Redefining hotkey for screen switching?
Locutus
Post by Locutus »
Hello everyone!
I discovered this software while looking for a thin client distribution, and I'm very much in love with it! :) Using it on Raspberry Pis now.
Question: Can I redefine the hotkey to switch virtual screens, from the Windows key to something else? Because Windows+1, Windows+2 etc. is also used as a Windows hotkey to switch to applications on the task bar! :)
Kind regards,
Frank
Re: Redefining hotkey for screen switching?
Locutus wrote:...to something else?
What else? Tell me the combinations that are not used.
Locutus
Post by Locutus »
Well, best would be a user-definable combination I suppose.
I personally would use something like Windows+Ctrl+1 etc.
Or at least, allow users to turn off the keyboard shortcut, so they can use it in Windows, and can still click the info window in the lower right to switch screens.
Kind regards,
Frank
Hi!
Please, try this build: http://pxe.ru/files/testing/201708072132.zip
In config:
screenswitch=win-ctrl-n
Or:
screenswitch=none
Does it work as expected?
