Hi!
I'm doing some tests connecting WTware to a VNC server (using server=vnc:IP:port). It's working great so far, but I cannot pass the correct keyboard layout to the server.
If I set "keyboard=pt-br" , the default keyboard (en-us) is still passed to the VNC server. Is this supposed to work like that?
Keyboard layout configuration on VNC server
Re: Keyboard layout configuration on VNC server
I attached the log file after the connection to the server.
- 5452VNC-log.txt
- (21.6 KiB) Downloaded 827 times
"keyboard=" for RDP session only. "language=" should work for VNC client. But there is no pt-br for language= now.
Is there right keyboard layout for brasil keyboard?
http://ascii-table.com/keyboard.php/275
Hey aka! thanks for replying!aka wrote:http://ascii-table.com/keyboard.php/275
Yes, this seems to be the correct one for me!
Please, try wtware 5.4.62.
Worked great aka, thank you!
