Raspberry Pi3 RemoteFX Server 2016 Sound/Video Redirection
Posted: Mon Sep 04, 2017 9:10 am
I have read in this article USB-sound redirection (cameras, garniture, USB speakers) , if I understand correctly, that you could only have one or the other in terms of either a microphone or sound output. This does seem to be the case, when the microphone is built into the web cam. I have tried a mixture of things in the config file such as defining the sound hardware value
This gives me playback sound on the virtual desktop:
If I do:
I lose playback sound but now the microphone built into the usb web cam is working and recognized by the virtual desktop.
I guess my question is, is this something that has been resolved and I am just missing a ling in the config to make both the speakers over HDMI and the microphone through the webcam work or is this still in the sate where you would have to have a separate usb microphone?
I have also tried microphone = on, hw:1:0 and other values but those throw errors, not entirely sure I have the right HW referenced for the microphone as I am not sure how to obtain that usb value. If anyone could point me in the correct direction I would appreciate it.
sound=on, hw:0:0Code: Select all
microphone = onCode: Select all
sound=remoteI guess my question is, is this something that has been resolved and I am just missing a ling in the config to make both the speakers over HDMI and the microphone through the webcam work or is this still in the sate where you would have to have a separate usb microphone?
[ rdpclient 732] [ 33.532079] RDP5 encryption (X.509).
[ rdpclient 732] [ 33.583894] GFX codec.
[ rdpclient 732] [ 34.117746] Run 4 tile threads.
[ rdpclient 732] [ 34.134829] errorInfo 0x00000000.
[ rdpclient 732] [ 34.597069] SessionId 0x00000002: DomainName\UserID.
[ rdpclient 732] [ 100.717292] Sound version: 8.
[ rdpclient 732] [ 100.717509] ADPCM sound compression.
[ rdpclient 732] [ 100.717761] Sound redirection: 44100 frames per second.
[ rdpsnd] [ 101.170093] ALSA: use device hw:0,0.
[ rdpsnd] [ 101.171007] ALSA: Hardware rate 44100Hz.
[ rdpsnd] [ 101.171337] ALSA: chunk size 512 frames, 1024 bytes, 11 msec.
[rdpdr-usb 0458:708c] [ 208.744751] rdpdr[usb]-main.cpp ( 2280): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpdr-usb 0458:708c] [ 208.745674] rdpdr[usb]-main.cpp ( 2269): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpdr-usb 0458:708c] [ 224.787619] rdpdr[usb]-main.cpp ( 2280): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpdr-usb 0458:708c] [ 224.788652] rdpdr[usb]-main.cpp ( 2269): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ rdpaudin] [ 241.851317] ALSA: /sys/class/sound/pcmC0D0c/dev does not exist. Choose another recording device.
[ rdpclient 732] [ 241.851409] Audin daemon is dead.
[ rdpaudin] [ 241.851505] ALSA ERROR: no sound devices in hw:0. Correct sound= value.
[ rdpclient 732] [ 241.851551] rdpclient-audin.cpp ( 266): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ rdpaudin] [ 241.851636] rdpaudin-main.cpp ( 529): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ rdpclient 732] [ 241.851681] I'm tired.
[ pfac] [ 241.851990] Process pid 695 terminated, status 00000100.
[ gm] [ 241.852311] Final message: I'm tired.
[ rdpsnd] [ 241.887916] Link lost.
[rdpdr-usb 041e:4095] [ 241.888029] rdpdr[usb]-main.cpp ( 1794): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ pfac] [ 241.888679] Process pid 732 terminated, status 00000009.
