Wireless WPA2 Enterprise Authentication
Re: Wireless WPA2 Enterprise Authentication
Hi Aka,
Yes the Radius server work with static IP.
Yes wireless is important for my deployment.
I hope it will work, I will install the test version and let you know.
Thanks,
Ken
Thanks,
Ken
Hi Aka,
Please refer to attach photos.
1. ifconfig.jpg - The Static IP Address was define here
2. iwconfig.jpg - No IP address is being observer
3.ping.jpg - Ping did not went through the gateway
Will continue with log on next post as maximum only 3 phot allow.
Thanks,
Ken
Thanks,
Ken
- ping.jpg (180.19 KiB) Viewed 164249 times
- iwconfig.jpg (198.81 KiB) Viewed 164249 times
- ifconfig.jpg (254.52 KiB) Viewed 164249 times
Hi Aka,
4. all_log1.jpg - Authentication successful has been observer
5. all_log2.jpg - No relevant Wireless log
6. all_log3.jpg - No relevant wireless log
Thanks,
Ken
Thanks,
Ken
- all_long1.jpg (222.78 KiB) Viewed 164249 times
- all_long3.jpg (159.59 KiB) Viewed 164249 times
- all_long2.jpg (147.42 KiB) Viewed 164249 times
ifconfig and iwconfig look right. And there is some traffic received/transmitted.
Why are there 1500 seconds since boot? Did you take the photos immediately after boot, without entering setup?
4. all_log1.jpg - CTRL-EVENT-DISCONNECTED, and it knows AP mac. Seems it is not the first connection after reboot. Please, make me photos after boot.
2. iwconfig.jpg - No IP address is being observed - iwconfig should not display IP. It's WiFi configuration.
3.ping.jpg - Ping did not went through the gateway. - Please, ping something LOCAL. In WiFi subnet.
And please disconnect USB mouse Logitech. It disconnects every minute and sends a lot of text to log.
Hi Aka,
I am sorry for the delay, please refer to the new photo taken.
1. Ping.jpg - I have tried to ping IP address on the same subnet but same result.
2. All_log1.jpg, All_log2.jpg - Hope you can help to find something here.
Thanks,
Ken
Thanks,
Ken
- all_log1.jpg (186.84 KiB) Viewed 164230 times
- all_log2.jpg (161.9 KiB) Viewed 164230 times
Hi Aka,
Continue with all_log3.jpg, all_log4.jpg - Hope it is useful for you to help to make it work.
Thanks,
Ken
Thanks,
Ken
- all_log3.jpg (199.82 KiB) Viewed 164230 times
- all_log4.jpg (195.14 KiB) Viewed 164230 times
Everything is right, as far as I know.
Does Raspbian work with your WiFi?
Send me dmesg, ifconfig, iwconfig output:
dmesg > /tmp/123.log
ifconfig > /tmp/234.log
iwconfig > /tmp/345.log
and wpa_supplicant.conf, if it exists
To support@wtware.com
Hi Aka,
It my fault, I have remove the following parameter from the wpa_supplication.conf "phase1="peaplabel=1"" and immediately it started working.
And I am very happy to tell you job well done!
Thanks,
Ken
Thanks,
Ken
Great! For we had no more ideas.
