Remove Config Prompt On Startup
mhays243
Post by mhays243 » Fri Sep 01, 2017 10:32 pm
Is there a way to remove the option for local configuration at startup of WTware?..... and if not at least decrease visible time/remove the text that is displayed so that anyone wanting to play with it might be unaware of the config mode key.
Re: Remove Config Prompt On Startup
Post by akatik » Sat Sep 02, 2017 11:21 am
I don't understand, what are you talking about. Send me plaese screen photo, log: https://wtware.com/logs.html and so on.
sadaharu
Post by sadaharu » Mon Sep 04, 2017 2:49 am
I think he wants to remove the message "Press DEL to enter SETUP" during terminal boot.
mhays243
Post by mhays243 » Wed Sep 06, 2017 11:05 pm
Yes sadaharu, I would like Mr. aka to remove the press delete prompt as we use the online configs for them in most cases.
Post by akatik » Tue Sep 12, 2017 10:57 am
Install this and make new boot SD:
http://pxe.ru/files/testing/201709102140.zip
And add:
no_setup
to the very beginning of cmdline.txt file on boot SD. You should get something like:
no_setup quiet wtboot=mmc
"no_setup" should completely disable Setup menu.
"hide_setup" should hide text "Press Del", but menu will work when pressing del.
tony
Post by tony » Tue Jan 02, 2018 12:33 pm
File not Found
Not Found
The requested URL /files/testing/201709102140.zip was not found on this server.
Apache/2.4.25 Server at pxe.ru Port 80
Post by akatik » Tue Jan 02, 2018 1:19 pm
Four month ago! Just use the latest version from https://wtware.com
