Keyboard Switching
abtest
Keyboard Switching
Post by abtest » Fri Mar 03, 2017 2:24 pm
Hello
I am using a UK Keyboard but the symbols are incorrect, if i enable key-switch and press the buttons it changes the layout but doesn't save it as every time a restart the terminal the layout goes back to the original is there anyway to permanently make the keyboard stay switched ?
VXRDanny
Re: Keyboard Switching
Post by VXRDanny » Wed Nov 22, 2017 4:46 pm
This doesn't seem to fix the issue for the login prompt.
I have also tried language=en-gb,default in the config file.
but this does not work either. Any ideas?
Post by aka » Wed Nov 22, 2017 7:21 pm
Windows login prompt or wtware login prompt? Send screen photo if you're unsure.
VXRDanny
Post by VXRDanny » Thu Nov 23, 2017 3:20 pm
This is for the wtware login.
Post by akatik » Thu Nov 23, 2017 6:16 pm
language= option configure keyboard in wtware (but not windows!) login interface.
Find your keyboard layout here: http://ascii-table.com/keyboards.php
Guest
Post by Guest » Thu Nov 23, 2017 6:52 pm
OK - here is my keyboard layout - http://ascii-table.com/keyboard.php/166
I have tried, in the configuration file specified "language=en-gb", "language=en-gb,default" and "language=166", none of which change the keyboard.
Can you tell me what I need to do to make this work for the login prompt within wtware please?
Thanks,
Danny.
VXRDanny
Post by VXRDanny » Thu Nov 23, 2017 6:54 pm
This is my keyboard layout - http://ascii-table.com/keyboard.php/166
I have tried the following in my configuration file
language=en-gb
language=166
None of these work for the wtware login prompt. Can you tell me what I need to put to make this work please?
Thanks,
Danny
Post by aka » Thu Nov 23, 2017 9:48 pm
Try this build: http://pxe.ru/files/testing/201711232246.zip
VXRDanny
Post by VXRDanny » Fri Nov 24, 2017 4:57 pm
Great- re-installing that build worked for me.
Thanks.
henczy
Post by henczy » Thu Nov 30, 2017 6:14 pm
Just tried this build by updating 5.6.20 to 5.6.21, but UK layout didn't work.
Then I reinstalled this 5.6.21 image to the SD card, but it still doesn't work.
Can you please advise?
Thanks in advance,
Zoltan
Post by aka » Thu Nov 30, 2017 8:00 pm
