts?
Thanks and best regards,
Chris
Re: Does WTware support Power-Button for Raspberri Pi?
Posted: Fri Oct 06, 2017 9:54 am
Only this one:
Posted: Fri Oct 06, 2017 12:51 pm
by CKoewing
But that's a solution without a clean shutdown, which can destroy the file system on the SD card. :-/
Posted: Fri Oct 06, 2017 1:54 pm
No. WTware only mounts SD for writing when it really needs to write. Most boot time SD is mounted read-only. After booting, SD is unmounted.
