Wifi WPA password with 31 characters only ?
Posted: Wed Feb 01, 2017 12:52 pm
by Elric
Hi Support guys,
I want to test WTWare & raspberry with wifi so i wanted to enter my WPA password.
But my password has more than 31 characters and WPA password field is limited to 31 characters only.
Normally a WPA password should contain up to 63 characters right ?
Is it possible to add more than 31 characters in a way or another ?
Thanks for your help!
Re: Wifi WPA password with 31 characters only ?
Posted: Wed Feb 01, 2017 1:06 pm
You can remember more than 31 characters password? :shock:
Posted: Wed Feb 01, 2017 2:18 pm
by Elric
:D : yes without any problem !
Posted: Wed Feb 01, 2017 4:29 pm
by Elric
It's in fact easy to remember when you use a sentence as a password like for example :
"Ohmygod!MyTaylorisreallyveryrichindeed!"
Easy to remember and much longer than 31 characters :D .
Posted: Sat Feb 04, 2017 4:29 pm
Try wtware 5.4.70. Up to 63 chars passwords should work.
Posted: Mon Feb 06, 2017 4:59 pm
by Elric
I'd like other companies support to be as fast as you are to solve issues!
Thanks a lot for this quick resolution !
Posted: Tue Feb 07, 2017 12:24 pm
by Elric
Hello again,
I've just started to test the new version and i can already see that wifi password is written in initrd.wtc file but is not encrypted...
I mean, all the others passwords (setup, vnc) are encrypted so i'm wondering : is it possible to crypt the wifi password ?
Thanks for your work !
Posted: Thu Feb 09, 2017 2:35 am
Please, try this:
http://pxe.ru/files/testing/201702090334.zip
Note it's the security mirage, not real security.
Posted: Wed Feb 15, 2017 11:34 am
by Elric
Hi Support guys,
Downloaded and tested : works great !
I feel better with my encrypted wifi password.
Thanks for your help and your speed.
