Password containing '#' character not working for connecting to Server.
estefano.peroza
Post by estefano.peroza »
Hello there,
In my configuration file, i need to set something like:
User=user1:Passw#ord
The password contains a hashtag character and i cannot connect to server because it says my username/password is wrong.
After connection failure, i come back to my configuration file and the User parameter becomes something like:
User=user1:Passw
The string after the hashtag symbol disappears!
I am using the latest version of wtware.
is there some trick for solving this?
Thanks !
Re: Password containing '#' character not working for connecting to Server.
Use Configurator, it knows the trick. "User=user1:Passw#ord" coded as:
user=user1:\x50\x61\x73\x73\x77\x23\x6f\x72\x64
