Wtware Pi 5.4.56
Posted: Thu Nov 17, 2016 4:35 pm
by Alon
Trying now this 5.4.56 release on Win2012R2, I don't see any changelog so can't look for specific changes,here's what i found so far:
On WtwareCenter on the right pane when checking logs, mouse scroll doesn't work, it works on the left pane (terminal list).
On the Left pane, the terminal list, the sorting is not working as expected, it sorts only by the last portion of the IP: say we have (1.0.3.3, 1.0.1.1 and 1.0.0.2) it sorts as (1.0.1.1 , 1.0.0.2 and 1.0.3.3) when it should be (1.0.0.2, 1.0.1.1 and 1.0.3.3.) . when you have lots of clients on different ip segments it's difficult to find the IP you are looking for if it's not sorted the right way.
When connecting to an unavailable rdp server it takes 207 seconds to stop trying to connect, also it cannot be interrupted (closed) by the red "X" next to the server address you are trying to connect on the "infobox". I tried connect_timeout 0 and 15 with the same results.
Thank you for your hard work.
14-26-58-358| [wtc.exe] Terminal will restart now.
14-26-58-358| RSH: got command restart from 10.1.1.10.
14-26-58-420| Reboot.
14-27-08-520| [wtc.exe] Connection closed.
14-27-14-833| [TFTP] Got RRQ, 204 bytes.
14-27-14-849| [TFTP] 00000000: 57 54 77 61 72 65 20 76 2e 35 2e 34 2e 35 36 20
14-27-14-849| [TFTP] 00000010: 61 74 20 42 38 3a 32 37 3a 45 42 3a 42 31 3a 33
14-27-14-849| [TFTP] 00000020: 42 3a 44 42 2c 20 70 6c 61 74 66 6f 72 6d 3d 50
14-27-14-849| [TFTP] 00000030: 69 32 42 2c 20 69 70 3d 31 30 2e 31 2e 31 39 32
14-27-14-864| [TFTP] 00000040: 2e 37 37 2c 20 73 69 67 6e 3d 45 43 44 44 39 38
14-27-14-864| [TFTP] 00000050: 31 41 41 42 45 39 34 33 44 35 43 42 45 33 32 30
14-27-14-864| [TFTP] 00000060: 32 42 46 41 34 36 46 33 34 42 33 37 34 46 31 31
14-27-14-864| [TFTP] 00000070: 41 32 45 39 31 38 35 41 30 37 34 37 36 46 37 39
14-27-14-880| [TFTP] 00000080: 36 37 30 34 35 30 41 45 42 39 31 36 43 32 30 44
14-27-14-880| [TFTP] 00000090: 36 46 30 46 46 41 37 33 36 38 31 37 30 32 32 46
14-27-14-895| [TFTP] 000000a0: 41 30 32 31 36 44 36 45 35 45 35 31 44 33 31 46
14-27-14-895| [TFTP] 000000b0: 31 32 39 34 30 45 44 30 45 34 39 39 31 31 39 32
14-27-14-895| [TFTP] 000000c0: 41 45 32 32 41 36 32 38 30 36 2e 00
14-27-14-895| [TFTP] WTware v.5.4.56 found at host [], mac B8:27:EB:B1:3B:DB.
14-27-14-989| [TFTP] Sending WTware TFTP version.
14-27-14-989| [TFTP] Got RRQ, 45 bytes.
14-27-15-005| [TFTP] 00000000: 45 76 65 72 79 6f 6e 65 2f 6c 69 73 74 2e 77 74
14-27-15-005| [TFTP] 00000010: 63 00 6f 63 74 65 74 00 74 73 69 7a 65 00 30 00
14-27-15-020| [TFTP] 00000020: 62 6c 6b 73 69 7a 65 00 31 34 30 30 00
14-27-15-020| [TFTP] Request block size 1400, forced to 1360.
14-27-15-036| [TFTP] Requests file "Everyone\list.wtc". Tsize is requested, blksize 1360 bytes.
14-27-15-036| [TFTP] Sending OASK (tsize 1209, blksize 1360).
14-27-15-036| [TFTP] Transfer of file "Everyone\list.wtc" completed.
14-27-15-052| [TFTP] Connection closed.
14-27-15-052| [TFTP] Got RRQ, 66 bytes.
14-27-15-052| [TFTP] 00000000: 54 65 72 6d 69 6e 61 6c 73 2f 42 38 2e 32 37 2e
14-27-15-067| [TFTP] 00000010: 45 42 2e 42 31 2e 33 42 2e 44 42 2f 63 6f 6e 66
14-27-15-067| [TFTP] 00000020: 69 67 2e 77 74 63 00 6f 63 74 65 74 00 74 73 69
14-27-15-084| [TFTP] 00000030: 7a 65 00 30 00 62 6c 6b 73 69 7a 65 00 31 34 30
14-27-15-084| [TFTP] 00000040: 30 00
14-27-15-099| [TFTP] Request block size 1400, forced to 1360.
14-27-15-099| [TFTP] Requests file "Terminals\B8.27.EB.B1.3B.DB\config.wtc". Tsize is requested, blksize 1360 bytes.
14-27-15-114| [TFTP] Sending OASK (tsize 522, blksize 1360).
14-27-15-114| [TFTP] Transfer of file "Terminals\B8.27.EB.B1.3B.DB\config.wtc" completed.
14-27-15-130| [TFTP] Connection closed.
14-27-15-130| [TFTP] Got RRQ, 44 bytes.
14-27-15-146| [TFTP] 00000000: 45 76 65 72 79 6f 6e 65 2f 61 6c 6c 2e 77 74 63
14-27-15-146| [TFTP] 00000010: 00 6f 63 74 65 74 00 74 73 69 7a 65 00 30 00 62
14-27-15-161| [TFTP] 00000020: 6c 6b 73 69 7a 65 00 31 34 30 30 00
14-27-15-161| [TFTP] Request block size 1400, forced to 1360.
14-27-15-178| [TFTP] Requests file "Everyone\all.wtc". Tsize is requested, blksize 1360 bytes.
14-27-15-178| [TFTP] Sending OASK (tsize 41, blksize 1360).
14-27-15-192| [TFTP] Transfer of file "Everyone\all.wtc" completed.
14-27-15-192| [TFTP] Connection closed.
14-27-15-208| [TFTP] Got RRQ, 50 bytes.
14-27-15-208| [TFTP] 00000000: 54 65 6d 70 6c 61 74 65 73 2f 48 61 73 68 2d 42
14-27-15-224| [TFTP] 00000010: 79 73 2e 77 74 63 00 6f 63 74 65 74 00 74 73 69
14-27-15-224| [TFTP] 00000020: 7a 65 00 30 00 62 6c 6b 73 69 7a 65 00 31 34 30
14-27-15-224| [TFTP] 00000030: 30 00
14-27-15-224| [TFTP] Request block size 1400, forced to 1360.
14-27-15-239| [TFTP] Requests file "Templates\Hash-RDPTeminal.wtc". Tsize is requested, blksize 1360 bytes.
14-27-15-239| [TFTP] Sending OASK (tsize 260, blksize 1360).
14-27-15-255| [TFTP] Transfer of file "Templates\Hash-RDPTeminal.wtc" completed.
14-27-15-255| [TFTP] Connection closed.
14-27-15-271| [TFTP] Got RRQ, 51 bytes.
14-27-15-271| [TFTP] 00000000: 43 6f 6e 6e 65 63 74 69 6f 6e 73 2f 48 61 73 68
14-27-15-286| [TFTP] 00000010: 61 6c 61 2e 77 74 63 00 6f 63 74 65 74 00 74 73
14-27-15-286| [TFTP] 00000020: 69 7a 65 00 30 00 62 6c 6b 73 69 7a 65 00 31 34
14-27-15-302| [TFTP] 00000030: 30 30 00
14-27-15-302| [TFTP] Request block size 1400, forced to 1360.
14-27-15-317| [TFTP] Requests file "Connections\coreb.wtc". Tsize is requested, blksize 1360 bytes.
14-27-15-317| [TFTP] Sending OASK (tsize 82, blksize 1360).
14-27-15-333| [TFTP] Transfer of file "Connections\coreb.wtc" completed.
14-27-15-333| [TFTP] Connection closed.
14-27-15-349| [TFTP] Got RRQ, 47 bytes.
14-27-15-364| [TFTP] 00000000: 43 6f 6e 6e 65 63 74 69 6f 6e 73 2f 42 59 53 2e
14-27-15-364| [TFTP] 00000010: 77 74 63 00 6f 63 74 65 74 00 74 73 69 7a 65 00
14-27-15-364| [TFTP] 00000020: 30 00 62 6c 6b 73 69 7a 65 00 31 34 30 30 00
14-27-15-364| [TFTP] Request block size 1400, forced to 1360.
14-27-15-380| [TFTP] Requests file "Connections\RDPTeminal.wtc". Tsize is requested, blksize 1360 bytes.
14-27-15-380| [TFTP] Sending OASK (tsize 82, blksize 1360).
14-27-15-396| [TFTP] Transfer of file "Connections\RDPTeminal.wtc" completed.
14-27-15-396| [TFTP] Connection closed.
14-27-15-411| [TFTP] Got RRQ, 50 bytes.
14-27-15-411| [TFTP] 00000000: 43 6f 6e 6e 65 63 74 69 6f 6e 73 2f 54 73 5f 44
14-27-15-427| [TFTP] 00000010: 65 76 2e 77 74 63 00 6f 63 74 65 74 00 74 73 69
14-27-15-442| [TFTP] 00000020: 7a 65 00 30 00 62 6c 6b 73 69 7a 65 00 31 34 30
14-27-15-458| [TFTP] 00000030: 30 00
14-27-15-458| [TFTP] Request block size 1400, forced to 1360.
14-27-15-458| [TFTP] Requests file "Connections\Ts_1.wtc". Tsize is requested, blksize 1360 bytes.
14-27-15-458| [TFTP] Sending OASK (tsize 112, blksize 1360).
14-27-15-474| [TFTP] Got RRQ, 50 bytes.
14-27-15-474| [TFTP] 00000000: 43 6f 6e 6e 65 63 74 69 6f 6e 73 2f 54 73 5f 4f
14-27-15-489| [TFTP] 00000010: 72 61 2e 77 74 63 00 6f 63 74 65 74 00 74 73 69
14-27-15-489| [TFTP] 00000020: 7a 65 00 30 00 62 6c 6b 73 69 7a 65 00 31 34 30
14-27-15-489| [TFTP] 00000030: 30 00
14-27-15-505| [TFTP] Request block size 1400, forced to 1360.
14-27-15-521| [TFTP] Requests file "Connections\Ts_2.wtc". Tsize is requested, blksize 1360 bytes.
14-27-15-521| [TFTP] Sending OASK (tsize 64, blksize 1360).
14-27-15-536| [TFTP] Transfer of file "Connections\Ts_1.wtc" completed.
14-27-15-536| [TFTP] Connection closed.
14-27-15-552| [TFTP] Transfer of file "Connections\Ts_2.wtc" completed.
14-27-15-552| [TFTP] Connection closed.
14-27-15-567| [TFTP] Got RRQ, 46 bytes.
14-27-15-567| [TFTP] 00000000: 43 6f 6e 6e 65 63 74 69 6f 6e 73 2f 54 38 2e 77
14-27-15-583| [TFTP] 00000010: 74 63 00 6f 63 74 65 74 00 74 73 69 7a 65 00 30
14-27-15-583| [TFTP] 00000020: 00 62 6c 6b 73 69 7a 65 00 31 34 30 30 00
14-27-15-599| [TFTP] Request block size 1400, forced to 1360.
14-27-15-599| [TFTP] Requests file "Connections\T8.wtc". Tsize is requested, blksize 1360 bytes.
14-27-15-614| [TFTP] Sending OASK (tsize 56, blksize 1360).
14-27-15-614| [TFTP] Transfer of file "Connections\T8.wtc" completed.
14-27-15-630| [TFTP] Connection closed.
14-27-15-630| [TFTP] Got RRQ, 47 bytes.
14-27-15-630| [TFTP] 00000000: 43 6f 6e 6e 65 63 74 69 6f 6e 73 2f 42 59 53 2e
14-27-15-646| [TFTP] 00000010: 77 74 63 00 6f 63 74 65 74 00 74 73 69 7a 65 00
14-27-15-646| [TFTP] 00000020: 30 00 62 6c 6b 73 69 7a 65 00 31 34 30 30 00
14-27-15-646| [TFTP] Request block size 1400, forced to 1360.
14-27-15-677| [TFTP] Requests file "Connections\RDPTeminal.wtc". Tsize is requested, blksize 1360 bytes.
14-27-15-677| [TFTP] Sending OASK (tsize 82, blksize 1360).
14-27-15-693| [TFTP] Transfer of file "Connections\RDPTeminal.wtc" completed.
14-27-15-693| [TFTP] Connection closed.
14-27-15-708| [TFTP] Got RRQ, 51 bytes.
14-27-15-708| [TFTP] 00000000: 43 6f 6e 6e 65 63 74 69 6f 6e 73 2f 48 61 73 68
14-27-15-724| [TFTP] 00000010: 61 6c 61 2e 77 74 63 00 6f 63 74 65 74 00 74 73
14-27-15-724| [TFTP] 00000020: 69 7a 65 00 30 00 62 6c 6b 73 69 7a 65 00 31 34
14-27-15-739| [TFTP] 00000030: 30 30 00
14-27-15-739| [TFTP] Request block size 1400, forced to 1360.
14-27-15-755| [TFTP] Requests file "Connections\coreb.wtc". Tsize is requested, blksize 1360 bytes.
14-27-15-771| [TFTP] Sending OASK (tsize 82, blksize 1360).
14-27-15-771| [TFTP] Transfer of file "Connections\coreb.wtc" completed.
14-27-15-786| [TFTP] Connection closed.
14-27-15-802| [TFTP] Got RRQ, 50 bytes.
14-27-15-802| [TFTP] 00000000: 43 6f 6e 6e 65 63 74 69 6f 6e 73 2f 54 73 5f 44
14-27-15-818| [TFTP] 00000010: 65 76 2e 77 74 63 00 6f 63 74 65 74 00 74 73 69
14-27-15-818| [TFTP] 00000020: 7a 65 00 30 00 62 6c 6b 73 69 7a 65 00 31 34 30
14-27-15-833| [TFTP] 00000030: 30 00
14-27-15-833| [TFTP] Request block size 1400, forced to 1360.
14-27-15-849| [TFTP] Requests file "Connections\Ts_1.wtc". Tsize is requested, blksize 1360 bytes.
14-27-15-865| [TFTP] Sending OASK (tsize 112, blksize 1360).
14-27-15-865| [TFTP] Transfer of file "Connections\Ts_1.wtc" completed.
14-27-15-880| [TFTP] Connection closed.
14-27-15-880| [TFTP] Got RRQ, 50 bytes.
14-27-15-896| [TFTP] 00000000: 43 6f 6e 6e 65 63 74 69 6f 6e 73 2f 54 73 5f 4f
14-27-15-896| [TFTP] 00000010: 72 61 2e 77 74 63 00 6f 63 74 65 74 00 74 73 69
14-27-15-911| [TFTP] 00000020: 7a 65 00 30 00 62 6c 6b 73 69 7a 65 00 31 34 30
14-27-15-911| [TFTP] 00000030: 30 00
14-27-15-927| [TFTP] Request block size 1400, forced to 1360.
14-27-15-927| [TFTP] Requests file "Connections\Ts_2.wtc". Tsize is requested, blksize 1360 bytes.
14-27-15-958| [TFTP] Sending OASK (tsize 64, blksize 1360).
14-27-15-958| [TFTP] Transfer of file "Connections\Ts_2.wtc" completed.
14-27-15-974| [TFTP] Connection closed.
14-27-15-989| [TFTP] Got RRQ, 47 bytes.
14-27-15-989| [TFTP] 00000000: 47 72 61 70 68 69 63 2f 70 6b 2f 6d 65 6e 75 2e
14-27-16-005| [TFTP] 00000010: 70 6e 67 00 6f 63 74 65 74 00 74 73 69 7a 65 00
14-27-16-021| [TFTP] 00000020: 30 00 62 6c 6b 73 69 7a 65 00 31 34 30 30 00
14-27-16-021| [TFTP] Request block size 1400, forced to 1360.
14-27-16-036| [TFTP] Requests file "Graphic\pk\menu.png". Tsize is requested, blksize 1360 bytes.
14-27-16-036| [TFTP] Sending OASK (tsize 1010577, blksize 1360).
14-27-16-146| [TFTP] Transfer of file "Graphic\pk\menu.png" completed.
14-27-16-161| [TFTP] Connection closed.
14-27-16-161| [TFTP] Got RRQ, 48 bytes.
14-27-16-177| [TFTP] 00000000: 47 72 61 70 68 69 63 2f 70 6b 2f 70 6f 70 75 70
14-27-16-177| [TFTP] 00000010: 2e 70 6e 67 00 6f 63 74 65 74 00 74 73 69 7a 65
14-27-16-208| [TFTP] 00000020: 00 30 00 62 6c 6b 73 69 7a 65 00 31 34 30 30 00
14-27-16-208| [TFTP] Request block size 1400, forced to 1360.
14-27-16-224| [TFTP] Requests file "Graphic\pk\popup.png". Tsize is requested, blksize 1360 bytes.
14-27-16-224| [TFTP] Sending OASK (tsize 7637, blksize 1360).
14-27-16-239| [TFTP] Transfer of file "Graphic\pk\popup.png" completed.
14-27-16-239| [TFTP] Connection closed.
14-27-16-271| [TFTP] Got RRQ, 48 bytes.
14-27-16-302| [TFTP] 00000000: 47 72 61 70 68 69 63 2f 70 6b 2f 73 61 76 65 72
14-27-16-302| [TFTP] 00000010: 2e 70 6e 67 00 6f 63 74 65 74 00 74 73 69 7a 65
14-27-16-317| [TFTP] 00000020: 00 30 00 62 6c 6b 73 69 7a 65 00 31 34 30 30 00
14-27-16-317| [TFTP] Request block size 1400, forced to 1360.
14-27-16-349| [TFTP] Requests file "Graphic\pk\saver.png". Tsize is requested, blksize 1360 bytes.
14-27-16-349| [TFTP] Requested file "C:\ProgramData\WTware\Graphic\pk\saver.png" not found.
14-27-16-380| [TFTP] Got RRQ, 48 bytes.
14-27-16-380| [TFTP] 00000000: 47 72 61 70 68 69 63 2f 70 6b 2f 73 61 76 65 72
14-27-16-396| [TFTP] 00000010: 2e 67 69 66 00 6f 63 74 65 74 00 74 73 69 7a 65
14-27-16-396| [TFTP] 00000020: 00 30 00 62 6c 6b 73 69 7a 65 00 31 34 30 30 00
14-27-16-411| [TFTP] Request block size 1400, forced to 1360.
14-27-16-411| [TFTP] Requests file "Graphic\pk\saver.gif". Tsize is requested, blksize 1360 bytes.
14-27-16-458| [TFTP] Requested file "C:\ProgramData\WTware\Graphic\pk\saver.gif" not found.
14-27-16-458| [TFTP] Got RRQ, 47 bytes.
14-27-16-474| [TFTP] 00000000: 47 72 61 70 68 69 63 2f 70 6b 2f 77 61 69 74 2e
14-27-16-474| [TFTP] 00000010: 70 6e 67 00 6f 63 74 65 74 00 74 73 69 7a 65 00
14-27-16-489| [TFTP] 00000020: 30 00 62 6c 6b 73 69 7a 65 00 31 34 30 30 00
14-27-16-489| [TFTP] Request block size 1400, forced to 1360.
14-27-16-505| [TFTP] Requests file "Graphic\pk\wait.png". Tsize is requested, blksize 1360 bytes.
14-27-16-521| [TFTP] Sending OASK (tsize 19459, blksize 1360).
14-27-16-521| [TFTP] Transfer of file "Graphic\pk\wait.png" completed.
14-27-16-536| [TFTP] Connection closed.
14-45-45-815| WTware v.5.4.56/RPi supervisor.
14-45-45-815| WTC listener is active.
14-45-45-815| WTC broadcast listener is active.
14-45-45-815| [        KERNEL] [    0.000000] Booting Linux on physical CPU 0xf00
14-45-45-815| [        KERNEL] [    0.000000] Initializing cgroup subsys cpuset
14-45-45-815| [        KERNEL] [    0.000000] Initializing cgroup subsys cpuacct
14-45-45-815| [        KERNEL] [    0.000000] Linux version 4.4.30 (aka@c12) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.1) ) #23 SMP Wed Nov 9 17:33:20 +04 2016
14-45-45-815| [        KERNEL] [    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
14-45-45-815| [        KERNEL] [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
14-45-45-815| [        KERNEL] [    0.000000] Machine model: Raspberry Pi 2 Model B Rev 1.1
14-45-45-815| [        KERNEL] [    0.000000] cma: Reserved 8 MiB at 0x3a800000
14-45-45-815| [        KERNEL] [    0.000000] Memory policy: Data cache writealloc
14-45-45-815| [        KERNEL] [    0.000000] On node 0 totalpages: 241664
14-45-45-815| [        KERNEL] [    0.000000] free_area_init_node: node 0, pgdat 8090f480, node_mem_map b9fa6000
14-45-45-815| [        KERNEL] [    0.000000]   Normal zone: 2124 pages used for memmap
14-45-45-815| [        KERNEL] [    0.000000]   Normal zone: 0 pages reserved
14-45-45-815| [        KERNEL] [    0.000000]   Normal zone: 241664 pages, LIFO batch:31
14-45-45-815| [        KERNEL] [    0.000000] [bcm2709_smp_init_cpus] enter (94c0->f3003010)
14-45-45-815| [        KERNEL] [    0.000000] [bcm2709_smp_init_cpus] ncores=4
14-45-45-815| [        KERNEL] [    0.000000] PERCPU: Embedded 11 pages/cpu @b9f6a000 s13324 r8192 d23540 u45056
14-45-45-815| [        KERNEL] [    0.000000] pcpu-alloc: s13324 r8192 d23540 u45056 alloc=11*4096
14-45-45-815| [        KERNEL] [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
14-45-45-815| [        KERNEL] [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 239540
14-45-45-815| [        KERNEL] [    0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1024 bcm2708_fb.fbheight=768 bcm2709.boardrev=0xa01041 bcm2709.serial=0x4bb13bdb smsc95xx.macaddr=B8:27:EB:B1:3B:DB bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  console=ttyAMA0,115200 console=tty1 quiet wtboot=mmc
14-45-45-815| [        KERNEL] [    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
14-45-45-815| [        KERNEL] [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
14-45-45-815| [        KERNEL] [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
14-45-45-815| [        KERNEL] [    0.000000] Memory: 939232K/966656K available (3795K kernel code, 168K rwdata, 1176K rodata, 4108K init, 365K bss, 19232K reserved, 8192K cma-reserved)
14-45-45-815| [        KERNEL] [    0.000000] Virtual kernel memory layout:
14-45-45-815| [        KERNEL] [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
14-45-45-815| [        KERNEL] [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
14-45-45-815| [        KERNEL] [    0.000000]     vmalloc : 0xbb800000 - 0xff800000   (1088 MB)
14-45-45-815| [        KERNEL] [    0.000000]     lowmem  : 0x80000000 - 0xbb000000   ( 944 MB)
14-45-45-815| [        KERNEL] [    0.000000]     modules : 0x7f000000 - 0x80000000   (  16 MB)
14-45-45-815| [        KERNEL] [    0.000000]       .text : 0x80008000 - 0x804e2f94   (4972 kB)
14-45-45-815| [        KERNEL] [    0.000000]       .init : 0x804e3000 - 0x808e6000   (4108 kB)
14-45-45-815| [        KERNEL] [    0.000000]       .data : 0x808e6000 - 0x80910380   ( 169 kB)
14-45-45-815| [        KERNEL] [    0.000000]        .bss : 0x80913000 - 0x8096e54c   ( 366 kB)
14-45-45-815| [        KERNEL] [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
14-45-45-815| [        KERNEL] [    0.000000] Hierarchical RCU implementation.
14-45-45-815| [        KERNEL] [    0.000000] 	Build-time adjustment of leaf fanout to 32.
14-45-45-815| [        KERNEL] [    0.000000] NR_IRQS:16 nr_irqs:16 16
14-45-45-815| [        KERNEL] [    0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
14-45-45-815| [        KERNEL] [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
14-45-45-815| [        KERNEL] [    0.000010] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
14-45-45-815| [        KERNEL] [    0.000029] Switching to timer-based delay loop, resolution 52ns
14-45-45-815| [        KERNEL] [    0.000240] Console: colour dummy device 80x30
14-45-45-815| [        KERNEL] [    0.000439] console [tty1] enabled
14-45-45-815| [        KERNEL] [    0.000464] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
14-45-45-815| [        KERNEL] [    0.000487] pid_max: default: 32768 minimum: 301
14-45-45-815| [        KERNEL] [    0.000646] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
14-45-45-815| [        KERNEL] [    0.000663] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
14-45-45-815| [        KERNEL] [    0.001792] Disabling cpuset control group subsystem
14-45-45-815| [        KERNEL] [    0.001828] Initializing cgroup subsys io
14-45-45-815| [        KERNEL] [    0.001860] Initializing cgroup subsys memory
14-45-45-815| [        KERNEL] [    0.001909] Initializing cgroup subsys devices
14-45-45-815| [        KERNEL] [    0.001932] Initializing cgroup subsys freezer
14-45-45-815| [        KERNEL] [    0.001989] CPU: Testing write buffer coherency: ok
14-45-45-815| [        KERNEL] [    0.002603] CPU0: update cpu_capacity 1024
14-45-45-815| [        KERNEL] [    0.002624] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
14-45-45-815| [        KERNEL] [    0.002637] [bcm2709_smp_prepare_cpus] enter
14-45-45-815| [        KERNEL] [    0.002730] Setting up static identity map for 0x8240 - 0x8274
14-45-45-815| [        KERNEL] [    0.004669] [bcm2709_boot_secondary] cpu:1 started (0) 16
14-45-45-815| [        KERNEL] [    0.004963] [bcm2709_secondary_init] enter cpu:1
14-45-45-815| [        KERNEL] [    0.005010] CPU1: update cpu_capacity 1024
14-45-45-815| [        KERNEL] [    0.005017] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
14-45-45-815| [        KERNEL] [    0.005514] [bcm2709_boot_secondary] cpu:2 started (0) 16
14-45-45-815| [        KERNEL] [    0.005740] [bcm2709_secondary_init] enter cpu:2
14-45-45-815| [        KERNEL] [    0.005768] CPU2: update cpu_capacity 1024
14-45-45-815| [        KERNEL] [    0.005775] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
14-45-45-815| [        KERNEL] [    0.006224] [bcm2709_boot_secondary] cpu:3 started (0) 16
14-45-45-815| [        KERNEL] [    0.006430] [bcm2709_secondary_init] enter cpu:3
14-45-45-815| [        KERNEL] [    0.006455] CPU3: update cpu_capacity 1024
14-45-45-815| [        KERNEL] [    0.006463] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
14-45-45-815| [        KERNEL] [    0.006540] Brought up 4 CPUs
14-45-45-815| [        KERNEL] [    0.006567] SMP: Total of 4 processors activated (153.60 BogoMIPS).
14-45-45-815| [        KERNEL] [    0.006576] CPU: All CPU(s) started in HYP mode.
14-45-45-815| [        KERNEL] [    0.006583] CPU: Virtualization extensions available.
14-45-45-815| [        KERNEL] [    0.007151] devtmpfs: initialized
14-45-45-815| [        KERNEL] [    0.019095] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
14-45-45-815| [        KERNEL] [    0.019601] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
14-45-45-815| [        KERNEL] [    0.020314] pinctrl core: initialized pinctrl subsystem
14-45-45-815| [        KERNEL] [    0.020922] NET: Registered protocol family 16
14-45-45-815| [        KERNEL] [    0.026505] DMA: preallocated 4096 KiB pool for atomic coherent allocations
14-45-45-815| [        KERNEL] [    0.049968] cpuidle: using governor ladder
14-45-45-815| [        KERNEL] [    0.079995] cpuidle: using governor menu
14-45-45-815| [        KERNEL] [    0.087594] Serial: AMBA PL011 UART driver
14-45-45-815| [        KERNEL] [    0.087975] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
14-45-45-815| [        KERNEL] [    0.088357] console [ttyAMA0] enabled
14-45-45-815| [        KERNEL] [    0.089037] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
14-45-45-815| [        KERNEL] [    0.163656] bcm2835-dma 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0x1
14-45-45-815| [        KERNEL] [    0.164389] usbcore: registered new interface driver usbfs
14-45-45-815| [        KERNEL] [    0.164577] usbcore: registered new interface driver hub
14-45-45-815| [        KERNEL] [    0.164716] usbcore: registered new device driver usb
14-45-45-815| [        KERNEL] [    0.170309] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-10-25 16:02
14-45-45-815| [        KERNEL] [    0.198661] clocksource: Switched to clocksource arch_sys_counter
14-45-45-815| [        KERNEL] [    0.215065] NET: Registered protocol family 2
14-45-45-815| [        KERNEL] [    0.215810] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
14-45-45-815| [        KERNEL] [    0.215947] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
14-45-45-815| [        KERNEL] [    0.216138] TCP: Hash tables configured (established 8192 bind 8192)
14-45-45-815| [        KERNEL] [    0.216256] UDP hash table entries: 512 (order: 2, 16384 bytes)
14-45-45-815| [        KERNEL] [    0.216318] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
14-45-45-815| [        KERNEL] [    0.216609] NET: Registered protocol family 1
14-45-45-815| [        KERNEL] [    2.831657] futex hash table entries: 1024 (order: 4, 65536 bytes)
14-45-45-815| [        KERNEL] [    2.893624] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
14-45-45-815| [        KERNEL] [    2.893659] io scheduler noop registered
14-45-45-815| [        KERNEL] [    2.893679] io scheduler deadline registered (default)
14-45-45-815| [        KERNEL] [    2.900476] BCM2708FB: allocated DMA memory fac00000
14-45-45-815| [        KERNEL] [    2.900567] BCM2708FB: allocated DMA channel 0 @ f3007000
14-45-45-815| [        KERNEL] [    2.925511] Console: switching to colour frame buffer device 128x48
14-45-45-815| [        KERNEL] [    3.962194] bcm2835-rng 3f104000.rng: hwrng registered
14-45-45-815| [        KERNEL] [    3.962477] vc-cma: Videocore CMA driver
14-45-45-815| [        KERNEL] [    3.962497] vc-cma: vc_cma_base      = 0x00000000
14-45-45-815| [        KERNEL] [    3.962509] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
14-45-45-815| [        KERNEL] [    3.962518] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
14-45-45-815| [        KERNEL] [    3.962891] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
14-45-45-815| [        KERNEL] [    3.964754] vchiq: vchiq_init_state: slot_zero = 0xbac80000, is_master = 0
14-45-45-815| [        KERNEL] [    3.972379] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
14-45-45-815| [        KERNEL] [    4.172852] Core Release: 2.80a
14-45-45-815| [        KERNEL] [    4.172892] Setting default values for core params
14-45-45-815| [        KERNEL] [    4.172936] Finished setting default values for core params
14-45-45-815| [        KERNEL] [    4.373361] Using Buffer DMA mode
14-45-45-815| [        KERNEL] [    4.373384] Periodic Transfer Interrupt Enhancement - disabled
14-45-45-815| [        KERNEL] [    4.373395] Multiprocessor Interrupt Enhancement - disabled
14-45-45-815| [        KERNEL] [    4.373405] OTG VER PARAM: 0, OTG VER FLAG: 0
14-45-45-815| [        KERNEL] [    4.373458] Dedicated Tx FIFOs mode
14-45-45-815| [        KERNEL] [    4.374118] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbac14000 dma = 0xfac14000 len=9024
14-45-45-815| [        KERNEL] [    4.374157] FIQ FSM acceleration enabled for :
14-45-45-815| [        KERNEL] [    4.374157] Non-periodic Split Transactions
14-45-45-815| [        KERNEL] [    4.374157] Periodic Split Transactions
14-45-45-815| [        KERNEL] [    4.374157] High-Speed Isochronous Endpoints
14-45-45-815| [        KERNEL] [    4.374157] Interrupt/Control Split Transaction hack enabled
14-45-45-815| [        KERNEL] [    4.374183] dwc_otg: Microframe scheduler enabled
14-45-45-815| [        KERNEL] [    4.374248] WARN::hcd_init_fiq:413: FIQ on core 1 at 0x8025a168
14-45-45-815| [        KERNEL] [    4.374265] WARN::hcd_init_fiq:414: FIQ ASM at 0x8025a4cc length 36
14-45-45-815| [        KERNEL] [    4.374283] WARN::hcd_init_fiq:439: MPHI regs_base at 0xbb908000
14-45-45-815| [        KERNEL] [    4.374361] dwc_otg 3f980000.usb: DWC OTG Controller
14-45-45-815| [        KERNEL] [    4.374412] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
14-45-45-815| [        KERNEL] [    4.374459] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
14-45-45-815| [        KERNEL] [    4.374514] Init: Port Power? op_state=1
14-45-45-815| [        KERNEL] [    4.374525] Init: Power Port (0)
14-45-45-815| [        KERNEL] [    4.374782] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
14-45-45-815| [        KERNEL] [    4.374801] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
14-45-45-815| [        KERNEL] [    4.374815] usb usb1: Product: DWC OTG Controller
14-45-45-815| [        KERNEL] [    4.374830] usb usb1: Manufacturer: Linux 4.4.30 dwc_otg_hcd
14-45-45-815| [        KERNEL] [    4.374844] usb usb1: SerialNumber: 3f980000.usb
14-45-45-815| [        KERNEL] [    4.376179] hub 1-0:1.0: USB hub found
14-45-45-815| [        KERNEL] [    4.376269] hub 1-0:1.0: 1 port detected
14-45-45-815| [        KERNEL] [    4.376861] dwc_otg: FIQ enabled
14-45-45-815| [        KERNEL] [    4.376877] dwc_otg: NAK holdoff enabled
14-45-45-815| [        KERNEL] [    4.376885] dwc_otg: FIQ split-transaction FSM enabled
14-45-45-815| [        KERNEL] [    4.376931] Module dwc_common_port init
14-45-45-815| [        KERNEL] [    4.377989] usbcore: registered new interface driver usbtouchscreen
14-45-45-815| [        KERNEL] [    4.381811] bcm2835-cpufreq: min=600000 max=900000
14-45-45-815| [        KERNEL] [    4.385211] sdhost: log_buf @ bac13000 (fac13000)
14-45-45-815| [        KERNEL] [    4.438712] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
14-45-45-815| [        KERNEL] [    4.439113] hidraw: raw HID events driver (C) Jiri Kosina
14-45-45-815| [        KERNEL] [    4.439962] usbcore: registered new interface driver usbhid
14-45-45-815| [        KERNEL] [    4.439976] usbhid: USB HID core driver
14-45-45-815| [        KERNEL] [    4.440558] NET: Registered protocol family 17
14-45-45-815| [        KERNEL] [    4.440898] Registering SWP/SWPB emulation handler
14-45-45-815| [        KERNEL] [    4.441797] registered taskstats version 1
14-45-45-815| [        KERNEL] [    4.441910] vc-sm: Videocore shared memory driver
14-45-45-815| [        KERNEL] [    4.441935] [vc_sm_connected_init]: start
14-45-45-815| [        KERNEL] [    4.452583] [vc_sm_connected_init]: end - returning 0
14-45-45-815| [        KERNEL] [    4.458854] Freeing unused kernel memory: 4108K (804e3000 - 808e6000)
14-45-45-815| [        KERNEL] [    4.495980] mmc0: host does not support reading read-only switch, assuming write-enable
14-45-45-815| [        KERNEL] [    4.497945] mmc0: new high speed SDHC card at address 59b4
14-45-45-815| [        KERNEL] [    4.500867] mmcblk0: mmc0:59b4 00000 7.35 GiB
14-45-45-815| [        KERNEL] [    4.502443]  mmcblk0: p1
14-45-45-815| [       hotplug] [    4.496814] Block device 179:1. No action.
14-45-45-815| [       hotplug] [    4.498783] Block device 179:0. No action.
14-45-45-815| [        KERNEL] [    4.569197] Indeed it is in host mode hprt0 = 00021501
14-45-45-815| [        KERNEL] [    4.748702] usb 1-1: new high-speed USB device number 2 using dwc_otg
14-45-45-815| [        KERNEL] [    4.748859] Indeed it is in host mode hprt0 = 00001101
14-45-45-815| [          pfac] [    4.781079] Run /sbin/initrd.
14-45-45-815| [          pfac] [    4.781257] Ok, PID 532.
14-45-45-815| [        initrd] [    4.784673] WTware shell v.5.4.56/RPi
14-45-45-815| [        initrd] [    4.813367] Local media boot.
14-45-45-815| [        initrd] [    4.813551] USB boot.
14-45-45-815| [        KERNEL] [    4.949012] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
14-45-45-815| [        KERNEL] [    4.949040] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
14-45-45-815| [        KERNEL] [    4.949986] hub 1-1:1.0: USB hub found
14-45-45-815| [        KERNEL] [    4.950135] hub 1-1:1.0: 5 ports detected
14-45-45-815| [        KERNEL] [    5.228705] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
14-45-45-815| [        KERNEL] [    5.328992] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
14-45-45-815| [        KERNEL] [    5.329016] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
14-45-45-815| [        KERNEL] [    5.408700] usb 1-1.2: new low-speed USB device number 4 using dwc_otg
14-45-45-815| [        KERNEL] [    5.514709] usb 1-1.2: New USB device found, idVendor=045e, idProduct=0040
14-45-45-815| [        KERNEL] [    5.514732] usb 1-1.2: New USB device strings: Mfr=1, Product=3, SerialNumber=0
14-45-45-815| [        KERNEL] [    5.514748] usb 1-1.2: Product: Microsoft 3-Button Mouse with IntelliEye(TM)
14-45-45-815| [        KERNEL] [    5.514763] usb 1-1.2: Manufacturer: Microsoft
14-45-45-815| [        KERNEL] [    5.524358] input: Microsoft Microsoft 3-Button Mouse with IntelliEye(TM) as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:045E:0040.0001/input/input0
14-45-45-815| [        KERNEL] [    5.524991] hid-generic 0003:045E:0040.0001: input,hidraw0: USB HID v1.10 Mouse [Microsoft Microsoft 3-Button Mouse with IntelliEye(TM)] on usb-3f980000.usb-1.2/input0
14-45-45-815| [        KERNEL] [    5.618705] usb 1-1.3: new low-speed USB device number 5 using dwc_otg
14-45-45-815| [        KERNEL] [    5.744624] usb 1-1.3: New USB device found, idVendor=0557, idProduct=2221
14-45-45-815| [        KERNEL] [    5.744647] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
14-45-45-815| [        KERNEL] [    5.744662] usb 1-1.3: Product: UC-10KM V1.3.124
14-45-45-815| [        KERNEL] [    5.744676] usb 1-1.3: Manufacturer: ATEN
14-45-45-815| [        KERNEL] [    5.744692] usb 1-1.3: SerialNumber: USB Composite device
14-45-45-815| [        KERNEL] [    5.773341] input: ATEN UC-10KM V1.3.124 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:0557:2221.0002/input/input1
14-45-45-815| [        KERNEL] [    5.861277] hid-generic 0003:0557:2221.0002: input,hidraw1: USB HID v1.10 Keyboard [ATEN UC-10KM V1.3.124] on usb-3f980000.usb-1.3/input0
14-45-45-815| [        KERNEL] [    5.882338] input: ATEN UC-10KM V1.3.124 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:0557:2221.0003/input/input2
14-45-45-815| [        KERNEL] [    5.883139] hid-generic 0003:0557:2221.0003: input,hidraw2: USB HID v1.10 Mouse [ATEN UC-10KM V1.3.124] on usb-3f980000.usb-1.3/input1
14-45-45-815| [        initrd] [    6.415259] WTpassword empty.
14-45-45-815| /--- FILE "/bootmedia/configs/initrd.wtc" -----------------------
14-45-45-815| | clientIP = *
14-45-45-815| | config = network
14-45-45-815| | tftpIP = 10.1.1.10
14-45-45-815| \----------------------------------------------------
14-45-45-815| [        initrd] [    8.412455] Load ethernet drivers.
14-45-45-815| [        initrd] [    8.412599] modprobe smsc95xx.
14-45-45-815| [        KERNEL] [    8.431040] smsc95xx v1.0.4
14-45-45-815| [        KERNEL] [    8.492755] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:b1:3b:db
14-45-45-815| [        KERNEL] [    8.493052] usbcore: registered new interface driver smsc95xx
14-45-45-815| [        KERNEL] [    8.551093] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
14-45-45-815| [        KERNEL] [   10.011117] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
14-45-45-815| [        initrd] [   10.046779] WTpassword empty.
14-45-45-815| [        initrd] [   10.532423] dhcp: 336 bytes from 10.1.2.254.
14-45-45-815| [        initrd] [   10.532602] 00000000:0000013c00000000001100000a01c0fe0a01c04d00430044013c000002010601  ...<..............M.C.D.<......
14-45-45-815| [        initrd] [   10.532711] 00000020:67458b6b00000000000000000a01c04d0a01c80f00000000b827ebb13bdb0000  gE.k...........M.........'..;...
14-45-45-815| [        initrd] [   10.532810] 00000040:0000000000000000000000000000000000000000000000000000000000000000  ................................
14-45-45-815| [        initrd] [   10.532910] 00000060:0000000000000000000000000000000000000000000000000000000000000000  ................................
14-45-45-815| [        initrd] [   12.040394] dhcp: 336 bytes from 10.1.2.254.
14-45-45-815| [        initrd] [   12.040538] 00000000:0000013c00000000001100000a01c0fe0a01c04d00430044013c000002010601  ...<..............M.C.D.<......
14-45-45-815| [        initrd] [   12.040644] 00000020:67458b6b00000000000000000a01c04d0000000000000000b827ebb13bdb0000  gE.k...........M.........'..;...
14-45-45-815| [        initrd] [   12.040744] 00000040:0000000000000000000000000000000000000000000000000000000000000000  ................................
14-45-45-815| [        initrd] [   12.040844] 00000060:0000000000000000000000000000000000000000000000000000000000000000  ................................
14-45-45-815| [        initrd] [   12.070136] dhcp: server address 10.1.1.2.
14-45-45-815| [        initrd] [   12.070252] dhcp: 10.1.3.77/255.255.255.0.
14-45-45-815| [        initrd] [   12.070360] dhcp: default gateway 10.1.2.254.
14-45-45-815| [        initrd] [   12.070462] dhcp: DNS 10.1.1.2.
14-45-45-815| [        initrd] [   12.070560] dhcp: DNS 10.1.1.1.
14-45-45-815| [        initrd] [   12.070662] dhcp: domain mydomain.org.uk.
14-45-45-815| [        initrd] [   12.070762] TFTP IP 10.1.1.10 already specified.
14-45-45-815| [        initrd] [   12.070866] No boot file from DHCP.
14-45-45-815| [        initrd] [   12.070969] TFTP binary "", configs prefix "", using "/" slash.
14-45-45-815| Send broadcast WTCU discover.
14-45-45-815| [          pfac] [   12.073866] Run /sbin/httpd.
14-45-45-815| [        initrd] [   12.074002] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
14-45-45-815| [          pfac] [   12.074188] Ok, PID 575.
14-45-45-815| [         httpd] [   12.080531] HTTP Server, WTware v.5.4.56/RPi
14-45-45-815| [        KERNEL] [   12.104808] random: httpd: uninitialized urandom read (32 bytes read, 113 bits of entropy available)
14-45-45-815| [        initrd] [   12.207334] USB: 0424:9514 Standard Microsystems Corp. SMC9514 Hub.
14-45-45-815| [        initrd] [   12.207532] USB: 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter.
14-45-45-815| [        initrd] [   12.207655] USB: 045e:0040 Microsoft Corp. Wheel Mouse Optical.
14-45-45-815| [        initrd] [   12.207764] USB: 0557:2221 ATEN International Co., Ltd Winbond Hermon.
14-45-45-815| [        initrd] [   12.207870] [TFTP] Download config file Everyone/list.wtc from 10.1.1.10.
14-45-45-815| [        initrd] [   12.217119] WTware TFTP v.5.4.56.
14-45-45-815| /--- FILE "/tmp/list.wtc" -----------------------
14-45-45-815| | #
14-45-45-815| | # Include files list.
14-45-45-815| | #
14-45-45-815| | # This way of terminals configuration is meant only for manual
14-45-45-815| | # terminals management. Graphic configurator doesn't read list.wtc,
14-45-45-815| | # doesn't read or edit files from ListIncludes directory. So be careful
14-45-45-815| | # not to configure one terminal in configurator and in list.wtc.
14-45-45-815| | #
14-45-45-815| | # This file uses such syntax:
14-45-45-815| | #
14-45-45-815| | #    01.02.03.04.05.06[([username@][terminalname])] [file [file ...]]] [# note]
14-45-45-815| | #
14-45-45-815| | # Examples:
14-45-45-815| | #
14-45-45-815| | #     02.03.04.05.06.07 file1
14-45-45-815| | #
14-45-45-815| | # It means that terminal with MAC-address 02.03.04.05.06.07
14-45-45-815| | # reads parameters from file ListIncludes/file1.
14-45-45-815| | #
14-45-45-815| | #
14-45-45-815| | #     03.04.05.06.07.08(vasja@) file2
14-45-45-815| | #
14-45-45-815| | # It means that terminal with MAC-address 03.04.05.06.07.08
14-45-45-815| | # reads parameters from file ListIncludes/file2
14-45-45-815| | # and sets user name "vasja" in "Windows login" window.
14-45-45-815| | #
14-45-45-815| | #
14-45-45-815| | #     04.05.06.07.08.09(term5) file6 file7 # John notebook.
14-45-45-815| | #
14-45-45-815| | # It means that terminal with MAC-address 04.05.06.07.08.09
14-45-45-815| | # is named term5, the same as specify clienthostname parameter,
14-45-45-815| | # and it reads parameters from files ListIncludes/file6 and
14-45-45-815| | # ListIncludes/file7.
14-45-45-815| | #
14-45-45-815| | #
14-45-45-815| | # To specify user name using non-latin letters open this file in
14-45-45-815| | # Notepad and save with Encoding: Unicode.
14-45-45-815| | #
14-45-45-815| [        initrd] [   12.222539] [TFTP] Download config file Terminals/B8.27.EB.B1.3B.DB/config.wtc from 10.1.1.10.
14-45-45-815| /--- FILE "/tmp/config.wtc" -----------------------
14-45-45-815| | server=wtmang.mydomain.org.uk; 10.1.1.10
14-45-45-815| | clienthostname=Myts
14-45-45-815| | template Hash-RDPTeminal
14-45-45-815| | connection coreb
14-45-45-815| | connection RDPTeminal
14-45-45-815| | connection Ts_1
14-45-45-815| | connection Ts_2
14-45-45-815| | connection T8
14-45-45-815| | next screen
14-45-45-815| [        initrd] [   12.227628] [TFTP] Download config file Everyone/all.wtc from 10.1.1.10.
14-45-45-815| /--- FILE "/tmp/all.wtc" -----------------------
14-45-45-815| | server=wtmang.mydomain.org.uk;10.1.1.10;
14-45-45-815| [        initrd] [   12.230951] [TFTP] Download config file Templates/Hash-RDPTeminal.wtc from 10.1.1.10.
14-45-45-815| /--- FILE "/tmp/tmp.wtc" -----------------------
14-45-45-815| | [BOM]
14-45-45-815| | vnc=on
14-45-45-815| | vnc_password=hex:a4f4fc5d544013bebad15701ecf6fb4c
14-45-45-815| | display=1024x768
14-45-45-815| | skin=pk
14-45-45-815| [        initrd] [   12.233782] [TFTP] Download config file Connections/coreb.wtc from 10.1.1.10.
14-45-45-815| | server=10.1.4.50
14-45-45-815| | domain=mydom
14-45-45-815| [        initrd] [   12.237038] [TFTP] Download config file Connections/RDPTeminal.wtc from 10.1.1.10.
14-45-45-815| | server=10.1.4.30
14-45-45-815| [        initrd] [   12.239115] [TFTP] Download config file Connections/Ts_1.wtc from 10.1.1.10.
14-45-45-815| | server=Ts_1.mydomain.org.uk
14-45-45-815| | domain=mydomain.org.uk
14-45-45-815| [        initrd] [   12.242203] [TFTP] Download config file Connections/Ts_2.wtc from 10.1.1.10.
14-45-45-815| | server=Ts_2.mydomain.org.uk
14-45-45-815| [        initrd] [   12.247743] [TFTP] Download config file Connections/T8.wtc from 10.1.1.10.
14-45-45-815| | server=T8.mydomain.org.uk
14-45-45-815| [        initrd] [   12.249511] [TFTP] Download config file Connections/RDPTeminal.wtc from 10.1.1.10.
14-45-45-815| [        initrd] [   12.252097] [TFTP] Download config file Connections/coreb.wtc from 10.1.1.10.
14-45-45-815| [        initrd] [   12.253913] [TFTP] Download config file Connections/Ts_1.wtc from 10.1.1.10.
14-45-45-815| [        initrd] [   12.256005] [TFTP] Download config file Connections/Ts_2.wtc from 10.1.1.10.
14-45-45-815| [        KERNEL] [   12.266805] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
14-45-45-815| /--- FILE "/etc/config.compiled" -----------------------
14-45-45-815| [        initrd] [   12.286400] Hostname: "Myts".
14-45-45-815| Everyone can control terminal by RSH.
14-45-45-815| RSH: listener is active.
14-45-45-815| [         httpd] [   12.487752] Reread settings.
14-45-45-815| [         httpd] [   12.488126] Everyone can control terminal by HTTP.
14-45-45-815| [            gm] [   12.491165] WTware session manager v.5.4.56/RPi.
14-45-45-815| [            gm] [   12.550325] EV_REL flag found. Add mouse event2: ATEN UC-10KM V1.3.124.
14-45-45-815| [            gm] [   12.550490] Add keyboard event1: ATEN UC-10KM V1.3.124.
14-45-45-815| [            gm] [   12.610169] EV_REL flag found. Add mouse event0: Microsoft Microsoft 3-Button Mouse with IntelliEye(TM).
14-45-45-815| [            gm] [   12.610456] Display mode: 1024x768, 32 bit, 0 Hz, modeline "", DDC enabled, connector 0.
14-45-45-815| [            gm] [   12.628156] Framebuffer device found.
14-45-45-815| [            gm] [   12.628282] LINELENBYTES 4096
14-45-45-815| [            gm] [   12.628390] VLEN 3145728
14-45-45-815| [            gm] [   12.647923] [TFTP] Download config file Graphic/pk/menu.png from 10.1.1.10.
14-45-45-815| [        KERNEL] [   12.880470] random: nonblocking pool is initialized
14-45-45-815| [            gm] [   13.522839] [TFTP] Download config file Graphic/pk/popup.png from 10.1.1.10.
14-45-45-815| [            gm] [   13.539613] [TFTP] Download config file Graphic/pk/saver.png from 10.1.1.10.
14-45-45-815| [            gm] [   13.540590] [TFTP] Error code 1: File not found..
14-45-45-815| [            gm] [   13.540720] [TFTP] Download config file Graphic/pk/saver.gif from 10.1.1.10.
14-45-45-815| [            gm] [   13.549767] [TFTP] Error code 1: File not found..
14-45-45-815| [            gm] [   13.549885] [TFTP] Download config file Graphic/pk/wait.png from 10.1.1.10.
14-45-45-815| [            gm] [   13.591465] /tmp/wait.png: 464x195.
14-45-45-815| [            gm] [   13.790962] /tmp/menu.png: 1024x768.
14-45-45-815| [            gm] [   13.817134] /graphic/winlg.png: 48x48.
14-45-45-815| [            gm] [   13.818101] /graphic/winsm.png: 38x38.
14-45-45-815| [            gm] [   13.818644] Everyone can control terminal by VNC.
14-45-45-815| [            gm] [   13.818760] VNC listener at port 5900.
14-45-45-815| [            gm] [  215.127735] [VNC] Connection from 10.1.1.10.
14-45-45-815| [            gm] [  215.128464] [VNC] Client VNC version 8 (RFB 003.008).
14-45-45-815| [            gm] [  217.492426] [VNC] Password ok.
14-45-45-815| [            gm] [  217.565212] [VNC] bits-per-pixel 32, depth 24, big-endian false, true-colour true.
14-45-45-815| [            gm] [  217.565348] [VNC] red-max 0x00ff, green-max 0x00ff, blue-max 0x00ff.
14-45-45-815| [            gm] [  217.565460] [VNC] red-shift 16, green-shift 8, blue-shift 0.
14-45-45-815| [            gm] [  217.565565] [VNC] 32-bit server, 32-bit client.
14-45-45-815| [            gm] [  217.565669] [VNC] 25 encodings.
14-45-45-815| [            gm] [  217.565771] [VNC] Encoding 16.
14-45-45-815| [            gm] [  217.565904] [VNC] Encoding 17.
14-45-45-815| [            gm] [  217.566008] [VNC] Encoding 10.
14-45-45-815| [            gm] [  217.566109] [VNC] Encoding 9.
14-45-45-815| [            gm] [  217.566211] [VNC] Encoding 8.
14-45-45-815| [            gm] [  217.566312] [VNC] Encoding 6.
14-45-45-815| [            gm] [  217.566412] [VNC] Encoding 5.
14-45-45-815| [            gm] [  217.566513] [VNC] Encoding 4.
14-45-45-815| [            gm] [  217.566614] [VNC] Encoding 2.
14-45-45-815| [            gm] [  217.566715] [VNC] Encoding 1.
14-45-45-815| [            gm] [  217.566815] [VNC] Encoding 0.
14-45-45-815| [            gm] [  217.566915] [VNC] Encoding -250.
14-45-45-815| [            gm] [  217.567016] [VNC] Encoding -239.
14-45-45-815| [            gm] [  217.567116] [VNC] Encoding -232.
14-45-45-815| [            gm] [  217.567218] [VNC] Encoding -26.
14-45-45-815| [            gm] [  217.567318] [VNC] Encoding -65530.
14-45-45-815| [            gm] [  217.567418] [VNC] Encoding -224.
14-45-45-815| [            gm] [  217.567519] [VNC] Encoding -223.
14-45-45-815| [            gm] [  217.567619] [VNC] Encoding -65535.
14-45-45-815| [            gm] [  217.567720] [VNC] Encoding -32768.
14-45-45-815| [            gm] [  217.567821] [VNC] Encoding -32767.
14-45-45-815| [            gm] [  217.567921] [VNC] Encoding -32764.
14-45-45-815| [            gm] [  217.568021] [VNC] Encoding -32766.
14-45-45-815| [            gm] [  217.568121] [VNC] Encoding -32765.
14-45-45-815| [            gm] [  217.568222] [VNC] Encoding -1063131698.
14-45-45-815| [            gm] [  218.174734] [VNC] bits-per-pixel 32, depth 24, big-endian false, true-colour true.
14-45-45-815| [            gm] [  218.174914] [VNC] red-max 0x00ff, green-max 0x00ff, blue-max 0x00ff.
14-45-45-815| [            gm] [  218.175023] [VNC] red-shift 16, green-shift 8, blue-shift 0.
14-45-45-815| [            gm] [  218.175117] [VNC] 32-bit server, 32-bit client.
14-45-45-815| [            gm] [  218.175204] [VNC] 24 encodings.
14-45-45-815| [            gm] [  218.175277] [VNC] Encoding 5.
14-45-45-815| [            gm] [  218.175348] [VNC] Encoding 17.
14-45-45-815| [            gm] [  218.175417] [VNC] Encoding 16.
14-45-45-815| [            gm] [  218.175487] [VNC] Encoding 10.
14-45-45-815| [            gm] [  218.175556] [VNC] Encoding 9.
14-45-45-815| [            gm] [  218.175625] [VNC] Encoding 8.
14-45-45-815| [            gm] [  218.175694] [VNC] Encoding 6.
14-45-45-815| [            gm] [  218.175763] [VNC] Encoding 4.
14-45-45-815| [            gm] [  218.175834] [VNC] Encoding 2.
14-45-45-815| [            gm] [  218.175904] [VNC] Encoding 1.
14-45-45-815| [            gm] [  218.175972] [VNC] Encoding 0.
14-45-45-815| [            gm] [  218.176047] [VNC] Encoding -250.
14-45-45-815| [            gm] [  218.176120] [VNC] Encoding -239.
14-45-45-815| [            gm] [  218.176190] [VNC] Encoding -232.
14-45-45-815| [            gm] [  218.176262] [VNC] Encoding -26.
14-45-45-815| [            gm] [  218.176332] [VNC] Encoding -65530.
14-45-45-815| [            gm] [  218.176401] [VNC] Encoding -224.
14-45-45-815| [            gm] [  218.176470] [VNC] Encoding -223.
14-45-45-815| [            gm] [  218.176545] [VNC] Encoding -32768.
14-45-45-815| [            gm] [  218.176623] [VNC] Encoding -32767.
14-45-45-815| [            gm] [  218.176697] [VNC] Encoding -32764.
14-45-45-815| [            gm] [  218.176766] [VNC] Encoding -32766.
14-45-45-815| [            gm] [  218.176836] [VNC] Encoding -32765.
14-45-45-815| [            gm] [  218.176907] [VNC] Encoding -1063131698.
14-45-45-815| [            gm] [  224.015927] Run '/sbin/resolver 0x973f28 dns [T8.mydomain.org.uk]', log '', env '', pid ''.
14-45-45-815| [          pfac] [  224.016234] Run /sbin/resolver 0x973f28 dns [T8.mydomain.org.uk].
14-45-45-815| [          pfac] [  224.016399] Ok, PID 583.
14-45-45-815| [          pfac] [  224.026603] Process pid 583 terminated, status 00000000.
14-45-45-815| [            gm] [  224.157761] T8.mydomain.org.uk => 10.1.96.1.
14-45-45-815| [            gm] [  224.157967] Free ram before fork terminal client /sbin/rdpclient (session 1): 919892 Kb.
14-45-45-815| [          pfac] [  224.158682] Run /sbin/rdpclient 1.
14-45-45-815| [            gm] [  224.158788] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
14-45-45-815| [          pfac] [  224.158924] Ok, PID 584.
14-45-45-815| [ rdpclient 584] [  224.168674] RDP Terminal Client, WTware v.5.4.56/RPi, pipe 1, pid 584.
14-45-45-815| [ rdpclient 584] [  224.170991] Make RDP session with 10.1.96.1, port 3389.
14-45-45-815| [ rdpclient 584] [  224.171176]  No username.
14-45-45-815| [ rdpclient 584] [  224.171305]  No password.
14-45-45-815| [ rdpclient 584] [  224.171418]  No PIN.
14-45-45-815| [ rdpclient 584] [  224.171527]  No domain.
14-45-45-815| [ rdpclient 584] [  224.171633]  No shell.
14-45-45-815| [ rdpclient 584] [  224.171737]  No directory.
14-45-45-815| [ rdpclient 584] [  224.171841]  Window: 1024x768@24.
14-45-45-815| [ rdpclient 584] [  224.171978]  PFlags 0x0000002F.
14-45-45-815| [ rdpclient 584] [  224.172086]  Keyboard 00000409:00000000.
14-45-45-815| [ rdpclient 584] [  224.172192]  My hostname "Myts".
14-45-45-815| [ rdpclient 584] [  224.172298] TCP: connecting to 10.1.96.1:3389.
14-45-45-815| [ rdpclient 584] [  351.520263]          fstream.cpp (  437): -- ERROR -- Conection with 10.1.96.1:3389 failed, errno 110.
14-45-45-815| [ rdpclient 584] [  351.620391]    rdpclient-tcp.cpp (  260): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
14-45-45-815| [ rdpclient 584] [  351.620529] Server 10.1.96.1, port 3389: connection rejected.
14-45-45-815| Make sure that terminal service works on this server.
14-45-45-815| Try to connect using mstsc.exe.
14-45-45-815| [          pfac] [  351.621991] Process pid 584 terminated, status 00000009.
14-45-45-815| [            gm] [  351.631129] Final message: Server 10.1.96.1, port 3389: connection rejected.
14-45-45-815| [            gm] [  351.635488] /graphic/exlm.png: 44x42.
14-45-45-824| Connection from wtc.exe at 10.1.1.10.
Re: Wtware Pi 5.4.56
Posted: Thu Nov 17, 2016 11:25 pm
Alon wrote:On WtwareCenter on the right pane when checking logs, mouse scroll doesn't work, it works on the left pane (terminal list).
Yes. We should fix it some time... Scroll works when mouse pointer is over the scroller of the right pane.
Alon wrote:it sorts only by the last portion of the IP
Yes. Already fixed in 5.4.58.
Alon wrote:When connecting to an unavailable rdp server it takes 207 seconds to stop trying to connect, also it cannot be interrupted (closed) by the red "X" next to the server address you are trying to connect on the "infobox". I tried connect_timeout 0 and 15 with the same results.
connect_timeout is a lower limit, not upper. It was designed many years ago to wake up on-demand ppp links and seems useless now.
Red "X" doesn't work because... mmm.. it just does not work in this case :(
Posted: Fri Nov 18, 2016 12:45 pm
Posted: Mon Nov 28, 2016 3:33 pm
by Alon
Hi Aka,
I've been away for a while, thank you for the quick support, found that v5.4.62 has been released, trying it now.
Well, seems that all the 3 problems have been fixed in v5.4.62 ! :P
Mouse scroll OK.
Sort by IP OK.
Rdp time out is also OK!
Thank you.
