PXE/netboot on Pi3
Gnome
PXE/netboot on Pi3
Post by Gnome » Fri Nov 04, 2016 2:34 pm
Hello!
Pi3 can generally boot over Network without SD-Card. Has anyone tried this for WT-Ware?
Description on the RasPi website didn't help me to get PXE-boot to work.
Any hints or experience on how to configure a Pi3 for netboot to WT-Ware without SD-Card?
Re: PXE/netboot on Pi3
Post by aka » Sat Nov 05, 2016 9:55 pm
Gnome wrote:Pi3 can generally boot over Network without SD-Card
Really? Give me an instruction. As far as I know, Pi3 can not start without SD.
J1mbo
Post by J1mbo » Mon Nov 07, 2016 2:47 pm
Guest
Post by Guest » Fri Nov 11, 2016 5:11 am
Prepared the Pi3 as described and it seems to access the network for boot information (LAN-leds flashing) but nothing more happens. Screen is black. Any ideas how to get further?
J1mbo
Post by J1mbo » Fri Nov 11, 2016 12:17 pm
Did you update the RPi firmware with the net boot settings from Raspbian?
Gnome
Post by Gnome » Fri Nov 11, 2016 1:36 pm
Yes. Updated next_branch firmware and activated netboot option. Had the WTware netboot active before, starting from SD card, and it worked. RPi's netboot may not be working the same way as WTwares netboot...
Think this is more or less a question to the technicians at WTware...
Did anyone try to boot from blank RPi to WTware before?
Gnome
Post by Gnome » Fri Nov 11, 2016 11:56 pm
I cracked the nut !!!
Managed to netboot WTware client without SD card.
There may be certain restrictions...
Let me have some tests done before I tell you more.
:D
J1mbo
Post by J1mbo » Mon Nov 14, 2016 12:31 pm
Please do :)
Cza
Post by Cza » Fri Jan 13, 2017 7:46 pm
Please send me some instruction about the diskless wtware configuration.
Regards,
Cza
rodo
Post by rodo » Fri Feb 24, 2017 1:54 pm
@Gnome
How are you?
No longer heard from you.
Best regards
Rolf
uncle_muddy
Post by uncle_muddy » Fri Mar 17, 2017 10:22 pm
My 1st post so please be gentle with me ;) 1st thing to say is what an awesome product this is, and was just what I have been looking for..
I too am trying to get this to work, I have tested that I can get the Pi3 to boot as standard without SD from the network and that works fine (or at least it did after a fashion) But once I get past that bit I'm getting a little (very) lost.
What I'm trying to do now is bend it so I can get wtware to boot in the same fashion, so that I don't need to have an SD card in the Pi to get it to boot to wtware.
If anyone has any useful info or pointers they would be much appreciated
UM
uncle_muddy
Post by uncle_muddy » Sun Mar 19, 2017 6:25 pm
I've made a bunch of progress on this over the last couple of days, but now I'm stuck.
I can get the Pi to boot and load up to the "Press DEL to enter SETUP" screen, thats when we run into problems, I then get the following on the screen
ERROR: INTERNAL ERROR
WTware v.5.4.78/RPi
File: initrd.cpp
Line: 254
Please, report this information to WTware tech support.
Please, correct the error to continue.
WTware v.5.4.78/RPi documentation is avaialble at http://www.wtware.com/doc.html
Techsupport, forum: http://forum.wtware.com
    email: support@wtware.com
    Skype: wtware
and I'm dumped out to a # prompt on the machine, I'm going to be a little tied for time over the coming days but if anyone has any pointer I can test and report back results
UM
uncle_muddy
Post by uncle_muddy » Mon Mar 20, 2017 12:05 pm
I have over come the problem and managed to get it to work :twisted:
Post by aka » Mon Mar 20, 2017 12:15 pm
We'll release wtware with this boot in a few days.
