Is Configurator compatible with Windows 10?
jzholzer
Post by jzholzer »
I was recently "upgraded" to Window$ 10, and now my SD card isn't seen by the configurator software. I know the card is good because I can see it on another PC running windows 7. The card is recognized in windows 10 as HDSC and I do have full administrative privileges. Just in case, I ran configurator as admin and that didn't help. Any ideas would be most welcoms since our entire department will be forced into Window$ 10 soon.
Re: Is Configurator compatible with Windows 10?
Compatible. It fact, we only tested it under Win10 now.
Does Win10 itself see SD?
Does SD formatter under Win10 see SD? https://www.sdcard.org/downloads/formatter_4/
jzholzer
Post by jzholzer »
yes, underlying OS has no problem seeing the SD card. SD formatter also sees and can format. Nothing shows up under "disk" in the configurator window.
