WTware on Raspberry Pi 3 with USB scanner
novotny
Post by novotny » Mon Sep 18, 2017 2:54 pm
Hello, could you please help me? I´m curently using raspberry Pi3 with Wtware and scanner Symbol LS2208 connected via RS232 emulator. I want to connect it just by usb cabel, so raspberry will have to power the scanner. Would you think, that it will make problems, or is it ok to connect it that way?
Re: WTware on Raspberry Pi 3 with USB scanner
Post by akatik » Mon Sep 18, 2017 4:40 pm
I expect two problems:
1. Not enough power.
2. No drivers in wtware for usb-serial bridge in scanner.
Try it with "serial=com1(usb)" in wtware config. If not working, show the log: http://wtware.com/logs.html
novotny
Post by novotny » Tue Sep 19, 2017 1:42 pm
I connected two terminals via USB and one works really good so far, but the other has some problems so far. The one with problems after while of working stops to scann codes.
I´m sending you both logs.
The problem one:
09-23-19-278| Close connection with wtc.exe.
09-23-19-278| Send WTCU discover to 10.1.21.12.
09-23-19-278| [ rdpclient 977] [69357.805428] errorInfo 0x00000002.
09-23-19-278| [ rdpclient 977] [69357.805506] ERRINFO_RPC_INITIATED_LOGOFF
09-23-19-278| [ rdpclient 977] [69357.930541] Receive Disconnect Provider Ultimatum.
09-23-19-278| [ gm] [69357.930663] TSClient (sessionId 8, pid 977) gracefully end.
09-23-19-278| [rdpdr-serial 0] [69357.938842] Close client connection 0 (id 8).
09-23-19-278| [ pfac] [69357.939396] Process pid 977 terminated, status 00000009.
09-23-19-278| [ gm] [69357.940117] Run '/sbin/resolver 0x107bdf8 dns [brq_rdp_brokers]', log '', env '', pid ''.
09-23-19-278| [ pfac] [69357.940206] Run /sbin/resolver 0x107bdf8 dns [brq_rdp_brokers].
09-23-19-278| [ pfac] [69357.940516] Ok, PID 996.
09-23-19-278| [ pfac] [69357.946622] Process pid 996 terminated, status 00000000.
09-23-19-278| [ gm] [69358.059289] brq_rdp_brokers => 10.1.2.17.
09-23-19-278| [ gm] [69358.059419] brq_rdp_brokers => 10.1.2.16.
09-23-19-278| [ gm] [69358.068329] Free ram before fork terminal client /sbin/rdpclient (session 9): 927148 Kb.
09-23-19-278| [ gm] [69358.068485] Run '/sbin/rdpclient 9', log '/tmp/rdpclient.out', env '', pid ''.
09-23-19-278| [ pfac] [69358.068717] Run /sbin/rdpclient 9.
09-23-19-278| [ pfac] [69358.069117] Ok, PID 997.
09-23-19-278| [ rdpclient 997] [69358.076451] RDP Terminal Client, WTware 5.6.12/RPi, pipe 9, pid 997.
09-23-19-278| [ gm] [69358.077333] ttyUSB0, single device.
09-23-19-278| [ rdpclient 997] [69358.077425] Use /lib/ui16.so.
09-23-19-278| [ gm] [69358.077569] COM1 => ttyUSB0.
09-23-19-278| [ rdpclient 997] [69358.078554] Add serial redirection, COM1 in the session = hardware ttyUSB0.
09-23-19-278| [ rdpclient 997] [69358.078676] Make RDP session with 10.1.2.17, 10.1.2.16, port 3389.
09-23-19-278| [ rdpclient 997] [69358.078757] Username: "svc.brq.terminal".
09-23-19-278| [ rdpclient 997] [69358.078836] Password: present.
09-23-19-278| [ rdpclient 997] [69358.078914] No PIN.
09-23-19-278| [ rdpclient 997] [69358.079008] Domain: "CORPORATE".
09-23-19-278| [ rdpclient 997] [69358.079085] Shell: "C:\Program Files (x86)\SnT\Gral2\TraceViewer\TraceViewer2.exe "BRQTERM20022"".
09-23-19-278| [ rdpclient 997] [69358.079166] No directory.
09-23-19-278| [ rdpclient 997] [69358.079243] Window: 1280x1024@16.
09-23-19-278| [ rdpclient 997] [69358.079320] PFlags 0x0000002F.
09-23-19-278| [ rdpclient 997] [69358.079396] Keyboard 00000409:00000000.
09-23-19-278| [ rdpclient 997] [69358.079474] My hostname "BRQTERM20022".
09-23-19-278| [rdpdr-serial 0] [69358.079678] New client connection, id 9.
09-23-19-278| [ rdpclient 997] [69358.081310] TCP: connection with 10.1.2.16:3389 established.
09-23-19-278| [ rdpclient 997] [69358.081458] Turn keepalive on.
09-23-19-278| [ rdpclient 997] [69358.081538] Free ram after buffers allocation: 926364 KB.
09-23-19-278| [ rdpclient 997] [69358.081621] Use Balance Info 39 bytes: 'tsv://MS Terminal Services Plugin.1.RDP'.
09-23-19-278| [ rdpclient 997] [69358.086577] Server supports GFX Pipeline.
09-23-19-278| [ rdpclient 997] [69358.089119] Process RDP server certificate.
09-23-19-278| [ rdpclient 997] [69358.089240] RDP4 encryption.
09-23-19-278| [ rdpclient 997] [69358.094856] Enable font smoothing and Desktop Composition.
09-23-19-278| [ rdpclient 997] [69358.165271] GFX codec.
09-23-19-278| [ rdpclient 997] [69358.671870] Run 4 tile threads.
09-23-19-278| [ rdpclient 997] [69359.281954] Server Redirection flags 0x00000b0d.
09-23-19-278| [ rdpclient 997] [69359.282149] Server 10.1.2.18.
09-23-19-278| [ rdpclient 997] [69359.282279] User "svc.brq.terminal".
09-23-19-278| [ rdpclient 997] [69359.282405] Domain "CORPORATE".
09-23-19-278| [ rdpclient 997] [69359.282547] Send Disconnect Provider Ultimatum.
09-23-19-278| [ gm] [69359.282765] TSClient (sessionId 9, pid 997) gracefully end.
09-23-19-278| [ gm] [69359.283408] Free ram before fork terminal client /sbin/rdpclient (session 10): 913220 Kb.
09-23-19-278| [ gm] [69359.283559] Run '/sbin/rdpclient 10', log '/tmp/rdpclient.out', env '', pid ''.
09-23-19-278| [ pfac] [69359.284098] Run /sbin/rdpclient 10.
09-23-19-278| [ pfac] [69359.284207] Ok, PID 1004.
09-23-19-278| [rdpdr-serial 0] [69359.290165] Close client connection 0 (id 9).
09-23-19-278| [ pfac] [69359.290677] Process pid 997 terminated, status 00000009.
09-23-19-278| [rdpclient 1004] [69359.291758] RDP Terminal Client, WTware 5.6.12/RPi, pipe 10, pid 1004.
09-23-19-278| [ gm] [69359.292479] ttyUSB0, single device.
09-23-19-278| [rdpclient 1004] [69359.292565] Use /lib/ui16.so.
09-23-19-278| [ gm] [69359.292709] COM1 => ttyUSB0.
09-23-19-278| [rdpdr-serial 0] [69359.293411] New client connection, id 10.
09-23-19-278| [rdpclient 1004] [69359.293489] Add serial redirection, COM1 in the session = hardware ttyUSB0.
09-23-19-278| [rdpclient 1004] [69359.293577] Make RDP session with 10.1.2.18, port 3389.
09-23-19-278| [rdpclient 1004] [69359.293656] Username: "svc.brq.terminal".
09-23-19-278| [rdpclient 1004] [69359.293734] Password: present.
09-23-19-278| [rdpclient 1004] [69359.293811] No PIN.
09-23-19-278| [rdpclient 1004] [69359.293886] Domain: "CORPORATE".
09-23-19-278| [rdpclient 1004] [69359.293963] Shell: "C:\Program Files (x86)\SnT\Gral2\TraceViewer\TraceViewer2.exe "BRQTERM20022"".
09-23-19-278| [rdpclient 1004] [69359.294042] No directory.
09-23-19-278| [rdpclient 1004] [69359.294118] Window: 1280x1024@16.
09-23-19-278| [rdpclient 1004] [69359.294195] PFlags 0x0000002F.
09-23-19-278| [rdpclient 1004] [69359.294273] Keyboard 00000409:00000000.
09-23-19-278| [rdpclient 1004] [69359.294349] My hostname "BRQTERM20022".
09-23-19-278| [rdpclient 1004] [69359.294426] TCP: connecting to 10.1.2.18:3389.
09-23-19-278| [rdpclient 1004] [69359.294504] TCP: connection with 10.1.2.18:3389 established.
09-23-19-278| [rdpclient 1004] [69359.294581] Turn keepalive on.
09-23-19-278| [rdpclient 1004] [69359.295292] Free ram after buffers allocation: 926480 KB.
09-23-19-278| [rdpclient 1004] [69359.295389] Empty Balance Info.
09-23-19-278| [rdpclient 1004] [69359.299588] Server supports GFX Pipeline.
09-23-19-278| [rdpclient 1004] [69359.299675] Redirected Session ID 0x00000000.
09-23-19-278| [rdpclient 1004] [69359.302910] Process RDP server certificate.
09-23-19-278| [rdpclient 1004] [69359.303001] RDP5 encryption (X.509).
09-23-19-278| [rdpclient 1004] [69359.307520] Enable font smoothing and Desktop Composition.
09-23-19-278| [rdpclient 1004] [69359.446693] GFX codec.
09-23-19-278| [rdpclient 1004] [69360.203994] Run 4 tile threads.
09-23-19-278| [rdpclient 1004] [69360.274480] LOGON_EX_LOGONERRORS: ErrorNotificationType 0xfffffffe, ErrorNotificationData 0x00000059.
09-23-19-278| [rdpclient 1004] [69360.305953] SessionId 0x00000059: CORPORATE\svc.brq.terminal.
09-23-19-291| Connection from wtc.exe at 10.1.21.12.
10-44-01-831| [rdpclient 1004] [74254.255685] errorInfo 0x00000002.
10-44-02-033| [rdpclient 1004] [74254.255894] ERRINFO_RPC_INITIATED_LOGOFF
10-44-02-033| [rdpclient 1004] [74254.396816] Receive Disconnect Provider Ultimatum.
10-44-02-033| [ gm] [74254.396984] TSClient (sessionId 10, pid 1004) gracefully end.
10-44-02-033| [ gm] [74254.409660] Run '/sbin/resolver 0x107bdf8 dns [brq_rdp_brokers]', log '', env '', pid ''.
10-44-02-033| [ pfac] [74254.410184] Run /sbin/resolver 0x107bdf8 dns [brq_rdp_brokers].
10-44-02-033| [ pfac] [74254.410645] Ok, PID 1027.
10-44-02-033| [rdpdr-serial 0] [74254.415119] Close client connection 0 (id 10).
10-44-02-033| [ pfac] [74254.415523] Process pid 1004 terminated, status 00000009.
10-44-02-033| [ pfac] [74254.417767] Process pid 1027 terminated, status 00000000.
10-44-02-127| [ gm] [74254.529495] brq_rdp_brokers => 10.1.2.16.
10-44-02-127| [ gm] [74254.529665] brq_rdp_brokers => 10.1.2.17.
10-44-02-127| [ gm] [74254.538871] Free ram before fork terminal client /sbin/rdpclient (session 11): 927348 Kb.
10-44-02-127| [ gm] [74254.538993] Run '/sbin/rdpclient 11', log '/tmp/rdpclient.out', env '', pid ''.
10-44-02-127| [ pfac] [74254.539197] Run /sbin/rdpclient 11.
10-44-02-127| [ pfac] [74254.539578] Ok, PID 1028.
10-44-02-127| [rdpclient 1028] [74254.547102] RDP Terminal Client, WTware 5.6.12/RPi, pipe 11, pid 1028.
10-44-02-127| [ gm] [74254.549363] ttyUSB0, single device.
10-44-02-127| [rdpdr-serial 0] [74254.549409] New client connection, id 11.
10-44-02-127| [rdpclient 1028] [74254.549434] Use /lib/ui16.so.
10-44-02-127| [ gm] [74254.549501] COM1 => ttyUSB0.
10-44-02-127| [rdpclient 1028] [74254.549522] Add serial redirection, COM1 in the session = hardware ttyUSB0.
10-44-02-127| [rdpclient 1028] [74254.549584] Make RDP session with 10.1.2.16, 10.1.2.17, port 3389.
10-44-02-127| [rdpclient 1028] [74254.549641] Username: "svc.brq.terminal".
10-44-02-127| [rdpclient 1028] [74254.549713] Password: present.
10-44-02-127| [rdpclient 1028] [74254.549769] No PIN.
10-44-02-127| [rdpclient 1028] [74254.549826] Domain: "CORPORATE".
10-44-02-127| [rdpclient 1028] [74254.549880] Shell: "C:\Program Files (x86)\SnT\Gral2\TraceViewer\TraceViewer2.exe "BRQTERM20022"".
10-44-02-127| [rdpclient 1028] [74254.549938] No directory.
10-44-02-127| [rdpclient 1028] [74254.550108] Window: 1280x1024@16.
10-44-02-127| [rdpclient 1028] [74254.550166] PFlags 0x0000002F.
10-44-02-127| [rdpclient 1028] [74254.550224] Keyboard 00000409:00000000.
10-44-02-127| [rdpclient 1028] [74254.550279] My hostname "BRQTERM20022".
10-44-02-330| [rdpclient 1028] [74254.551842] TCP: connection with 10.1.2.16:3389 established.
10-44-02-330| [rdpclient 1028] [74254.551939] Turn keepalive on.
10-44-02-330| [rdpclient 1028] [74254.551999] Free ram after buffers allocation: 926536 KB.
10-44-02-330| [rdpclient 1028] [74254.552055] Use Balance Info 39 bytes: 'tsv://MS Terminal Services Plugin.1.RDP'.
10-44-02-330| [rdpclient 1028] [74254.556699] Server supports GFX Pipeline.
10-44-02-330| [rdpclient 1028] [74254.560179] Process RDP server certificate.
10-44-02-330| [rdpclient 1028] [74254.560254] RDP4 encryption.
10-44-02-330| [rdpclient 1028] [74254.566051] Enable font smoothing and Desktop Composition.
10-44-02-330| [rdpclient 1028] [74254.638844] GFX codec.
10-44-02-704| [rdpclient 1028] [74255.134952] Run 4 tile threads.
10-44-03-219| [rdpclient 1028] [74255.650190] Server Redirection flags 0x00000b0d.
10-44-03-235| [rdpclient 1028] [74255.650371] Server 10.1.2.18.
10-44-03-235| [rdpclient 1028] [74255.650486] User "svc.brq.terminal".
10-44-03-235| [rdpclient 1028] [74255.650591] Domain "CORPORATE".
10-44-03-235| [rdpclient 1028] [74255.650715] Send Disconnect Provider Ultimatum.
10-44-03-235| [ gm] [74255.650922] TSClient (sessionId 11, pid 1028) gracefully end.
10-44-03-235| [ gm] [74255.651340] Free ram before fork terminal client /sbin/rdpclient (session 12): 913248 Kb.
10-44-03-235| [ gm] [74255.651408] Run '/sbin/rdpclient 12', log '/tmp/rdpclient.out', env '', pid ''.
10-44-03-235| [ pfac] [74255.651469] Run /sbin/rdpclient 12.
10-44-03-235| [ pfac] [74255.651963] Ok, PID 1035.
10-44-03-235| [rdpdr-serial 0] [74255.658421] Close client connection 0 (id 11).
10-44-03-235| [ pfac] [74255.659026] Process pid 1028 terminated, status 00000009.
10-44-03-235| [rdpclient 1035] [74255.659220] RDP Terminal Client, WTware 5.6.12/RPi, pipe 12, pid 1035.
10-44-03-235| [ gm] [74255.659922] ttyUSB0, single device.
10-44-03-235| [ gm] [74255.659989] COM1 => ttyUSB0.
10-44-03-235| [rdpclient 1035] [74255.660099] Use /lib/ui16.so.
10-44-03-235| [rdpdr-serial 0] [74255.660920] New client connection, id 12.
10-44-03-235| [rdpclient 1035] [74255.660953] Add serial redirection, COM1 in the session = hardware ttyUSB0.
10-44-03-235| [rdpclient 1035] [74255.661018] Make RDP session with 10.1.2.18, port 3389.
10-44-03-235| [rdpclient 1035] [74255.661076] Username: "svc.brq.terminal".
10-44-03-235| [rdpclient 1035] [74255.661172] Password: present.
10-44-03-235| [rdpclient 1035] [74255.661228] No PIN.
10-44-03-235| [rdpclient 1035] [74255.661283] Domain: "CORPORATE".
10-44-03-235| [rdpclient 1035] [74255.661337] Shell: "C:\Program Files (x86)\SnT\Gral2\TraceViewer\TraceViewer2.exe "BRQTERM20022"".
10-44-03-235| [rdpclient 1035] [74255.661395] No directory.
10-44-03-235| [rdpclient 1035] [74255.661448] Window: 1280x1024@16.
10-44-03-235| [rdpclient 1035] [74255.661503] PFlags 0x0000002F.
10-44-03-235| [rdpclient 1035] [74255.661557] Keyboard 00000409:00000000.
10-44-03-235| [rdpclient 1035] [74255.661612] My hostname "BRQTERM20022".
10-44-03-235| [rdpclient 1035] [74255.661667] TCP: connecting to 10.1.2.18:3389.
10-44-03-235| [rdpclient 1035] [74255.661723] TCP: connection with 10.1.2.18:3389 established.
10-44-03-235| [rdpclient 1035] [74255.661779] Turn keepalive on.
10-44-03-453| [rdpclient 1035] [74255.662946] Free ram after buffers allocation: 925912 KB.
10-44-03-453| [rdpclient 1035] [74255.663025] Empty Balance Info.
10-44-03-453| [rdpclient 1035] [74255.668739] Server supports GFX Pipeline.
10-44-03-453| [rdpclient 1035] [74255.668803] Redirected Session ID 0x00000000.
10-44-03-453| [rdpclient 1035] [74255.671966] Process RDP server certificate.
10-44-03-453| [rdpclient 1035] [74255.672079] RDP5 encryption (X.509).
10-44-03-453| [rdpclient 1035] [74255.677231] Enable font smoothing and Desktop Composition.
10-44-03-453| [rdpclient 1035] [74255.834672] GFX codec.
10-44-04-015| [rdpclient 1035] [74256.448439] Run 4 tile threads.
10-44-04-233| [rdpclient 1035] [74256.662268] LOGON_EX_LOGONERRORS: ErrorNotificationType 0xfffffffe, ErrorNotificationData 0x0000004c.
10-44-04-451| [rdpclient 1035] [74256.693888] SessionId 0x0000004c: CORPORATE\svc.brq.terminal.
11-55-31-842| [rdpclient 1035] [78544.321119] errorInfo 0x00000002.
11-55-32-045| [rdpclient 1035] [78544.321201] ERRINFO_RPC_INITIATED_LOGOFF
11-55-32-061| [rdpclient 1035] [78544.445958] Receive Disconnect Provider Ultimatum.
11-55-32-061| [ gm] [78544.446030] TSClient (sessionId 12, pid 1035) gracefully end.
11-55-32-076| [rdpdr-serial 0] [78544.454281] Close client connection 0 (id 12).
11-55-32-076| [ pfac] [78544.454826] Process pid 1035 terminated, status 00000009.
11-55-32-092| [ gm] [78544.455002] Run '/sbin/resolver 0x107bdf8 dns [brq_rdp_brokers]', log '', env '', pid ''.
11-55-32-092| [ pfac] [78544.455343] Run /sbin/resolver 0x107bdf8 dns [brq_rdp_brokers].
11-55-32-092| [ pfac] [78544.455386] Ok, PID 1056.
11-55-32-092| [ pfac] [78544.459631] Process pid 1056 terminated, status 00000000.
11-55-32-092| [ gm] [78544.516248] brq_rdp_brokers => 10.1.2.17.
11-55-32-092| [ gm] [78544.516308] brq_rdp_brokers => 10.1.2.16.
11-55-32-108| [ gm] [78544.520780] Free ram before fork terminal client /sbin/rdpclient (session 13): 927000 Kb.
11-55-32-108| [ gm] [78544.520853] Run '/sbin/rdpclient 13', log '/tmp/rdpclient.out', env '', pid ''.
11-55-32-108| [ pfac] [78544.520974] Run /sbin/rdpclient 13.
11-55-32-108| [ pfac] [78544.521216] Ok, PID 1057.
11-55-32-123| [rdpclient 1057] [78544.525282] RDP Terminal Client, WTware 5.6.12/RPi, pipe 13, pid 1057.
11-55-32-123| [rdpclient 1057] [78544.526009] Use /lib/ui16.so.
11-55-32-123| [ gm] [78544.526990] ttyUSB0, single device.
11-55-32-123| [ gm] [78544.527213] COM1 => ttyUSB0.
11-55-32-123| [rdpclient 1057] [78544.528327] Add serial redirection, COM1 in the session = hardware ttyUSB0.
11-55-32-123| [rdpclient 1057] [78544.528403] Make RDP session with 10.1.2.17, 10.1.2.16, port 3389.
11-55-32-139| [rdpclient 1057] [78544.528462] Username: "svc.brq.terminal".
11-55-32-139| [rdpclient 1057] [78544.528518] Password: present.
11-55-32-139| [rdpclient 1057] [78544.528573] No PIN.
11-55-32-139| [rdpclient 1057] [78544.528626] Domain: "CORPORATE".
11-55-32-139| [rdpclient 1057] [78544.528680] Shell: "C:\Program Files (x86)\SnT\Gral2\TraceViewer\TraceViewer2.exe "BRQTERM20022"".
11-55-32-154| [rdpclient 1057] [78544.528747] No directory.
11-55-32-154| [rdpclient 1057] [78544.528803] Window: 1280x1024@16.
11-55-32-154| [rdpclient 1057] [78544.528857] PFlags 0x0000002F.
11-55-32-154| [rdpclient 1057] [78544.528911] Keyboard 00000409:00000000.
11-55-32-154| [rdpclient 1057] [78544.528966] My hostname "BRQTERM20022".
11-55-32-154| [rdpdr-serial 0] [78544.529126] New client connection, id 13.
11-55-32-170| [rdpclient 1057] [78544.530160] TCP: connection with 10.1.2.17:3389 established.
11-55-32-170| [rdpclient 1057] [78544.530277] Turn keepalive on.
11-55-32-170| [rdpclient 1057] [78544.530639] Free ram after buffers allocation: 926404 KB.
11-55-32-170| [rdpclient 1057] [78544.530705] Use Balance Info 39 bytes: 'tsv://MS Terminal Services Plugin.1.RDP'.
11-55-32-170| [rdpclient 1057] [78544.536937] Server supports GFX Pipeline.
11-55-32-170| [rdpclient 1057] [78544.539996] Process RDP server certificate.
11-55-32-186| [rdpclient 1057] [78544.540157] RDP4 encryption.
11-55-32-279| [rdpclient 1057] [78544.546391] Enable font smoothing and Desktop Composition.
11-55-32-279| [rdpclient 1057] [78544.627025] GFX codec.
11-55-32-716| [rdpclient 1057] [78545.185674] Run 4 tile threads.
11-55-33-168| [rdpclient 1057] [78545.651935] TS_STATUS_FINDING_DESTINATION
11-55-33-324| [rdpclient 1057] [78545.655481] TS_STATUS_LOADING_DESTINATION
11-55-33-340| [rdpclient 1057] [78545.655921] TS_STATUS_REDIRECTING_TO_DESTINATION
11-55-33-340| [rdpclient 1057] [78545.686448] TS_STATUS_BRINGING_SESSION_ONLINE
11-55-33-340| [rdpclient 1057] [78545.784677] Server Redirection flags 0x00000b0d.
11-55-33-340| [rdpclient 1057] [78545.784817] Server 10.1.2.18.
11-55-33-356| [rdpclient 1057] [78545.784925] User "svc.brq.terminal".
11-55-33-356| [rdpclient 1057] [78545.785029] Domain "CORPORATE".
11-55-33-356| [rdpclient 1057] [78545.785153] Send Disconnect Provider Ultimatum.
11-55-33-356| [ gm] [78545.785349] TSClient (sessionId 13, pid 1057) gracefully end.
11-55-33-371| [ gm] [78545.786073] Free ram before fork terminal client /sbin/rdpclient (session 14): 913032 Kb.
11-55-33-371| [ gm] [78545.786148] Run '/sbin/rdpclient 14', log '/tmp/rdpclient.out', env '', pid ''.
11-55-33-371| [ pfac] [78545.786285] Run /sbin/rdpclient 14.
11-55-33-371| [ pfac] [78545.786651] Ok, PID 1064.
11-55-33-387| [rdpdr-serial 0] [78545.792569] Close client connection 0 (id 13).
11-55-33-387| [ pfac] [78545.792950] Process pid 1057 terminated, status 00000009.
11-55-33-387| [rdpclient 1064] [78545.794585] RDP Terminal Client, WTware 5.6.12/RPi, pipe 14, pid 1064.
11-55-33-387| [ gm] [78545.796735] ttyUSB0, single device.
11-55-33-387| [rdpdr-serial 0] [78545.796774] New client connection, id 14.
11-55-33-402| [rdpclient 1064] [78545.796798] Use /lib/ui16.so.
11-55-33-402| [ gm] [78545.796927] COM1 => ttyUSB0.
11-55-33-402| [rdpclient 1064] [78545.797101] Add serial redirection, COM1 in the session = hardware ttyUSB0.
11-55-33-402| [rdpclient 1064] [78545.797167] Make RDP session with 10.1.2.18, port 3389.
11-55-33-402| [rdpclient 1064] [78545.797225] Username: "svc.brq.terminal".
11-55-33-402| [rdpclient 1064] [78545.797281] Password: present.
11-55-33-402| [rdpclient 1064] [78545.797335] No PIN.
11-55-33-402| [rdpclient 1064] [78545.797388] Domain: "CORPORATE".
11-55-33-418| [rdpclient 1064] [78545.797441] Shell: "C:\Program Files (x86)\SnT\Gral2\TraceViewer\TraceViewer2.exe "BRQTERM20022"".
11-55-33-418| [rdpclient 1064] [78545.797498] No directory.
11-55-33-418| [rdpclient 1064] [78545.797552] Window: 1280x1024@16.
11-55-33-418| [rdpclient 1064] [78545.797605] PFlags 0x0000002F.
11-55-33-434| [rdpclient 1064] [78545.797660] Keyboard 00000409:00000000.
11-55-33-434| [rdpclient 1064] [78545.797714] My hostname "BRQTERM20022".
11-55-33-434| [rdpclient 1064] [78545.797769] TCP: connecting to 10.1.2.18:3389.
11-55-33-543| [rdpclient 1064] [78545.799141] TCP: connection with 10.1.2.18:3389 established.
11-55-33-543| [rdpclient 1064] [78545.799223] Turn keepalive on.
11-55-33-543| [rdpclient 1064] [78545.799280] Free ram after buffers allocation: 926380 KB.
11-55-33-558| [rdpclient 1064] [78545.799336] Empty Balance Info.
11-55-33-558| [rdpclient 1064] [78545.803585] Server supports GFX Pipeline.
11-55-33-574| [rdpclient 1064] [78545.803650] Redirected Session ID 0x00000000.
11-55-33-574| [rdpclient 1064] [78545.806917] Process RDP server certificate.
11-55-33-574| [rdpclient 1064] [78545.806981] RDP5 encryption (X.509).
11-55-33-574| [rdpclient 1064] [78545.811562] Enable font smoothing and Desktop Composition.
11-55-33-590| [rdpclient 1064] [78545.962518] GFX codec.
11-55-34-229| [rdpclient 1064] [78546.704878] Run 4 tile threads.
11-55-34-432| [rdpclient 1064] [78546.805576] LOGON_EX_LOGONERRORS: ErrorNotificationType 0xfffffffe, ErrorNotificationData 0x00000058.
11-55-34-432| [rdpclient 1064] [78546.839398] SessionId 0x00000058: CORPORATE\svc.brq.terminal.
12-01-14-705| [ httpd] [78887.182693] Mount /bootmedia as read-only.
12-01-14-908| [ httpd] [78887.195699] Success: media /dev/mmcblk0p1 mounted to /bootmedia.
12-01-14-908| [ httpd] [78887.199861] Umount /bootmedia.
12-01-27-341| [ httpd] [78899.819355] Mount /bootmedia as read-only.
12-01-27-560| [ httpd] [78899.832122] Success: media /dev/mmcblk0p1 mounted to /bootmedia.
12-01-27-560| [ httpd] [78899.836112] Umount /bootmedia.
novotny
Post by novotny » Tue Sep 19, 2017 2:04 pm
Good one:
12-18-17-806| WTware 5.6.12/RPi supervisor.
12-18-17-806| [ KERNEL] [ 0.000000] Booting Linux on physical CPU 0x0
12-18-17-806| [ KERNEL] [ 0.000000] Linux version 4.9.39 (aka@c12) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.4) ) #9 SMP Sat Jul 29 14:51:22 +04 2017
12-18-17-806| [ KERNEL] [ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
12-18-17-806| [ KERNEL] [ 0.000000] CPU: div instructions available: patching division code
12-18-17-806| [ KERNEL] [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
12-18-17-806| [ KERNEL] [ 0.000000] OF: fdt:Machine model: Raspberry Pi 3 Model B Rev 1.2
12-18-17-806| [ KERNEL] [ 0.000000] cma: Reserved 8 MiB at 0x3a800000
12-18-17-806| [ KERNEL] [ 0.000000] Memory policy: Data cache writealloc
12-18-17-806| [ KERNEL] [ 0.000000] On node 0 totalpages: 241664
12-18-17-806| [ KERNEL] [ 0.000000] free_area_init_node: node 0, pgdat 80b22f40, node_mem_map b9faa000
12-18-17-806| [ KERNEL] [ 0.000000] Normal zone: 2124 pages used for memmap
12-18-17-806| [ KERNEL] [ 0.000000] Normal zone: 0 pages reserved
12-18-17-806| [ KERNEL] [ 0.000000] Normal zone: 241664 pages, LIFO batch:31
12-18-17-806| [ KERNEL] [ 0.000000] percpu: Embedded 11 pages/cpu @b9f70000 s16076 r8192 d20788 u45056
12-18-17-806| [ KERNEL] [ 0.000000] pcpu-alloc: s16076 r8192 d20788 u45056 alloc=11*4096
12-18-17-806| [ KERNEL] [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
12-18-17-806| [ KERNEL] [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 239540
12-18-17-806| [ KERNEL] [ 0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=1280 bcm2708_fb.fbheight=1024 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 wtware.dhcp_retries=300 quiet wtboot=mmc
12-18-17-806| [ KERNEL] [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
12-18-17-806| [ KERNEL] [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
12-18-17-806| [ KERNEL] [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
12-18-17-806| [ KERNEL] [ 0.000000] Memory: 938116K/966656K available (5120K kernel code, 143K rwdata, 916K rodata, 4096K init, 373K bss, 20348K reserved, 8192K cma-reserved)
12-18-17-806| [ hotplug] [ 2.953731] Block device 179:0. No action.
12-18-17-806| [ KERNEL] [ 0.000000] Virtual kernel memory layout:
12-18-17-806| [ KERNEL] [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
12-18-17-806| [ KERNEL] [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
12-18-17-806| [ KERNEL] [ 0.000000] vmalloc : 0xbb800000 - 0xff800000 (1088 MB)
12-18-17-806| [ KERNEL] [ 0.000000] lowmem : 0x80000000 - 0xbb000000 ( 944 MB)
12-18-17-806| [ KERNEL] [ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
12-18-17-806| [ KERNEL] [ 0.000000] .text : 0x80008000 - 0x80600000 (6112 kB)
12-18-17-806| [ KERNEL] [ 0.000000] .init : 0x80700000 - 0x80b00000 (4096 kB)
12-18-17-806| [ KERNEL] [ 0.000000] .data : 0x80b00000 - 0x80b23fd8 ( 144 kB)
12-18-17-806| [ KERNEL] [ 0.000000] .bss : 0x80b25000 - 0x80b82660 ( 374 kB)
12-18-17-806| [ KERNEL] [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
12-18-17-806| [ KERNEL] [ 0.000000] Hierarchical RCU implementation.
12-18-17-806| [ KERNEL] [ 0.000000] Build-time adjustment of leaf fanout to 32.
12-18-17-806| [ KERNEL] [ 0.000000] NR_IRQS:16 nr_irqs:16 16
12-18-17-806| [ KERNEL] [ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
12-18-17-806| [ KERNEL] [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
12-18-17-806| [ KERNEL] [ 0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
12-18-17-806| [ KERNEL] [ 0.000018] Switching to timer-based delay loop, resolution 52ns
12-18-17-806| [ KERNEL] [ 0.000240] Console: colour dummy device 80x30
12-18-17-806| [ KERNEL] [ 0.000257] console [tty0] enabled
12-18-17-806| [ KERNEL] [ 0.000276] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
12-18-17-806| [ KERNEL] [ 0.000292] pid_max: default: 32768 minimum: 301
12-18-17-806| [ KERNEL] [ 0.000439] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
12-18-17-806| [ KERNEL] [ 0.000446] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
12-18-17-806| [ KERNEL] [ 0.001309] Disabling cpuset control group subsystem
12-18-17-806| [ KERNEL] [ 0.001438] CPU: Testing write buffer coherency: ok
12-18-17-806| [ KERNEL] [ 0.001881] CPU0: update cpu_capacity 1024
12-18-17-806| [ KERNEL] [ 0.001888] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
12-18-17-806| [ KERNEL] [ 0.001933] Setting up static identity map for 0x100000 - 0x100034
12-18-17-806| [ KERNEL] [ 0.003631] CPU1: update cpu_capacity 1024
12-18-17-806| [ KERNEL] [ 0.003637] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
12-18-17-806| [ KERNEL] [ 0.004202] CPU2: update cpu_capacity 1024
12-18-17-806| [ KERNEL] [ 0.004208] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
12-18-17-806| [ KERNEL] [ 0.004751] CPU3: update cpu_capacity 1024
12-18-17-806| [ hotplug] [ 2.954364] Block device 179:1. No action.
12-18-17-806| [ KERNEL] [ 0.004758] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
12-18-17-806| [ KERNEL] [ 0.004831] Brought up 4 CPUs
12-18-17-806| [ KERNEL] [ 0.004841] SMP: Total of 4 processors activated (153.60 BogoMIPS).
12-18-17-806| [ KERNEL] [ 0.004845] CPU: All CPU(s) started in HYP mode.
12-18-17-806| [ KERNEL] [ 0.004848] CPU: Virtualization extensions available.
12-18-17-806| [ KERNEL] [ 0.005384] devtmpfs: initialized
12-18-17-806| [ KERNEL] [ 0.015004] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
12-18-17-806| [ KERNEL] [ 0.015387] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
12-18-17-806| [ KERNEL] [ 0.015403] futex hash table entries: 1024 (order: 4, 65536 bytes)
12-18-17-806| [ KERNEL] [ 0.015879] pinctrl core: initialized pinctrl subsystem
12-18-17-806| [ KERNEL] [ 0.016408] NET: Registered protocol family 16
12-18-17-806| [ KERNEL] [ 0.018279] DMA: preallocated 1024 KiB pool for atomic coherent allocations
12-18-17-806| [ KERNEL] [ 0.028412] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
12-18-17-806| [ KERNEL] [ 0.111149] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb80f000, dmachans=0x1
12-18-17-806| [ KERNEL] [ 0.113494] usbcore: registered new interface driver usbfs
12-18-17-806| [ KERNEL] [ 0.113621] usbcore: registered new interface driver hub
12-18-17-806| [ KERNEL] [ 0.113709] usbcore: registered new device driver usb
12-18-17-806| [ KERNEL] [ 0.120117] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-07-21 23:56
12-18-17-806| [ KERNEL] [ 0.122421] clocksource: Switched to clocksource arch_sys_counter
12-18-17-806| [ KERNEL] [ 0.137264] NET: Registered protocol family 2
12-18-17-806| [ KERNEL] [ 0.137837] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
12-18-17-806| [ KERNEL] [ 0.137944] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
12-18-17-806| [ KERNEL] [ 0.138127] TCP: Hash tables configured (established 8192 bind 8192)
12-18-17-806| [ KERNEL] [ 0.138211] UDP hash table entries: 512 (order: 2, 16384 bytes)
12-18-17-806| [ KERNEL] [ 0.138252] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
12-18-17-806| [ KERNEL] [ 0.138430] NET: Registered protocol family 1
12-18-17-806| [ KERNEL] [ 2.226087] workingset: timestamp_bits=14 max_order=18 bucket_order=4
12-18-17-806| [ KERNEL] [ 2.263341] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
12-18-17-806| [ KERNEL] [ 2.263352] io scheduler noop registered
12-18-17-806| [ KERNEL] [ 2.263357] io scheduler deadline registered (default)
12-18-17-806| [ KERNEL] [ 2.276211] BCM2708FB: allocated DMA memory fa910000
12-18-17-806| [ KERNEL] [ 2.276249] BCM2708FB: allocated DMA channel 0 @ bb80f000
12-18-17-806| [ KERNEL] [ 2.296519] Console: switching to colour frame buffer device 160x64
12-18-17-806| [ KERNEL] [ 2.311002] bcm2835-rng 3f104000.rng: hwrng registered
12-18-17-806| [ KERNEL] [ 2.311177] vc-cma: Videocore CMA driver
12-18-17-806| [ KERNEL] [ 2.311185] vc-cma: vc_cma_base = 0x00000000
12-18-17-806| [ KERNEL] [ 2.311190] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
12-18-17-806| [ KERNEL] [ 2.311195] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
12-18-17-806| [ KERNEL] [ 2.311660] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
12-18-17-806| [ KERNEL] [ 2.316088] zram: Added device: zram0
12-18-17-806| [ KERNEL] [ 2.316120] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
12-18-17-806| [ KERNEL] [ 2.544208] Core Release: 2.80a
12-18-17-806| [ KERNEL] [ 2.544219] Setting default values for core params
12-18-17-806| [ KERNEL] [ 2.544243] Finished setting default values for core params
12-18-17-806| [ KERNEL] [ 2.744588] Using Buffer DMA mode
12-18-17-806| [ KERNEL] [ 2.744594] Periodic Transfer Interrupt Enhancement - disabled
12-18-17-806| [ KERNEL] [ 2.744598] Multiprocessor Interrupt Enhancement - disabled
12-18-17-806| [ KERNEL] [ 2.744605] OTG VER PARAM: 0, OTG VER FLAG: 0
12-18-17-806| [ KERNEL] [ 2.744633] Dedicated Tx FIFOs mode
12-18-17-806| [ KERNEL] [ 2.745118] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xba904000 dma = 0xfa904000 len=9024
12-18-17-806| [ KERNEL] [ 2.745143] FIQ FSM acceleration enabled for :
12-18-17-806| [ KERNEL] [ 2.745143] Non-periodic Split Transactions
12-18-17-806| [ KERNEL] [ 2.745143] Periodic Split Transactions
12-18-17-806| [ KERNEL] [ 2.745143] High-Speed Isochronous Endpoints
12-18-17-806| [ KERNEL] [ 2.745143] Interrupt/Control Split Transaction hack enabled
12-18-17-806| [ KERNEL] [ 2.745149] dwc_otg: Microframe scheduler enabled
12-18-17-806| [ KERNEL] [ 2.745188] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x80394034
12-18-17-806| [ KERNEL] [ 2.745196] WARN::hcd_init_fiq:460: FIQ ASM at 0x80394398 length 36
12-18-17-806| [ KERNEL] [ 2.745205] WARN::hcd_init_fiq:486: MPHI regs_base at 0xbb925000
12-18-17-806| [ KERNEL] [ 2.745255] dwc_otg 3f980000.usb: DWC OTG Controller
12-18-17-806| [ KERNEL] [ 2.745288] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
12-18-17-806| [ KERNEL] [ 2.745318] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
12-18-17-806| [ KERNEL] [ 2.745362] Init: Port Power? op_state=1
12-18-17-806| [ KERNEL] [ 2.745365] Init: Power Port (0)
12-18-17-806| [ KERNEL] [ 2.745537] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
12-18-17-806| [ KERNEL] [ 2.745547] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
12-18-17-806| [ KERNEL] [ 2.745555] usb usb1: Product: DWC OTG Controller
12-18-17-806| [ KERNEL] [ 2.745562] usb usb1: Manufacturer: Linux 4.9.39 dwc_otg_hcd
12-18-17-806| [ KERNEL] [ 2.745569] usb usb1: SerialNumber: 3f980000.usb
12-18-17-806| [ KERNEL] [ 2.746399] hub 1-0:1.0: USB hub found
12-18-17-806| [ KERNEL] [ 2.746438] hub 1-0:1.0: 1 port detected
12-18-17-806| [ KERNEL] [ 2.747078] dwc_otg: FIQ enabled
12-18-17-806| [ KERNEL] [ 2.747082] dwc_otg: NAK holdoff enabled
12-18-17-806| [ KERNEL] [ 2.747086] dwc_otg: FIQ split-transaction FSM enabled
12-18-17-806| [ KERNEL] [ 2.747159] Module dwc_common_port init
12-18-17-806| [ KERNEL] [ 2.747730] usbcore: registered new interface driver usbtouchscreen
12-18-17-806| [ KERNEL] [ 2.749304] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
12-18-17-806| [ KERNEL] [ 2.749797] bcm2835-cpufreq: min=600000 max=1200000
12-18-17-806| [ KERNEL] [ 2.750970] sdhost-bcm2835 3f202000.sdhost: could not get clk, deferring probe
12-18-17-806| [ KERNEL] [ 2.753388] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
12-18-17-806| [ KERNEL] [ 2.758072] ledtrig-cpu: registered to indicate activity on CPUs
12-18-17-806| [ KERNEL] [ 2.758174] hidraw: raw HID events driver (C) Jiri Kosina
12-18-17-806| [ KERNEL] [ 2.758878] usbcore: registered new interface driver usbhid
12-18-17-806| [ KERNEL] [ 2.758882] usbhid: USB HID core driver
12-18-17-806| [ KERNEL] [ 2.761585] vchiq: vchiq_init_state: slot_zero = 0xba980000, is_master = 0
12-18-17-806| [ KERNEL] [ 2.767696] NET: Registered protocol family 17
12-18-17-806| [ KERNEL] [ 2.767835] Registering SWP/SWPB emulation handler
12-18-17-806| [ KERNEL] [ 2.768339] registered taskstats version 1
12-18-17-806| [ KERNEL] [ 2.768536] vc-sm: Videocore shared memory driver
12-18-17-806| [ KERNEL] [ 2.768543] [vc_sm_connected_init]: start
12-18-17-806| [ KERNEL] [ 2.774936] [vc_sm_connected_init]: end - returning 0
12-18-17-806| [ KERNEL] [ 2.778413] sdhost: log_buf @ ba907000 (fa907000)
12-18-17-806| [ KERNEL] [ 2.862438] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
12-18-17-806| [ KERNEL] [ 2.864572] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
12-18-17-806| [ KERNEL] [ 2.864576] mmc-bcm2835 3f300000.mmc: DMA channel allocated
12-18-17-806| [ KERNEL] [ 2.922473] of_cfs_init
12-18-17-806| [ KERNEL] [ 2.922525] of_cfs_init: OK
12-18-17-806| [ KERNEL] [ 2.932194] Freeing unused kernel memory: 4096K (80700000 - 80b00000)
12-18-17-806| [ KERNEL] [ 2.949511] mmc0: host does not support reading read-only switch, assuming write-enable
12-18-17-806| [ KERNEL] [ 2.951431] mmc0: new high speed SDHC card at address 1234
12-18-17-806| [ KERNEL] [ 2.951947] mmcblk0: mmc0:1234 SA16G 14.4 GiB
12-18-17-806| [ KERNEL] [ 2.953545] mmcblk0: p1
12-18-17-806| [ KERNEL] [ 2.959331] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
12-18-17-806| [ KERNEL] [ 2.960826] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
12-18-17-806| [ KERNEL] [ 2.962314] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
12-18-17-806| [ KERNEL] [ 2.964988] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
12-18-17-806| [ KERNEL] [ 2.972500] Indeed it is in host mode hprt0 = 00021501
12-18-17-806| [ KERNEL] [ 3.044143] random: fast init done
12-18-17-806| [ KERNEL] [ 3.112056] mmc1: new high speed SDIO card at address 0001
12-18-17-806| [ KERNEL] [ 3.182627] usb 1-1: new high-speed USB device number 2 using dwc_otg
12-18-17-806| [ KERNEL] [ 3.182761] Indeed it is in host mode hprt0 = 00001101
12-18-17-806| [ hotplug] [ 3.219269] Block device 254:0. No action.
12-18-17-806| [ pfac] [ 3.253075] Run /sbin/initrd.
12-18-17-806| [ pfac] [ 3.253182] Ok, PID 604.
12-18-17-806| [ initrd] [ 3.256192] WTware shell 5.6.12/RPi
12-18-17-806| [ initrd] [ 3.276283] HDD/MMC/SD boot.
12-18-17-806| [ KERNEL] [ 3.412699] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
12-18-17-806| [ KERNEL] [ 3.412711] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
12-18-17-806| [ KERNEL] [ 3.413503] hub 1-1:1.0: USB hub found
12-18-17-806| [ KERNEL] [ 3.413601] hub 1-1:1.0: 5 ports detected
12-18-17-806| [ KERNEL] [ 3.732457] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
12-18-17-806| [ KERNEL] [ 3.862667] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
12-18-17-806| [ KERNEL] [ 3.862677] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
12-18-17-806| [ KERNEL] [ 3.962454] usb 1-1.2: new full-speed USB device number 4 using dwc_otg
12-18-17-806| [ KERNEL] [ 4.121323] usb 1-1.2: New USB device found, idVendor=0403, idProduct=6001
12-18-17-806| [ KERNEL] [ 4.121334] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
12-18-17-806| [ KERNEL] [ 4.121341] usb 1-1.2: Product: USB Serial Converter
12-18-17-806| [ KERNEL] [ 4.121348] usb 1-1.2: Manufacturer: FTDI
12-18-17-806| [ KERNEL] [ 4.121355] usb 1-1.2: SerialNumber: FT8ZSKC1
12-18-17-806| [ KERNEL] [ 4.232446] usb 1-1.3: new full-speed USB device number 5 using dwc_otg
12-18-17-806| [ KERNEL] [ 4.423825] usb 1-1.3: New USB device found, idVendor=04e7, idProduct=0020
12-18-17-806| [ KERNEL] [ 4.423836] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
12-18-17-806| [ KERNEL] [ 4.423843] usb 1-1.3: Product: Elo TouchSystems 2700 IntelliTouch(r) USB Touchmonitor Interface
12-18-17-806| [ KERNEL] [ 4.423851] usb 1-1.3: Manufacturer: Elo TouchSystems, Inc.
12-18-17-806| [ KERNEL] [ 4.423858] usb 1-1.3: SerialNumber: 20I70971
12-18-17-806| [ KERNEL] [ 4.441156] input: Elo TouchSystems, Inc. Elo TouchSystems 2700 IntelliTouch(r) USB Touchmonitor Interface as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/input/input0
12-18-17-806| [ initrd] [ 13.430112] Keyboard not found.
12-18-17-806| [ initrd] [ 13.443137] Success: media /dev/mmcblk0p1 mounted to /bootmedia.
12-18-17-806| /--- FILE "/bootmedia/config.txt" -----------------------
12-18-17-806| | # For more options and information see
12-18-17-806| | # http://www.raspberrypi.org/documentatio ... fig-txt.md
12-18-17-806| | # Some settings may impact device functionality. See link above for details
12-18-17-806| | # uncomment if you get no picture on HDMI for a default "safe" mode
12-18-17-806| | #hdmi_safe=1
12-18-17-806| | # uncomment this if your display has a black border of unused pixels visible
12-18-17-806| | # and your display can output without overscan
12-18-17-806| | disable_overscan=1
12-18-17-806| | # uncomment if hdmi display is not detected and composite is being output
12-18-17-806| | hdmi_force_hotplug=1
12-18-17-806| | # uncomment to force a specific HDMI mode (this will force VGA)
12-18-17-806| | hdmi_group=2
12-18-17-806| | hdmi_mode=36
12-18-17-806| | # uncomment to force a HDMI mode rather than DVI. This can make audio work in
12-18-17-806| | # DMT (computer monitor) modes
12-18-17-806| | hdmi_drive=2
12-18-17-806| | # uncomment to increase signal to HDMI, if you have interference, blanking, or
12-18-17-806| | # no display
12-18-17-806| | config_hdmi_boost=4
12-18-17-806| | #uncomment to overclock the arm. 700 MHz is the default.
12-18-17-806| | #arm_freq=800
12-18-17-806| | disable_splash=1
12-18-17-806| | # U-Boot need it since https://github.com/raspberrypi/firmware/issues/527
12-18-17-806| | device_tree_address=0x02100000
12-18-17-806| | [pi3]
12-18-17-806| | dtoverlay=pi3-disable-bt
12-18-17-806| | [all]
12-18-17-806| | #hdmi_group=2
12-18-17-806| | # 800x600: hdmi_mode=9
12-18-17-806| | # 1024x768: hdmi_mode=16
12-18-17-806| | # 1280x1024: hdmi_mode=35
12-18-17-806| | # 1360x768: hdmi_mode=39
12-18-17-806| | # 1400x1050: hdmi_mode=42
12-18-17-806| | # 1440x900: hdmi_mode=47
12-18-17-806| | # 1600x1200: hdmi_mode=51
12-18-17-806| | # 1680x1050: hdmi_mode=58
12-18-17-806| | # 1366x768: hdmi_mode=81
12-18-17-806| | # 1920x1080: hdmi_mode=82
12-18-17-806| | # 1920x1200: hdmi_mode=69
12-18-17-806| | framebuffer_depth=16
12-18-17-806| | # Uncomment for 32-bit color. Note that it is about two
12-18-17-806| | # times slower than default 16-bit.
12-18-17-806| | # framebuffer_depth=32
12-18-17-806| | # Enable onboard audio (HDMI or jack).
12-18-17-806| | # dtparam=audio=on
12-18-17-806| | #removes the warning overlay.
12-18-17-806| | #avoid_warnings=1
12-18-17-806| | #additionally allows turbo when low-voltage is present.
12-18-17-806| | #avoid_warnings=2
12-18-17-806| \----------------------------------------------------
novotny
12-18-17-806| [ initrd] [ 13.449057] WTpassword present: 25ea23fd01d78ecd21e57b09f7234590.
12-18-17-806| /--- FILE "/bootmedia/configs/initrd.wtc" -----------------------
12-18-17-806| | clientIP = *
12-18-17-806| | config = local
12-18-17-806| | setupPassword = 25ea23fd01d78ecd21e57b09f7234590
12-18-17-806| [ initrd] [ 15.446026] Load ethernet drivers.
12-18-17-806| [ initrd] [ 15.446141] modprobe smsc95xx.
12-18-17-806| [ KERNEL] [ 15.455954] smsc95xx v1.0.5
12-18-17-806| [ KERNEL] [ 15.556218] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:d3:53:6f
12-18-17-806| [ KERNEL] [ 15.556407] usbcore: registered new interface driver smsc95xx
12-18-17-806| [ KERNEL] [ 15.644311] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
12-18-17-806| [ KERNEL] [ 17.111856] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC1E1
12-18-17-806| [ initrd] [ 17.145077] WTpassword present: 25ea23fd01d78ecd21e57b09f7234590.
12-18-17-806| [ initrd] [ 17.660154] dhcp: 342 bytes from 10.1.20.1.
12-18-17-806| [ initrd] [ 17.660266] 00000000:0000014200000000001100000A0114010A0114F5004300440142000002010600 ...B..............C.D.B......
12-18-17-806| [ initrd] [ 17.660339] 00000020:67458B6B00000000000000000A0114F50A0102030A011401B827EBD3536F0000 gE.k...................'..So..
12-18-17-806| [ initrd] [ 17.660409] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
12-18-17-806| [ initrd] [ 17.660478] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
12-18-17-806| [ initrd] [ 17.660546] 00000080:0000000000000000000000000000000000000000000000000000000000000000 ................................
12-18-17-806| [ initrd] [ 17.660614] 000000a0:0000000000000000000000000000000000000000000000000000000000000000 ................................
12-18-17-806| [ initrd] [ 17.660683] 000000c0:0000000000000000000000000000000000000000000000000000000000000000 ................................
12-18-17-806| [ initrd] [ 17.660750] 000000e0:0000000000000000000000000000000000000000000000000000000000000000 ................................
12-18-17-806| [ initrd] [ 19.220129] dhcp: 342 bytes from 10.1.20.1.
12-18-17-806| [ initrd] [ 19.220223] 00000000:0000014200000000001100000A0114010A0114F5004300440142000002010600 ...B..............C.D.B......
12-18-17-806| [ initrd] [ 19.220297] 00000020:67458B6B00000000000000000A0114F5000000000A011401B827EBD3536F0000 gE.k...................'..So..
12-18-17-806| [ initrd] [ 19.220366] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
12-18-17-806| [ initrd] [ 19.220435] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
12-18-17-806| [ initrd] [ 19.220528] 00000080:0000000000000000000000000000000000000000000000000000000000000000 ................................
12-18-17-806| [ initrd] [ 19.220596] 000000a0:0000000000000000000000000000000000000000000000000000000000000000 ................................
12-18-17-806| [ initrd] [ 19.220665] 000000c0:0000000000000000000000000000000000000000000000000000000000000000 ................................
12-18-17-806| [ initrd] [ 19.220732] 000000e0:0000000000000000000000000000000000000000000000000000000000000000 ................................
12-18-17-806| [ initrd] [ 19.260090] dhcp: server address 10.1.2.3.
12-18-17-806| [ initrd] [ 19.260164] dhcp: 10.1.20.245/255.255.252.0.
12-18-17-806| [ initrd] [ 19.260233] dhcp: default gateway 10.1.20.1.
12-18-17-806| [ initrd] [ 19.260300] dhcp: DNS 10.1.2.102.
12-18-17-806| [ initrd] [ 19.260367] dhcp: DNS 149.244.7.40.
12-18-17-806| [ initrd] [ 19.260433] dhcp: domain corp.knorr-bremse.com.
12-18-17-806| [ initrd] [ 19.260500] dhcp: TFTP from siaddr 10.1.2.3.
12-18-17-806| [ initrd] [ 19.260569] dhcp: TFTP 10.1.2.3.
12-18-17-806| [ initrd] [ 19.260636] No boot file from DHCP.
12-18-17-806| [ initrd] [ 19.260701] TFTP binary "", configs prefix "", using "/" slash.
12-18-17-806| WTC listener is active.
12-18-17-806| WTC broadcast listener is active.
12-18-17-806| Send broadcast WTCU discover.
12-18-17-806| [ pfac] [ 19.262646] Run /sbin/httpd.
12-18-17-806| [ initrd] [ 19.262716] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
12-18-17-806| [ pfac] [ 19.262815] Ok, PID 631.
12-18-17-806| [ httpd] [ 19.266453] HTTP Server, WTware 5.6.12/RPi
12-18-17-806| [ initrd] [ 19.385690] USB: 04e7:0020 Elo TouchSystems Touchscreen Interface (2700).
12-18-17-806| [ initrd] [ 19.385827] USB: 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter.
12-18-17-806| [ initrd] [ 19.385903] USB: 0424:9514 Standard Microsystems Corp. SMC9514 Hub.
12-18-17-806| [ initrd] [ 19.385974] USB: 0403:6001 Future Technology Devices International, Ltd FT232 Serial (UART) IC.
12-18-17-806| [ initrd] [ 19.386047] Copy /bootmedia/configs/config.wtc to /tmp/config.wtc.
12-18-17-806| [ initrd] [ 19.386831] Common local disk config:
12-18-17-806| /--- FILE "/tmp/config.wtc" -----------------------
12-18-17-806| | [BOM]
12-18-17-806| | server=brq_rdp_brokers
12-18-17-806| | loadbalanceinfo=tsv://MS Terminal Services Plugin.1.RDP
12-18-17-806| | clienthostname=BRQTERM20227
12-18-17-806| | managed=on
12-18-17-806| | user=svc.brq.terminal:TraceEdt32!
12-18-17-806| | domain=CORPORATE
12-18-17-806| | keepalive=1,1,1
12-18-17-806| | vnc=on
12-18-17-806| | onerror = 60
12-18-17-806| | vnc_password=Admin123
12-18-17-806| | serial=com1(usb)
12-18-17-806| | shell=C:\Program Files (x86)\SnT\Gral2\TraceViewer\TraceViewer2.exe "BRQTERM20227"
12-18-17-806| | connection
12-18-17-806| /--- FILE "/etc/config.compiled" -----------------------
12-18-17-806| | onerror=60
12-18-17-806| [ initrd] [ 19.389066] Hostname: "BRQTERM20227".
12-18-17-806| Everyone can control terminal by RSH.
12-18-17-806| RSH: listener is active.
12-18-17-806| [ httpd] [ 19.664989] Reread settings.
12-18-17-806| [ gm] [ 19.669468] WTware session manager 5.6.12/RPi.
12-18-17-806| [ httpd] [ 19.670329] Everyone can control terminal by HTTP.
12-18-17-806| [ gm] [ 19.671362] EV_ABS flag found. Add mouse event0: Elo TouchSystems, Inc. Elo TouchSystems 2700 IntelliTouch(r) USB Touchmonitor Interface.
12-18-17-806| [ gm] [ 19.671579] Display mode: 1280x1024, 16 bit, 0 Hz, modeline "", DDC enabled, connector 0.
12-18-17-806| [ gm] [ 19.683534] Framebuffer device found.
12-18-17-806| [ gm] [ 19.683613] LINELENBYTES 2560
12-18-17-806| [ gm] [ 19.683692] VLEN 2621440
12-18-17-806| [ gm] [ 19.696458] Use /lib/ui16.so.
12-18-17-806| [ gm] [ 19.718919] Load usb <-> serial bridges drivers.
12-18-17-806| [ gm] [ 19.721760] modprobe usbserial.
12-18-17-806| [ KERNEL] [ 19.732330] usbcore: registered new interface driver usbserial
12-18-17-806| [ KERNEL] [ 19.732461] usbcore: registered new interface driver usbserial_generic
12-18-17-806| [ KERNEL] [ 19.732540] usbserial: USB Serial support registered for generic
12-18-17-806| [ gm] [ 19.731472] modprobe pl2303.
12-18-17-806| [ gm] [ 19.741760] modprobe ftdi_sio.
12-18-17-806| [ KERNEL] [ 19.743010] usbcore: registered new interface driver pl2303
12-18-17-806| [ KERNEL] [ 19.743101] usbserial: USB Serial support registered for pl2303
12-18-17-806| [ KERNEL] [ 19.754835] usbcore: registered new interface driver ftdi_sio
12-18-17-806| [ KERNEL] [ 19.754986] usbserial: USB Serial support registered for FTDI USB Serial Device
12-18-17-806| [ KERNEL] [ 19.755348] ftdi_sio 1-1.2:1.0: FTDI USB Serial Device converter detected
12-18-17-806| [ KERNEL] [ 19.755631] usb 1-1.2: Detected FT232RL
12-18-17-806| [ KERNEL] [ 19.756985] usb 1-1.2: FTDI USB Serial Device converter now attached to ttyUSB0
12-18-17-806| [ gm] [ 19.755647] modprobe cp210x.
12-18-17-806| [ gm] [ 19.764927] modprobe ch341.
12-18-17-806| [ KERNEL] [ 19.765947] usbcore: registered new interface driver cp210x
12-18-17-806| [ KERNEL] [ 19.766128] usbserial: USB Serial support registered for cp210x
12-18-17-806| [ gm] [ 19.773484] modprobe metro-usb.
12-18-17-806| [ KERNEL] [ 19.774815] usbcore: registered new interface driver ch341
12-18-17-806| [ KERNEL] [ 19.774914] usbserial: USB Serial support registered for ch341-uart
12-18-17-806| [ gm] [ 19.782153] modprobe symbolserial.
12-18-17-806| [ KERNEL] [ 19.783427] usbcore: registered new interface driver metro_usb
12-18-17-806| [ KERNEL] [ 19.783524] usbserial: USB Serial support registered for Metrologic USB to Serial
12-18-17-806| [ KERNEL] [ 19.791892] usbcore: registered new interface driver symbolserial
12-18-17-806| [ KERNEL] [ 19.791990] usbserial: USB Serial support registered for symbol
12-18-17-806| [ gm] [ 19.790579] modprobe opticon.
12-18-17-806| [ gm] [ 19.799725] modprobe cdc-acm.
12-18-17-806| [ KERNEL] [ 19.800660] usbcore: registered new interface driver opticon
12-18-17-806| [ KERNEL] [ 19.800792] usbserial: USB Serial support registered for opticon
12-18-17-806| [ KERNEL] [ 19.810810] usbcore: registered new interface driver cdc_acm
12-18-17-806| [ KERNEL] [ 19.810823] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
12-18-17-806| [ gm] [ 19.852751] Run '/sbin/resolver 0x1ab0df8 dns [brq_rdp_brokers]', log '', env '', pid ''.
12-18-17-806| [ pfac] [ 19.852909] Run /sbin/resolver 0x1ab0df8 dns [brq_rdp_brokers].
12-18-17-806| [ gm] [ 19.852957] Everyone can control terminal by VNC.
12-18-17-806| [ gm] [ 19.853065] [VNC] Listener at port 5900.
12-18-17-806| [ pfac] [ 19.853190] Ok, PID 681.
12-18-17-806| [ gm] [ 19.859807] brq_rdp_brokers => 10.1.2.16.
12-18-17-806| [ gm] [ 19.859914] brq_rdp_brokers => 10.1.2.17.
12-18-17-806| [ pfac] [ 19.860632] Process pid 681 terminated, status 00000000.
12-18-17-806| [ gm] [ 19.868996] Free ram before fork terminal client /sbin/rdpclient (session 1): 927076 Kb.
12-18-17-806| [ pfac] [ 19.869084] Run /sbin/rdpclient 1.
12-18-17-806| [ gm] [ 19.869132] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
12-18-17-806| [ pfac] [ 19.869354] Ok, PID 682.
12-18-17-806| [ rdpclient 682] [ 19.876719] RDP Terminal Client, WTware 5.6.12/RPi, pipe 1, pid 682.
12-18-17-806| [ gm] [ 19.877387] ttyUSB0, single device.
12-18-17-806| [ gm] [ 19.877471] Run serial daemon for ttyUSB0.
12-18-17-806| [ pfac] [ 19.877549] Run /sbin/rdpdr[serial] 0 0.
12-18-17-806| [ gm] [ 19.877593] Run '/sbin/rdpdr[serial] 0 0', log '', env '', pid ''.
12-18-17-806| [ rdpclient 682] [ 19.877637] Use /lib/ui16.so.
12-18-17-806| [ pfac] [ 19.877799] Ok, PID 683.
12-18-17-806| [rdpdr-serial 0] [ 19.880895] RDP Serial Port Redirector, WTware 5.6.12/RPi, device ttyUSB0.
12-18-17-806| [ gm] [ 19.927648] COM1 => ttyUSB0.
12-18-17-806| [ rdpclient 682] [ 19.927954] Add serial redirection, COM1 in the session = hardware ttyUSB0.
12-18-17-806| [ rdpclient 682] [ 19.928497] Make RDP session with 10.1.2.16, 10.1.2.17, port 3389.
12-18-17-806| [rdpdr-serial 0] [ 19.928586] New client connection, id 1.
12-18-17-806| [ rdpclient 682] [ 19.928685] Username: "svc.brq.terminal".
12-18-17-806| [ rdpclient 682] [ 19.928850] Password: present.
12-18-17-806| [ rdpclient 682] [ 19.928935] No PIN.
12-18-17-806| [ rdpclient 682] [ 19.929046] Domain: "CORPORATE".
12-18-17-806| [ rdpclient 682] [ 19.929124] Shell: "C:\Program Files (x86)\SnT\Gral2\TraceViewer\TraceViewer2.exe "BRQTERM20227"".
12-18-17-806| [ rdpclient 682] [ 19.929212] No directory.
12-18-17-806| [ rdpclient 682] [ 19.929302] Window: 1280x1024@16.
12-18-17-806| [ rdpclient 682] [ 19.929389] PFlags 0x0000002F.
12-18-17-806| [ rdpclient 682] [ 19.929501] Keyboard 00000409:00000000.
12-18-17-806| [ rdpclient 682] [ 19.929588] My hostname "BRQTERM20227".
12-18-17-806| [ rdpclient 682] [ 19.929668] TCP: connection with 10.1.2.16:3389 established.
12-18-17-806| [ rdpclient 682] [ 19.929792] Turn keepalive on.
12-18-17-806| [ rdpclient 682] [ 19.930673] Free ram after buffers allocation: 926424 KB.
12-18-17-806| [ rdpclient 682] [ 19.930867] Use Balance Info 39 bytes: 'tsv://MS Terminal Services Plugin.1.RDP'.
12-18-17-806| [ rdpclient 682] [ 19.935806] Server supports GFX Pipeline.
12-18-17-806| [ rdpclient 682] [ 19.938474] Process RDP server certificate.
12-18-17-806| [ rdpclient 682] [ 19.938562] RDP4 encryption.
12-18-17-806| [ rdpclient 682] [ 19.944236] Enable font smoothing and Desktop Composition.
12-18-17-806| [ rdpclient 682] [ 20.016578] GFX codec.
12-18-17-806| [ rdpclient 682] [ 20.529746] Run 4 tile threads.
12-18-17-806| [ rdpclient 682] [ 21.034969] TS_STATUS_FINDING_DESTINATION
12-18-17-806| [ rdpclient 682] [ 21.041996] TS_STATUS_LOADING_DESTINATION
12-18-17-806| [ rdpclient 682] [ 21.042325] TS_STATUS_REDIRECTING_TO_DESTINATION
12-18-17-806| [ rdpclient 682] [ 21.232179] TS_STATUS_BRINGING_SESSION_ONLINE
12-18-17-806| [ rdpclient 682] [ 21.303171] Server Redirection flags 0x00000b0d.
12-18-17-806| [ rdpclient 682] [ 21.303269] Server 10.1.2.18.
12-18-17-806| [ gm] [ 21.303346] TSClient (sessionId 1, pid 682) gracefully end.
12-18-17-806| [ rdpclient 682] [ 21.303408] User "svc.brq.terminal".
12-18-17-806| [ rdpclient 682] [ 21.303495] Domain "CORPORATE".
12-18-17-806| [ rdpclient 682] [ 21.303577] Send Disconnect Provider Ultimatum.
12-18-17-806| [ gm] [ 21.303903] Free ram before fork terminal client /sbin/rdpclient (session 2): 913924 Kb.
12-18-17-806| [ gm] [ 21.303990] Run '/sbin/rdpclient 2', log '/tmp/rdpclient.out', env '', pid ''.
12-18-17-806| [ pfac] [ 21.304070] Run /sbin/rdpclient 2.
12-18-17-806| [ pfac] [ 21.304499] Ok, PID 690.
12-18-17-806| [rdpdr-serial 0] [ 21.311302] Close client connection 0 (id 1).
12-18-17-806| [ rdpclient 690] [ 21.311563] RDP Terminal Client, WTware 5.6.12/RPi, pipe 2, pid 690.
12-18-17-806| [ gm] [ 21.312300] ttyUSB0, single device.
12-18-17-806| [ gm] [ 21.312391] COM1 => ttyUSB0.
12-18-17-806| [ rdpclient 690] [ 21.312472] Use /lib/ui16.so.
12-18-17-806| [ rdpclient 690] [ 21.313083] Add serial redirection, COM1 in the session = hardware ttyUSB0.
12-18-17-806| [rdpdr-serial 0] [ 21.313286] New client connection, id 2.
12-18-17-806| [ rdpclient 690] [ 21.313344] Make RDP session with 10.1.2.18, port 3389.
12-18-17-806| [ rdpclient 690] [ 21.313429] Username: "svc.brq.terminal".
12-18-17-806| [ rdpclient 690] [ 21.313512] Password: present.
12-18-17-806| [ rdpclient 690] [ 21.313590] No PIN.
12-18-17-806| [ pfac] [ 21.313666] Process pid 682 terminated, status 00000009.
12-18-17-806| [ rdpclient 690] [ 21.313709] Domain: "CORPORATE".
12-18-17-806| [ rdpclient 690] [ 21.313787] Shell: "C:\Program Files (x86)\SnT\Gral2\TraceViewer\TraceViewer2.exe "BRQTERM20227"".
12-18-17-806| [ rdpclient 690] [ 21.313870] No directory.
12-18-17-806| [ rdpclient 690] [ 21.313951] Window: 1280x1024@16.
12-18-17-806| [ rdpclient 690] [ 21.314032] PFlags 0x0000002F.
12-18-17-806| [ rdpclient 690] [ 21.314109] Keyboard 00000409:00000000.
12-18-17-806| [ rdpclient 690] [ 21.314188] My hostname "BRQTERM20227".
12-18-17-806| [ rdpclient 690] [ 21.314266] TCP: connecting to 10.1.2.18:3389.
12-18-17-806| [ rdpclient 690] [ 21.314345] TCP: connection with 10.1.2.18:3389 established.
12-18-17-806| [ rdpclient 690] [ 21.314425] Turn keepalive on.
12-18-17-806| [ rdpclient 690] [ 21.314959] Free ram after buffers allocation: 926800 KB.
12-18-17-806| [ rdpclient 690] [ 21.315049] Empty Balance Info.
12-18-17-806| [ rdpclient 690] [ 21.319142] Server supports GFX Pipeline.
12-18-17-806| [ rdpclient 690] [ 21.319227] Redirected Session ID 0x00000000.
12-18-17-806| [ rdpclient 690] [ 21.322119] Process RDP server certificate.
12-18-17-806| [ rdpclient 690] [ 21.322209] RDP5 encryption (X.509).
12-18-17-806| [ rdpclient 690] [ 21.326926] Enable font smoothing and Desktop Composition.
12-18-17-806| [ rdpclient 690] [ 21.456664] GFX codec.
12-18-17-806| [ rdpclient 690] [ 22.052823] Run 4 tile threads.
12-18-17-806| [ rdpclient 690] [ 22.315280] errorInfo 0x00000000.
12-18-17-806| [ rdpclient 690] [ 22.659233] SessionId 0x00000026: CORPORATE\svc.brq.terminal.
12-18-17-806| [ KERNEL] [ 27.642085] random: crng init done
12-18-17-806| [ rdpclient 690] [ 99.288861] errorInfo 0x00000002.
12-18-17-806| [ rdpclient 690] [ 99.288991] ERRINFO_RPC_INITIATED_LOGOFF
12-18-17-806| [ rdpclient 690] [ 99.429487] Receive Disconnect Provider Ultimatum.
12-18-17-806| [ gm] [ 99.429575] TSClient (sessionId 2, pid 690) gracefully end.
12-18-17-806| [rdpdr-serial 0] [ 99.437641] Close client connection 0 (id 2).
12-18-17-806| [ pfac] [ 99.437906] Process pid 690 terminated, status 00000009.
12-18-17-806| [ gm] [ 99.439268] Run '/sbin/resolver 0x1ab0df8 dns [brq_rdp_brokers]', log '', env '', pid ''.
12-18-17-806| [ pfac] [ 99.439366] Run /sbin/resolver 0x1ab0df8 dns [brq_rdp_brokers].
12-18-17-806| [ pfac] [ 99.439733] Ok, PID 701.
12-18-17-806| [ gm] [ 99.445919] brq_rdp_brokers => 10.1.2.17.
12-18-17-806| [ gm] [ 99.446025] brq_rdp_brokers => 10.1.2.16.
12-18-17-806| [ pfac] [ 99.446312] Process pid 701 terminated, status 00000000.
12-18-17-806| [ gm] [ 99.455054] Free ram before fork terminal client /sbin/rdpclient (session 3): 927028 Kb.
12-18-17-806| [ pfac] [ 99.455146] Run /sbin/rdpclient 3.
12-18-17-806| [ gm] [ 99.455190] Run '/sbin/rdpclient 3', log '/tmp/rdpclient.out', env '', pid ''.
12-18-17-806| [ pfac] [ 99.455419] Ok, PID 702.
12-18-17-806| [ rdpclient 702] [ 99.462565] RDP Terminal Client, WTware 5.6.12/RPi, pipe 3, pid 702.
12-18-17-806| [ gm] [ 99.463290] ttyUSB0, single device.
12-18-17-806| [ gm] [ 99.463372] COM1 => ttyUSB0.
12-18-17-806| [ rdpclient 702] [ 99.463415] Use /lib/ui16.so.
12-18-17-806| [ rdpclient 702] [ 99.464180] Add serial redirection, COM1 in the session = hardware ttyUSB0.
12-18-17-806| [rdpdr-serial 0] [ 99.464510] New client connection, id 3.
12-18-17-806| [ rdpclient 702] [ 99.464557] Make RDP session with 10.1.2.17, 10.1.2.16, port 3389.
12-18-17-806| [ rdpclient 702] [ 99.464649] Username: "svc.brq.terminal".
12-18-17-806| [ rdpclient 702] [ 99.464730] Password: present.
12-18-17-806| [ rdpclient 702] [ 99.464813] No PIN.
12-18-17-806| [ rdpclient 702] [ 99.464893] Domain: "CORPORATE".
12-18-17-806| [ rdpclient 702] [ 99.464971] Shell: "C:\Program Files (x86)\SnT\Gral2\TraceViewer\TraceViewer2.exe "BRQTERM20227"".
12-18-17-806| [ rdpclient 702] [ 99.465060] No directory.
12-18-17-806| [ rdpclient 702] [ 99.465139] Window: 1280x1024@16.
12-18-17-806| [ rdpclient 702] [ 99.465220] PFlags 0x0000002F.
12-18-17-806| [ rdpclient 702] [ 99.465304] Keyboard 00000409:00000000.
12-18-17-806| [ rdpclient 702] [ 99.465397] My hostname "BRQTERM20227".
12-18-17-806| [ rdpclient 702] [ 99.465494] TCP: connection with 10.1.2.17:3389 established.
12-18-17-806| [ rdpclient 702] [ 99.465581] Turn keepalive on.
12-18-17-806| [ rdpclient 702] [ 99.466586] Free ram after buffers allocation: 926668 KB.
12-18-17-806| [ rdpclient 702] [ 99.466804] Use Balance Info 39 bytes: 'tsv://MS Terminal Services Plugin.1.RDP'.
12-18-17-806| [ rdpclient 702] [ 99.472179] Server supports GFX Pipeline.
12-18-17-806| [ rdpclient 702] [ 99.474802] Process RDP server certificate.
12-18-17-806| [ rdpclient 702] [ 99.474888] RDP4 encryption.
12-18-17-806| [ rdpclient 702] [ 99.480739] Enable font smoothing and Desktop Composition.
12-18-17-806| [ rdpclient 702] [ 99.549627] GFX codec.
12-18-17-806| [ rdpclient 702] [ 100.040855] Run 4 tile threads.
12-18-17-806| [ rdpclient 702] [ 100.682776] TS_STATUS_LOADING_DESTINATION
12-18-17-806| [ rdpclient 702] [ 100.683151] TS_STATUS_REDIRECTING_TO_DESTINATION
12-18-17-806| [ rdpclient 702] [ 100.706564] TS_STATUS_BRINGING_SESSION_ONLINE
12-18-17-806| [ rdpclient 702] [ 100.781236] Server Redirection flags 0x00000b0d.
12-18-17-806| [ rdpclient 702] [ 100.781338] Server 10.1.2.18.
12-18-17-806| [ gm] [ 100.781426] TSClient (sessionId 3, pid 702) gracefully end.
12-18-17-806| [ rdpclient 702] [ 100.781473] User "svc.brq.terminal".
12-18-17-806| [ rdpclient 702] [ 100.781557] Domain "CORPORATE".
12-18-17-806| [ rdpclient 702] [ 100.781641] Send Disconnect Provider Ultimatum.
12-18-17-806| [ gm] [ 100.781933] Free ram before fork terminal client /sbin/rdpclient (session 4): 913788 Kb.
12-18-17-806| [ pfac] [ 100.782023] Run /sbin/rdpclient 4.
12-18-17-806| [ gm] [ 100.782066] Run '/sbin/rdpclient 4', log '/tmp/rdpclient.out', env '', pid ''.
12-18-17-806| [ pfac] [ 100.782532] Ok, PID 709.
12-18-17-806| [rdpdr-serial 0] [ 100.789234] Close client connection 0 (id 3).
12-18-17-806| [ rdpclient 709] [ 100.789500] RDP Terminal Client, WTware 5.6.12/RPi, pipe 4, pid 709.
12-18-17-806| [ pfac] [ 100.790094] Process pid 702 terminated, status 00000009.
12-18-17-806| [ gm] [ 100.790293] ttyUSB0, single device.
12-18-17-806| [ gm] [ 100.790382] COM1 => ttyUSB0.
12-18-17-806| [ rdpclient 709] [ 100.790463] Use /lib/ui16.so.
12-18-17-806| [ rdpclient 709] [ 100.791086] Add serial redirection, COM1 in the session = hardware ttyUSB0.
12-18-17-806| [rdpdr-serial 0] [ 100.791294] New client connection, id 4.
12-18-17-806| [ rdpclient 709] [ 100.791354] Make RDP session with 10.1.2.18, port 3389.
12-18-17-806| [ rdpclient 709] [ 100.791439] Username: "svc.brq.terminal".
12-18-17-806| [ rdpclient 709] [ 100.791524] Password: present.
12-18-17-806| [ rdpclient 709] [ 100.791607] No PIN.
12-18-17-806| [ rdpclient 709] [ 100.791690] Domain: "CORPORATE".
12-18-17-806| [ rdpclient 709] [ 100.791776] Shell: "C:\Program Files (x86)\SnT\Gral2\TraceViewer\TraceViewer2.exe "BRQTERM20227"".
12-18-17-806| [ rdpclient 709] [ 100.791862] No directory.
12-18-17-806| [ rdpclient 709] [ 100.791942] Window: 1280x1024@16.
12-18-17-806| [ rdpclient 709] [ 100.792026] PFlags 0x0000002F.
12-18-17-806| [ rdpclient 709] [ 100.792105] Keyboard 00000409:00000000.
12-18-17-806| [ rdpclient 709] [ 100.792184] My hostname "BRQTERM20227".
12-18-17-806| [ rdpclient 709] [ 100.792265] TCP: connecting to 10.1.2.18:3389.
12-18-17-806| [ rdpclient 709] [ 100.792343] TCP: connection with 10.1.2.18:3389 established.
12-18-17-806| [ rdpclient 709] [ 100.792422] Turn keepalive on.
12-18-17-806| [ rdpclient 709] [ 100.793016] Free ram after buffers allocation: 926800 KB.
12-18-17-806| [ rdpclient 709] [ 100.793104] Empty Balance Info.
12-18-17-806| [ rdpclient 709] [ 100.797752] Server supports GFX Pipeline.
12-18-17-806| [ rdpclient 709] [ 100.797837] Redirected Session ID 0x00000000.
12-18-17-806| [ rdpclient 709] [ 100.800994] Process RDP server certificate.
12-18-17-806| [ rdpclient 709] [ 100.801081] RDP5 encryption (X.509).
12-18-17-806| [ rdpclient 709] [ 100.816995] Enable font smoothing and Desktop Composition.
12-18-17-806| [ rdpclient 709] [ 100.977186] GFX codec.
12-18-17-806| [ rdpclient 709] [ 101.604876] Run 4 tile threads.
12-18-17-806| [ rdpclient 709] [ 101.914218] LOGON_EX_LOGONERRORS: ErrorNotificationType 0xfffffffe, ErrorNotificationData 0x00000058.
12-18-17-806| [ rdpclient 709] [ 102.008104] SessionId 0x00000058: CORPORATE\svc.brq.terminal.
12-18-17-806| [ gm] [ 118.820048] [TOUCHSCREEN] ==================================================
12-18-17-806| [ gm] [ 118.820204] [TOUCHSCREEN] Hardware configuration:
12-18-17-806| [ gm] [ 118.820286] [TOUCHSCREEN] touchscreen = 0..4095,0..4095
12-18-17-806| [ gm] [ 118.820363] [TOUCHSCREEN] ==================================================
12-18-17-806| [ gm] [32338.480671] Close input device 'Elo TouchSystems, Inc. Elo TouchSystems 2700 IntelliTouch(r) USB Touchmonitor Interface', errno 19.
12-18-17-806| [ KERNEL] [32338.482567] usb 1-1.3: USB disconnect, device number 5
12-18-17-806| [ KERNEL] [33263.192571] usb 1-1.3: new full-speed USB device number 6 using dwc_otg
12-18-17-806| [ KERNEL] [33263.383938] usb 1-1.3: New USB device found, idVendor=04e7, idProduct=0020
12-18-17-806| [ KERNEL] [33263.383949] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
12-18-17-806| [ KERNEL] [33263.383957] usb 1-1.3: Product: Elo TouchSystems 2700 IntelliTouch(r) USB Touchmonitor Interface
12-18-17-806| [ KERNEL] [33263.383964] usb 1-1.3: Manufacturer: Elo TouchSystems, Inc.
12-18-17-806| [ KERNEL] [33263.383971] usb 1-1.3: SerialNumber: 20I70971
12-18-17-806| [ KERNEL] [33263.399366] input: Elo TouchSystems, Inc. Elo TouchSystems 2700 IntelliTouch(r) USB Touchmonitor Interface as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/input/input1
12-18-17-806| [ gm] [33266.992504] Close input device 'Elo TouchSystems, Inc. Elo TouchSystems 2700 IntelliTouch(r) USB Touchmonitor Interface', errno 19.
12-18-17-806| [ KERNEL] [33266.994526] usb 1-1.3: USB disconnect, device number 6
12-18-17-806| [ KERNEL] [57991.772655] usb 1-1.3: new full-speed USB device number 7 using dwc_otg
12-18-17-806| [ KERNEL] [57991.964014] usb 1-1.3: New USB device found, idVendor=04e7, idProduct=0020
12-18-17-806| [ KERNEL] [57991.964026] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
12-18-17-806| [ KERNEL] [57991.964034] usb 1-1.3: Product: Elo TouchSystems 2700 IntelliTouch(r) USB Touchmonitor Interface
12-18-17-806| [ KERNEL] [57991.964041] usb 1-1.3: Manufacturer: Elo TouchSystems, Inc.
12-18-17-806| [ KERNEL] [57991.964047] usb 1-1.3: SerialNumber: 20I70971
12-18-17-806| [ KERNEL] [57991.979431] input: Elo TouchSystems, Inc. Elo TouchSystems 2700 IntelliTouch(r) USB Touchmonitor Interface as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/input/input2
12-18-17-806| [ rdpclient 709] [70431.831578] errorInfo 0x0000000c.
12-18-17-806| [ rdpclient 709] [70431.831760] ERRINFO_LOGOFF_BY_USER
12-18-17-806| [ rdpclient 709] [70431.956547] Receive Disconnect Provider Ultimatum.
12-18-17-806| [ gm] [70431.960195] TSClient (sessionId 4, pid 709) gracefully end.
12-18-17-806| [ gm] [70431.966370] Run '/sbin/resolver 0x1ab0df8 dns [brq_rdp_brokers]', log '', env '', pid ''.
12-18-17-806| [ pfac] [70431.966610] Run /sbin/resolver 0x1ab0df8 dns [brq_rdp_brokers].
12-18-17-806| [ pfac] [70431.966991] Ok, PID 1022.
12-18-17-806| [ gm] [70431.973763] brq_rdp_brokers => 10.1.2.16.
12-18-17-806| [ gm] [70431.973914] brq_rdp_brokers => 10.1.2.17.
12-18-17-806| [ pfac] [70431.974553] Process pid 1022 terminated, status 00000000.
12-18-17-806| [ gm] [70431.983095] Free ram before fork terminal client /sbin/rdpclient (session 5): 922364 Kb.
12-18-17-806| [ gm] [70431.983320] Run '/sbin/rdpclient 5', log '/tmp/rdpclient.out', env '', pid ''.
12-18-17-806| [ pfac] [70431.983573] Run /sbin/rdpclient 5.
12-18-17-806| [ pfac] [70431.983979] Ok, PID 1023.
12-18-17-806| [rdpdr-serial 0] [70431.986253] Close client connection 0 (id 4).
12-18-17-806| [ pfac] [70431.986359] Process pid 709 terminated, status 00000009.
12-18-17-806| [rdpclient 1023] [70431.991427] RDP Terminal Client, WTware 5.6.12/RPi, pipe 5, pid 1023.
12-18-17-806| [ gm] [70431.992296] ttyUSB0, single device.
12-18-17-806| [rdpclient 1023] [70431.992389] Use /lib/ui16.so.
12-18-17-806| [ gm] [70431.992537] COM1 => ttyUSB0.
12-18-17-806| [rdpdr-serial 0] [70431.993711] New client connection, id 5.
12-18-17-806| [rdpclient 1023] [70431.993818] Add serial redirection, COM1 in the session = hardware ttyUSB0.
12-18-17-806| [rdpclient 1023] [70431.993920] Make RDP session with 10.1.2.16, 10.1.2.17, port 3389.
12-18-17-806| [rdpclient 1023] [70431.994002] Username: "svc.brq.terminal".
12-18-17-806| [rdpclient 1023] [70431.994079] Password: present.
12-18-17-806| [rdpclient 1023] [70431.994175] No PIN.
12-18-17-806| [rdpclient 1023] [70431.994253] Domain: "CORPORATE".
12-18-17-806| [rdpclient 1023] [70431.994332] Shell: "C:\Program Files (x86)\SnT\Gral2\TraceViewer\TraceViewer2.exe "BRQTERM20227"".
12-18-17-806| [rdpclient 1023] [70431.994415] No directory.
12-18-17-806| [rdpclient 1023] [70431.994492] Window: 1280x1024@16.
12-18-17-806| [rdpclient 1023] [70431.994570] PFlags 0x0000002F.
12-18-17-806| [rdpclient 1023] [70431.994648] Keyboard 00000409:00000000.
12-18-17-806| [rdpclient 1023] [70431.994725] My hostname "BRQTERM20227".
12-18-17-806| [rdpclient 1023] [70431.996890] TCP: connection with 10.1.2.16:3389 established.
12-18-17-806| [rdpclient 1023] [70431.997075] Turn keepalive on.
12-18-17-806| [rdpclient 1023] [70431.997156] Free ram after buffers allocation: 926768 KB.
12-18-17-806| [rdpclient 1023] [70431.997235] Use Balance Info 39 bytes: 'tsv://MS Terminal Services Plugin.1.RDP'.
12-18-17-806| [rdpclient 1023] [70432.002693] Server supports GFX Pipeline.
12-18-17-806| [rdpclient 1023] [70432.005380] Process RDP server certificate.
12-18-17-806| [rdpclient 1023] [70432.005464] RDP4 encryption.
12-18-17-806| [rdpclient 1023] [70432.011066] Enable font smoothing and Desktop Composition.
12-18-17-806| [rdpclient 1023] [70432.083323] GFX codec.
12-18-17-806| [rdpclient 1023] [70432.586869] Run 4 tile threads.
12-18-17-806| [rdpclient 1023] [70433.023117] TS_STATUS_FINDING_DESTINATION
12-18-17-806| [rdpclient 1023] [70433.029974] TS_STATUS_LOADING_DESTINATION
12-18-17-806| [rdpclient 1023] [70433.030308] TS_STATUS_REDIRECTING_TO_DESTINATION
12-18-17-806| [rdpclient 1023] [70433.061982] TS_STATUS_BRINGING_SESSION_ONLINE
12-18-17-806| [rdpclient 1023] [70433.160840] Server Redirection flags 0x00000b0d.
12-18-17-806| [rdpclient 1023] [70433.161020] Server 10.1.2.18.
12-18-17-806| [rdpclient 1023] [70433.161148] User "svc.brq.terminal".
12-18-17-806| [rdpclient 1023] [70433.161272] Domain "CORPORATE".
12-18-17-806| [rdpclient 1023] [70433.161411] Send Disconnect Provider Ultimatum.
12-18-17-806| [ gm] [70433.161695] TSClient (sessionId 5, pid 1023) gracefully end.
12-18-17-806| [ gm] [70433.162187] Free ram before fork terminal client /sbin/rdpclient (session 6): 914020 Kb.
12-18-17-806| [ gm] [70433.162340] Run '/sbin/rdpclient 6', log '/tmp/rdpclient.out', env '', pid ''.
12-18-17-806| [ pfac] [70433.162862] Run /sbin/rdpclient 6.
12-18-17-806| [ pfac] [70433.162978] Ok, PID 1030.
12-18-17-806| [rdpdr-serial 0] [70433.168778] Close client connection 0 (id 5).
12-18-17-806| [ pfac] [70433.169297] Process pid 1023 terminated, status 00000009.
12-18-17-806| [rdpclient 1030] [70433.170237] RDP Terminal Client, WTware 5.6.12/RPi, pipe 6, pid 1030.
12-18-17-806| [ gm] [70433.171076] ttyUSB0, single device.
12-18-17-806| [rdpclient 1030] [70433.171167] Use /lib/ui16.so.
12-18-17-806| [ gm] [70433.171312] COM1 => ttyUSB0.
12-18-17-806| [rdpclient 1030] [70433.171839] Add serial redirection, COM1 in the session = hardware ttyUSB0.
12-18-17-806| [rdpdr-serial 0] [70433.172032] New client connection, id 6.
12-18-17-806| [rdpclient 1030] [70433.172078] Make RDP session with 10.1.2.18, port 3389.
12-18-17-806| [rdpclient 1030] [70433.172159] Username: "svc.brq.terminal".
12-18-17-806| [rdpclient 1030] [70433.172289] Password: present.
12-18-17-806| [rdpclient 1030] [70433.172366] No PIN.
12-18-17-806| [rdpclient 1030] [70433.172441] Domain: "CORPORATE".
12-18-17-806| [rdpclient 1030] [70433.172703] Shell: "C:\Program Files (x86)\SnT\Gral2\TraceViewer\TraceViewer2.exe "BRQTERM20227"".
12-18-17-806| [rdpclient 1030] [70433.172808] No directory.
12-18-17-806| [rdpclient 1030] [70433.172888] Window: 1280x1024@16.
12-18-17-806| [rdpclient 1030] [70433.172966] PFlags 0x0000002F.
12-18-17-806| [rdpclient 1030] [70433.173043] Keyboard 00000409:00000000.
12-18-17-806| [rdpclient 1030] [70433.173123] My hostname "BRQTERM20227".
12-18-17-806| [rdpclient 1030] [70433.173204] TCP: connecting to 10.1.2.18:3389.
12-18-17-806| [rdpclient 1030] [70433.173284] TCP: connection with 10.1.2.18:3389 established.
12-18-17-806| [rdpclient 1030] [70433.173363] Turn keepalive on.
12-18-17-806| [rdpclient 1030] [70433.173673] Free ram after buffers allocation: 927188 KB.
12-18-17-806| [rdpclient 1030] [70433.173803] Empty Balance Info.
12-18-17-806| [rdpclient 1030] [70433.179119] Server supports GFX Pipeline.
12-18-17-806| [rdpclient 1030] [70433.179230] Redirected Session ID 0x00000000.
12-18-17-806| [rdpclient 1030] [70433.182239] Process RDP server certificate.
12-18-17-806| [rdpclient 1030] [70433.182402] RDP5 encryption (X.509).
12-18-17-806| [rdpclient 1030] [70433.187207] Enable font smoothing and Desktop Composition.
12-18-17-806| [rdpclient 1030] [70433.332252] GFX codec.
12-18-17-806| [rdpclient 1030] [70433.898406] Run 4 tile threads.
12-18-17-806| [rdpclient 1030] [70434.175610] LOGON_EX_LOGONERRORS: ErrorNotificationType 0xfffffffe, ErrorNotificationData 0x00000051.
12-18-17-806| [rdpclient 1030] [70434.206701] SessionId 0x00000051: CORPORATE\svc.brq.terminal.
12-18-17-806| [ gm] [72068.320092] [VNC] Connection from 10.1.2.16.
12-18-17-806| [ gm] [72068.321155] [VNC] Client VNC version 8 (RFB 003.008).
12-18-17-806| [ gm] [72068.321614] [VNC] Password ok.
12-18-17-806| [ gm] [72069.387455] [VNC] bits-per-pixel 16, depth 16, big-endian false, true-colour true.
12-18-17-806| [ gm] [72069.387553] [VNC] red-max 0x001f, green-max 0x003f, blue-max 0x001f.
12-18-17-806| [ gm] [72069.387646] [VNC] red-shift 11, green-shift 5, blue-shift 0.
12-18-17-806| [ gm] [72069.387724] [VNC] 16-bit server, 16-bit client.
12-18-17-806| [ gm] [72069.387814] [VNC] 24 encodings: 5 17 16 10 9 8 6 4 2 1 0 -250 -239 -232 -26 -65530 -224 -223 -32768 -32767 -32764 -32766 -32765 -1063131698.
12-18-17-806| [ gm] [72069.388808] [VNC] bits-per-pixel 16, depth 16, big-endian false, true-colour true.
12-18-17-806| [ gm] [72069.388891] [VNC] red-max 0x001f, green-max 0x003f, blue-max 0x001f.
12-18-17-806| [ gm] [72069.388968] [VNC] red-shift 11, green-shift 5, blue-shift 0.
12-18-17-806| [ gm] [72069.389043] [VNC] 16-bit server, 16-bit client.
12-18-17-806| [ gm] [72069.389117] [VNC] 24 encodings: 5 17 16 10 9 8 6 4 2 1 0 -250 -239 -232 -26 -65530 -224 -223 -32768 -32767 -32764 -32766 -32765 -1063131698.
12-18-17-806| [ gm] [86027.568479] Close input device 'Elo TouchSystems, Inc. Elo TouchSystems 2700 IntelliTouch(r) USB Touchmonitor Interface', errno 19.
12-18-17-806| [ KERNEL] [86027.570688] usb 1-1.3: USB disconnect, device number 7
12-18-17-806| [ KERNEL] [86384.472750] usb 1-1.3: new full-speed USB device number 8 using dwc_otg
12-18-17-806| [ KERNEL] [86384.664103] usb 1-1.3: New USB device found, idVendor=04e7, idProduct=0020
12-18-17-806| [ KERNEL] [86384.664114] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
12-18-17-806| [ KERNEL] [86384.664122] usb 1-1.3: Product: Elo TouchSystems 2700 IntelliTouch(r) USB Touchmonitor Interface
12-18-17-806| [ KERNEL] [86384.664129] usb 1-1.3: Manufacturer: Elo TouchSystems, Inc.
12-18-17-806| [ KERNEL] [86384.664136] usb 1-1.3: SerialNumber: 20I70971
12-18-17-806| [ KERNEL] [86384.679548] input: Elo TouchSystems, Inc. Elo TouchSystems 2700 IntelliTouch(r) USB Touchmonitor Interface as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/input/input3
12-18-17-806| [ gm] [104755.248652] Close input device 'Elo TouchSystems, Inc. Elo TouchSystems 2700 IntelliTouch(r) USB Touchmonitor Interface', errno 19.
12-18-17-806| [ KERNEL] [104755.250748] usb 1-1.3: USB disconnect, device number 8
12-18-17-806| [ KERNEL] [112640.342842] usb 1-1.3: new full-speed USB device number 9 using dwc_otg
12-18-17-806| [ KERNEL] [112640.534180] usb 1-1.3: New USB device found, idVendor=04e7, idProduct=0020
12-18-17-806| [ KERNEL] [112640.534191] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
12-18-17-806| [ KERNEL] [112640.534199] usb 1-1.3: Product: Elo TouchSystems 2700 IntelliTouch(r) USB Touchmonitor Interface
12-18-17-806| [ KERNEL] [112640.534206] usb 1-1.3: Manufacturer: Elo TouchSystems, Inc.
12-18-17-806| [ KERNEL] [112640.534213] usb 1-1.3: SerialNumber: 20I70971
12-18-17-806| [ KERNEL] [112640.549603] input: Elo TouchSystems, Inc. Elo TouchSystems 2700 IntelliTouch(r) USB Touchmonitor Interface as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/input/input4
12-18-17-806| [ gm] [114816.048634] Close input device 'Elo TouchSystems, Inc. Elo TouchSystems 2700 IntelliTouch(r) USB Touchmonitor Interface', errno 19.
12-18-17-806| [ KERNEL] [114816.050855] usb 1-1.3: USB disconnect, device number 9
12-18-17-806| [ KERNEL] [303201.113498] usb 1-1.3: new full-speed USB device number 10 using dwc_otg
12-18-17-806| [ KERNEL] [303201.304902] usb 1-1.3: New USB device found, idVendor=04e7, idProduct=0020
12-18-17-806| [ KERNEL] [303201.304916] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
12-18-17-806| [ KERNEL] [303201.304924] usb 1-1.3: Product: Elo TouchSystems 2700 IntelliTouch(r) USB Touchmonitor Interface
12-18-17-806| [ KERNEL] [303201.304932] usb 1-1.3: Manufacturer: Elo TouchSystems, Inc.
12-18-17-806| [ KERNEL] [303201.304939] usb 1-1.3: SerialNumber: 20I70971
12-18-17-806| [ KERNEL] [303201.320331] input: Elo TouchSystems, Inc. Elo TouchSystems 2700 IntelliTouch(r) USB Touchmonitor Interface as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/input/input5
12-18-17-806| Send WTCU discover to 10.1.21.12.
12-18-17-806| [ KERNEL] [374098.483640] usb 1-1.3: USB disconnect, device number 10
12-18-17-806| [ gm] [374098.480801] Close input device 'Elo TouchSystems, Inc. Elo TouchSystems 2700 IntelliTouch(r) USB Touchmonitor Interface', errno 19.
12-18-17-806| [ KERNEL] [403937.623840] usb 1-1.3: new full-speed USB device number 11 using dwc_otg
12-18-17-806| [ KERNEL] [403937.815200] usb 1-1.3: New USB device found, idVendor=04e7, idProduct=0020
12-18-17-806| [ KERNEL] [403937.815213] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
12-18-17-806| [ KERNEL] [403937.815221] usb 1-1.3: Product: Elo TouchSystems 2700 IntelliTouch(r) USB Touchmonitor Interface
12-18-17-806| [ KERNEL] [403937.815228] usb 1-1.3: Manufacturer: Elo TouchSystems, Inc.
12-18-17-806| [ KERNEL] [403937.815235] usb 1-1.3: SerialNumber: 20I70971
12-18-17-806| [ KERNEL] [403937.830657] input: Elo TouchSystems, Inc. Elo TouchSystems 2700 IntelliTouch(r) USB Touchmonitor Interface as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/input/input6
12-18-17-811| Connection from wtc.exe at 10.1.21.12.
novotny
Re: WTware on Raspberry Pi 3 with USB scanner
Post by novotny » Tue Sep 19, 2017 5:18 pm
Sorry, this is LOG of terminal with USB scanner, that is working fine
16-07-24-634| WTware 5.6.13/RPi supervisor.
16-07-24-634| [ KERNEL] [ 0.000000] Booting Linux on physical CPU 0x0
16-07-24-634| [ KERNEL] [ 0.000000] Linux version 4.9.47 (aka@c12) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.4) ) #3 SMP Fri Sep 8 01:20:26 +04 2017
16-07-24-634| [ KERNEL] [ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
16-07-24-634| [ KERNEL] [ 0.000000] CPU: div instructions available: patching division code
16-07-24-634| [ KERNEL] [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
16-07-24-634| [ KERNEL] [ 0.000000] OF: fdt:Machine model: Raspberry Pi 3 Model B Rev 1.2
16-07-24-634| [ KERNEL] [ 0.000000] cma: Reserved 8 MiB at 0x3a800000
16-07-24-634| [ KERNEL] [ 0.000000] Memory policy: Data cache writealloc
16-07-24-634| [ KERNEL] [ 0.000000] On node 0 totalpages: 241664
16-07-24-634| [ KERNEL] [ 0.000000] free_area_init_node: node 0, pgdat 80b22cc0, node_mem_map b9faa000
16-07-24-634| [ KERNEL] [ 0.000000] Normal zone: 2124 pages used for memmap
16-07-24-634| [ KERNEL] [ 0.000000] Normal zone: 0 pages reserved
16-07-24-634| [ KERNEL] [ 0.000000] Normal zone: 241664 pages, LIFO batch:31
16-07-24-634| [ KERNEL] [ 0.000000] percpu: Embedded 11 pages/cpu @b9f70000 s16076 r8192 d20788 u45056
16-07-24-634| [ KERNEL] [ 0.000000] pcpu-alloc: s16076 r8192 d20788 u45056 alloc=11*4096
16-07-24-634| [ KERNEL] [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
16-07-24-634| [ KERNEL] [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 239540
16-07-24-634| [ KERNEL] [ 0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=1280 bcm2708_fb.fbheight=1024 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 wtware.dhcp_retries=300 quiet wtboot=mmc
16-07-24-634| [ KERNEL] [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
16-07-24-634| [ KERNEL] [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
16-07-24-634| [ KERNEL] [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
16-07-24-634| [ KERNEL] [ 0.000000] Memory: 938116K/966656K available (5120K kernel code, 143K rwdata, 920K rodata, 4096K init, 373K bss, 20348K reserved, 8192K cma-reserved)
16-07-24-634| [ KERNEL] [ 0.000000] Virtual kernel memory layout:
16-07-24-634| [ KERNEL] [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
16-07-24-634| [ KERNEL] [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
16-07-24-634| [ KERNEL] [ 0.000000] vmalloc : 0xbb800000 - 0xff800000 (1088 MB)
16-07-24-634| [ KERNEL] [ 0.000000] lowmem : 0x80000000 - 0xbb000000 ( 944 MB)
16-07-24-634| [ KERNEL] [ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
16-07-24-634| [ KERNEL] [ 0.000000] .text : 0x80008000 - 0x80600000 (6112 kB)
16-07-24-634| [ KERNEL] [ 0.000000] .init : 0x80700000 - 0x80b00000 (4096 kB)
16-07-24-634| [ KERNEL] [ 0.000000] .data : 0x80b00000 - 0x80b23f78 ( 144 kB)
16-07-24-634| [ KERNEL] [ 0.000000] .bss : 0x80b25000 - 0x80b826a0 ( 374 kB)
16-07-24-634| [ KERNEL] [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
16-07-24-634| [ KERNEL] [ 0.000000] Hierarchical RCU implementation.
16-07-24-634| [ KERNEL] [ 0.000000] Build-time adjustment of leaf fanout to 32.
16-07-24-634| [ KERNEL] [ 0.000000] NR_IRQS:16 nr_irqs:16 16
16-07-24-634| [ KERNEL] [ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
16-07-24-634| [ KERNEL] [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
16-07-24-634| [ KERNEL] [ 0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
16-07-24-634| [ KERNEL] [ 0.000019] Switching to timer-based delay loop, resolution 52ns
16-07-24-634| [ KERNEL] [ 0.000237] Console: colour dummy device 80x30
16-07-24-634| [ KERNEL] [ 0.000255] console [tty0] enabled
16-07-24-634| [ KERNEL] [ 0.000274] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
16-07-24-634| [ KERNEL] [ 0.000289] pid_max: default: 32768 minimum: 301
16-07-24-634| [ KERNEL] [ 0.000440] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
16-07-24-634| [ KERNEL] [ 0.000447] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
16-07-24-634| [ KERNEL] [ 0.001309] Disabling cpuset control group subsystem
16-07-24-634| [ KERNEL] [ 0.001440] CPU: Testing write buffer coherency: ok
16-07-24-634| [ KERNEL] [ 0.001880] CPU0: update cpu_capacity 1024
16-07-24-634| [ KERNEL] [ 0.001887] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
16-07-24-634| [ KERNEL] [ 0.001932] Setting up static identity map for 0x100000 - 0x100034
16-07-24-634| [ KERNEL] [ 0.003597] CPU1: update cpu_capacity 1024
16-07-24-634| [ KERNEL] [ 0.003604] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
16-07-24-634| [ KERNEL] [ 0.004173] CPU2: update cpu_capacity 1024
16-07-24-634| [ KERNEL] [ 0.004179] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
16-07-24-634| [ KERNEL] [ 0.004723] CPU3: update cpu_capacity 1024
16-07-24-634| [ KERNEL] [ 0.004729] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
16-07-24-634| [ KERNEL] [ 0.004806] Brought up 4 CPUs
16-07-24-634| [ KERNEL] [ 0.004815] SMP: Total of 4 processors activated (153.60 BogoMIPS).
16-07-24-634| [ KERNEL] [ 0.004819] CPU: All CPU(s) started in HYP mode.
16-07-24-634| [ KERNEL] [ 0.004822] CPU: Virtualization extensions available.
16-07-24-634| [ KERNEL] [ 0.005354] devtmpfs: initialized
16-07-24-634| [ KERNEL] [ 0.014974] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
16-07-24-634| [ KERNEL] [ 0.015359] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
16-07-24-634| [ KERNEL] [ 0.015375] futex hash table entries: 1024 (order: 4, 65536 bytes)
16-07-24-634| [ KERNEL] [ 0.015853] pinctrl core: initialized pinctrl subsystem
16-07-24-634| [ KERNEL] [ 0.016382] NET: Registered protocol family 16
16-07-24-634| [ KERNEL] [ 0.018253] DMA: preallocated 1024 KiB pool for atomic coherent allocations
16-07-24-634| [ KERNEL] [ 0.028484] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
16-07-24-634| [ KERNEL] [ 0.111151] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb80f000, dmachans=0x1
16-07-24-634| [ KERNEL] [ 0.113532] usbcore: registered new interface driver usbfs
16-07-24-634| [ KERNEL] [ 0.113659] usbcore: registered new interface driver hub
16-07-24-634| [ KERNEL] [ 0.113746] usbcore: registered new device driver usb
16-07-24-634| [ KERNEL] [ 0.120144] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-07-21 23:56
16-07-24-634| [ KERNEL] [ 0.122456] clocksource: Switched to clocksource arch_sys_counter
16-07-24-634| [ KERNEL] [ 0.137272] NET: Registered protocol family 2
16-07-24-634| [ KERNEL] [ 0.137846] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
16-07-24-634| [ KERNEL] [ 0.137953] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
16-07-24-634| [ KERNEL] [ 0.138137] TCP: Hash tables configured (established 8192 bind 8192)
16-07-24-634| [ KERNEL] [ 0.138221] UDP hash table entries: 512 (order: 2, 16384 bytes)
16-07-24-634| [ KERNEL] [ 0.138261] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
16-07-24-634| [ KERNEL] [ 0.138439] NET: Registered protocol family 1
16-07-24-634| [ KERNEL] [ 2.243192] workingset: timestamp_bits=14 max_order=18 bucket_order=4
16-07-24-634| [ KERNEL] [ 2.279100] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
16-07-24-634| [ KERNEL] [ 2.279113] io scheduler noop registered
16-07-24-634| [ KERNEL] [ 2.279118] io scheduler deadline registered (default)
16-07-24-634| [ KERNEL] [ 2.287921] BCM2708FB: allocated DMA memory fa910000
16-07-24-634| [ KERNEL] [ 2.287967] BCM2708FB: allocated DMA channel 0 @ bb80f000
16-07-24-634| [ KERNEL] [ 2.308430] Console: switching to colour frame buffer device 160x64
16-07-24-634| [ KERNEL] [ 2.322139] bcm2835-rng 3f104000.rng: hwrng registered
16-07-24-634| [ KERNEL] [ 2.322343] vc-cma: Videocore CMA driver
16-07-24-634| [ KERNEL] [ 2.322350] vc-cma: vc_cma_base = 0x00000000
16-07-24-634| [ KERNEL] [ 2.322355] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
16-07-24-634| [ KERNEL] [ 2.322359] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
16-07-24-634| [ KERNEL] [ 2.323049] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
16-07-24-634| [ KERNEL] [ 2.331210] zram: Added device: zram0
16-07-24-634| [ KERNEL] [ 2.331252] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
16-07-24-634| [ KERNEL] [ 2.559480] Core Release: 2.80a
16-07-24-634| [ KERNEL] [ 2.559488] Setting default values for core params
16-07-24-634| [ KERNEL] [ 2.559512] Finished setting default values for core params
16-07-24-634| [ KERNEL] [ 2.759857] Using Buffer DMA mode
16-07-24-634| [ KERNEL] [ 2.759863] Periodic Transfer Interrupt Enhancement - disabled
16-07-24-634| [ KERNEL] [ 2.759867] Multiprocessor Interrupt Enhancement - disabled
16-07-24-634| [ KERNEL] [ 2.759874] OTG VER PARAM: 0, OTG VER FLAG: 0
16-07-24-634| [ KERNEL] [ 2.759884] Dedicated Tx FIFOs mode
16-07-24-634| [ KERNEL] [ 2.760316] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xba904000 dma = 0xfa904000 len=9024
16-07-24-634| [ KERNEL] [ 2.760339] FIQ FSM acceleration enabled for :
16-07-24-634| [ KERNEL] [ 2.760339] Non-periodic Split Transactions
16-07-24-634| [ KERNEL] [ 2.760339] Periodic Split Transactions
16-07-24-634| [ KERNEL] [ 2.760339] High-Speed Isochronous Endpoints
16-07-24-634| [ KERNEL] [ 2.760339] Interrupt/Control Split Transaction hack enabled
16-07-24-634| [ KERNEL] [ 2.760345] dwc_otg: Microframe scheduler enabled
16-07-24-634| [ KERNEL] [ 2.760414] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x80398958
16-07-24-634| [ KERNEL] [ 2.760423] WARN::hcd_init_fiq:460: FIQ ASM at 0x80398cbc length 36
16-07-24-634| [ KERNEL] [ 2.760432] WARN::hcd_init_fiq:486: MPHI regs_base at 0xbb925000
16-07-24-634| [ KERNEL] [ 2.760487] dwc_otg 3f980000.usb: DWC OTG Controller
16-07-24-634| [ KERNEL] [ 2.760520] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
16-07-24-634| [ KERNEL] [ 2.760549] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
16-07-24-634| [ KERNEL] [ 2.760594] Init: Port Power? op_state=1
16-07-24-634| [ KERNEL] [ 2.760598] Init: Power Port (0)
16-07-24-634| [ KERNEL] [ 2.760774] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
16-07-24-634| [ KERNEL] [ 2.760783] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
16-07-24-634| [ KERNEL] [ 2.760790] usb usb1: Product: DWC OTG Controller
16-07-24-634| [ KERNEL] [ 2.760797] usb usb1: Manufacturer: Linux 4.9.47 dwc_otg_hcd
16-07-24-634| [ KERNEL] [ 2.760804] usb usb1: SerialNumber: 3f980000.usb
16-07-24-634| [ KERNEL] [ 2.761667] hub 1-0:1.0: USB hub found
16-07-24-634| [ KERNEL] [ 2.761705] hub 1-0:1.0: 1 port detected
16-07-24-634| [ KERNEL] [ 2.762345] dwc_otg: FIQ enabled
16-07-24-634| [ KERNEL] [ 2.762349] dwc_otg: NAK holdoff enabled
16-07-24-634| [ KERNEL] [ 2.762352] dwc_otg: FIQ split-transaction FSM enabled
16-07-24-634| [ KERNEL] [ 2.762433] Module dwc_common_port init
16-07-24-634| [ KERNEL] [ 2.763099] usbcore: registered new interface driver usbtouchscreen
16-07-24-634| [ KERNEL] [ 2.764609] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
16-07-24-634| [ KERNEL] [ 2.765122] bcm2835-cpufreq: min=600000 max=1200000
16-07-24-634| [ KERNEL] [ 2.766248] sdhost-bcm2835 3f202000.sdhost: could not get clk, deferring probe
16-07-24-634| [ KERNEL] [ 2.768697] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
16-07-24-634| [ KERNEL] [ 2.772329] ledtrig-cpu: registered to indicate activity on CPUs
16-07-24-634| [ KERNEL] [ 2.772780] hidraw: raw HID events driver (C) Jiri Kosina
16-07-24-634| [ KERNEL] [ 2.775623] usbcore: registered new interface driver usbhid
16-07-24-634| [ KERNEL] [ 2.775635] usbhid: USB HID core driver
16-07-24-634| [ KERNEL] [ 2.777225] vchiq: vchiq_init_state: slot_zero = 0xba980000, is_master = 0
16-07-24-634| [ KERNEL] [ 2.788784] NET: Registered protocol family 17
16-07-24-634| [ KERNEL] [ 2.789016] Registering SWP/SWPB emulation handler
16-07-24-634| [ KERNEL] [ 2.789889] registered taskstats version 1
16-07-24-634| [ KERNEL] [ 2.797135] sdhost: log_buf @ ba907000 (fa907000)
16-07-24-634| [ KERNEL] [ 2.872502] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
16-07-24-634| [ KERNEL] [ 2.874814] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
16-07-24-634| [ KERNEL] [ 2.874822] mmc-bcm2835 3f300000.mmc: DMA channel allocated
16-07-24-634| [ KERNEL] [ 2.942552] of_cfs_init
16-07-24-634| [ KERNEL] [ 2.942635] of_cfs_init: OK
16-07-24-634| [ KERNEL] [ 2.960687] Freeing unused kernel memory: 4096K
16-07-24-634| [ KERNEL] [ 2.982579] Indeed it is in host mode hprt0 = 00021501
16-07-24-634| [ KERNEL] [ 3.045552] mmc0: host does not support reading read-only switch, assuming write-enable
16-07-24-634| [ KERNEL] [ 3.048521] mmc0: new high speed SDHC card at address 59b4
16-07-24-634| [ KERNEL] [ 3.049174] mmcblk0: mmc0:59b4 USD 15.0 GiB
16-07-24-634| [ KERNEL] [ 3.051071] mmcblk0: p1
16-07-24-634| [ hotplug] [ 3.051720] Block device 179:1. No action.
16-07-24-634| [ hotplug] [ 3.051936] Block device 179:0. No action.
16-07-24-634| [ KERNEL] [ 3.055208] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
16-07-24-634| [ KERNEL] [ 3.056751] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
16-07-24-634| [ KERNEL] [ 3.058286] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
16-07-24-634| [ KERNEL] [ 3.061043] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
16-07-24-634| [ KERNEL] [ 3.064375] random: fast init done
16-07-24-634| [ KERNEL] [ 3.154086] mmc1: new high speed SDIO card at address 0001
16-07-24-634| [ KERNEL] [ 3.202504] usb 1-1: new high-speed USB device number 2 using dwc_otg
16-07-24-634| [ KERNEL] [ 3.202696] Indeed it is in host mode hprt0 = 00001101
16-07-24-634| [ hotplug] [ 3.231960] Block device 254:0. No action.
16-07-24-634| [ pfac] [ 3.296326] Run /sbin/initrd.
16-07-24-634| [ pfac] [ 3.296565] Ok, PID 603.
16-07-24-634| [ initrd] [ 3.300152] WTware shell 5.6.13/RPi
16-07-24-634| [ initrd] [ 3.320365] HDD/MMC/SD boot.
16-07-24-634| [ KERNEL] [ 3.432731] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
16-07-24-634| [ KERNEL] [ 3.432742] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
16-07-24-634| [ KERNEL] [ 3.433497] hub 1-1:1.0: USB hub found
16-07-24-634| [ KERNEL] [ 3.433606] hub 1-1:1.0: 5 ports detected
16-07-24-634| [ KERNEL] [ 3.752489] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
16-07-24-634| [ KERNEL] [ 3.882717] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
16-07-24-634| [ KERNEL] [ 3.882727] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
16-07-24-634| [ KERNEL] [ 3.982492] usb 1-1.3: new full-speed USB device number 4 using dwc_otg
16-07-24-634| [ KERNEL] [ 4.167026] usb 1-1.3: New USB device found, idVendor=04e7, idProduct=0020
16-07-24-634| [ KERNEL] [ 4.167036] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
16-07-24-634| [ KERNEL] [ 4.167043] usb 1-1.3: Product: Elo TouchSystems 2700 IntelliTouch(r) USB
16-07-24-634| [ KERNEL] [ 4.167051] usb 1-1.3: Manufacturer: Elo TouchSystems, Inc.
16-07-24-634| [ KERNEL] [ 4.167057] usb 1-1.3: SerialNumber: 20F53872
16-07-24-634| [ KERNEL] [ 4.192420] input: Elo TouchSystems, Inc. Elo TouchSystems 2700 IntelliTouch(r) USB as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/input/input0
16-07-24-634| [ KERNEL] [ 4.492489] usb 1-1.2: new full-speed USB device number 5 using dwc_otg
16-07-24-634| [ KERNEL] [ 4.637526] usb 1-1.2: New USB device found, idVendor=05e0, idProduct=1200
16-07-24-634| [ KERNEL] [ 4.637536] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
16-07-24-634| [ KERNEL] [ 4.637544] usb 1-1.2: Product: Symbol Bar Code Scanner
16-07-24-634| [ KERNEL] [ 4.637551] usb 1-1.2: Manufacturer: ᄅSymbol Technologies, Inc, 2002
16-07-24-634| [ KERNEL] [ 4.637559] usb 1-1.2: SerialNumber: S/N:BD6409D962F7E84983EEB10959FF8C8A Rev:NBRMSAAEDM:24MAR113
16-07-24-634| [ KERNEL] [ 4.648978] input: ᄅSymbol Technologies, Inc, 2002 Symbol Bar Code Scanner as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:05E0:1200.0001/input/input1
16-07-24-634| [ KERNEL] [ 4.723860] hid-generic 0003:05E0:1200.0001: input,hidraw0: USB HID v1.10 Keyboard [ᄅSymbol Technologies, Inc, 2002 Symbol Bar Code Scanner] on usb-3f980000.usb-1.2/input0
16-07-24-634| [ initrd] [ 5.145329] Success: media /dev/mmcblk0p1 mounted to /bootmedia.
16-07-24-634| /--- FILE "/bootmedia/config.txt" -----------------------
16-07-24-634| | # For more options and information see
16-07-24-634| | # http://www.raspberrypi.org/documentatio ... fig-txt.md
16-07-24-634| | # Some settings may impact device functionality. See link above for details
16-07-24-634| | # uncomment if you get no picture on HDMI for a default "safe" mode
16-07-24-634| | #hdmi_safe=1
16-07-24-634| | # uncomment this if your display has a black border of unused pixels visible
16-07-24-634| | # and your display can output without overscan
16-07-24-634| | disable_overscan=1
16-07-24-634| | # uncomment if hdmi display is not detected and composite is being output
16-07-24-634| | hdmi_force_hotplug=1
16-07-24-634| | # uncomment to force a specific HDMI mode (this will force VGA)
16-07-24-634| | hdmi_group=2
16-07-24-634| | hdmi_mode=36
16-07-24-634| | # uncomment to force a HDMI mode rather than DVI. This can make audio work in
16-07-24-634| | # DMT (computer monitor) modes
16-07-24-634| | hdmi_drive=2
16-07-24-634| | # uncomment to increase signal to HDMI, if you have interference, blanking, or
16-07-24-634| | # no display
16-07-24-634| | config_hdmi_boost=4
16-07-24-634| | #uncomment to overclock the arm. 700 MHz is the default.
16-07-24-634| | #arm_freq=800
16-07-24-634| | disable_splash=1
16-07-24-634| | # U-Boot need it since https://github.com/raspberrypi/firmware/issues/527
16-07-24-634| | device_tree_address=0x02100000
16-07-24-634| | [pi3]
16-07-24-634| | dtoverlay=pi3-disable-bt
16-07-24-634| | [all]
16-07-24-634| | #hdmi_group=2
16-07-24-634| | # 800x600: hdmi_mode=9
16-07-24-634| | # 1024x768: hdmi_mode=16
16-07-24-634| | # 1280x1024: hdmi_mode=35
16-07-24-634| | # 1360x768: hdmi_mode=39
16-07-24-634| | # 1400x1050: hdmi_mode=42
16-07-24-634| | # 1440x900: hdmi_mode=47
16-07-24-634| | # 1600x1200: hdmi_mode=51
16-07-24-634| | # 1680x1050: hdmi_mode=58
16-07-24-634| | # 1366x768: hdmi_mode=81
16-07-24-634| | # 1920x1080: hdmi_mode=82
16-07-24-634| | # 1920x1200: hdmi_mode=69
16-07-24-634| | framebuffer_depth=16
16-07-24-634| | # Uncomment for 32-bit color. Note that it is about two
16-07-24-634| | # times slower than default 16-bit.
16-07-24-634| | # framebuffer_depth=32
16-07-24-634| | # Enable onboard audio (HDMI or jack).
16-07-24-634| | # dtparam=audio=on
16-07-24-634| | #removes the warning overlay.
16-07-24-634| | #avoid_warnings=1
16-07-24-634| | #additionally allows turbo when low-voltage is present.
16-07-24-634| | #avoid_warnings=2
16-07-24-634| \----------------------------------------------------
16-07-24-634| [ initrd] [ 5.151343] WTpassword present: 25ea23fd01d78ecd21e57b09f7234590.
16-07-24-634| /--- FILE "/bootmedia/configs/initrd.wtc" -----------------------
16-07-24-634| | clientIP = *
16-07-24-634| | config = local
16-07-24-634| | setupPassword = 25ea23fd01d78ecd21e57b09f7234590
16-07-24-634| [ initrd] [ 7.155942] Load ethernet drivers.
16-07-24-634| [ initrd] [ 7.156062] modprobe smsc95xx.
16-07-24-634| [ KERNEL] [ 7.165848] smsc95xx v1.0.5
16-07-24-634| [ KERNEL] [ 7.256051] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:df:57:a8
16-07-24-634| [ KERNEL] [ 7.256305] usbcore: registered new interface driver smsc95xx
16-07-24-634| [ KERNEL] [ 7.364671] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
16-07-24-634| [ KERNEL] [ 8.959817] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC1E1
16-07-24-634| [ initrd] [ 8.965736] WTpassword present: 25ea23fd01d78ecd21e57b09f7234590.
16-07-24-634| [ initrd] [ 10.160408] dhcp: 342 bytes from 10.1.20.1.
16-07-24-634| [ initrd] [ 10.160527] 00000000:0000014200000000001100000A0114010A011506004300440142000002010600 ...B..............C.D.B......
16-07-24-634| [ initrd] [ 10.160617] 00000020:67458B6B00000000000000000A0115060A0102030A011401B827EBDF57A80000 gE.k...................'..W...
16-07-24-634| [ initrd] [ 10.160701] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
16-07-24-634| [ initrd] [ 10.160772] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
16-07-24-634| [ initrd] [ 10.160840] 00000080:0000000000000000000000000000000000000000000000000000000000000000 ................................
16-07-24-634| [ initrd] [ 10.160907] 000000a0:0000000000000000000000000000000000000000000000000000000000000000 ................................
16-07-24-634| [ initrd] [ 10.160975] 000000c0:0000000000000000000000000000000000000000000000000000000000000000 ................................
16-07-24-634| [ initrd] [ 10.161041] 000000e0:0000000000000000000000000000000000000000000000000000000000000000 ................................
16-07-24-634| [ initrd] [ 12.440150] dhcp: 342 bytes from 10.1.20.1.
16-07-24-634| [ initrd] [ 12.440325] 00000000:0000014200000000001100000A0114010A011506004300440142000002010600 ...B..............C.D.B......
16-07-24-634| [ initrd] [ 12.440456] 00000020:67458B6B00000000000000000A011506000000000A011401B827EBDF57A80000 gE.k...................'..W...
16-07-24-634| [ initrd] [ 12.440600] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
16-07-24-634| [ initrd] [ 12.440764] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
16-07-24-634| [ initrd] [ 12.440892] 00000080:0000000000000000000000000000000000000000000000000000000000000000 ................................
16-07-24-634| [ initrd] [ 12.441019] 000000a0:0000000000000000000000000000000000000000000000000000000000000000 ................................
16-07-24-634| [ initrd] [ 12.441142] 000000c0:0000000000000000000000000000000000000000000000000000000000000000 ................................
16-07-24-634| [ initrd] [ 12.441266] 000000e0:0000000000000000000000000000000000000000000000000000000000000000 ................................
16-07-24-634| [ initrd] [ 12.500096] dhcp: server address 10.1.2.3.
16-07-24-634| [ initrd] [ 12.500209] dhcp: 10.1.21.6/255.255.252.0.
16-07-24-634| [ initrd] [ 12.500315] dhcp: default gateway 10.1.20.1.
16-07-24-634| [ initrd] [ 12.500436] dhcp: DNS 10.1.2.102.
16-07-24-634| [ initrd] [ 12.500641] dhcp: DNS 149.244.7.40.
16-07-24-634| [ initrd] [ 12.500713] dhcp: domain corp.knorr-bremse.com.
16-07-24-634| [ initrd] [ 12.500781] dhcp: TFTP from siaddr 10.1.2.3.
16-07-24-634| [ initrd] [ 12.500847] dhcp: TFTP 10.1.2.3.
16-07-24-634| [ initrd] [ 12.500912] No boot file from DHCP.
16-07-24-634| [ initrd] [ 12.500977] TFTP binary "", configs prefix "", using "/" slash.
16-07-24-634| WTC listener is active.
16-07-24-634| WTC broadcast listener is active.
16-07-24-634| Send broadcast WTCU discover.
16-07-24-634| [ initrd] [ 12.503606] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
16-07-24-634| [ pfac] [ 12.503724] Run /sbin/httpd.
16-07-24-634| [ pfac] [ 12.504008] Ok, PID 639.
16-07-24-634| [ httpd] [ 12.514483] HTTP Server, WTware 5.6.13/RPi
16-07-24-634| [ initrd] [ 12.627569] USB: 04e7:0020 Elo TouchSystems Touchscreen Interface (2700).
16-07-24-634| [ initrd] [ 12.627793] USB: 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter.
16-07-24-634| [ initrd] [ 12.627925] USB: 0424:9514 Standard Microsystems Corp. SMC9514 Hub.
16-07-24-634| [ initrd] [ 12.628049] USB: 05e0:1200 Symbol Technologies Bar Code Scanner.
16-07-24-634| [ initrd] [ 12.628479] Copy /bootmedia/configs/config.wtc to /tmp/config.wtc.
16-07-24-634| [ initrd] [ 12.629517] Common local disk config:
16-07-24-634| /--- FILE "/tmp/config.wtc" -----------------------
16-07-24-634| | [BOM]
16-07-24-634| | server=brqs7019
16-07-24-634| | clienthostname=BRQTERMXXXXX
16-07-24-634| | managed=on
16-07-24-634| | user=svc.brq.terminal:TraceEdt32!
16-07-24-634| | domain=CORPORATE
16-07-24-634| | keepalive=1,1,1
16-07-24-634| | vnc=on
16-07-24-634| | onerror = 60
16-07-24-634| | vnc_password=Admin123
16-07-24-634| | serial=com1(usb)
16-07-24-634| | shell=C:\Program Files (x86)\SnT\Gral2\TraceViewer7011\TraceViewer2.exe "BRQTERMXXXXX"
16-07-24-634| | connection
16-07-24-634| /--- FILE "/etc/config.compiled" -----------------------
16-07-24-634| | onerror=60
16-07-24-634| [ initrd] [ 12.631727] Hostname: "BRQTERMXXXXX".
16-07-24-634| Everyone can control terminal by RSH.
16-07-24-634| RSH: listener is active.
16-07-24-634| [ httpd] [ 12.896334] Reread settings.
16-07-24-634| [ httpd] [ 12.896621] Everyone can control terminal by HTTP.
16-07-24-634| [ gm] [ 12.899130] WTware session manager 5.6.13/RPi.
16-07-24-634| [ gm] [ 12.900619] Add keyboard event1: ᄅSymbol Technologies, Inc, 2002 Symbol Bar Code Scanner.
16-07-24-634| [ gm] [ 12.900732] EV_ABS flag found. Add mouse event0: Elo TouchSystems, Inc. Elo TouchSystems 2700 IntelliTouch(r) USB.
16-07-24-634| [ gm] [ 12.900891] Display mode: 1280x1024, 16 bit, 0 Hz, modeline "", DDC enabled, connector 0.
16-07-24-634| [ gm] [ 12.912883] Framebuffer device found.
16-07-24-634| [ gm] [ 12.912966] LINELENBYTES 2560
16-07-24-634| [ gm] [ 12.913039] VLEN 2621440
16-07-24-634| [ gm] [ 12.925919] Use /lib/ui16.so.
16-07-24-634| [ gm] [ 12.948614] Load usb <-> serial bridges drivers.
16-07-24-634| [ gm] [ 12.951469] modprobe usbserial.
16-07-24-634| [ KERNEL] [ 12.962119] usbcore: registered new interface driver usbserial
16-07-24-634| [ KERNEL] [ 12.962200] usbcore: registered new interface driver usbserial_generic
16-07-24-634| [ KERNEL] [ 12.962277] usbserial: USB Serial support registered for generic
16-07-24-634| [ gm] [ 12.961031] modprobe pl2303.
16-07-24-634| [ KERNEL] [ 12.972368] usbcore: registered new interface driver pl2303
16-07-24-634| [ KERNEL] [ 12.972516] usbserial: USB Serial support registered for pl2303
16-07-24-634| [ gm] [ 12.971166] modprobe ftdi_sio.
16-07-24-634| [ gm] [ 12.983491] modprobe cp210x.
16-07-24-634| [ KERNEL] [ 12.983983] usbcore: registered new interface driver ftdi_sio
16-07-24-634| [ KERNEL] [ 12.984087] usbserial: USB Serial support registered for FTDI USB Serial Device
16-07-24-634| [ gm] [ 12.992652] modprobe ch341.
16-07-24-634| [ KERNEL] [ 12.993649] usbcore: registered new interface driver cp210x
16-07-24-634| [ KERNEL] [ 12.993757] usbserial: USB Serial support registered for cp210x
16-07-24-634| [ KERNEL] [ 13.002342] usbcore: registered new interface driver ch341
16-07-24-634| [ KERNEL] [ 13.002490] usbserial: USB Serial support registered for ch341-uart
16-07-24-634| [ gm] [ 13.001057] modprobe metro-usb.
16-07-24-634| [ gm] [ 13.009845] modprobe symbolserial.
16-07-24-634| [ KERNEL] [ 13.010879] usbcore: registered new interface driver metro_usb
16-07-24-634| [ KERNEL] [ 13.010977] usbserial: USB Serial support registered for Metrologic USB to Serial
16-07-24-634| [ gm] [ 13.019850] modprobe opticon.
16-07-24-634| [ KERNEL] [ 13.021166] usbcore: registered new interface driver symbolserial
16-07-24-634| [ KERNEL] [ 13.021259] usbserial: USB Serial support registered for symbol
16-07-24-634| [ gm] [ 13.028758] modprobe cdc-acm.
16-07-24-634| [ KERNEL] [ 13.029885] usbcore: registered new interface driver opticon
16-07-24-634| [ KERNEL] [ 13.030026] usbserial: USB Serial support registered for opticon
16-07-24-634| [ KERNEL] [ 13.039601] usbcore: registered new interface driver cdc_acm
16-07-24-634| [ KERNEL] [ 13.039610] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
16-07-24-634| [ gm] [ 13.092991] Run '/sbin/resolver 0x1b80050 dns [brqs7019]', log '', env '', pid ''.
16-07-24-634| [ pfac] [ 13.093145] Run /sbin/resolver 0x1b80050 dns [brqs7019].
16-07-24-634| [ gm] [ 13.093195] Everyone can control terminal by VNC.
16-07-24-634| [ gm] [ 13.093285] [VNC] Listener at port 5900.
16-07-24-634| [ pfac] [ 13.093408] Ok, PID 687.
16-07-24-634| [ gm] [ 13.099972] brqs7019 => 10.1.2.19.
16-07-24-634| [ pfac] [ 13.100686] Process pid 687 terminated, status 00000000.
16-07-24-634| [ gm] [ 13.109066] Free ram before fork terminal client /sbin/rdpclient (session 1): 927636 Kb.
16-07-24-634| [ pfac] [ 13.109151] Run /sbin/rdpclient 1.
16-07-24-634| [ gm] [ 13.109195] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
16-07-24-634| [ pfac] [ 13.109361] Ok, PID 688.
16-07-24-634| [ rdpclient 688] [ 13.116441] RDP Terminal Client, WTware 5.6.13/RPi, pipe 1, pid 688.
16-07-24-634| [ rdpclient 688] [ 13.117715] Use /lib/ui16.so.
16-07-24-634| [ gm] [ 13.118607] ttyUSB0, single device.
16-07-24-634| [ gm] [ 13.118692] Run serial daemon for ttyUSB0.
16-07-24-634| [ pfac] [ 13.118769] Run /sbin/rdpdr[serial] 0 0.
16-07-24-634| [ gm] [ 13.118812] Run '/sbin/rdpdr[serial] 0 0', log '', env '', pid ''.
16-07-24-634| [ pfac] [ 13.118988] Ok, PID 689.
16-07-24-634| [rdpdr-serial 0] [ 13.121752] RDP Serial Port Redirector, WTware 5.6.13/RPi, device ttyUSB0.
16-07-24-634| [ gm] [ 13.168859] COM1 => ttyUSB0.
16-07-24-634| [ rdpclient 688] [ 13.169424] Add serial redirection, COM1 in the session = hardware ttyUSB0.
16-07-24-634| [ rdpclient 688] [ 13.170047] Make RDP session with 10.1.2.19, port 3389.
16-07-24-634| [rdpdr-serial 0] [ 13.170134] New client connection, id 1.
16-07-24-634| [ rdpclient 688] [ 13.170225] Username: "svc.brq.terminal".
16-07-24-634| [ rdpclient 688] [ 13.170309] Password: present.
16-07-24-634| [ rdpclient 688] [ 13.170738] No PIN.
16-07-24-634| [ rdpclient 688] [ 13.170829] Domain: "CORPORATE".
16-07-24-634| [ rdpclient 688] [ 13.170994] Shell: "C:\Program Files (x86)\SnT\Gral2\TraceViewer7011\TraceViewer2.exe "BRQTERMXXXXX"".
16-07-24-634| [ rdpclient 688] [ 13.171098] No directory.
16-07-24-634| [ rdpclient 688] [ 13.171177] Window: 1280x1024@16.
16-07-24-634| [ rdpclient 688] [ 13.171305] PFlags 0x0000002F.
16-07-24-634| [ rdpclient 688] [ 13.171411] Keyboard 00000409:00000000.
16-07-24-634| [ rdpclient 688] [ 13.171517] My hostname "BRQTERMXXXXX".
16-07-24-634| [ rdpclient 688] [ 13.171816] TCP: connecting to 10.1.2.19:3389.
16-07-24-634| [ rdpclient 688] [ 13.172007] TCP: connection with 10.1.2.19:3389 established.
16-07-24-634| [ rdpclient 688] [ 13.172095] Turn keepalive on.
16-07-24-634| [ rdpclient 688] [ 13.172174] Free ram after buffers allocation: 927084 KB.
16-07-24-634| [ rdpclient 688] [ 13.178073] Server supports GFX Pipeline.
16-07-24-634| [ rdpclient 688] [ 13.181199] Process RDP server certificate.
16-07-24-634| [ rdpclient 688] [ 13.181364] RDP5 encryption (X.509).
16-07-24-634| [ rdpclient 688] [ 13.185928] Enable font smoothing and Desktop Composition.
16-07-24-634| [ rdpclient 688] [ 13.254961] GFX codec.
16-07-24-634| [ rdpclient 688] [ 13.833502] Run 4 tile threads.
16-07-24-634| [ rdpclient 688] [ 14.198272] Server Redirection flags 0x00000b0d.
16-07-24-634| [ gm] [ 14.198477] TSClient (sessionId 1, pid 688) gracefully end.
16-07-24-634| [ rdpclient 688] [ 14.198533] Server 10.1.2.18.
16-07-24-634| [ rdpclient 688] [ 14.198617] User "svc.brq.terminal".
16-07-24-634| [ rdpclient 688] [ 14.198804] Domain "CORPORATE".
16-07-24-634| [ gm] [ 14.198883] Free ram before fork terminal client /sbin/rdpclient (session 2): 913744 Kb.
16-07-24-634| [ rdpclient 688] [ 14.198929] Send Disconnect Provider Ultimatum.
16-07-24-634| [ pfac] [ 14.199005] Run /sbin/rdpclient 2.
16-07-24-634| [ gm] [ 14.199048] Run '/sbin/rdpclient 2', log '/tmp/rdpclient.out', env '', pid ''.
16-07-24-634| [ pfac] [ 14.199234] Ok, PID 696.
16-07-24-634| [ rdpclient 696] [ 14.206604] RDP Terminal Client, WTware 5.6.13/RPi, pipe 2, pid 696.
16-07-24-634| [rdpdr-serial 0] [ 14.207073] Close client connection 0 (id 1).
16-07-24-634| [ gm] [ 14.207207] ttyUSB0, single device.
16-07-24-634| [ gm] [ 14.207298] COM1 => ttyUSB0.
16-07-24-634| [ rdpclient 696] [ 14.207379] Use /lib/ui16.so.
16-07-24-634| [ pfac] [ 14.207931] Process pid 688 terminated, status 00000009.
16-07-24-634| [ rdpclient 696] [ 14.208041] Add serial redirection, COM1 in the session = hardware ttyUSB0.
16-07-24-634| [rdpdr-serial 0] [ 14.208172] New client connection, id 2.
16-07-24-634| [ rdpclient 696] [ 14.208233] Make RDP session with 10.1.2.18, port 3389.
16-07-24-634| [ rdpclient 696] [ 14.208336] Username: "svc.brq.terminal".
16-07-24-634| [ rdpclient 696] [ 14.208416] Password: present.
16-07-24-634| [ rdpclient 696] [ 14.208572] No PIN.
16-07-24-634| [ rdpclient 696] [ 14.208652] Domain: "CORPORATE".
16-07-24-634| [ rdpclient 696] [ 14.208748] Shell: "C:\Program Files (x86)\SnT\Gral2\TraceViewer7011\TraceViewer2.exe "BRQTERMXXXXX"".
16-07-24-634| [ rdpclient 696] [ 14.208828] No directory.
16-07-24-634| [ rdpclient 696] [ 14.209076] Window: 1280x1024@16.
16-07-24-634| [ rdpclient 696] [ 14.209156] PFlags 0x0000002F.
16-07-24-634| [ rdpclient 696] [ 14.209234] Keyboard 00000409:00000000.
16-07-24-634| [ rdpclient 696] [ 14.209311] My hostname "BRQTERMXXXXX".
16-07-24-634| [ rdpclient 696] [ 14.209389] TCP: connecting to 10.1.2.18:3389.
16-07-24-634| [ rdpclient 696] [ 14.209467] TCP: connection with 10.1.2.18:3389 established.
16-07-24-634| [ rdpclient 696] [ 14.209579] Turn keepalive on.
16-07-24-634| [ rdpclient 696] [ 14.209935] Free ram after buffers allocation: 926848 KB.
16-07-24-634| [ rdpclient 696] [ 14.210108] Empty Balance Info.
16-07-24-634| [ rdpclient 696] [ 14.215733] Server supports GFX Pipeline.
16-07-24-634| [ rdpclient 696] [ 14.215843] Redirected Session ID 0x00000000.
16-07-24-634| [ rdpclient 696] [ 14.218765] Process RDP server certificate.
16-07-24-634| [ rdpclient 696] [ 14.218920] RDP5 encryption (X.509).
16-07-24-634| [ rdpclient 696] [ 14.225517] Enable font smoothing and Desktop Composition.
16-07-24-634| [ rdpclient 696] [ 14.376358] GFX codec.
16-07-24-634| [ rdpclient 696] [ 14.972332] Run 4 tile threads.
16-07-24-634| [ rdpclient 696] [ 15.235459] LOGON_EX_LOGONERRORS: ErrorNotificationType 0xfffffffe, ErrorNotificationData 0x00000042.
16-07-24-634| [ rdpclient 696] [ 15.282307] SessionId 0x00000042: CORPORATE\svc.brq.terminal.
16-07-24-634| [ KERNEL] [ 15.467177] random: crng init done
16-07-24-634| [ gm] [59428.974130] [TOUCHSCREEN] ==================================================
16-07-24-634| [ gm] [59428.974256] [TOUCHSCREEN] Hardware configuration:
16-07-24-634| [ gm] [59428.974335] [TOUCHSCREEN] touchscreen = 0..4095,0..4095
16-07-24-634| [ gm] [59428.974411] [TOUCHSCREEN] ==================================================
16-07-24-634| Send WTCU discover to 10.1.21.12.
16-07-24-634| [ rdpclient 696] [78309.517334] errorInfo 0x00000002.
16-07-24-634| [ rdpclient 696] [78309.517533] ERRINFO_RPC_INITIATED_LOGOFF
16-07-24-634| [ rdpclient 696] [78309.642276] Receive Disconnect Provider Ultimatum.
16-07-24-634| [ gm] [78309.642465] TSClient (sessionId 2, pid 696) gracefully end.
16-07-24-634| [rdpdr-serial 0] [78309.652546] Close client connection 0 (id 2).
16-07-24-634| [ pfac] [78309.653105] Process pid 696 terminated, status 00000009.
16-07-24-634| [ gm] [78309.659459] Run '/sbin/resolver 0x1b80050 dns [brqs7019]', log '', env '', pid ''.
16-07-24-634| [ pfac] [78309.659707] Run /sbin/resolver 0x1b80050 dns [brqs7019].
16-07-24-634| [ pfac] [78309.660282] Ok, PID 1204.
16-07-24-634| [ gm] [78309.666648] brqs7019 => 10.1.2.19.
16-07-24-634| [ pfac] [78309.667316] Process pid 1204 terminated, status 00000000.
16-07-24-634| [ gm] [78309.675763] Free ram before fork terminal client /sbin/rdpclient (session 3): 927308 Kb.
16-07-24-634| [ gm] [78309.675909] Run '/sbin/rdpclient 3', log '/tmp/rdpclient.out', env '', pid ''.
16-07-24-634| [ pfac] [78309.676109] Run /sbin/rdpclient 3.
16-07-24-634| [ pfac] [78309.676490] Ok, PID 1205.
16-07-24-634| [rdpclient 1205] [78309.683985] RDP Terminal Client, WTware 5.6.13/RPi, pipe 3, pid 1205.
16-07-24-634| [ gm] [78309.684872] ttyUSB0, single device.
16-07-24-634| [rdpclient 1205] [78309.684963] Use /lib/ui16.so.
16-07-24-634| [ gm] [78309.685109] COM1 => ttyUSB0.
16-07-24-634| [rdpdr-serial 0] [78309.686447] New client connection, id 3.
16-07-24-634| [rdpclient 1205] [78309.686572] Add serial redirection, COM1 in the session = hardware ttyUSB0.
16-07-24-634| [rdpclient 1205] [78309.686682] Make RDP session with 10.1.2.19, port 3389.
16-07-24-634| [rdpclient 1205] [78309.686767] Username: "svc.brq.terminal".
16-07-24-634| [rdpclient 1205] [78309.686846] Password: present.
16-07-24-634| [rdpclient 1205] [78309.686923] No PIN.
16-07-24-634| [rdpclient 1205] [78309.687000] Domain: "CORPORATE".
16-07-24-634| [rdpclient 1205] [78309.687077] Shell: "C:\Program Files (x86)\SnT\Gral2\TraceViewer7011\TraceViewer2.exe "BRQTERMXXXXX"".
16-07-24-634| [rdpclient 1205] [78309.687160] No directory.
16-07-24-634| [rdpclient 1205] [78309.687236] Window: 1280x1024@16.
16-07-24-634| [rdpclient 1205] [78309.687314] PFlags 0x0000002F.
16-07-24-634| [rdpclient 1205] [78309.687391] Keyboard 00000409:00000000.
16-07-24-634| [rdpclient 1205] [78309.687469] My hostname "BRQTERMXXXXX".
16-07-24-634| [rdpclient 1205] [78309.687546] TCP: connecting to 10.1.2.19:3389.
16-07-24-634| [rdpclient 1205] [78309.689854] TCP: connection with 10.1.2.19:3389 established.
16-07-24-634| [rdpclient 1205] [78309.689974] Turn keepalive on.
16-07-24-634| [rdpclient 1205] [78309.690115] Free ram after buffers allocation: 926696 KB.
16-07-24-634| [rdpclient 1205] [78309.695468] Server supports GFX Pipeline.
16-07-24-634| [rdpclient 1205] [78309.706086] Process RDP server certificate.
16-07-24-634| [rdpclient 1205] [78309.706179] RDP5 encryption (X.509).
16-07-24-634| [rdpclient 1205] [78309.710942] Enable font smoothing and Desktop Composition.
16-07-24-634| [rdpclient 1205] [78310.534927] GFX codec.
16-07-24-634| [rdpclient 1205] [78313.346461] Run 4 tile threads.
16-07-24-634| [rdpclient 1205] [78314.087434] Server Redirection flags 0x00000b0d.
16-07-24-634| [rdpclient 1205] [78314.087627] Server 10.1.2.18.
16-07-24-634| [rdpclient 1205] [78314.087760] User "svc.brq.terminal".
16-07-24-634| [rdpclient 1205] [78314.087885] Domain "CORPORATE".
16-07-24-634| [rdpclient 1205] [78314.088026] Send Disconnect Provider Ultimatum.
16-07-24-634| [ pfac] [78314.088758] Run /sbin/rdpclient 4.
16-07-24-634| [ gm] [78314.088821] TSClient (sessionId 3, pid 1205) gracefully end.
16-07-24-634| [ gm] [78314.088909] Free ram before fork terminal client /sbin/rdpclient (session 4): 913736 Kb.
16-07-24-634| [ pfac] [78314.089021] Ok, PID 1212.
16-07-24-634| [ gm] [78314.089077] Run '/sbin/rdpclient 4', log '/tmp/rdpclient.out', env '', pid ''.
16-07-24-634| [rdpdr-serial 0] [78314.096494] Close client connection 0 (id 3).
16-07-24-634| [ pfac] [78314.096669] Process pid 1205 terminated, status 00000009.
16-07-24-634| [rdpclient 1212] [78314.096875] RDP Terminal Client, WTware 5.6.13/RPi, pipe 4, pid 1212.
16-07-24-634| [ gm] [78314.098237] ttyUSB0, single device.
16-07-24-634| [rdpclient 1212] [78314.098298] Use /lib/ui16.so.
16-07-24-634| [ gm] [78314.098400] COM1 => ttyUSB0.
16-07-24-634| [rdpclient 1212] [78314.098539] Add serial redirection, COM1 in the session = hardware ttyUSB0.
16-07-24-634| [rdpdr-serial 0] [78314.098642] New client connection, id 4.
16-07-24-634| [rdpclient 1212] [78314.098686] Make RDP session with 10.1.2.18, port 3389.
16-07-24-634| [rdpclient 1212] [78314.098781] Username: "svc.brq.terminal".
16-07-24-634| [rdpclient 1212] [78314.098861] Password: present.
16-07-24-634| [rdpclient 1212] [78314.098938] No PIN.
16-07-24-634| [rdpclient 1212] [78314.099013] Domain: "CORPORATE".
16-07-24-634| [rdpclient 1212] [78314.099089] Shell: "C:\Program Files (x86)\SnT\Gral2\TraceViewer7011\TraceViewer2.exe "BRQTERMXXXXX"".
16-07-24-634| [rdpclient 1212] [78314.099168] No directory.
16-07-24-634| [rdpclient 1212] [78314.099244] Window: 1280x1024@16.
16-07-24-634| [rdpclient 1212] [78314.099321] PFlags 0x0000002F.
16-07-24-634| [rdpclient 1212] [78314.099397] Keyboard 00000409:00000000.
16-07-24-634| [rdpclient 1212] [78314.099475] My hostname "BRQTERMXXXXX".
16-07-24-634| [rdpclient 1212] [78314.099552] TCP: connecting to 10.1.2.18:3389.
16-07-24-634| [rdpclient 1212] [78314.099629] TCP: connection with 10.1.2.18:3389 established.
16-07-24-634| [rdpclient 1212] [78314.099707] Turn keepalive on.
16-07-24-634| [rdpclient 1212] [78314.100369] Free ram after buffers allocation: 926692 KB.
16-07-24-634| [rdpclient 1212] [78314.100496] Empty Balance Info.
16-07-24-634| [rdpclient 1212] [78314.105931] Server supports GFX Pipeline.
16-07-24-634| [rdpclient 1212] [78314.106023] Redirected Session ID 0x00000000.
16-07-24-634| [rdpclient 1212] [78314.109039] Process RDP server certificate.
16-07-24-634| [rdpclient 1212] [78314.109126] RDP5 encryption (X.509).
16-07-24-634| [rdpclient 1212] [78314.113993] Enable font smoothing and Desktop Composition.
16-07-24-634| [rdpclient 1212] [78314.268297] GFX codec.
16-07-24-634| [rdpclient 1212] [78314.863790] Run 4 tile threads.
16-07-24-634| [rdpclient 1212] [78315.111516] LOGON_EX_LOGONERRORS: ErrorNotificationType 0xfffffffe, ErrorNotificationData 0x00000059.
16-07-24-634| [rdpclient 1212] [78315.142880] SessionId 0x00000059: CORPORATE\svc.brq.terminal.
16-07-24-634| [rdpclient 1212] [78842.608164] errorInfo 0x00000002.
16-07-24-634| [rdpclient 1212] [78842.608347] ERRINFO_RPC_INITIATED_LOGOFF
16-07-24-634| [rdpclient 1212] [78842.748647] Receive Disconnect Provider Ultimatum.
16-07-24-634| [ gm] [78842.748823] TSClient (sessionId 4, pid 1212) gracefully end.
16-07-24-634| [rdpdr-serial 0] [78842.758435] Close client connection 0 (id 4).
16-07-24-634| [ gm] [78842.758778] Run '/sbin/resolver 0x1b80050 dns [brqs7019]', log '', env '', pid ''.
16-07-24-634| [ pfac] [78842.759426] Run /sbin/resolver 0x1b80050 dns [brqs7019].
16-07-24-634| [ pfac] [78842.759584] Ok, PID 1221.
16-07-24-634| [ pfac] [78842.760168] Process pid 1212 terminated, status 00000009.
16-07-24-634| [ gm] [78842.765630] brqs7019 => 10.1.2.19.
16-07-24-634| [ pfac] [78842.765988] Process pid 1221 terminated, status 00000000.
16-07-24-634| [ gm] [78842.775020] Free ram before fork terminal client /sbin/rdpclient (session 5): 927424 Kb.
16-07-24-634| [ gm] [78842.775174] Run '/sbin/rdpclient 5', log '/tmp/rdpclient.out', env '', pid ''.
16-07-24-634| [ pfac] [78842.775674] Run /sbin/rdpclient 5.
16-07-24-634| [ pfac] [78842.775778] Ok, PID 1222.
16-07-24-634| [rdpclient 1222] [78842.782937] RDP Terminal Client, WTware 5.6.13/RPi, pipe 5, pid 1222.
16-07-24-634| [ gm] [78842.783794] ttyUSB0, single device.
16-07-24-634| [rdpclient 1222] [78842.783887] Use /lib/ui16.so.
16-07-24-634| [ gm] [78842.784031] COM1 => ttyUSB0.
16-07-24-634| [rdpdr-serial 0] [78842.785192] New client connection, id 5.
16-07-24-634| [rdpclient 1222] [78842.785305] Add serial redirection, COM1 in the session = hardware ttyUSB0.
16-07-24-634| [rdpclient 1222] [78842.785414] Make RDP session with 10.1.2.19, port 3389.
16-07-24-634| [rdpclient 1222] [78842.785498] Username: "svc.brq.terminal".
16-07-24-634| [rdpclient 1222] [78842.785578] Password: present.
16-07-24-634| [rdpclient 1222] [78842.785656] No PIN.
16-07-24-634| [rdpclient 1222] [78842.785732] Domain: "CORPORATE".
16-07-24-634| [rdpclient 1222] [78842.785826] Shell: "C:\Program Files (x86)\SnT\Gral2\TraceViewer7011\TraceViewer2.exe "BRQTERMXXXXX"".
16-07-24-634| [rdpclient 1222] [78842.785910] No directory.
16-07-24-634| [rdpclient 1222] [78842.785989] Window: 1280x1024@16.
16-07-24-634| [rdpclient 1222] [78842.786068] PFlags 0x0000002F.
16-07-24-634| [rdpclient 1222] [78842.786145] Keyboard 00000409:00000000.
16-07-24-634| [rdpclient 1222] [78842.786222] My hostname "BRQTERMXXXXX".
16-07-24-634| [rdpclient 1222] [78842.786298] TCP: connecting to 10.1.2.19:3389.
16-07-24-634| [rdpclient 1222] [78842.788292] TCP: connection with 10.1.2.19:3389 established.
16-07-24-634| [rdpclient 1222] [78842.788471] Turn keepalive on.
16-07-24-634| [rdpclient 1222] [78842.788574] Free ram after buffers allocation: 927148 KB.
16-07-24-634| [rdpclient 1222] [78842.794819] Server supports GFX Pipeline.
16-07-24-634| [rdpclient 1222] [78842.798847] Process RDP server certificate.
16-07-24-634| [rdpclient 1222] [78842.798935] RDP5 encryption (X.509).
16-07-24-634| [rdpclient 1222] [78842.803993] Enable font smoothing and Desktop Composition.
16-07-24-634| [rdpclient 1222] [78842.877177] GFX codec.
16-07-24-634| [rdpclient 1222] [78843.578523] Run 4 tile threads.
16-07-24-634| [rdpclient 1222] [78843.960525] Server Redirection flags 0x00000b0d.
16-07-24-634| [rdpclient 1222] [78843.960723] Server 10.1.2.18.
16-07-24-634| [rdpclient 1222] [78843.960855] User "svc.brq.terminal".
16-07-24-634| [rdpclient 1222] [78843.960981] Domain "CORPORATE".
16-07-24-634| [rdpclient 1222] [78843.961122] Send Disconnect Provider Ultimatum.
16-07-24-634| [ gm] [78843.961391] TSClient (sessionId 5, pid 1222) gracefully end.
16-07-24-634| [ gm] [78843.961995] Free ram before fork terminal client /sbin/rdpclient (session 6): 913804 Kb.
16-07-24-634| [ gm] [78843.962150] Run '/sbin/rdpclient 6', log '/tmp/rdpclient.out', env '', pid ''.
16-07-24-634| [ pfac] [78843.962677] Run /sbin/rdpclient 6.
16-07-24-634| [ pfac] [78843.962792] Ok, PID 1229.
16-07-24-634| [rdpdr-serial 0] [78843.968485] Close client connection 0 (id 5).
16-07-24-634| [ pfac] [78843.968924] Process pid 1222 terminated, status 00000009.
16-07-24-634| [rdpclient 1229] [78843.969978] RDP Terminal Client, WTware 5.6.13/RPi, pipe 6, pid 1229.
16-07-24-634| [ gm] [78843.970889] ttyUSB0, single device.
16-07-24-634| [rdpclient 1229] [78843.971018] Use /lib/ui16.so.
16-07-24-634| [ gm] [78843.971158] COM1 => ttyUSB0.
16-07-24-634| [rdpclient 1229] [78843.971707] Add serial redirection, COM1 in the session = hardware ttyUSB0.
16-07-24-634| [rdpdr-serial 0] [78843.971803] New client connection, id 6.
16-07-24-634| [rdpclient 1229] [78843.971847] Make RDP session with 10.1.2.18, port 3389.
16-07-24-634| [rdpclient 1229] [78843.971925] Username: "svc.brq.terminal".
16-07-24-634| [rdpclient 1229] [78843.972002] Password: present.
16-07-24-634| [rdpclient 1229] [78843.972125] No PIN.
16-07-24-634| [rdpclient 1229] [78843.972202] Domain: "CORPORATE".
16-07-24-634| [rdpclient 1229] [78843.972278] Shell: "C:\Program Files (x86)\SnT\Gral2\TraceViewer7011\TraceViewer2.exe "BRQTERMXXXXX"".
16-07-24-634| [rdpclient 1229] [78843.972357] No directory.
16-07-24-634| [rdpclient 1229] [78843.972433] Window: 1280x1024@16.
16-07-24-634| [rdpclient 1229] [78843.972682] PFlags 0x0000002F.
16-07-24-634| [rdpclient 1229] [78843.972763] Keyboard 00000409:00000000.
16-07-24-634| [rdpclient 1229] [78843.972841] My hostname "BRQTERMXXXXX".
16-07-24-634| [rdpclient 1229] [78843.972917] TCP: connecting to 10.1.2.18:3389.
16-07-24-634| [rdpclient 1229] [78843.972996] TCP: connection with 10.1.2.18:3389 established.
16-07-24-634| [rdpclient 1229] [78843.973074] Turn keepalive on.
16-07-24-634| [rdpclient 1229] [78843.973606] Free ram after buffers allocation: 926916 KB.
16-07-24-634| [rdpclient 1229] [78843.973754] Empty Balance Info.
16-07-24-634| [rdpclient 1229] [78843.978928] Server supports GFX Pipeline.
16-07-24-634| [rdpclient 1229] [78843.979012] Redirected Session ID 0x00000000.
16-07-24-634| [rdpclient 1229] [78843.982169] Process RDP server certificate.
16-07-24-634| [rdpclient 1229] [78843.982333] RDP5 encryption (X.509).
16-07-24-634| [rdpclient 1229] [78843.987465] Enable font smoothing and Desktop Composition.
16-07-24-634| [rdpclient 1229] [78844.150360] GFX codec.
16-07-24-634| [rdpclient 1229] [78844.782482] Run 4 tile threads.
16-07-24-634| [rdpclient 1229] [78845.623818] LOGON_EX_LOGONERRORS: ErrorNotificationType 0xfffffffe, ErrorNotificationData 0x00000042.
16-07-24-634| [rdpclient 1229] [78845.655027] SessionId 0x00000042: CORPORATE\svc.brq.terminal.
16-07-24-634| Connection from wtc.exe at 10.1.21.12.
Post by akatik » Tue Sep 19, 2017 5:45 pm
We've just updated our manual about logs - http://wtware.com/docs5/logs.html, please read it and make problem log again. From boot to first error. I need full problem log, with boot messages, config and other.
