5.4.46 mouse click stop working
Posted: Tue Sep 20, 2016 1:35 pm
by Alon
hi,
when connected to server 2008r2 mouse clicks stop working , i can see and move the cursor, i can move it to the corner and switch screens, open a new connection and keep working. it is only on that session that the mouse stops sending clicks, keyboard works ok, I can alt+tab and switch programs, type etc. only mouse clicks on that rdp session don't work.
Tried closing all programs with the keyboard and mouse clicks don't come back, other users on the same server keep working normally.
I experience the same on thinstation linux with rdesktop v1.7.1, btw which client and version is used on wtware 5.4.46 ?
thx
Re: 5.4.46 mouse click stop working
Posted: Wed Sep 21, 2016 8:52 am
I need complete terminal log after error. To create log press: Start - All Programs - WTware - Configurator,
Select needed terminal, tab "Logs", press big button "Get log from terminal". When you press this button, many text lines will appear. Then press "Save log".
Second way: enter terminal IP in browser address line from another computer in the network, section Log.
Posted: Sun Sep 25, 2016 3:46 pm
by Alon
14-25-17-052| WTware v.5.4.32/RPi supervisor.
14-25-17-052| WTC listener is active.
14-25-17-052| WTC broadcast listener is active.
14-25-17-052| [        KERNEL] [    0.000000] Booting Linux on physical CPU 0x0
14-25-17-052| [        KERNEL] [    0.000000] Initializing cgroup subsys cpuset
14-25-17-052| [        KERNEL] [    0.000000] Initializing cgroup subsys cpuacct
14-25-17-052| [        KERNEL] [    0.000000] Linux version 4.4.8 (aka@c12) (gcc version 5.3.1 20160413 (Ubuntu/Linaro 5.3.1-14ubuntu2) ) #27 SMP Sun May 15 21:34:47 SAMT 2016
14-25-17-052| [        KERNEL] [    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
14-25-17-052| [        KERNEL] [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
14-25-17-052| [        KERNEL] [    0.000000] Machine model: Raspberry Pi 3 Model B Rev 1.2
14-25-17-052| [        KERNEL] [    0.000000] cma: Reserved 8 MiB at 0x3a800000
14-25-17-052| [        KERNEL] [    0.000000] Memory policy: Data cache writealloc
14-25-17-052| [        KERNEL] [    0.000000] On node 0 totalpages: 241664
14-25-17-052| [        KERNEL] [    0.000000] free_area_init_node: node 0, pgdat 8086c480, node_mem_map b9fa6000
14-25-17-052| [        KERNEL] [    0.000000]   Normal zone: 2124 pages used for memmap
14-25-17-052| [        KERNEL] [    0.000000]   Normal zone: 0 pages reserved
14-25-17-052| [        KERNEL] [    0.000000]   Normal zone: 241664 pages, LIFO batch:31
14-25-17-052| [        KERNEL] [    0.000000] [bcm2709_smp_init_cpus] enter (94c0->f3003010)
14-25-17-052| [        KERNEL] [    0.000000] [bcm2709_smp_init_cpus] ncores=4
14-25-17-052| [        KERNEL] [    0.000000] PERCPU: Embedded 11 pages/cpu @b9f6b000 s12480 r8192 d24384 u45056
14-25-17-052| [        KERNEL] [    0.000000] pcpu-alloc: s12480 r8192 d24384 u45056 alloc=11*4096
14-25-17-052| [        KERNEL] [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
14-25-17-052| [        KERNEL] [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 239540
14-25-17-052| [        KERNEL] [    0.000000] Kernel command line: 8250.nr_uarts=1 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1024 bcm2708_fb.fbheight=768 bcm2709.boardrev=0xa02082 bcm2709.serial=0x43a20062 smsc95xx.macaddr=B8:27:EB:A2:00:62 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  console=ttyS0,115200 console=tty1 verbose wtboot=mmc
14-25-17-052| [        KERNEL] [    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
14-25-17-052| [        KERNEL] [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
14-25-17-052| [        KERNEL] [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
14-25-17-052| [        KERNEL] [    0.000000] Memory: 939892K/966656K available (3755K kernel code, 164K rwdata, 1160K rodata, 3516K init, 365K bss, 18572K reserved, 8192K cma-reserved)
14-25-17-052| [        KERNEL] [    0.000000] Virtual kernel memory layout:
14-25-17-052| [        KERNEL] [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
14-25-17-052| [        KERNEL] [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
14-25-17-052| [        KERNEL] [    0.000000]     vmalloc : 0xbb800000 - 0xff800000   (1088 MB)
14-25-17-052| [        KERNEL] [    0.000000]     lowmem  : 0x80000000 - 0xbb000000   ( 944 MB)
14-25-17-052| [        KERNEL] [    0.000000]     modules : 0x7f000000 - 0x80000000   (  16 MB)
14-25-17-052| [        KERNEL] [    0.000000]       .text : 0x80008000 - 0x804d4fac   (4916 kB)
14-25-17-052| [        KERNEL] [    0.000000]       .init : 0x804d5000 - 0x80844000   (3516 kB)
14-25-17-052| [        KERNEL] [    0.000000]       .data : 0x80844000 - 0x8086d368   ( 165 kB)
14-25-17-052| [        KERNEL] [    0.000000]        .bss : 0x80870000 - 0x808cb60c   ( 366 kB)
14-25-17-052| [        KERNEL] [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
14-25-17-052| [        KERNEL] [    0.000000] Hierarchical RCU implementation.
14-25-17-052| [        KERNEL] [    0.000000] 	Build-time adjustment of leaf fanout to 32.
14-25-17-052| [        KERNEL] [    0.000000] NR_IRQS:16 nr_irqs:16 16
14-25-17-052| [        KERNEL] [    0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
14-25-17-052| [        KERNEL] [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
14-25-17-052| [        KERNEL] [    0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
14-25-17-052| [        KERNEL] [    0.000022] Switching to timer-based delay loop, resolution 52ns
14-25-17-052| [        KERNEL] [    0.000196] Console: colour dummy device 80x30
14-25-17-052| [        KERNEL] [    0.000930] console [tty1] enabled
14-25-17-052| [        KERNEL] [    0.000966] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
14-25-17-052| [        KERNEL] [    0.001021] pid_max: default: 32768 minimum: 301
14-25-17-052| [        KERNEL] [    0.001150] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
14-25-17-052| [        KERNEL] [    0.001184] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
14-25-17-052| [        KERNEL] [    0.002027] Disabling cpuset control group subsystem
14-25-17-052| [        KERNEL] [    0.002075] Initializing cgroup subsys io
14-25-17-052| [        KERNEL] [    0.002117] Initializing cgroup subsys memory
14-25-17-052| [        KERNEL] [    0.002165] Initializing cgroup subsys devices
14-25-17-052| [        KERNEL] [    0.002199] Initializing cgroup subsys freezer
14-25-17-052| [        KERNEL] [    0.002255] CPU: Testing write buffer coherency: ok
14-25-17-052| [        KERNEL] [    0.002713] CPU0: update cpu_capacity 1024
14-25-17-052| [        KERNEL] [    0.002744] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
14-25-17-052| [        KERNEL] [    0.002773] [bcm2709_smp_prepare_cpus] enter
14-25-17-052| [        KERNEL] [    0.002868] Setting up static identity map for 0x8240 - 0x8274
14-25-17-052| [        KERNEL] [    0.004214] [bcm2709_boot_secondary] cpu:1 started (0) 17
14-25-17-052| [        KERNEL] [    0.004406] [bcm2709_secondary_init] enter cpu:1
14-25-17-052| [        KERNEL] [    0.004441] CPU1: update cpu_capacity 1024
14-25-17-052| [        KERNEL] [    0.004446] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
14-25-17-052| [        KERNEL] [    0.004776] [bcm2709_boot_secondary] cpu:2 started (0) 17
14-25-17-052| [        KERNEL] [    0.004915] [bcm2709_secondary_init] enter cpu:2
14-25-17-052| [        KERNEL] [    0.004933] CPU2: update cpu_capacity 1024
14-25-17-052| [        KERNEL] [    0.004939] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
14-25-17-052| [        KERNEL] [    0.005239] [bcm2709_boot_secondary] cpu:3 started (0) 15
14-25-17-052| [        KERNEL] [    0.005369] [bcm2709_secondary_init] enter cpu:3
14-25-17-052| [        KERNEL] [    0.005386] CPU3: update cpu_capacity 1024
14-25-17-052| [        KERNEL] [    0.005392] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
14-25-17-052| [        KERNEL] [    0.005445] Brought up 4 CPUs
14-25-17-052| [        KERNEL] [    0.005538] SMP: Total of 4 processors activated (153.60 BogoMIPS).
14-25-17-052| [        KERNEL] [    0.005566] CPU: All CPU(s) started in HYP mode.
14-25-17-052| [        KERNEL] [    0.005590] CPU: Virtualization extensions available.
14-25-17-052| [        KERNEL] [    0.005980] devtmpfs: initialized
14-25-17-052| [        KERNEL] [    0.014304] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
14-25-17-052| [        KERNEL] [    0.014663] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
14-25-17-052| [        KERNEL] [    0.015176] pinctrl core: initialized pinctrl subsystem
14-25-17-052| [        KERNEL] [    0.015579] NET: Registered protocol family 16
14-25-17-052| [        KERNEL] [    0.020522] DMA: preallocated 4096 KiB pool for atomic coherent allocations
14-25-17-052| [        KERNEL] [    0.026663] bcm2709: Mini UART enabled
14-25-17-052| [        KERNEL] [    0.026889] Serial: AMBA PL011 UART driver
14-25-17-052| [        KERNEL] [    0.027088] uart-pl011 3f201000.uart: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
14-25-17-052| [        KERNEL] [    0.027328] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
14-25-17-052| [        KERNEL] [    0.091072] bcm2835-dma 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0x1
14-25-17-052| [        KERNEL] [    0.092617] usbcore: registered new interface driver usbfs
14-25-17-052| [        KERNEL] [    0.092767] usbcore: registered new interface driver hub
14-25-17-052| [        KERNEL] [    0.092876] usbcore: registered new device driver usb
14-25-17-052| [        KERNEL] [    0.100101] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-04-24 17:58
14-25-17-052| [        KERNEL] [    0.127769] clocksource: Switched to clocksource arch_sys_counter
14-25-17-052| [        KERNEL] [    0.139933] NET: Registered protocol family 2
14-25-17-052| [        KERNEL] [    0.140501] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
14-25-17-052| [        KERNEL] [    0.140637] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
14-25-17-052| [        KERNEL] [    0.140845] TCP: Hash tables configured (established 8192 bind 8192)
14-25-17-052| [        KERNEL] [    0.140956] UDP hash table entries: 512 (order: 2, 16384 bytes)
14-25-17-052| [        KERNEL] [    0.141022] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
14-25-17-052| [        KERNEL] [    0.141227] NET: Registered protocol family 1
14-25-17-052| [        KERNEL] [    1.914510] futex hash table entries: 1024 (order: 4, 65536 bytes)
14-25-17-052| [        KERNEL] [    1.963157] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
14-25-17-052| [        KERNEL] [    1.963226] io scheduler noop registered
14-25-17-052| [        KERNEL] [    1.963263] io scheduler deadline registered (default)
14-25-17-052| [        KERNEL] [    1.965734] BCM2708FB: allocated DMA memory fac00000
14-25-17-052| [        KERNEL] [    1.965799] BCM2708FB: allocated DMA channel 0 @ f3007000
14-25-17-052| [        KERNEL] [    1.978924] Console: switching to colour frame buffer device 128x48
14-25-17-052| [        KERNEL] [    2.965400] bcm2835-rng 3f104000.rng: hwrng registered
14-25-17-052| [        KERNEL] [    2.965712] vc-cma: Videocore CMA driver
14-25-17-052| [        KERNEL] [    2.965790] vc-cma: vc_cma_base      = 0x00000000
14-25-17-052| [        KERNEL] [    2.965872] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
14-25-17-052| [        KERNEL] [    2.965963] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
14-25-17-052| [        KERNEL] [    2.968021] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
14-25-17-052| [        KERNEL] [    2.969870] vchiq: vchiq_init_state: slot_zero = 0xbac80000, is_master = 0
14-25-17-052| [        KERNEL] [    2.973707] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
14-25-17-052| [        KERNEL] [    3.174310] Core Release: 2.80a
14-25-17-052| [        KERNEL] [    3.174394] Setting default values for core params
14-25-17-052| [        KERNEL] [    3.174498] Finished setting default values for core params
14-25-17-052| [        KERNEL] [    3.374930] Using Buffer DMA mode
14-25-17-052| [        KERNEL] [    3.375007] Periodic Transfer Interrupt Enhancement - disabled
14-25-17-052| [        KERNEL] [    3.375101] Multiprocessor Interrupt Enhancement - disabled
14-25-17-052| [        KERNEL] [    3.375193] OTG VER PARAM: 0, OTG VER FLAG: 0
14-25-17-052| [        KERNEL] [    3.375293] Dedicated Tx FIFOs mode
14-25-17-052| [        KERNEL] [    3.375790] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbac14000 dma = 0xfac14000 len=9024
14-25-17-052| [        KERNEL] [    3.375963] FIQ FSM acceleration enabled for :
14-25-17-052| [        KERNEL] [    3.375963] Non-periodic Split Transactions
14-25-17-052| [        KERNEL] [    3.375963] Periodic Split Transactions
14-25-17-052| [        KERNEL] [    3.375963] High-Speed Isochronous Endpoints
14-25-17-052| [        KERNEL] [    3.375963] Interrupt/Control Split Transaction hack enabled
14-25-17-052| [        KERNEL] [    3.392879] dwc_otg: Microframe scheduler enabled
14-25-17-052| [        KERNEL] [    3.392928] WARN::hcd_init_fiq:413: FIQ on core 1 at 0x80258e80
14-25-17-052| [        KERNEL] [    3.396279] WARN::hcd_init_fiq:414: FIQ ASM at 0x802591e4 length 36
14-25-17-052| [        KERNEL] [    3.399594] WARN::hcd_init_fiq:439: MPHI regs_base at 0xbb90a000
14-25-17-052| [        KERNEL] [    3.402920] dwc_otg 3f980000.usb: DWC OTG Controller
14-25-17-052| [        KERNEL] [    3.406196] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
14-25-17-052| [        KERNEL] [    3.409501] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
14-25-17-052| [        KERNEL] [    3.412827] Init: Port Power? op_state=1
14-25-17-052| [        KERNEL] [    3.416119] Init: Power Port (0)
14-25-17-052| [        KERNEL] [    3.419528] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
14-25-17-052| [        KERNEL] [    3.422803] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
14-25-17-052| [        KERNEL] [    3.426052] usb usb1: Product: DWC OTG Controller
14-25-17-052| [        KERNEL] [    3.429295] usb usb1: Manufacturer: Linux 4.4.8 dwc_otg_hcd
14-25-17-052| [        KERNEL] [    3.432497] usb usb1: SerialNumber: 3f980000.usb
14-25-17-052| [        KERNEL] [    3.436445] hub 1-0:1.0: USB hub found
14-25-17-052| [        KERNEL] [    3.439883] hub 1-0:1.0: 1 port detected
14-25-17-052| [        KERNEL] [    3.443480] dwc_otg: FIQ enabled
14-25-17-052| [        KERNEL] [    3.443489] dwc_otg: NAK holdoff enabled
14-25-17-052| [        KERNEL] [    3.443496] dwc_otg: FIQ split-transaction FSM enabled
14-25-17-052| [        KERNEL] [    3.443618] Module dwc_common_port init
14-25-17-052| [        KERNEL] [    3.446395] bcm2835-cpufreq: min=600000 max=1200000
14-25-17-052| [        KERNEL] [    3.451946] sdhost: log_buf @ bac13000 (fac13000)
14-25-17-052| [        KERNEL] [    3.527778] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
14-25-17-052| [        KERNEL] [    3.551571] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
14-25-17-052| [        KERNEL] [    3.553131] mmc-bcm2835 3f300000.mmc: Forcing PIO mode
14-25-17-052| [        KERNEL] [    3.587932] hidraw: raw HID events driver (C) Jiri Kosina
14-25-17-052| [        KERNEL] [    3.590089] usbcore: registered new interface driver usbhid
14-25-17-052| [        KERNEL] [    3.591909] usbhid: USB HID core driver
14-25-17-052| [        KERNEL] [    3.594120] NET: Registered protocol family 17
14-25-17-052| [        KERNEL] [    3.596109] Registering SWP/SWPB emulation handler
14-25-17-052| [        KERNEL] [    3.598135] registered taskstats version 1
14-25-17-052| [        KERNEL] [    3.599886] vc-sm: Videocore shared memory driver
14-25-17-052| [        KERNEL] [    3.601500] [vc_sm_connected_init]: start
14-25-17-052| [        KERNEL] [    3.603341] [vc_sm_connected_init]: end - returning 0
14-25-17-052| [        KERNEL] [    3.604713] mmc0: host does not support reading read-only switch, assuming write-enable
14-25-17-052| [        KERNEL] [    3.606744] mmc0: new high speed SDHC card at address d555
14-25-17-052| [        KERNEL] [    3.607790] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
14-25-17-052| [        KERNEL] [    3.612754] mmcblk0: mmc0:d555 SU08G 7.61 GiB
14-25-17-052| [        KERNEL] [    3.612951] Freeing unused kernel memory: 3516K (804d5000 - 80844000)
14-25-17-052| [        KERNEL] [    3.617005]  mmcblk0: p1
14-25-17-052| [        KERNEL] [    3.637194] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
14-25-17-052| [        KERNEL] [    3.638692] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
14-25-17-052| [        KERNEL] [    3.640181] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
14-25-17-052| [        KERNEL] [    3.642853] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
14-25-17-052| [        KERNEL] [    3.648158] Indeed it is in host mode hprt0 = 00021501
14-25-17-052| [        KERNEL] [    3.728453] mmc1: new high speed SDIO card at address 0001
14-25-17-052| [        KERNEL] [    3.827787] usb 1-1: new high-speed USB device number 2 using dwc_otg
14-25-17-052| [        KERNEL] [    3.827867] Indeed it is in host mode hprt0 = 00001101
14-25-17-052| [       hotplug] [    3.911201] Block device 179:0. No action.
14-25-17-052| [       hotplug] [    3.911300] Block device 179:1. No action.
14-25-17-052| [          pfac] [    3.921861] Run /sbin/initrd.
14-25-17-052| [          pfac] [    3.921910] Ok, PID 530.
14-25-17-052| [        initrd] [    3.923452] WTware shell v.5.4.32/RPi
14-25-17-052| [        initrd] [    3.932917] Local media boot.
14-25-17-052| [        initrd] [    3.932989] USB boot.
14-25-17-052| [        KERNEL] [    4.027911] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
14-25-17-052| [        KERNEL] [    4.027922] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
14-25-17-052| [        KERNEL] [    4.028306] hub 1-1:1.0: USB hub found
14-25-17-052| [        KERNEL] [    4.028380] hub 1-1:1.0: 5 ports detected
14-25-17-052| [        KERNEL] [    4.307771] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
14-25-17-052| [        KERNEL] [    4.407898] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
14-25-17-052| [        KERNEL] [    4.407906] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
14-25-17-052| [        KERNEL] [    4.487777] usb 1-1.2: new low-speed USB device number 4 using dwc_otg
14-25-17-052| [        KERNEL] [    4.608590] usb 1-1.2: New USB device found, idVendor=045e, idProduct=07b9
14-25-17-052| [        KERNEL] [    4.608598] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
14-25-17-052| [        KERNEL] [    4.608603] usb 1-1.2: Product: USB Keyboard
14-25-17-052| [        KERNEL] [    4.608609] usb 1-1.2: Manufacturer: LITEON Technology
14-25-17-052| [        KERNEL] [    4.628744] input: LITEON Technology USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:045E:07B9.0001/input/input0
14-25-17-052| [        KERNEL] [    4.688210] hid-generic 0003:045E:07B9.0001: input,hidraw0: USB HID v1.10 Keyboard [LITEON Technology USB Keyboard] on usb-3f980000.usb-1.2/input0
14-25-17-052| [        KERNEL] [    4.767784] usb 1-1.3: new low-speed USB device number 5 using dwc_otg
14-25-17-052| [        KERNEL] [    4.871874] usb 1-1.3: New USB device found, idVendor=045e, idProduct=0797
14-25-17-052| [        KERNEL] [    4.871883] usb 1-1.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
14-25-17-052| [        KERNEL] [    4.871889] usb 1-1.3: Product: USB Optical Mouse
14-25-17-052| [        KERNEL] [    4.875425] input: USB Optical Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:045E:0797.0002/input/input1
14-25-17-052| [        KERNEL] [    4.875627] hid-generic 0003:045E:0797.0002: input,hidraw1: USB HID v1.11 Mouse [USB Optical Mouse] on usb-3f980000.usb-1.3/input0
14-25-17-052| [        initrd] [    4.897707] WTpassword empty.
14-25-17-052| /--- FILE "/bootmedia/configs/initrd.wtc" -----------------------
14-25-17-052| | clientIP = *
14-25-17-052| | config = network
14-25-17-052| | tftpIP = 192.168.10.83
14-25-17-052| \----------------------------------------------------
14-25-17-052| [        initrd] [    6.897773] Load ethernet drivers.
14-25-17-052| [        initrd] [    6.897819] modprobe smsc95xx.
14-25-17-052| [        KERNEL] [    6.909836] smsc95xx v1.0.4
14-25-17-052| [        KERNEL] [    6.969471] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:a2:00:62
14-25-17-052| [        KERNEL] [    6.969576] usbcore: registered new interface driver smsc95xx
14-25-17-052| [        KERNEL] [    7.028804] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
14-25-17-052| [        KERNEL] [    8.471689] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
14-25-17-052| [        initrd] [    9.005234] dhcp: 336 bytes from 192.168.92.254.
14-25-17-052| [        initrd] [    9.005290] 00000000:0000013c00000000001100000a01c0fe0a01c04f00430044013c000002010601  ...<..............O.C.D.<......
14-25-17-052| [        initrd] [    9.005328] 00000020:67458b6b00000000000000000a01c04f0a01c80f00000000b827eba200620000  gE.k...........O.........'...b..
14-25-17-052| [        initrd] [    9.005363] 00000040:0000000000000000000000000000000000000000000000000000000000000000  ................................
14-25-17-052| [        initrd] [    9.005399] 00000060:0000000000000000000000000000000000000000000000000000000000000000  ................................
14-25-17-052| [        initrd] [   10.480079] dhcp: 336 bytes from 192.168.92.254.
14-25-17-052| [        initrd] [   10.480141] 00000000:0000013c00000000001100000a01c0fe0a01c04f00430044013c000002010601  ...<..............O.C.D.<......
14-25-17-052| [        initrd] [   10.480178] 00000020:67458b6b00000000000000000a01c04f0000000000000000b827eba200620000  gE.k...........O.........'...b..
14-25-17-052| [        initrd] [   10.480214] 00000040:0000000000000000000000000000000000000000000000000000000000000000  ................................
14-25-17-052| [        initrd] [   10.480249] 00000060:0000000000000000000000000000000000000000000000000000000000000000  ................................
14-25-17-052| [        initrd] [   10.510049] dhcp: server address 192.168.10.15.
14-25-17-052| [        initrd] [   10.510088] dhcp: 192.168.92.79/255.255.255.0.
14-25-17-052| [        initrd] [   10.510125] dhcp: default gateway 192.168.92.254.
14-25-17-052| [        initrd] [   10.510159] dhcp: DNS 192.168.10.15.
14-25-17-052| [        initrd] [   10.510193] dhcp: DNS 192.168.10.14.
14-25-17-052| [        initrd] [   10.510227] dhcp: domain udom.internal.com.
14-25-17-052| [        initrd] [   10.510265] TFTP IP 192.168.10.83 already specified.
14-25-17-052| [        initrd] [   10.510304] No boot file from DHCP.
14-25-17-052| [        initrd] [   10.510337] TFTP binary "", configs prefix "", using "/" slash.
14-25-17-052| Send broadcast WTCU discover.
14-25-17-052| [        initrd] [   10.511177] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
14-25-17-052| [          pfac] [   10.511497] Run /sbin/httpd.
14-25-17-052| [          pfac] [   10.511564] Ok, PID 563.
14-25-17-052| [         httpd] [   10.514249] HTTP Server, WTware v.5.4.32/RPi
14-25-17-052| [        KERNEL] [   10.528156] random: httpd urandom read with 102 bits of entropy available
14-25-17-052| [        initrd] [   10.570468] USB: 0424:9514 Standard Microsystems Corp. SMC9514 Hub.
14-25-17-052| [        initrd] [   10.570539] USB: 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter.
14-25-17-052| [        initrd] [   10.570578] USB: 045e:07b9 Microsoft Corp..
14-25-17-052| [        initrd] [   10.570613] USB: 045e:0797 Microsoft Corp. Optical Mouse 200.
14-25-17-052| [        initrd] [   10.570649] [TFTP]: download file Everyone/list.wtc from 192.168.10.83.
14-25-17-052| [        initrd] [   10.626815] WTware TFTP v.5.4.32.
14-25-17-052| /--- FILE "/tmp/list.wtc" -----------------------
14-25-17-052| | #
14-25-17-052| | # Include files list.
14-25-17-052| | #
14-25-17-052| | # This way of terminals configuration is meant only for manual
14-25-17-052| | # terminals management. Graphic configurator doesn't read list.wtc,
14-25-17-052| | # doesn't read or edit files from ListIncludes directory. So be careful
14-25-17-052| | # not to configure one terminal in configurator and in list.wtc.
14-25-17-052| | #
14-25-17-052| | # This file uses such syntax:
14-25-17-052| | #
14-25-17-052| | #    01.02.03.04.05.06[([username@][terminalname])] [file [file ...]]] [# note]
14-25-17-052| | #
14-25-17-052| | # Examples:
14-25-17-052| | #
14-25-17-052| | #     02.03.04.05.06.07 file1
14-25-17-052| | #
14-25-17-052| | # It means that terminal with MAC-address 02.03.04.05.06.07
14-25-17-052| | # reads parameters from file ListIncludes/file1.
14-25-17-052| | #
14-25-17-052| | #
14-25-17-052| | #     03.04.05.06.07.08(vasja@) file2
14-25-17-052| | #
14-25-17-052| | # It means that terminal with MAC-address 03.04.05.06.07.08
14-25-17-052| | # reads parameters from file ListIncludes/file2
14-25-17-052| | # and sets user name "vasja" in "Windows login" window.
14-25-17-052| | #
14-25-17-052| | #
14-25-17-052| | #     04.05.06.07.08.09(term5) file6 file7 # John notebook.
14-25-17-052| | #
14-25-17-052| | # It means that terminal with MAC-address 04.05.06.07.08.09
14-25-17-052| | # is named term5, the same as specify clienthostname parameter,
14-25-17-052| | # and it reads parameters from files ListIncludes/file6 and
14-25-17-052| | # ListIncludes/file7.
14-25-17-052| | #
14-25-17-052| | #
14-25-17-052| | # To specify user name using non-latin letters open this file in
14-25-17-052| | # Notepad and save with Encoding: Unicode.
14-25-17-052| | #
14-25-17-052| [        initrd] [   10.628696] [TFTP]: download file Terminals/B8.27.EB.A2.00.62/config.wtc from 192.168.10.83.
14-25-17-052| /--- FILE "/tmp/config.wtc" -----------------------
14-25-17-052| | template Hash-rdh1
14-25-17-052| | connection rdh1
14-25-17-052| | connection rdh2
14-25-17-052| | next screen
14-25-17-052| [        initrd] [   10.630818] [TFTP]: download file Everyone/all.wtc from 192.168.10.83.
14-25-17-052| /--- FILE "/tmp/all.wtc" -----------------------
14-25-17-052| | server=tcmgr.udom.internal.com;192.168.10.83;
14-25-17-052| [        initrd] [   10.632097] [TFTP]: download file Everyone/wtware.lic from 192.168.10.83.
14-25-17-052| [        initrd] [   10.633614] [TFTP]: download file Templates/Hash-rdh1.wtc from 192.168.10.83.
14-25-17-052| /--- FILE "/tmp/tmp.wtc" -----------------------
14-25-17-052| | [BOM]
14-25-17-052| | vnc=on
14-25-17-052| | vnc_password=hex:a4f4fc5d544013bebad15701ecf6fb4c
14-25-17-052| | display=1024x768
14-25-17-052| | skin=pk
14-25-17-052| [        initrd] [   10.635134] [TFTP]: download file Connections/rdh1.wtc from 192.168.10.83.
14-25-17-052| | server=192.168.15.30
14-25-17-052| | domain=udom
14-25-17-052| [        initrd] [   10.640372] [TFTP]: download file Connections/rdh2.wtc from 192.168.10.83.
14-25-17-052| | server=192.168.15.50
14-25-17-052| [        initrd] [   10.643288] [TFTP]: download file Connections/rdh1.wtc from 192.168.10.83.
14-25-17-052| [        initrd] [   10.644612] [TFTP]: download file Connections/rdh2.wtc from 192.168.10.83.
14-25-17-052| /--- FILE "/etc/config.compiled" -----------------------
by Alon
14-25-17-052| [        initrd] [   10.665061] Hostname: "wtwB827EBA20062".
14-25-17-052| Everyone can control terminal by RSH.
14-25-17-052| RSH: listener is active.
14-25-17-052| [         httpd] [   10.842124] Reread settings.
14-25-17-052| [         httpd] [   10.842187] Everyone can control terminal by HTTP.
14-25-17-052| [            gm] [   10.844240] WTware session manager v.5.4.32/RPi.
14-25-17-052| [            gm] [   10.900086] EV_REL flag found. Add mouse event1: USB Optical Mouse.
14-25-17-052| [            gm] [   10.900137] Add keyboard event0: LITEON Technology USB Keyboard.
14-25-17-052| [            gm] [   10.900226] Display mode: 1024x768, 16 bit, 0 Hz, modeline "", DDC enabled, connector 0.
14-25-17-052| [            gm] [   10.904864] Framebuffer device found.
14-25-17-052| [            gm] [   10.904904] LINELENBYTES 2048
14-25-17-052| [            gm] [   10.904941] VLEN 1572864
14-25-17-052| [            gm] [   10.910459] [TFTP]: download file Graphic/pk/wait.png from 192.168.10.83.
14-25-17-052| [            gm] [   10.927962] /tmp/wait.png: 464x195.
14-25-17-052| [            gm] [   10.932854] [TFTP]: download file Graphic/pk/popup.png from 192.168.10.83.
14-25-17-052| [            gm] [   10.940050] [TFTP]: download file Graphic/pk/menu.png from 192.168.10.83.
14-25-17-052| [        KERNEL] [   11.368522] random: nonblocking pool is initialized
14-25-17-052| [            gm] [   11.528433] /tmp/menu.png: 1024x768.
14-25-17-052| [            gm] [   11.534276] /graphic/winlg.png: 48x48.
14-25-17-052| [            gm] [   11.534758] /graphic/winsm.png: 38x38.
14-25-17-052| [            gm] [   11.534834] Everyone can control terminal by VNC.
14-25-17-052| [            gm] [   11.534891] VNC listener at port 5900.
14-25-17-052| [            gm] [339687.009340] Run '/sbin/resolver 0x130a378 dns [192.168.15.30]', log '', env '', pid ''.
14-25-17-052| [          pfac] [339687.009867] Run /sbin/resolver 0x130a378 dns [192.168.15.30].
14-25-17-052| [          pfac] [339687.009957] Ok, PID 571.
14-25-17-052| [            gm] [339687.019025] 192.168.15.30 => 192.168.15.30.
14-25-17-052| [            gm] [339687.019088] Free ram before fork terminal client /sbin/rdpclient (session 1): 926816 Kb.
14-25-17-052| [            gm] [339687.019129] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
14-25-17-052| [          pfac] [339687.019169] Run /sbin/rdpclient 1.
14-25-17-052| [          pfac] [339687.019307] Ok, PID 572.
14-25-17-052| [          pfac] [339687.023432] Process pid 571 terminated, status 00000000.
14-25-17-052| [ rdpclient 572] [339687.023510] RDP Terminal Client, WTware v.5.4.32/RPi, pipe 1, pid 572.
14-25-17-052| [ rdpclient 572] [339687.024564] Make RDP session with 192.168.15.30, port 3389.
14-25-17-052| [ rdpclient 572] [339687.024625]  No username.
14-25-17-052| [ rdpclient 572] [339687.024665]  No password.
14-25-17-052| [ rdpclient 572] [339687.024704]  No PIN.
14-25-17-052| [ rdpclient 572] [339687.024743]  Domain: "udom".
14-25-17-052| [ rdpclient 572] [339687.024781]  No shell.
14-25-17-052| [ rdpclient 572] [339687.024820]  No directory.
14-25-17-052| [ rdpclient 572] [339687.024858]  Window: 1024x768@16.
14-25-17-052| [ rdpclient 572] [339687.024896]  PFlags 0x0000002F.
14-25-17-052| [ rdpclient 572] [339687.024934]  Keyboard 00000409:00000000.
14-25-17-052| [ rdpclient 572] [339687.024973]  My hostname "wtwB827EBA20062".
14-25-17-052| [ rdpclient 572] [339687.025013] TCP: connecting to 192.168.15.30:3389.
14-25-17-052| [ rdpclient 572] [339687.025052] TCP: connection with 192.168.15.30:3389 established.
14-25-17-052| [ rdpclient 572] [339687.025091] Turn keepalive on.
14-25-17-052| [ rdpclient 572] [339687.025302] Free ram after buffers allocation: 926000 KB.
14-25-17-052| [ rdpclient 572] [339687.035835] Process RDP server certificate.
14-25-17-052| [ rdpclient 572] [339687.035893] RDP5 encryption (X.509).
14-25-17-052| [ rdpclient 572] [339708.418140] LOGON_EX_LOGONERRORS 0xfffffffe 0x0000001b.
14-25-17-052| [ rdpclient 572] [339739.014416] SessionId 0x0000001b: udom\testusera.
14-25-17-052| [            gm] [340587.688886] /tmp/popup.png: 200x30.
14-25-17-052| [ rdpclient 572] [353501.220509] errorInfo 0x00000000.
14-25-17-052| [ rdpclient 572] [353501.220625] Receive Disconnect Provider Ultimatum.
14-25-17-052| [            gm] [353501.220744] TSClient gracefully end.
14-25-17-052| [          pfac] [353501.222144] Process pid 572 terminated, status 00000009.
14-25-17-052| [            gm] [422543.607385] Run '/sbin/resolver 0x130a378 dns [192.168.15.30]', log '', env '', pid ''.
14-25-17-052| [          pfac] [422543.607907] Run /sbin/resolver 0x130a378 dns [192.168.15.30].
14-25-17-052| [          pfac] [422543.607995] Ok, PID 574.
14-25-17-052| [            gm] [422543.611415] 192.168.15.30 => 192.168.15.30.
14-25-17-052| [            gm] [422543.611475] Free ram before fork terminal client /sbin/rdpclient (session 2): 926412 Kb.
14-25-17-052| [            gm] [422543.611515] Run '/sbin/rdpclient 2', log '/tmp/rdpclient.out', env '', pid ''.
14-25-17-052| [          pfac] [422543.611553] Run /sbin/rdpclient 2.
14-25-17-052| [          pfac] [422543.611710] Ok, PID 575.
14-25-17-052| [          pfac] [422543.611964] Process pid 574 terminated, status 00000000.
14-25-17-052| [ rdpclient 575] [422543.615664] RDP Terminal Client, WTware v.5.4.32/RPi, pipe 2, pid 575.
14-25-17-052| [ rdpclient 575] [422543.616701] Make RDP session with 192.168.15.30, port 3389.
14-25-17-052| [ rdpclient 575] [422543.616761]  No username.
14-25-17-052| [ rdpclient 575] [422543.616812]  No password.
14-25-17-052| [ rdpclient 575] [422543.616850]  No PIN.
14-25-17-052| [ rdpclient 575] [422543.616888]  Domain: "udom".
14-25-17-052| [ rdpclient 575] [422543.616925]  No shell.
14-25-17-052| [ rdpclient 575] [422543.616963]  No directory.
14-25-17-052| [ rdpclient 575] [422543.617000]  Window: 1024x768@16.
14-25-17-052| [ rdpclient 575] [422543.617039]  PFlags 0x0000002F.
14-25-17-052| [ rdpclient 575] [422543.617077]  Keyboard 00000409:00000000.
14-25-17-052| [ rdpclient 575] [422543.617120]  My hostname "wtwB827EBA20062".
14-25-17-052| [ rdpclient 575] [422543.617160] TCP: connecting to 192.168.15.30:3389.
14-25-17-052| [ rdpclient 575] [422543.617864] TCP: connection with 192.168.15.30:3389 established.
14-25-17-052| [ rdpclient 575] [422543.617926] Turn keepalive on.
14-25-17-052| [ rdpclient 575] [422543.617967] Free ram after buffers allocation: 925676 KB.
14-25-17-052| [ rdpclient 575] [422543.648514] Process RDP server certificate.
14-25-17-052| [ rdpclient 575] [422543.648578] RDP5 encryption (X.509).
14-25-17-052| [ rdpclient 575] [422586.856551] LOGON_EX_LOGONERRORS 0xfffffffe 0x00000005.
14-25-17-052| [ rdpclient 575] [422618.896146] SessionId 0x00000005: udom\testusera.
14-25-17-052| [ rdpclient 575] [429044.270952] errorInfo 0x00000000.
14-25-17-052| [ rdpclient 575] [429044.273028] Receive Disconnect Provider Ultimatum.
14-25-17-052| [            gm] [429044.273138] TSClient gracefully end.
14-25-17-052| [          pfac] [429044.274594] Process pid 575 terminated, status 00000009.
14-25-17-052| [            gm] [429058.779964] Run '/sbin/resolver 0x130a378 dns [192.168.15.30]', log '', env '', pid ''.
14-25-17-052| [          pfac] [429058.780526] Run /sbin/resolver 0x130a378 dns [192.168.15.30].
14-25-17-052| [          pfac] [429058.780640] Ok, PID 576.
14-25-17-052| [            gm] [429058.782603] 192.168.15.30 => 192.168.15.30.
14-25-17-052| [            gm] [429058.782674] Free ram before fork terminal client /sbin/rdpclient (session 3): 926412 Kb.
14-25-17-052| [            gm] [429058.782715] Run '/sbin/rdpclient 3', log '/tmp/rdpclient.out', env '', pid ''.
14-25-17-052| [          pfac] [429058.782755] Run /sbin/rdpclient 3.
14-25-17-052| [          pfac] [429058.782903] Ok, PID 577.
14-25-17-052| [          pfac] [429058.786962] Process pid 576 terminated, status 00000000.
14-25-17-052| [ rdpclient 577] [429058.787038] RDP Terminal Client, WTware v.5.4.32/RPi, pipe 3, pid 577.
14-25-17-052| [ rdpclient 577] [429058.787901] Make RDP session with 192.168.15.30, port 3389.
14-25-17-052| [ rdpclient 577] [429058.787959]  No username.
14-25-17-052| [ rdpclient 577] [429058.787999]  No password.
14-25-17-052| [ rdpclient 577] [429058.788037]  No PIN.
14-25-17-052| [ rdpclient 577] [429058.788074]  Domain: "udom".
14-25-17-052| [ rdpclient 577] [429058.788112]  No shell.
14-25-17-052| [ rdpclient 577] [429058.788149]  No directory.
14-25-17-052| [ rdpclient 577] [429058.788186]  Window: 1024x768@16.
14-25-17-052| [ rdpclient 577] [429058.788223]  PFlags 0x0000002F.
14-25-17-052| [ rdpclient 577] [429058.788260]  Keyboard 00000409:00000000.
14-25-17-052| [ rdpclient 577] [429058.788298]  My hostname "wtwB827EBA20062".
14-25-17-052| [ rdpclient 577] [429058.788336] TCP: connecting to 192.168.15.30:3389.
14-25-17-052| [ rdpclient 577] [429058.789035] TCP: connection with 192.168.15.30:3389 established.
14-25-17-052| [ rdpclient 577] [429058.789098] Turn keepalive on.
14-25-17-052| [ rdpclient 577] [429058.789137] Free ram after buffers allocation: 925604 KB.
14-25-17-052| [ rdpclient 577] [429058.804811] Process RDP server certificate.
14-25-17-052| [ rdpclient 577] [429058.804868] RDP5 encryption (X.509).
14-25-17-052| [ rdpclient 577] [429073.422149] LOGON_EX_LOGONERRORS 0xfffffffe 0x00000002.
14-25-17-052| [ rdpclient 577] [429162.580649] SessionId 0x00000002: udom\testusera.
14-25-17-052| [ rdpclient 577] [444066.301055] errorInfo 0x00000000.
14-25-17-052| [ rdpclient 577] [444066.301943] Receive Disconnect Provider Ultimatum.
14-25-17-052| [            gm] [444066.302053] TSClient gracefully end.
14-25-17-052| [          pfac] [444066.303437] Process pid 577 terminated, status 00000009.
14-25-17-052| [            gm] [515557.735569] Run '/sbin/resolver 0x130a378 dns [192.168.15.30]', log '', env '', pid ''.
14-25-17-052| [          pfac] [515557.736087] Run /sbin/resolver 0x130a378 dns [192.168.15.30].
14-25-17-052| [          pfac] [515557.736172] Ok, PID 578.
14-25-17-052| [            gm] [515557.739591] 192.168.15.30 => 192.168.15.30.
14-25-17-052| [          pfac] [515557.739691] Process pid 578 terminated, status 00000000.
14-25-17-052| [            gm] [515557.739802] Free ram before fork terminal client /sbin/rdpclient (session 4): 926364 Kb.
14-25-17-052| [            gm] [515557.739869] Run '/sbin/rdpclient 4', log '/tmp/rdpclient.out', env '', pid ''.
14-25-17-052| [          pfac] [515557.740160] Run /sbin/rdpclient 4.
14-25-17-052| [          pfac] [515557.740219] Ok, PID 579.
14-25-17-052| [ rdpclient 579] [515557.744073] RDP Terminal Client, WTware v.5.4.32/RPi, pipe 4, pid 579.
14-25-17-052| [ rdpclient 579] [515557.745128] Make RDP session with 192.168.15.30, port 3389.
14-25-17-052| [ rdpclient 579] [515557.745189]  No username.
14-25-17-052| [ rdpclient 579] [515557.745228]  No password.
14-25-17-052| [ rdpclient 579] [515557.745267]  No PIN.
14-25-17-052| [ rdpclient 579] [515557.745304]  Domain: "udom".
14-25-17-052| [ rdpclient 579] [515557.745342]  No shell.
14-25-17-052| [ rdpclient 579] [515557.745379]  No directory.
14-25-17-052| [ rdpclient 579] [515557.745416]  Window: 1024x768@16.
14-25-17-052| [ rdpclient 579] [515557.745453]  PFlags 0x0000002F.
14-25-17-052| [ rdpclient 579] [515557.745490]  Keyboard 00000409:00000000.
14-25-17-052| [ rdpclient 579] [515557.745527]  My hostname "wtwB827EBA20062".
14-25-17-052| [ rdpclient 579] [515557.745565] TCP: connecting to 192.168.15.30:3389.
14-25-17-052| [ rdpclient 579] [515557.746710] TCP: connection with 192.168.15.30:3389 established.
14-25-17-052| [ rdpclient 579] [515557.746771] Turn keepalive on.
14-25-17-052| [ rdpclient 579] [515557.746810] Free ram after buffers allocation: 925556 KB.
14-25-17-052| [ rdpclient 579] [515557.762214] Process RDP server certificate.
14-25-17-052| [ rdpclient 579] [515557.762274] RDP5 encryption (X.509).
14-25-17-052| [ rdpclient 579] [515571.860727] LOGON_EX_LOGONERRORS 0xfffffffe 0x0000001b.
14-25-17-052| [ rdpclient 579] [515610.450945] SessionId 0x0000001b: udom\testusera.
14-25-17-052| [ rdpclient 579] [530362.226358] errorInfo 0x00000000.
14-25-17-052| [ rdpclient 579] [530362.236773] Receive Disconnect Provider Ultimatum.
14-25-17-052| [            gm] [530362.236882] TSClient gracefully end.
14-25-17-052| [          pfac] [530362.238182] Process pid 579 terminated, status 00000009.
14-25-17-052| [          pfac] [597576.851601] Run /sbin/resolver 0x130a378 dns [192.168.15.50].
14-25-17-052| [            gm] [597576.851701] Run '/sbin/resolver 0x130a378 dns [192.168.15.50]', log '', env '', pid ''.
14-25-17-052| [          pfac] [597576.851772] Ok, PID 580.
14-25-17-052| [            gm] [597576.854950] 192.168.15.50 => 192.168.15.50.
14-25-17-052| [          pfac] [597576.855024] Process pid 580 terminated, status 00000000.
14-25-17-052| [            gm] [597576.855049] Free ram before fork terminal client /sbin/rdpclient (session 5): 926348 Kb.
14-25-17-052| [          pfac] [597576.855088] Run /sbin/rdpclient 5.
14-25-17-052| [            gm] [597576.855111] Run '/sbin/rdpclient 5', log '/tmp/rdpclient.out', env '', pid ''.
14-25-17-052| [          pfac] [597576.855196] Ok, PID 581.
14-25-17-052| [ rdpclient 581] [597576.859116] RDP Terminal Client, WTware v.5.4.32/RPi, pipe 5, pid 581.
14-25-17-052| [ rdpclient 581] [597576.860088] Make RDP session with 192.168.15.50, port 3389.
14-25-17-052| [ rdpclient 581] [597576.860151]  No username.
14-25-17-052| [ rdpclient 581] [597576.860227]  No password.
14-25-17-052| [ rdpclient 581] [597576.860267]  No PIN.
14-25-17-052| [ rdpclient 581] [597576.860305]  Domain: "udom".
14-25-17-052| [ rdpclient 581] [597576.860343]  No shell.
14-25-17-052| [ rdpclient 581] [597576.860381]  No directory.
14-25-17-052| [ rdpclient 581] [597576.860419]  Window: 1024x768@16.
14-25-17-052| [ rdpclient 581] [597576.860457]  PFlags 0x0000002F.
14-25-17-052| [ rdpclient 581] [597576.860494]  Keyboard 00000409:00000000.
14-25-17-052| [ rdpclient 581] [597576.860532]  My hostname "wtwB827EBA20062".
14-25-17-052| [ rdpclient 581] [597576.860570] TCP: connecting to 192.168.15.50:3389.
14-25-17-052| [ rdpclient 581] [597576.860788] TCP: connection with 192.168.15.50:3389 established.
14-25-17-052| [ rdpclient 581] [597576.860832] Turn keepalive on.
14-25-17-052| [ rdpclient 581] [597576.861268] Free ram after buffers allocation: 925416 KB.
14-25-17-052| [ rdpclient 581] [597576.890315] Process RDP server certificate.
14-25-17-052| [ rdpclient 581] [597576.890410] RDP5 encryption (X.509).
14-25-17-052| [ rdpclient 581] [597710.242497] errorInfo 0x00000000.
14-25-17-052| [ rdpclient 581] [597710.242861] Receive Disconnect Provider Ultimatum.
14-25-17-052| [            gm] [597710.242965] TSClient gracefully end.
14-25-17-052| [          pfac] [597710.244035] Process pid 581 terminated, status 00000009.
14-25-17-052| [            gm] [597722.785437] Run '/sbin/resolver 0x130a378 dns [192.168.15.50]', log '', env '', pid ''.
14-25-17-052| [          pfac] [597722.785619] Run /sbin/resolver 0x130a378 dns [192.168.15.50].
14-25-17-052| [          pfac] [597722.785856] Ok, PID 582.
14-25-17-052| [            gm] [597722.788210] 192.168.15.50 => 192.168.15.50.
14-25-17-052| [            gm] [597722.788270] Free ram before fork terminal client /sbin/rdpclient (session 6): 926364 Kb.
14-25-17-052| [          pfac] [597722.788311] Run /sbin/rdpclient 6.
14-25-17-052| [            gm] [597722.788343] Run '/sbin/rdpclient 6', log '/tmp/rdpclient.out', env '', pid ''.
14-25-17-052| [          pfac] [597722.788493] Ok, PID 583.
14-25-17-052| [          pfac] [597722.788695] Process pid 582 terminated, status 00000000.
14-25-17-052| [ rdpclient 583] [597722.792546] RDP Terminal Client, WTware v.5.4.32/RPi, pipe 6, pid 583.
14-25-17-052| [ rdpclient 583] [597722.793610] Make RDP session with 192.168.15.50, port 3389.
14-25-17-052| [ rdpclient 583] [597722.793671]  No username.
14-25-17-052| [ rdpclient 583] [597722.793711]  No password.
14-25-17-052| [ rdpclient 583] [597722.793749]  No PIN.
14-25-17-052| [ rdpclient 583] [597722.793787]  Domain: "udom".
14-25-17-052| [ rdpclient 583] [597722.793825]  No shell.
14-25-17-052| [ rdpclient 583] [597722.793862]  No directory.
14-25-17-052| [ rdpclient 583] [597722.793899]  Window: 1024x768@16.
14-25-17-052| [ rdpclient 583] [597722.793936]  PFlags 0x0000002F.
14-25-17-052| [ rdpclient 583] [597722.793974]  Keyboard 00000409:00000000.
14-25-17-052| [ rdpclient 583] [597722.794011]  My hostname "wtwB827EBA20062".
14-25-17-052| [ rdpclient 583] [597722.794049] TCP: connecting to 192.168.15.50:3389.
14-25-17-052| [ rdpclient 583] [597722.794818] TCP: connection with 192.168.15.50:3389 established.
14-25-17-052| [ rdpclient 583] [597722.794882] Turn keepalive on.
14-25-17-052| [ rdpclient 583] [597722.794922] Free ram after buffers allocation: 925448 KB.
14-25-17-052| [ rdpclient 583] [597722.801663] Process RDP server certificate.
14-25-17-052| [ rdpclient 583] [597722.801717] RDP5 encryption (X.509).
14-25-17-052| [ rdpclient 583] [597775.555157] errorInfo 0x00000000.
14-25-17-052| [ rdpclient 583] [597775.555225] Receive Disconnect Provider Ultimatum.
14-25-17-052| [            gm] [597775.555301] TSClient gracefully end.
14-25-17-052| [          pfac] [597775.556201] Process pid 583 terminated, status 00000009.
14-25-17-052| [            gm] [597781.289223] Run '/sbin/resolver 0x130a378 dns [192.168.15.30]', log '', env '', pid ''.
14-25-17-052| [          pfac] [597781.289400] Run /sbin/resolver 0x130a378 dns [192.168.15.30].
14-25-17-052| [          pfac] [597781.289633] Ok, PID 584.
14-25-17-052| [            gm] [597781.292036] 192.168.15.30 => 192.168.15.30.
14-25-17-052| [            gm] [597781.292096] Free ram before fork terminal client /sbin/rdpclient (session 7): 926364 Kb.
14-25-17-052| [            gm] [597781.292136] Run '/sbin/rdpclient 7', log '/tmp/rdpclient.out', env '', pid ''.
14-25-17-052| [          pfac] [597781.292175] Run /sbin/rdpclient 7.
14-25-17-052| [          pfac] [597781.292315] Ok, PID 585.
14-25-17-052| [          pfac] [597781.292452] Process pid 584 terminated, status 00000000.
14-25-17-052| [ rdpclient 585] [597781.296372] RDP Terminal Client, WTware v.5.4.32/RPi, pipe 7, pid 585.
14-25-17-052| [ rdpclient 585] [597781.297886] Make RDP session with 192.168.15.30, port 3389.
14-25-17-052| [ rdpclient 585] [597781.297950]  No username.
14-25-17-052| [ rdpclient 585] [597781.297991]  No password.
14-25-17-052| [ rdpclient 585] [597781.298030]  No PIN.
14-25-17-052| [ rdpclient 585] [597781.298068]  Domain: "udom".
14-25-17-052| [ rdpclient 585] [597781.298106]  No shell.
14-25-17-052| [ rdpclient 585] [597781.298143]  No directory.
14-25-17-052| [ rdpclient 585] [597781.298181]  Window: 1024x768@16.
14-25-17-052| [ rdpclient 585] [597781.298218]  PFlags 0x0000002F.
14-25-17-052| [ rdpclient 585] [597781.298256]  Keyboard 00000409:00000000.
14-25-17-052| [ rdpclient 585] [597781.298293]  My hostname "wtwB827EBA20062".
14-25-17-052| [ rdpclient 585] [597781.298331] TCP: connecting to 192.168.15.30:3389.
14-25-17-052| [ rdpclient 585] [597781.300100] TCP: connection with 192.168.15.30:3389 established.
14-25-17-052| [ rdpclient 585] [597781.300191] Turn keepalive on.
14-25-17-052| [ rdpclient 585] [597781.300232] Free ram after buffers allocation: 925864 KB.
14-25-17-052| [ rdpclient 585] [597781.309550] Process RDP server certificate.
14-25-17-052| [ rdpclient 585] [597781.309595] RDP5 encryption (X.509).
14-25-17-052| [ rdpclient 585] [597807.814101] LOGON_EX_LOGONERRORS 0xfffffffe 0x0000001d.
14-25-17-052| [ rdpclient 585] [597836.291460] SessionId 0x0000001d: udom\testusera.
14-25-17-052| [ rdpclient 585] [615113.706675] errorInfo 0x00000000.
14-25-17-052| [ rdpclient 585] [615113.741055] Receive Disconnect Provider Ultimatum.
14-25-17-052| [            gm] [615113.741173] TSClient gracefully end.
14-25-17-052| [          pfac] [615113.742536] Process pid 585 terminated, status 00000009.
14-25-17-052| [            gm] [937141.059026] Run '/sbin/resolver 0x130a378 dns [192.168.15.30]', log '', env '', pid ''.
14-25-17-052| [          pfac] [937141.059208] Run /sbin/resolver 0x130a378 dns [192.168.15.30].
14-25-17-052| [          pfac] [937141.059428] Ok, PID 586.
14-25-17-052| [            gm] [937141.068118] 192.168.15.30 => 192.168.15.30.
14-25-17-052| [          pfac] [937141.068239] Process pid 586 terminated, status 00000000.
14-25-17-052| [            gm] [937141.068350] Free ram before fork terminal client /sbin/rdpclient (session 8): 926284 Kb.
14-25-17-052| [            gm] [937141.068417] Run '/sbin/rdpclient 8', log '/tmp/rdpclient.out', env '', pid ''.
14-25-17-052| [          pfac] [937141.068510] Run /sbin/rdpclient 8.
14-25-17-052| [          pfac] [937141.068712] Ok, PID 587.
14-25-17-052| [ rdpclient 587] [937141.072712] RDP Terminal Client, WTware v.5.4.32/RPi, pipe 8, pid 587.
14-25-17-052| [ rdpclient 587] [937141.073768] Make RDP session with 192.168.15.30, port 3389.
14-25-17-052| [ rdpclient 587] [937141.073830]  No username.
14-25-17-052| [ rdpclient 587] [937141.073869]  No password.
14-25-17-052| [ rdpclient 587] [937141.073908]  No PIN.
14-25-17-052| [ rdpclient 587] [937141.073946]  Domain: "udom".
14-25-17-052| [ rdpclient 587] [937141.073983]  No shell.
14-25-17-052| [ rdpclient 587] [937141.074021]  No directory.
14-25-17-052| [ rdpclient 587] [937141.074058]  Window: 1024x768@16.
14-25-17-052| [ rdpclient 587] [937141.074096]  PFlags 0x0000002F.
14-25-17-052| [ rdpclient 587] [937141.074133]  Keyboard 00000409:00000000.
14-25-17-052| [ rdpclient 587] [937141.074176]  My hostname "wtwB827EBA20062".
14-25-17-052| [ rdpclient 587] [937141.074215] TCP: connecting to 192.168.15.30:3389.
14-25-17-052| [ rdpclient 587] [937141.074891] TCP: connection with 192.168.15.30:3389 established.
14-25-17-052| [ rdpclient 587] [937141.074956] Turn keepalive on.
14-25-17-052| [ rdpclient 587] [937141.074995] Free ram after buffers allocation: 925540 KB.
14-25-17-052| [ rdpclient 587] [937141.082591] Process RDP server certificate.
14-25-17-052| [ rdpclient 587] [937141.082645] RDP5 encryption (X.509).
14-25-17-052| [ rdpclient 587] [937157.278649] LOGON_EX_LOGONERRORS 0xfffffffe 0x00000015.
14-25-17-052| [ rdpclient 587] [937185.402286] SessionId 0x00000015: udom\testusera.
14-25-17-052| [ rdpclient 587] [961162.139056] errorInfo 0x00000000.
14-25-17-052| [ rdpclient 587] [961162.139791] Receive Disconnect Provider Ultimatum.
14-25-17-052| [            gm] [961162.139838] TSClient gracefully end.
14-25-17-052| [          pfac] [961162.141040] Process pid 587 terminated, status 00000009.
14-25-17-052| [            gm] [1026660.561341] Run '/sbin/resolver 0x130a378 dns [192.168.15.30]', log '', env '', pid ''.
14-25-17-052| [          pfac] [1026660.561515] Run /sbin/resolver 0x130a378 dns [192.168.15.30].
14-25-17-052| [          pfac] [1026660.561733] Ok, PID 591.
14-25-17-052| [            gm] [1026660.565186] 192.168.15.30 => 192.168.15.30.
14-25-17-052| [          pfac] [1026660.565345] Process pid 591 terminated, status 00000000.
14-25-17-052| [            gm] [1026660.565373] Free ram before fork terminal client /sbin/rdpclient (session 9): 925896 Kb.
14-25-17-052| [          pfac] [1026660.565414] Run /sbin/rdpclient 9.
14-25-17-052| [            gm] [1026660.565436] Run '/sbin/rdpclient 9', log '/tmp/rdpclient.out', env '', pid ''.
14-25-17-052| [          pfac] [1026660.565537] Ok, PID 592.
14-25-17-052| [ rdpclient 592] [1026660.569358] RDP Terminal Client, WTware v.5.4.32/RPi, pipe 9, pid 592.
14-25-17-052| [ rdpclient 592] [1026660.570130] Make RDP session with 192.168.15.30, port 3389.
14-25-17-052| [ rdpclient 592] [1026660.570192]  No username.
14-25-17-052| [ rdpclient 592] [1026660.570233]  No password.
14-25-17-052| [ rdpclient 592] [1026660.570275]  No PIN.
14-25-17-052| [ rdpclient 592] [1026660.570313]  Domain: "udom".
14-25-17-052| [ rdpclient 592] [1026660.570351]  No shell.
14-25-17-052| [ rdpclient 592] [1026660.570390]  No directory.
14-25-17-052| [ rdpclient 592] [1026660.570427]  Window: 1024x768@16.
14-25-17-052| [ rdpclient 592] [1026660.570465]  PFlags 0x0000002F.
14-25-17-052| [ rdpclient 592] [1026660.570502]  Keyboard 00000409:00000000.
14-25-17-052| [ rdpclient 592] [1026660.570541]  My hostname "wtwB827EBA20062".
14-25-17-052| [ rdpclient 592] [1026660.570580] TCP: connecting to 192.168.15.30:3389.
14-25-17-052| [ rdpclient 592] [1026660.571294] TCP: connection with 192.168.15.30:3389 established.
14-25-17-052| [ rdpclient 592] [1026660.571360] Turn keepalive on.
14-25-17-052| [ rdpclient 592] [1026660.571400] Free ram after buffers allocation: 925164 KB.
14-25-17-052| [ rdpclient 592] [1026660.578107] Process RDP server certificate.
14-25-17-052| [ rdpclient 592] [1026660.578154] RDP5 encryption (X.509).
14-25-17-052| [ rdpclient 592] [1026701.423383] LOGON_EX_LOGONERRORS 0xfffffffe 0x00000015.
14-25-17-052| [ rdpclient 592] [1026719.316741] SessionId 0x00000015: udom\testusera.
14-25-17-052| [ rdpclient 592] [1041802.979169] errorInfo 0x00000000.
14-25-17-052| [ rdpclient 592] [1041802.985079] Receive Disconnect Provider Ultimatum.
14-25-17-052| [            gm] [1041802.985193] TSClient gracefully end.
14-25-17-052| [          pfac] [1041802.986553] Process pid 592 terminated, status 00000009.
14-25-17-052| [            gm] [1041806.036460] Run '/sbin/resolver 0x130a378 dns [192.168.15.30]', log '', env '', pid ''.
14-25-17-052| [          pfac] [1041806.036641] Run /sbin/resolver 0x130a378 dns [192.168.15.30].
14-25-17-052| [          pfac] [1041806.036864] Ok, PID 593.
14-25-17-052| [            gm] [1041806.039504] 192.168.15.30 => 192.168.15.30.
14-25-17-052| [            gm] [1041806.039567] Free ram before fork terminal client /sbin/rdpclient (session 10): 925872 Kb.
14-25-17-052| [          pfac] [1041806.039608] Run /sbin/rdpclient 10.
14-25-17-052| [            gm] [1041806.039631] Run '/sbin/rdpclient 10', log '/tmp/rdpclient.out', env '', pid ''.
14-25-17-052| [          pfac] [1041806.039787] Ok, PID 594.
14-25-17-052| [          pfac] [1041806.039998] Process pid 593 terminated, status 00000000.
14-25-17-052| [ rdpclient 594] [1041806.043743] RDP Terminal Client, WTware v.5.4.32/RPi, pipe 10, pid 594.
14-25-17-052| [ rdpclient 594] [1041806.044782] Make RDP session with 192.168.15.30, port 3389.
14-25-17-052| [ rdpclient 594] [1041806.044843]  No username.
14-25-17-052| [ rdpclient 594] [1041806.044884]  No password.
14-25-17-052| [ rdpclient 594] [1041806.044922]  No PIN.
14-25-17-052| [ rdpclient 594] [1041806.044960]  Domain: "udom".
14-25-17-052| [ rdpclient 594] [1041806.044997]  No shell.
14-25-17-052| [ rdpclient 594] [1041806.045034]  No directory.
14-25-17-052| [ rdpclient 594] [1041806.045072]  Window: 1024x768@16.
14-25-17-052| [ rdpclient 594] [1041806.045109]  PFlags 0x0000002F.
14-25-17-052| [ rdpclient 594] [1041806.045146]  Keyboard 00000409:00000000.
14-25-17-052| [ rdpclient 594] [1041806.045184]  My hostname "wtwB827EBA20062".
14-25-17-052| [ rdpclient 594] [1041806.045221] TCP: connecting to 192.168.15.30:3389.
14-25-17-052| [ rdpclient 594] [1041806.046013] TCP: connection with 192.168.15.30:3389 established.
14-25-17-052| [ rdpclient 594] [1041806.046076] Turn keepalive on.
14-25-17-052| [ rdpclient 594] [1041806.046115] Free ram after buffers allocation: 925056 KB.
14-25-17-052| [ rdpclient 594] [1041806.055249] Process RDP server certificate.
14-25-17-052| [ rdpclient 594] [1041806.055301] RDP5 encryption (X.509).
14-25-17-052| [ rdpclient 594] [1041835.750760] LOGON_EX_LOGONERRORS 0xfffffffe 0x00000007.
14-25-17-052| [ rdpclient 594] [1041859.753723] SessionId 0x00000007: udom\testusera.
14-25-17-052| [ rdpclient 594] [1042638.934554] errorInfo 0x00000000.
14-25-17-052| [ rdpclient 594] [1042638.934932] Receive Disconnect Provider Ultimatum.
14-25-17-052| [            gm] [1042638.934977] TSClient gracefully end.
14-25-17-052| [          pfac] [1042638.936171] Process pid 594 terminated, status 00000009.
14-25-17-052| [            gm] [1114727.822069] Run '/sbin/resolver 0x130a378 dns [192.168.15.30]', log '', env '', pid ''.
14-25-17-052| [          pfac] [1114727.822249] Run /sbin/resolver 0x130a378 dns [192.168.15.30].
14-25-17-052| [          pfac] [1114727.822477] Ok, PID 595.
14-25-17-052| [            gm] [1114727.825801] 192.168.15.30 => 192.168.15.30.
14-25-17-052| [          pfac] [1114727.825909] Process pid 595 terminated, status 00000000.
14-25-17-052| [            gm] [1114727.826014] Free ram before fork terminal client /sbin/rdpclient (session 11): 925848 Kb.
14-25-17-052| [            gm] [1114727.826080] Run '/sbin/rdpclient 11', log '/tmp/rdpclient.out', env '', pid ''.
14-25-17-052| [          pfac] [1114727.826172] Run /sbin/rdpclient 11.
14-25-17-052| [          pfac] [1114727.826374] Ok, PID 596.
14-25-17-052| [ rdpclient 596] [1114727.830395] RDP Terminal Client, WTware v.5.4.32/RPi, pipe 11, pid 596.
14-25-17-052| [ rdpclient 596] [1114727.831393] Make RDP session with 192.168.15.30, port 3389.
14-25-17-052| [ rdpclient 596] [1114727.831457]  No username.
14-25-17-052| [ rdpclient 596] [1114727.831497]  No password.
14-25-17-052| [ rdpclient 596] [1114727.831535]  No PIN.
14-25-17-052| [ rdpclient 596] [1114727.831573]  Domain: "udom".
14-25-17-052| [ rdpclient 596] [1114727.831610]  No shell.
14-25-17-052| [ rdpclient 596] [1114727.831647]  No directory.
14-25-17-052| [ rdpclient 596] [1114727.831685]  Window: 1024x768@16.
14-25-17-052| [ rdpclient 596] [1114727.831722]  PFlags 0x0000002F.
14-25-17-052| [ rdpclient 596] [1114727.831759]  Keyboard 00000409:00000000.
14-25-17-052| [ rdpclient 596] [1114727.831797]  My hostname "wtwB827EBA20062".
14-25-17-052| [ rdpclient 596] [1114727.831840] TCP: connecting to 192.168.15.30:3389.
14-25-17-052| [ rdpclient 596] [1114727.832532] TCP: connection with 192.168.15.30:3389 established.
14-25-17-052| [ rdpclient 596] [1114727.832593] Turn keepalive on.
14-25-17-052| [ rdpclient 596] [1114727.832633] Free ram after buffers allocation: 925212 KB.
14-25-17-052| [ rdpclient 596] [1114727.847244] Process RDP server certificate.
14-25-17-052| [ rdpclient 596] [1114727.847297] RDP5 encryption (X.509).
14-25-17-052| [ rdpclient 596] [1114745.838171] LOGON_EX_LOGONERRORS 0xfffffffe 0x00000010.
14-25-17-052| [ rdpclient 596] [1114765.989605] SessionId 0x00000010: udom\testusera.
14-25-17-052| [            gm] [1115881.540591] Close input device 'USB Optical Mouse', errno 19.
14-25-17-052| [        KERNEL] [1115881.552082] usb 1-1.3: USB disconnect, device number 5
14-25-17-052| [        KERNEL] [1115890.581607] usb 1-1.3: new low-speed USB device number 6 using dwc_otg
14-25-17-052| [        KERNEL] [1115890.685980] usb 1-1.3: New USB device found, idVendor=045e, idProduct=0797
14-25-17-052| [        KERNEL] [1115890.685988] usb 1-1.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
14-25-17-052| [        KERNEL] [1115890.685994] usb 1-1.3: Product: USB Optical Mouse
14-25-17-052| [        KERNEL] [1115890.689374] input: USB Optical Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:045E:0797.0003/input/input2
14-25-17-052| [        KERNEL] [1115890.689615] hid-generic 0003:045E:0797.0003: input,hidraw1: USB HID v1.11 Mouse [USB Optical Mouse] on usb-3f980000.usb-1.3/input0
14-25-17-052| [            gm] [1116036.301863] Close input device 'USB Optical Mouse', errno 19.
14-25-17-052| [        KERNEL] [1116036.312128] usb 1-1.3: USB disconnect, device number 6
14-25-17-052| [        KERNEL] [1116044.201607] usb 1-1.5: new low-speed USB device number 7 using dwc_otg
14-25-17-052| [        KERNEL] [1116044.305709] usb 1-1.5: New USB device found, idVendor=045e, idProduct=0797
14-25-17-052| [        KERNEL] [1116044.305717] usb 1-1.5: New USB device strings: Mfr=0, Product=2, SerialNumber=0
14-25-17-052| [        KERNEL] [1116044.305724] usb 1-1.5: Product: USB Optical Mouse
14-25-17-052| [        KERNEL] [1116044.309298] input: USB Optical Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.0/0003:045E:0797.0004/input/input3
14-25-17-052| [        KERNEL] [1116044.309495] hid-generic 0003:045E:0797.0004: input,hidraw1: USB HID v1.11 Mouse [USB Optical Mouse] on usb-3f980000.usb-1.5/input0
14-25-17-052| [            gm] [1116070.401899] Close input device 'USB Optical Mouse', errno 19.
14-25-17-052| [        KERNEL] [1116070.412140] usb 1-1.5: USB disconnect, device number 7
14-25-17-052| [        KERNEL] [1116076.971609] usb 1-1.3: new low-speed USB device number 8 using dwc_otg
14-25-17-052| [        KERNEL] [1116077.075829] usb 1-1.3: New USB device found, idVendor=045e, idProduct=0797
14-25-17-052| [        KERNEL] [1116077.075837] usb 1-1.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
14-25-17-052| [        KERNEL] [1116077.075843] usb 1-1.3: Product: USB Optical Mouse
14-25-17-052| [        KERNEL] [1116077.079226] input: USB Optical Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:045E:0797.0005/input/input4
14-25-17-052| [        KERNEL] [1116077.079657] hid-generic 0003:045E:0797.0005: input,hidraw1: USB HID v1.11 Mouse [USB Optical Mouse] on usb-3f980000.usb-1.3/input0
14-25-17-052| [ rdpclient 596] [1116421.408960] errorInfo 0x00000000.
14-25-17-052| [            gm] [1116421.409035] TSClient gracefully end.
14-25-17-052| [ rdpclient 596] [1116421.409059] Receive Disconnect Provider Ultimatum.
14-25-17-052| [          pfac] [1116421.410233] Process pid 596 terminated, status 00000009.
14-25-17-052| [            gm] [1116426.735544] Run '/sbin/resolver 0x130a378 dns [192.168.15.30]', log '', env '', pid ''.
14-25-17-052| [          pfac] [1116426.735721] Run /sbin/resolver 0x130a378 dns [192.168.15.30].
14-25-17-052| [          pfac] [1116426.735958] Ok, PID 636.
14-25-17-052| [            gm] [1116426.738212] 192.168.15.30 => 192.168.15.30.
14-25-17-052| [          pfac] [1116426.738406] Process pid 636 terminated, status 00000000.
14-25-17-052| [            gm] [1116426.738435] Free ram before fork terminal client /sbin/rdpclient (session 12): 925872 Kb.
14-25-17-052| [          pfac] [1116426.738528] Run /sbin/rdpclient 12.
14-25-17-052| [            gm] [1116426.738563] Run '/sbin/rdpclient 12', log '/tmp/rdpclient.out', env '', pid ''.
14-25-17-052| [          pfac] [1116426.738627] Ok, PID 637.
14-25-17-052| [ rdpclient 637] [1116426.742597] RDP Terminal Client, WTware v.5.4.32/RPi, pipe 12, pid 637.
14-25-17-052| [ rdpclient 637] [1116426.744126] Make RDP session with 192.168.15.30, port 3389.
14-25-17-052| [ rdpclient 637] [1116426.744190]  No username.
14-25-17-052| [ rdpclient 637] [1116426.744231]  No password.
14-25-17-052| [ rdpclient 637] [1116426.744269]  No PIN.
14-25-17-052| [ rdpclient 637] [1116426.744308]  Domain: "udom".
14-25-17-052| [ rdpclient 637] [1116426.744346]  No shell.
14-25-17-052| [ rdpclient 637] [1116426.744384]  No directory.
14-25-17-052| [ rdpclient 637] [1116426.744430]  Window: 1024x768@16.
14-25-17-052| [ rdpclient 637] [1116426.744468]  PFlags 0x0000002F.
14-25-17-052| [ rdpclient 637] [1116426.744608]  Keyboard 00000409:00000000.
14-25-17-052| [ rdpclient 637] [1116426.744649]  My hostname "wtwB827EBA20062".
14-25-17-052| [ rdpclient 637] [1116426.744688] TCP: connecting to 192.168.15.30:3389.
14-25-17-052| [ rdpclient 637] [1116426.745394] TCP: connection with 192.168.15.30:3389 established.
14-25-17-052| [ rdpclient 637] [1116426.745465] Turn keepalive on.
14-25-17-052| [ rdpclient 637] [1116426.745504] Free ram after buffers allocation: 925460 KB.
14-25-17-052| [ rdpclient 637] [1116426.755113] Process RDP server certificate.
14-25-17-052| [ rdpclient 637] [1116426.755171] RDP5 encryption (X.509).
14-25-17-052| [ rdpclient 637] [1116447.095417] LOGON_EX_LOGONERRORS 0xfffffffe 0x0000001e.
14-25-17-052| [ rdpclient 637] [1116473.726323] SessionId 0x0000001e: udom\testusera.
14-25-17-052| [ rdpclient 637] [1129958.261337] errorInfo 0x00000000.
14-25-17-052| [ rdpclient 637] [1129958.300557] Receive Disconnect Provider Ultimatum.
14-25-17-052| [            gm] [1129958.300670] TSClient gracefully end.
14-25-17-052| [          pfac] [1129958.302036] Process pid 637 terminated, status 00000009.
14-25-17-052| [            gm] [1204793.812233] Run '/sbin/resolver 0x130a378 dns [192.168.15.30]', log '', env '', pid ''.
14-25-17-052| [          pfac] [1204793.812415] Run /sbin/resolver 0x130a378 dns [192.168.15.30].
14-25-17-052| [          pfac] [1204793.812637] Ok, PID 639.
14-25-17-052| [            gm] [1204793.816284] 192.168.15.30 => 192.168.15.30.
14-25-17-052| [          pfac] [1204793.816399] Process pid 639 terminated, status 00000000.
14-25-17-052| [            gm] [1204793.816498] Free ram before fork terminal client /sbin/rdpclient (session 13): 925716 Kb.
14-25-17-052| [            gm] [1204793.816565] Run '/sbin/rdpclient 13', log '/tmp/rdpclient.out', env '', pid ''.
14-25-17-052| [          pfac] [1204793.816655] Run /sbin/rdpclient 13.
14-25-17-052| [          pfac] [1204793.816857] Ok, PID 640.
14-25-17-052| [ rdpclient 640] [1204793.821713] RDP Terminal Client, WTware v.5.4.32/RPi, pipe 13, pid 640.
14-25-17-052| [ rdpclient 640] [1204793.821773] Make RDP session with 192.168.15.30, port 3389.
14-25-17-052| [ rdpclient 640] [1204793.821814]  No username.
14-25-17-052| [ rdpclient 640] [1204793.821852]  No password.
14-25-17-052| [ rdpclient 640] [1204793.821890]  No PIN.
14-25-17-052| [ rdpclient 640] [1204793.821928]  Domain: "udom".
14-25-17-052| [ rdpclient 640] [1204793.821965]  No shell.
14-25-17-052| [ rdpclient 640] [1204793.822003]  No directory.
14-25-17-052| [ rdpclient 640] [1204793.822698]  Window: 1024x768@16.
14-25-17-052| [ rdpclient 640] [1204793.822746]  PFlags 0x0000002F.
14-25-17-052| [ rdpclient 640] [1204793.822785]  Keyboard 00000409:00000000.
14-25-17-052| [ rdpclient 640] [1204793.822824]  My hostname "wtwB827EBA20062".
14-25-17-052| [ rdpclient 640] [1204793.822863] TCP: connecting to 192.168.15.30:3389.
14-25-17-052| [ rdpclient 640] [1204793.822901] TCP: connection with 192.168.15.30:3389 established.
14-25-17-052| [ rdpclient 640] [1204793.822938] Turn keepalive on.
14-25-17-052| [ rdpclient 640] [1204793.822975] Free ram after buffers allocation: 925008 KB.
14-25-17-052| [ rdpclient 640] [1204793.868217] Process RDP server certificate.
14-25-17-052| [ rdpclient 640] [1204793.868277] RDP5 encryption (X.509).
14-25-17-052| [ rdpclient 640] [1204834.964968] errorInfo 0x00000000.
14-25-17-052| [ rdpclient 640] [1204834.966471] Receive Disconnect Provider Ultimatum.
14-25-17-052| [            gm] [1204834.966557] TSClient gracefully end.
14-25-17-052| [          pfac] [1204834.967504] Process pid 640 terminated, status 00000009.
14-25-17-052| [            gm] [1204946.488556] Run '/sbin/resolver 0x130a378 dns [192.168.15.30]', log '', env '', pid ''.
14-25-17-052| [          pfac] [1204946.488736] Run /sbin/resolver 0x130a378 dns [192.168.15.30].
14-25-17-052| [          pfac] [1204946.488977] Ok, PID 641.
14-25-17-052| [            gm] [1204946.491368] 192.168.15.30 => 192.168.15.30.
14-25-17-052| [          pfac] [1204946.491441] Process pid 641 terminated, status 00000000.
14-25-17-052| [            gm] [1204946.491465] Free ram before fork terminal client /sbin/rdpclient (session 14): 925824 Kb.
14-25-17-052| [          pfac] [1204946.491543] Run /sbin/rdpclient 14.
14-25-17-052| [            gm] [1204946.491575] Run '/sbin/rdpclient 14', log '/tmp/rdpclient.out', env '', pid ''.
14-25-17-052| [          pfac] [1204946.491650] Ok, PID 642.
14-25-17-052| [ rdpclient 642] [1204946.495593] RDP Terminal Client, WTware v.5.4.32/RPi, pipe 14, pid 642.
14-25-17-052| [ rdpclient 642] [1204946.496631] Make RDP session with 192.168.15.30, port 3389.
14-25-17-052| [ rdpclient 642] [1204946.496700]  No username.
14-25-17-052| [ rdpclient 642] [1204946.496750]  No password.
14-25-17-052| [ rdpclient 642] [1204946.496789]  No PIN.
14-25-17-052| [ rdpclient 642] [1204946.496827]  Domain: "udom".
14-25-17-052| [ rdpclient 642] [1204946.496865]  No shell.
14-25-17-052| [ rdpclient 642] [1204946.496903]  No directory.
14-25-17-052| [ rdpclient 642] [1204946.496941]  Window: 1024x768@16.
14-25-17-052| [ rdpclient 642] [1204946.496979]  PFlags 0x0000002F.
14-25-17-052| [ rdpclient 642] [1204946.497017]  Keyboard 00000409:00000000.
14-25-17-052| [ rdpclient 642] [1204946.497055]  My hostname "wtwB827EBA20062".
14-25-17-052| [ rdpclient 642] [1204946.497093] TCP: connecting to 192.168.15.30:3389.
14-25-17-052| [ rdpclient 642] [1204946.500079] TCP: connection with 192.168.15.30:3389 established.
14-25-17-052| [ rdpclient 642] [1204946.500168] Turn keepalive on.
14-25-17-052| [ rdpclient 642] [1204946.500209] Free ram after buffers allocation: 925096 KB.
14-25-17-052| [ rdpclient 642] [1204946.517714] Process RDP server certificate.
14-25-17-052| [ rdpclient 642] [1204946.517762] RDP5 encryption (X.509).
14-25-17-052| [ rdpclient 642] [1204960.589073] LOGON_EX_LOGONERRORS 0xfffffffe 0x00000028.
14-25-17-052| [ rdpclient 642] [1204979.882622] SessionId 0x00000028: udom\testusera.
14-25-17-052| [ rdpclient 642] [1219750.345541] errorInfo 0x00000000.
14-25-17-052| [ rdpclient 642] [1219750.347671] Receive Disconnect Provider Ultimatum.
14-25-17-052| [            gm] [1219750.347776] TSClient gracefully end.
14-25-17-052| [          pfac] [1219750.349135] Process pid 642 terminated, status 00000009.
14-25-17-052| [            gm] [1550934.149959] Run '/sbin/resolver 0x130a378 dns [192.168.15.30]', log '', env '', pid ''.
14-25-17-052| [          pfac] [1550934.150196] Run /sbin/resolver 0x130a378 dns [192.168.15.30].
14-25-17-052| [          pfac] [1550934.150415] Ok, PID 643.
14-25-17-052| [            gm] [1550934.158932] 192.168.15.30 => 192.168.15.30.
14-25-17-052| [          pfac] [1550934.159065] Process pid 643 terminated, status 00000000.
14-25-17-052| [            gm] [1550934.159236] Free ram before fork terminal client /sbin/rdpclient (session 15): 925948 Kb.
14-25-17-052| [            gm] [1550934.159304] Run '/sbin/rdpclient 15', log '/tmp/rdpclient.out', env '', pid ''.
14-25-17-052| [          pfac] [1550934.159394] Run /sbin/rdpclient 15.
14-25-17-052| [          pfac] [1550934.159603] Ok, PID 644.
14-25-17-052| [ rdpclient 644] [1550934.163614] RDP Terminal Client, WTware v.5.4.32/RPi, pipe 15, pid 644.
14-25-17-052| [ rdpclient 644] [1550934.164675] Make RDP session with 192.168.15.30, port 3389.
14-25-17-052| [ rdpclient 644] [1550934.164737]  No username.
14-25-17-052| [ rdpclient 644] [1550934.164777]  No password.
14-25-17-052| [ rdpclient 644] [1550934.164815]  No PIN.
14-25-17-052| [ rdpclient 644] [1550934.164853]  Domain: "udom".
14-25-17-052| [ rdpclient 644] [1550934.164890]  No shell.
14-25-17-052| [ rdpclient 644] [1550934.164928]  No directory.
14-25-17-052| [ rdpclient 644] [1550934.164965]  Window: 1024x768@16.
14-25-17-052| [ rdpclient 644] [1550934.165003]  PFlags 0x0000002F.
14-25-17-052| [ rdpclient 644] [1550934.165040]  Keyboard 00000409:00000000.
14-25-17-052| [ rdpclient 644] [1550934.165078]  My hostname "wtwB827EBA20062".
14-25-17-052| [ rdpclient 644] [1550934.165115] TCP: connecting to 192.168.15.30:3389.
14-25-17-052| [ rdpclient 644] [1550934.169382] TCP: connection with 192.168.15.30:3389 established.
14-25-17-052| [ rdpclient 644] [1550934.169447] Turn keepalive on.
14-25-17-052| [ rdpclient 644] [1550934.169487] Free ram after buffers allocation: 925032 KB.
14-25-17-052| [ rdpclient 644] [1550934.191256] Process RDP server certificate.
14-25-17-052| [ rdpclient 644] [1550934.191318] RDP5 encryption (X.509).
14-25-17-052| [ rdpclient 644] [1550954.865631] LOGON_EX_LOGONERRORS 0xfffffffe 0x00000007.
14-25-17-052| [ rdpclient 644] [1550978.369650] SessionId 0x00000007: udom\testusera.
14-25-17-052| [ rdpclient 644] [1565567.227742] errorInfo 0x00000000.
14-25-17-052| [ rdpclient 644] [1565567.230733] Receive Disconnect Provider Ultimatum.
14-25-17-052| [            gm] [1565567.230844] TSClient gracefully end.
14-25-17-052| [          pfac] [1565567.232216] Process pid 644 terminated, status 00000009.
14-25-17-052| [            gm] [1719339.096909] Run '/sbin/resolver 0x130a378 dns [192.168.15.30]', log '', env '', pid ''.
14-25-17-052| [          pfac] [1719339.097091] Run /sbin/resolver 0x130a378 dns [192.168.15.30].
14-25-17-052| [          pfac] [1719339.097312] Ok, PID 645.
14-25-17-052| [            gm] [1719339.102567] 192.168.15.30 => 192.168.15.30.
14-25-17-052| [          pfac] [1719339.102680] Process pid 645 terminated, status 00000000.
14-25-17-052| [            gm] [1719339.102785] Free ram before fork terminal client /sbin/rdpclient (session 16): 925900 Kb.
14-25-17-052| [            gm] [1719339.102852] Run '/sbin/rdpclient 16', log '/tmp/rdpclient.out', env '', pid ''.
14-25-17-052| [          pfac] [1719339.102954] Run /sbin/rdpclient 16.
14-25-17-052| [          pfac] [1719339.103172] Ok, PID 646.
14-25-17-052| [ rdpclient 646] [1719339.107077] RDP Terminal Client, WTware v.5.4.32/RPi, pipe 16, pid 646.
14-25-17-052| [ rdpclient 646] [1719339.108109] Make RDP session with 192.168.15.30, port 3389.
14-25-17-052| [ rdpclient 646] [1719339.108173]  No username.
14-25-17-052| [ rdpclient 646] [1719339.108214]  No password.
14-25-17-052| [ rdpclient 646] [1719339.108252]  No PIN.
14-25-17-052| [ rdpclient 646] [1719339.108289]  Domain: "udom".
14-25-17-052| [ rdpclient 646] [1719339.108327]  No shell.
14-25-17-052| [ rdpclient 646] [1719339.108365]  No directory.
14-25-17-052| [ rdpclient 646] [1719339.108403]  Window: 1024x768@16.
14-25-17-052| [ rdpclient 646] [1719339.108440]  PFlags 0x0000002F.
14-25-17-052| [ rdpclient 646] [1719339.108478]  Keyboard 00000409:00000000.
14-25-17-052| [ rdpclient 646] [1719339.108515]  My hostname "wtwB827EBA20062".
14-25-17-052| [ rdpclient 646] [1719339.108553] TCP: connecting to 192.168.15.30:3389.
14-25-17-052| [ rdpclient 646] [1719339.110110] TCP: connection with 192.168.15.30:3389 established.
14-25-17-052| [ rdpclient 646] [1719339.110192] Turn keepalive on.
14-25-17-052| [ rdpclient 646] [1719339.110318] Free ram after buffers allocation: 925052 KB.
14-25-17-052| [ rdpclient 646] [1719339.122780] Process RDP server certificate.
14-25-17-052| [ rdpclient 646] [1719339.122866] RDP5 encryption (X.509).
14-25-17-052| [ rdpclient 646] [1719395.084378] LOGON_EX_LOGONERRORS 0xfffffffe 0x00000029.
14-25-17-052| [ rdpclient 646] [1719430.090486] SessionId 0x00000029: udom\testusera.
14-25-17-052| [ rdpclient 646] [1739389.089565] errorInfo 0x00000000.
14-25-17-052| [ rdpclient 646] [1739389.120376] Receive Disconnect Provider Ultimatum.
14-25-17-052| [            gm] [1739389.120487] TSClient gracefully end.
14-25-17-052| [          pfac] [1739389.121836] Process pid 646 terminated, status 00000009.
14-25-17-052| [            gm] [1807216.396286] Run '/sbin/resolver 0x130a378 dns [192.168.15.30]', log '', env '', pid ''.
14-25-17-052| [          pfac] [1807216.396466] Run /sbin/resolver 0x130a378 dns [192.168.15.30].
14-25-17-052| [          pfac] [1807216.396685] Ok, PID 647.
14-25-17-052| [            gm] [1807216.400431] 192.168.15.30 => 192.168.15.30.
14-25-17-052| [          pfac] [1807216.400503] Process pid 647 terminated, status 00000000.
14-25-17-052| [            gm] [1807216.400529] Free ram before fork terminal client /sbin/rdpclient (session 17): 925868 Kb.
14-25-17-052| [          pfac] [1807216.400568] Run /sbin/rdpclient 17.
14-25-17-052| [            gm] [1807216.400590] Run '/sbin/rdpclient 17', log '/tmp/rdpclient.out', env '', pid ''.
14-25-17-052| [          pfac] [1807216.400651] Ok, PID 648.
14-25-17-052| [ rdpclient 648] [1807216.404465] RDP Terminal Client, WTware v.5.4.32/RPi, pipe 17, pid 648.
14-25-17-052| [ rdpclient 648] [1807216.405696] Make RDP session with 192.168.15.30, port 3389.
14-25-17-052| [ rdpclient 648] [1807216.405756]  No username.
14-25-17-052| [ rdpclient 648] [1807216.405795]  No password.
14-25-17-052| [ rdpclient 648] [1807216.405834]  No PIN.
14-25-17-052| [ rdpclient 648] [1807216.405872]  Domain: "udom".
14-25-17-052| [ rdpclient 648] [1807216.405911]  No shell.
14-25-17-052| [ rdpclient 648] [1807216.405949]  No directory.
14-25-17-052| [ rdpclient 648] [1807216.405987]  Window: 1024x768@16.
14-25-17-052| [ rdpclient 648] [1807216.406025]  PFlags 0x0000002F.
14-25-17-052| [ rdpclient 648] [1807216.406063]  Keyboard 00000409:00000000.
14-25-17-052| [ rdpclient 648] [1807216.406100]  My hostname "wtwB827EBA20062".
14-25-17-052| [ rdpclient 648] [1807216.406140] TCP: connecting to 192.168.15.30:3389.
14-25-17-052| [ rdpclient 648] [1807216.406237] TCP: connection with 192.168.15.30:3389 established.
14-25-17-052| [ rdpclient 648] [1807216.406278] Turn keepalive on.
14-25-17-052| [ rdpclient 648] [1807216.406744] Free ram after buffers allocation: 925596 KB.
14-25-17-052| [ rdpclient 648] [1807216.424499] Process RDP server certificate.
14-25-17-052| [ rdpclient 648] [1807216.424557] RDP5 encryption (X.509).
14-25-17-052| [ rdpclient 648] [1807259.583318] LOGON_EX_LOGONERRORS 0xfffffffe 0x00000022.
14-25-17-052| [ rdpclient 648] [1807293.710686] SessionId 0x00000022: udom\testusera.
14-25-17-052| [ rdpclient 648] [1825032.370704] errorInfo 0x00000000.
14-25-17-052| [ rdpclient 648] [1825032.372942] Receive Disconnect Provider Ultimatum.
14-25-17-052| [            gm] [1825032.373046] TSClient gracefully end.
14-25-17-052| [          pfac] [1825032.374417] Process pid 648 terminated, status 00000009.
14-25-17-052| [            gm] [2154985.703216] Run '/sbin/resolver 0x130a378 dns [192.168.15.30]', log '', env '', pid ''.
14-25-17-052| [          pfac] [2154985.703398] Run /sbin/resolver 0x130a378 dns [192.168.15.30].
14-25-17-052| [          pfac] [2154985.703625] Ok, PID 649.
14-25-17-052| [            gm] [2154985.712463] 192.168.15.30 => 192.168.15.30.
14-25-17-052| [          pfac] [2154985.712597] Process pid 649 terminated, status 00000000.
14-25-17-052| [            gm] [2154985.712770] Free ram before fork terminal client /sbin/rdpclient (session 18): 925852 Kb.
14-25-17-052| [            gm] [2154985.712838] Run '/sbin/rdpclient 18', log '/tmp/rdpclient.out', env '', pid ''.
14-25-17-052| [          pfac] [2154985.712932] Run /sbin/rdpclient 18.
14-25-17-052| [          pfac] [2154985.713142] Ok, PID 650.
14-25-17-052| [ rdpclient 650] [2154985.717163] RDP Terminal Client, WTware v.5.4.32/RPi, pipe 18, pid 650.
14-25-17-052| [ rdpclient 650] [2154985.718660] Make RDP session with 192.168.15.30, port 3389.
14-25-17-052| [ rdpclient 650] [2154985.718725]  No username.
14-25-17-052| [ rdpclient 650] [2154985.718765]  No password.
14-25-17-052| [ rdpclient 650] [2154985.718804]  No PIN.
14-25-17-052| [ rdpclient 650] [2154985.718841]  Domain: "udom".
14-25-17-052| [ rdpclient 650] [2154985.718879]  No shell.
14-25-17-052| [ rdpclient 650] [2154985.718916]  No directory.
14-25-17-052| [ rdpclient 650] [2154985.718954]  Window: 1024x768@16.
14-25-17-052| [ rdpclient 650] [2154985.718992]  PFlags 0x0000002F.
14-25-17-052| [ rdpclient 650] [2154985.719129]  Keyboard 00000409:00000000.
14-25-17-052| [ rdpclient 650] [2154985.719169]  My hostname "wtwB827EBA20062".
14-25-17-052| [ rdpclient 650] [2154985.719208] TCP: connecting to 192.168.15.30:3389.
14-25-17-052| [ rdpclient 650] [2154985.719920] TCP: connection with 192.168.15.30:3389 established.
14-25-17-052| [ rdpclient 650] [2154985.719993] Turn keepalive on.
14-25-17-052| [ rdpclient 650] [2154985.720085] Free ram after buffers allocation: 925432 KB.
14-25-17-052| [ rdpclient 650] [2154985.737922] Process RDP server certificate.
14-25-17-052| [ rdpclient 650] [2154985.737984] RDP5 encryption (X.509).
14-25-17-052| [ rdpclient 650] [2155015.606150] LOGON_EX_LOGONERRORS 0xfffffffe 0x0000002c.
14-25-17-052| [ rdpclient 650] [2155052.914954] SessionId 0x0000002c: udom\testusera.
14-25-17-061| Connection from wtc.exe at 192.168.10.83.
Re: 5.4.46 mouse click stop working
Posted: Sun Sep 25, 2016 3:50 pm
by Alon
Had to cut log in half because message length limitation.
The log I sent is from a WTware v.5.4.32 next to the WTware v.5.4.46 that had the same problem, I was waiting for the problem to happen to get the logs, the problem happens randomly.
Posted: Mon Sep 26, 2016 9:01 am
by Alon
Now it did happen on WTware v.5.4.46 next to the previous:
16-30-34-247| [TFTP] WTware v.5.4.46 found at host [], mac B8:27:EB:C5:B5:01.
16-30-34-387| [TFTP] Sending WTware TFTP version.
16-30-34-387| [TFTP] Got RRQ, 45 bytes.
16-30-34-387| [TFTP] 00000000: 45 76 65 72 79 6f 6e 65 2f 6c 69 73 74 2e 77 74
16-30-34-387| [TFTP] 00000010: 63 00 6f 63 74 65 74 00 74 73 69 7a 65 00 30 00
16-30-34-387| [TFTP] 00000020: 62 6c 6b 73 69 7a 65 00 31 34 30 30 00
16-30-34-387| [TFTP] Request block size 1400, forced to 1360.
16-30-34-387| [TFTP] Requests file "Everyone\list.wtc". Tsize is requested, blksize 1360 bytes.
16-30-34-387| [TFTP] Sending OASK (tsize 1209, blksize 1360).
16-30-34-387| [TFTP] Transfer of file "Everyone\list.wtc" completed.
16-30-34-387| [TFTP] Connection closed.
16-30-34-387| [TFTP] Got RRQ, 66 bytes.
16-30-34-387| [TFTP] 00000000: 54 65 72 6d 69 6e 61 6c 73 2f 42 38 2e 32 37 2e
16-30-34-387| [TFTP] 00000010: 45 42 2e 43 35 2e 42 35 2e 30 31 2f 63 6f 6e 66
16-30-34-387| [TFTP] 00000020: 69 67 2e 77 74 63 00 6f 63 74 65 74 00 74 73 69
16-30-34-387| [TFTP] 00000030: 7a 65 00 30 00 62 6c 6b 73 69 7a 65 00 31 34 30
16-30-34-387| [TFTP] 00000040: 30 00
16-30-34-387| [TFTP] Requests file "Terminals\B8.27.EB.C5.B5.01\config.wtc". Tsize is requested, blksize 1360 bytes.
16-30-34-387| [TFTP] Sending OASK (tsize 210, blksize 1360).
16-30-34-387| [TFTP] Transfer of file "Terminals\B8.27.EB.C5.B5.01\config.wtc" completed.
16-30-34-387| [TFTP] Got RRQ, 44 bytes.
16-30-34-387| [TFTP] 00000000: 45 76 65 72 79 6f 6e 65 2f 61 6c 6c 2e 77 74 63
16-30-34-387| [TFTP] 00000010: 00 6f 63 74 65 74 00 74 73 69 7a 65 00 30 00 62
16-30-34-387| [TFTP] 00000020: 6c 6b 73 69 7a 65 00 31 34 30 30 00
16-30-34-387| [TFTP] Requests file "Everyone\all.wtc". Tsize is requested, blksize 1360 bytes.
16-30-34-387| [TFTP] Sending OASK (tsize 41, blksize 1360).
16-30-34-387| [TFTP] Transfer of file "Everyone\all.wtc" completed.
16-30-34-387| [TFTP] Got RRQ, 50 bytes.
16-30-34-387| [TFTP] 00000000: 54 65 6d 70 6c 61 74 65 73 2f 48 61 73 68 2d 42
16-30-34-387| [TFTP] 00000010: 79 73 2e 77 74 63 00 6f 63 74 65 74 00 74 73 69
16-30-34-387| [TFTP] 00000020: 7a 65 00 30 00 62 6c 6b 73 69 7a 65 00 31 34 30
16-30-34-387| [TFTP] 00000030: 30 00
16-30-34-387| [TFTP] Requests file "Templates\Hash-rdh1.wtc". Tsize is requested, blksize 1360 bytes.
16-30-34-387| [TFTP] Sending OASK (tsize 260, blksize 1360).
16-30-34-387| [TFTP] Transfer of file "Templates\Hash-rdh1.wtc" completed.
16-30-34-387| [TFTP] Got RRQ, 47 bytes.
16-30-34-387| [TFTP] 00000000: 43 6f 6e 6e 65 63 74 69 6f 6e 73 2f 42 59 53 2e
16-30-34-387| [TFTP] 00000010: 77 74 63 00 6f 63 74 65 74 00 74 73 69 7a 65 00
16-30-34-387| [TFTP] 00000020: 30 00 62 6c 6b 73 69 7a 65 00 31 34 30 30 00
16-30-34-387| [TFTP] Requests file "Connections\rdh1.wtc". Tsize is requested, blksize 1360 bytes.
16-30-34-387| [TFTP] Sending OASK (tsize 82, blksize 1360).
16-30-34-387| [TFTP] Transfer of file "Connections\rdh1.wtc" completed.
16-30-34-387| [TFTP] Got RRQ, 51 bytes.
16-30-34-387| [TFTP] 00000000: 43 6f 6e 6e 65 63 74 69 6f 6e 73 2f 48 61 73 68
16-30-34-387| [TFTP] 00000010: 61 6c 61 2e 77 74 63 00 6f 63 74 65 74 00 74 73
16-30-34-387| [TFTP] 00000020: 69 7a 65 00 30 00 62 6c 6b 73 69 7a 65 00 31 34
16-30-34-387| [TFTP] 00000030: 30 30 00
16-30-34-387| [TFTP] Requests file "Connections\rdh2.wtc". Tsize is requested, blksize 1360 bytes.
16-30-34-387| [TFTP] Transfer of file "Connections\rdh2.wtc" completed.
16-30-34-715| [TFTP] Got RRQ, 47 bytes.
16-30-34-715| [TFTP] 00000000: 47 72 61 70 68 69 63 2f 70 6b 2f 77 61 69 74 2e
16-30-34-715| [TFTP] 00000010: 70 6e 67 00 6f 63 74 65 74 00 74 73 69 7a 65 00
16-30-34-715| [TFTP] 00000020: 30 00 62 6c 6b 73 69 7a 65 00 31 34 30 30 00
16-30-34-715| [TFTP] Request block size 1400, forced to 1360.
16-30-34-715| [TFTP] Requests file "Graphic\pk\wait.png". Tsize is requested, blksize 1360 bytes.
16-30-34-715| [TFTP] Sending OASK (tsize 19459, blksize 1360).
16-30-34-731| [TFTP] Transfer of file "Graphic\pk\wait.png" completed.
16-30-34-731| [TFTP] Connection closed.
16-30-34-747| [TFTP] Got RRQ, 48 bytes.
16-30-34-747| [TFTP] 00000000: 47 72 61 70 68 69 63 2f 70 6b 2f 70 6f 70 75 70
16-30-34-747| [TFTP] 00000010: 2e 70 6e 67 00 6f 63 74 65 74 00 74 73 69 7a 65
16-30-34-747| [TFTP] 00000020: 00 30 00 62 6c 6b 73 69 7a 65 00 31 34 30 30 00
16-30-34-747| [TFTP] Request block size 1400, forced to 1360.
16-30-34-747| [TFTP] Requests file "Graphic\pk\popup.png". Tsize is requested, blksize 1360 bytes.
16-30-34-747| [TFTP] Sending OASK (tsize 7637, blksize 1360).
16-30-34-762| [TFTP] Transfer of file "Graphic\pk\popup.png" completed.
16-30-34-762| [TFTP] Connection closed.
16-30-34-762| [TFTP] Got RRQ, 47 bytes.
16-30-34-762| [TFTP] 00000000: 47 72 61 70 68 69 63 2f 70 6b 2f 6d 65 6e 75 2e
16-30-34-762| [TFTP] 00000010: 70 6e 67 00 6f 63 74 65 74 00 74 73 69 7a 65 00
16-30-34-762| [TFTP] 00000020: 30 00 62 6c 6b 73 69 7a 65 00 31 34 30 30 00
16-30-34-762| [TFTP] Request block size 1400, forced to 1360.
16-30-34-762| [TFTP] Requests file "Graphic\pk\menu.png". Tsize is requested, blksize 1360 bytes.
16-30-34-762| [TFTP] Sending OASK (tsize 1010577, blksize 1360).
16-30-35-637| [TFTP] Transfer of file "Graphic\pk\menu.png" completed.
16-30-35-637| [TFTP] Connection closed.
17-11-30-338| WTware v.5.4.46/RPi supervisor.
17-11-30-338| WTC listener is active.
17-11-30-338| WTC broadcast listener is active.
17-11-30-338| [        KERNEL] [    0.000000] Booting Linux on physical CPU 0x0
17-11-30-338| [        KERNEL] [    0.000000] Initializing cgroup subsys cpuset
17-11-30-338| [        KERNEL] [    0.000000] Initializing cgroup subsys cpuacct
17-11-30-338| [        KERNEL] [    0.000000] Linux version 4.4.20 (aka@c12) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.1) ) #12 SMP Mon Sep 12 09:50:11 SAMT 2016
17-11-30-338| [        KERNEL] [    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
17-11-30-338| [        KERNEL] [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
17-11-30-338| [        KERNEL] [    0.000000] Machine model: Raspberry Pi 3 Model B Rev 1.2
17-11-30-338| [        KERNEL] [    0.000000] cma: Reserved 8 MiB at 0x3a800000
17-11-30-338| [        KERNEL] [    0.000000] Memory policy: Data cache writealloc
17-11-30-338| [        KERNEL] [    0.000000] On node 0 totalpages: 241664
17-11-30-338| [        KERNEL] [    0.000000] free_area_init_node: node 0, pgdat 8090ed00, node_mem_map b9fa6000
17-11-30-338| [        KERNEL] [    0.000000]   Normal zone: 2124 pages used for memmap
17-11-30-338| [        KERNEL] [    0.000000]   Normal zone: 0 pages reserved
17-11-30-338| [        KERNEL] [    0.000000]   Normal zone: 241664 pages, LIFO batch:31
17-11-30-338| [        KERNEL] [    0.000000] [bcm2709_smp_init_cpus] enter (94c0->f3003010)
17-11-30-338| [        KERNEL] [    0.000000] [bcm2709_smp_init_cpus] ncores=4
17-11-30-338| [        KERNEL] [    0.000000] PERCPU: Embedded 11 pages/cpu @b9f6a000 s13324 r8192 d23540 u45056
17-11-30-338| [        KERNEL] [    0.000000] pcpu-alloc: s13324 r8192 d23540 u45056 alloc=11*4096
17-11-30-338| [        KERNEL] [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
17-11-30-338| [        KERNEL] [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 239540
17-11-30-338| [        KERNEL] [    0.000000] Kernel command line: 8250.nr_uarts=0 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1024 bcm2708_fb.fbheight=768 bcm2709.boardrev=0xa02082 bcm2709.serial=0x45c5b501 smsc95xx.macaddr=B8:27:EB:C5:B5:01 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  console=ttyS0,115200 console=tty1 quiet wtboot=mmc
17-11-30-338| [        KERNEL] [    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
17-11-30-338| [        KERNEL] [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
17-11-30-338| [        KERNEL] [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
17-11-30-338| [        KERNEL] [    0.000000] Memory: 939236K/966656K available (3779K kernel code, 167K rwdata, 1172K rodata, 4128K init, 365K bss, 19228K reserved, 8192K cma-reserved)
17-11-30-338| [        KERNEL] [    0.000000] Virtual kernel memory layout:
17-11-30-338| [        KERNEL] [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
17-11-30-338| [        KERNEL] [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
17-11-30-338| [        KERNEL] [    0.000000]     vmalloc : 0xbb800000 - 0xff800000   (1088 MB)
17-11-30-338| [        KERNEL] [    0.000000]     lowmem  : 0x80000000 - 0xbb000000   ( 944 MB)
17-11-30-338| [        KERNEL] [    0.000000]     modules : 0x7f000000 - 0x80000000   (  16 MB)
17-11-30-338| [        KERNEL] [    0.000000]       .text : 0x80008000 - 0x804ddfac   (4952 kB)
17-11-30-338| [        KERNEL] [    0.000000]       .init : 0x804de000 - 0x808e6000   (4128 kB)
17-11-30-338| [        KERNEL] [    0.000000]       .data : 0x808e6000 - 0x8090fc00   ( 167 kB)
17-11-30-338| [        KERNEL] [    0.000000]        .bss : 0x80912000 - 0x8096d50c   ( 366 kB)
17-11-30-338| [        KERNEL] [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
17-11-30-338| [        KERNEL] [    0.000000] Hierarchical RCU implementation.
17-11-30-338| [        KERNEL] [    0.000000] 	Build-time adjustment of leaf fanout to 32.
17-11-30-338| [        KERNEL] [    0.000000] NR_IRQS:16 nr_irqs:16 16
17-11-30-338| [        KERNEL] [    0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
17-11-30-338| [        KERNEL] [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
17-11-30-338| [        KERNEL] [    0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
17-11-30-338| [        KERNEL] [    0.000022] Switching to timer-based delay loop, resolution 52ns
17-11-30-338| [        KERNEL] [    0.000188] Console: colour dummy device 80x30
17-11-30-338| [        KERNEL] [    0.000362] console [tty1] enabled
17-11-30-338| [        KERNEL] [    0.000382] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
17-11-30-338| [        KERNEL] [    0.000398] pid_max: default: 32768 minimum: 301
17-11-30-338| [        KERNEL] [    0.000516] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
17-11-30-338| [        KERNEL] [    0.000529] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
17-11-30-338| [        KERNEL] [    0.001377] Disabling cpuset control group subsystem
17-11-30-338| [        KERNEL] [    0.001404] Initializing cgroup subsys io
17-11-30-338| [        KERNEL] [    0.001428] Initializing cgroup subsys memory
17-11-30-338| [        KERNEL] [    0.001463] Initializing cgroup subsys devices
17-11-30-338| [        KERNEL] [    0.001480] Initializing cgroup subsys freezer
17-11-30-338| [        KERNEL] [    0.001518] CPU: Testing write buffer coherency: ok
17-11-30-338| [        KERNEL] [    0.001949] CPU0: update cpu_capacity 1024
17-11-30-338| [        KERNEL] [    0.001961] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
17-11-30-338| [        KERNEL] [    0.001971] [bcm2709_smp_prepare_cpus] enter
17-11-30-338| [        KERNEL] [    0.002051] Setting up static identity map for 0x8240 - 0x8274
17-11-30-338| [        KERNEL] [    0.003370] [bcm2709_boot_secondary] cpu:1 started (0) 16
17-11-30-338| [        KERNEL] [    0.003561] [bcm2709_secondary_init] enter cpu:1
17-11-30-338| [        KERNEL] [    0.003599] CPU1: update cpu_capacity 1024
17-11-30-338| [        KERNEL] [    0.003604] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
17-11-30-338| [        KERNEL] [    0.003931] [bcm2709_boot_secondary] cpu:2 started (0) 16
17-11-30-338| [        KERNEL] [    0.004071] [bcm2709_secondary_init] enter cpu:2
17-11-30-338| [        KERNEL] [    0.004090] CPU2: update cpu_capacity 1024
17-11-30-338| [        KERNEL] [    0.004096] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
17-11-30-338| [        KERNEL] [    0.004391] [bcm2709_boot_secondary] cpu:3 started (0) 16
17-11-30-338| [        KERNEL] [    0.004519] [bcm2709_secondary_init] enter cpu:3
17-11-30-338| [        KERNEL] [    0.004537] CPU3: update cpu_capacity 1024
17-11-30-338| [        KERNEL] [    0.004543] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
17-11-30-338| [        KERNEL] [    0.004596] Brought up 4 CPUs
17-11-30-338| [        KERNEL] [    0.004617] SMP: Total of 4 processors activated (153.60 BogoMIPS).
17-11-30-338| [        KERNEL] [    0.004624] CPU: All CPU(s) started in HYP mode.
17-11-30-338| [        KERNEL] [    0.004631] CPU: Virtualization extensions available.
17-11-30-338| [        KERNEL] [    0.005000] devtmpfs: initialized
17-11-30-338| [        KERNEL] [    0.014394] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
17-11-30-338| [        KERNEL] [    0.014723] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
17-11-30-338| [        KERNEL] [    0.015193] pinctrl core: initialized pinctrl subsystem
17-11-30-338| [        KERNEL] [    0.015598] NET: Registered protocol family 16
17-11-30-338| [        KERNEL] [    0.020519] DMA: preallocated 4096 KiB pool for atomic coherent allocations
17-11-30-338| [        KERNEL] [    0.049937] cpuidle: using governor ladder
17-11-30-338| [        KERNEL] [    0.079956] cpuidle: using governor menu
17-11-30-338| [        KERNEL] [    0.085754] Serial: AMBA PL011 UART driver
17-11-30-338| [        KERNEL] [    0.085936] uart-pl011 3f201000.uart: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
17-11-30-338| [        KERNEL] [    0.086133] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
17-11-30-338| [        KERNEL] [    0.152493] bcm2835-dma 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0x1
17-11-30-338| [        KERNEL] [    0.153007] usbcore: registered new interface driver usbfs
17-11-30-338| [        KERNEL] [    0.153134] usbcore: registered new interface driver hub
17-11-30-338| [        KERNEL] [    0.153222] usbcore: registered new device driver usb
17-11-30-338| [        KERNEL] [    0.160135] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-09-07 14:46
17-11-30-338| [        KERNEL] [    0.187822] clocksource: Switched to clocksource arch_sys_counter
17-11-30-338| [        KERNEL] [    0.200121] NET: Registered protocol family 2
17-11-30-338| [        KERNEL] [    0.200676] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
17-11-30-338| [        KERNEL] [    0.200788] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
17-11-30-338| [        KERNEL] [    0.200976] TCP: Hash tables configured (established 8192 bind 8192)
17-11-30-338| [        KERNEL] [    0.201066] UDP hash table entries: 512 (order: 2, 16384 bytes)
17-11-30-338| [        KERNEL] [    0.201112] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
17-11-30-338| [        KERNEL] [    0.201307] NET: Registered protocol family 1
17-11-30-338| [        KERNEL] [    2.330039] futex hash table entries: 1024 (order: 4, 65536 bytes)
17-11-30-338| [        KERNEL] [    2.373323] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
17-11-30-338| [        KERNEL] [    2.373350] io scheduler noop registered
17-11-30-338| [        KERNEL] [    2.373369] io scheduler deadline registered (default)
17-11-30-338| [        KERNEL] [    2.377604] BCM2708FB: allocated DMA memory fac00000
17-11-30-338| [        KERNEL] [    2.377652] BCM2708FB: allocated DMA channel 0 @ f3007000
17-11-30-338| [        KERNEL] [    2.400459] Console: switching to colour frame buffer device 128x48
17-11-30-338| [        KERNEL] [    3.340409] bcm2835-rng 3f104000.rng: hwrng registered
17-11-30-338| [        KERNEL] [    3.340623] vc-cma: Videocore CMA driver
17-11-30-338| [        KERNEL] [    3.340634] vc-cma: vc_cma_base      = 0x00000000
17-11-30-338| [        KERNEL] [    3.340643] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
17-11-30-338| [        KERNEL] [    3.340650] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
17-11-30-338| [        KERNEL] [    3.340875] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
17-11-30-338| [        KERNEL] [    3.342234] vchiq: vchiq_init_state: slot_zero = 0xbac80000, is_master = 0
17-11-30-338| [        KERNEL] [    3.348107] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
17-11-30-338| [        KERNEL] [    3.548467] Core Release: 2.80a
17-11-30-338| [        KERNEL] [    3.548484] Setting default values for core params
17-11-30-338| [        KERNEL] [    3.548513] Finished setting default values for core params
17-11-30-338| [        KERNEL] [    3.748862] Using Buffer DMA mode
17-11-30-338| [        KERNEL] [    3.748874] Periodic Transfer Interrupt Enhancement - disabled
17-11-30-338| [        KERNEL] [    3.748882] Multiprocessor Interrupt Enhancement - disabled
17-11-30-338| [        KERNEL] [    3.748890] OTG VER PARAM: 0, OTG VER FLAG: 0
17-11-30-338| [        KERNEL] [    3.748905] Dedicated Tx FIFOs mode
17-11-30-338| [        KERNEL] [    3.749299] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbac14000 dma = 0xfac14000 len=9024
17-11-30-338| [        KERNEL] [    3.749329] FIQ FSM acceleration enabled for :
17-11-30-338| [        KERNEL] [    3.749329] Non-periodic Split Transactions
17-11-30-338| [        KERNEL] [    3.749329] Periodic Split Transactions
17-11-30-338| [        KERNEL] [    3.749329] High-Speed Isochronous Endpoints
17-11-30-338| [        KERNEL] [    3.749329] Interrupt/Control Split Transaction hack enabled
17-11-30-338| [        KERNEL] [    3.749350] dwc_otg: Microframe scheduler enabled
17-11-30-338| [        KERNEL] [    3.749397] WARN::hcd_init_fiq:413: FIQ on core 1 at 0x80259bd0
17-11-30-338| [        KERNEL] [    3.749411] WARN::hcd_init_fiq:414: FIQ ASM at 0x80259f34 length 36
17-11-30-338| [        KERNEL] [    3.749426] WARN::hcd_init_fiq:439: MPHI regs_base at 0xbb90a000
17-11-30-338| [        KERNEL] [    3.749482] dwc_otg 3f980000.usb: DWC OTG Controller
17-11-30-338| [        KERNEL] [    3.749519] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
17-11-30-338| [        KERNEL] [    3.749550] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
17-11-30-338| [        KERNEL] [    3.749597] Init: Port Power? op_state=1
17-11-30-338| [        KERNEL] [    3.749604] Init: Power Port (0)
17-11-30-338| [        KERNEL] [    3.749775] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
17-11-30-338| [        KERNEL] [    3.749789] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
17-11-30-338| [        KERNEL] [    3.749800] usb usb1: Product: DWC OTG Controller
17-11-30-338| [        KERNEL] [    3.749812] usb usb1: Manufacturer: Linux 4.4.20 dwc_otg_hcd
17-11-30-338| [        KERNEL] [    3.749823] usb usb1: SerialNumber: 3f980000.usb
17-11-30-338| [        KERNEL] [    3.750477] hub 1-0:1.0: USB hub found
17-11-30-338| [        KERNEL] [    3.750516] hub 1-0:1.0: 1 port detected
17-11-30-338| [        KERNEL] [    3.750942] dwc_otg: FIQ enabled
17-11-30-338| [        KERNEL] [    3.750951] dwc_otg: NAK holdoff enabled
17-11-30-338| [        KERNEL] [    3.750959] dwc_otg: FIQ split-transaction FSM enabled
17-11-30-338| [        KERNEL] [    3.750995] Module dwc_common_port init
17-11-30-338| [        KERNEL] [    3.753736] bcm2835-cpufreq: min=600000 max=1200000
17-11-30-338| [        KERNEL] [    3.755941] sdhost: log_buf @ bac13000 (fac13000)
17-11-30-338| [        KERNEL] [    3.807835] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
17-11-30-338| [        KERNEL] [    3.809987] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
17-11-30-338| [        KERNEL] [    3.809993] mmc-bcm2835 3f300000.mmc: Forcing PIO mode
17-11-30-338| [        KERNEL] [    3.848024] hidraw: raw HID events driver (C) Jiri Kosina
17-11-30-338| [        KERNEL] [    3.848483] usbcore: registered new interface driver usbhid
17-11-30-338| [        KERNEL] [    3.848495] usbhid: USB HID core driver
17-11-30-338| [        KERNEL] [    3.848968] NET: Registered protocol family 17
17-11-30-338| [        KERNEL] [    3.849264] Registering SWP/SWPB emulation handler
17-11-30-338| [        KERNEL] [    3.851128] registered taskstats version 1
17-11-30-338| [        KERNEL] [    3.851186] vc-sm: Videocore shared memory driver
17-11-30-338| [        KERNEL] [    3.851198] [vc_sm_connected_init]: start
17-11-30-338| [        KERNEL] [    3.854643] [vc_sm_connected_init]: end - returning 0
17-11-30-338| [        KERNEL] [    3.856641] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
17-11-30-338| [        KERNEL] [    3.860570] Freeing unused kernel memory: 4128K (804de000 - 808e6000)
17-11-30-338| [        KERNEL] [    3.865211] mmc0: host does not support reading read-only switch, assuming write-enable
17-11-30-338| [        KERNEL] [    3.867099] mmc0: new high speed SDHC card at address 59b4
17-11-30-338| [        KERNEL] [    3.868465] mmcblk0: mmc0:59b4 00000 7.35 GiB
17-11-30-338| [        KERNEL] [    3.869601]  mmcblk0: p1
17-11-30-338| [        KERNEL] [    3.889734] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
17-11-30-338| [        KERNEL] [    3.891224] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
17-11-30-338| [        KERNEL] [    3.892709] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
17-11-30-338| [        KERNEL] [    3.895376] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
17-11-30-338| [        KERNEL] [    3.947883] Indeed it is in host mode hprt0 = 00021501
17-11-30-338| [        KERNEL] [    3.990160] mmc1: new high speed SDIO card at address 0001
17-11-30-338| [        KERNEL] [    4.127858] usb 1-1: new high-speed USB device number 2 using dwc_otg
17-11-30-338| [        KERNEL] [    4.127980] Indeed it is in host mode hprt0 = 00001101
17-11-30-338| [       hotplug] [    4.166777] Block device 179:0. No action.
17-11-30-338| [       hotplug] [    4.167506] Block device 179:1. No action.
17-11-30-338| [          pfac] [    4.168274] Run /sbin/initrd.
17-11-30-338| [          pfac] [    4.168360] Ok, PID 536.
17-11-30-338| [        initrd] [    4.170790] WTware shell v.5.4.46/RPi
17-11-30-338| [        initrd] [    4.193925] Local media boot.
17-11-30-338| [        initrd] [    4.194048] USB boot.
17-11-30-338| [        KERNEL] [    4.328085] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
17-11-30-338| [        KERNEL] [    4.328104] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
17-11-30-338| [        KERNEL] [    4.328801] hub 1-1:1.0: USB hub found
17-11-30-338| [        KERNEL] [    4.328918] hub 1-1:1.0: 5 ports detected
17-11-30-338| [        KERNEL] [    4.607851] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
17-11-30-338| [        KERNEL] [    4.708066] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
17-11-30-338| [        KERNEL] [    4.708081] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
17-11-30-338| [        KERNEL] [    4.787850] usb 1-1.3: new low-speed USB device number 4 using dwc_otg
17-11-30-338| [        KERNEL] [    4.891942] usb 1-1.3: New USB device found, idVendor=045e, idProduct=0797
17-11-30-338| [        KERNEL] [    4.891957] usb 1-1.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
17-11-30-338| [        KERNEL] [    4.891969] usb 1-1.3: Product: USB Optical Mouse
17-11-30-338| [        KERNEL] [    4.897025] input: USB Optical Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:045E:0797.0001/input/input0
17-11-30-338| [        KERNEL] [    4.897478] hid-generic 0003:045E:0797.0001: input,hidraw0: USB HID v1.11 Mouse [USB Optical Mouse] on usb-3f980000.usb-1.3/input0
17-11-30-338| [        KERNEL] [    4.977849] usb 1-1.5: new low-speed USB device number 5 using dwc_otg
17-11-30-338| [        KERNEL] [    5.091968] usb 1-1.5: New USB device found, idVendor=045e, idProduct=0752
17-11-30-338| [        KERNEL] [    5.091982] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
17-11-30-338| [        KERNEL] [    5.091995] usb 1-1.5: Product: Wired Keyboard 400
17-11-30-338| [        KERNEL] [    5.092007] usb 1-1.5: Manufacturer: Microsoft
17-11-30-338| [        KERNEL] [    5.104469] input: Microsoft Wired Keyboard 400 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.0/0003:045E:0752.0002/input/input1
17-11-30-338| [        KERNEL] [    5.158806] hid-generic 0003:045E:0752.0002: input,hidraw1: USB HID v1.11 Keyboard [Microsoft Wired Keyboard 400] on usb-3f980000.usb-1.5/input0
17-11-30-338| [        initrd] [    5.664908] WTpassword empty.
17-11-30-338| /--- FILE "/bootmedia/configs/initrd.wtc" -----------------------
17-11-30-338| | clientIP = *
17-11-30-338| | config = network
17-11-30-338| | tftpIP = 192.168.10.83
17-11-30-338| \----------------------------------------------------
17-11-30-338| [        initrd] [    7.659436] Load ethernet drivers.
17-11-30-338| [        initrd] [    7.659521] modprobe smsc95xx.
17-11-30-338| [        KERNEL] [    7.674337] smsc95xx v1.0.4
17-11-30-338| [        KERNEL] [    7.730696] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:c5:b5:01
17-11-30-338| [        KERNEL] [    7.730918] usbcore: registered new interface driver smsc95xx
17-11-30-338| [        KERNEL] [    7.789673] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
17-11-30-338| [        KERNEL] [    9.248728] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
17-11-30-338| [        initrd] [    9.381735] dhcp: 336 bytes from 192.168.92.254.
17-11-30-338| [        initrd] [    9.381829] 00000000:0000013c00000000001100000a01c0fe0a01c05000430044013c000002010601  ...<..............P.C.D.<......
17-11-30-338| [        initrd] [    9.381904] 00000020:67458b6b00000000000000000a01c0500a01c80f00000000b827ebc5b5010000  gE.k...........P.........'......
17-11-30-338| [        initrd] [    9.381976] 00000040:0000000000000000000000000000000000000000000000000000000000000000  ................................
17-11-30-338| [        initrd] [    9.382048] 00000060:0000000000000000000000000000000000000000000000000000000000000000  ................................
17-11-30-338| [        initrd] [   10.880156] dhcp: 336 bytes from 192.168.92.254.
17-11-30-338| [        initrd] [   10.880272] 00000000:0000013c00000000001100000a01c0fe0a01c05000430044013c000002010601  ...<..............P.C.D.<......
17-11-30-338| [        initrd] [   10.880348] 00000020:67458b6b00000000000000000a01c0500000000000000000b827ebc5b5010000  gE.k...........P.........'......
17-11-30-338| [        initrd] [   10.880420] 00000040:0000000000000000000000000000000000000000000000000000000000000000  ................................
17-11-30-338| [        initrd] [   10.880490] 00000060:0000000000000000000000000000000000000000000000000000000000000000  ................................
17-11-30-338| [        initrd] [   10.910090] dhcp: server address 192.168.10.15.
17-11-30-338| [        initrd] [   10.910167] dhcp: 192.168.92.80/255.255.255.0.
17-11-30-338| [        initrd] [   10.910239] dhcp: default gateway 192.168.92.254.
17-11-30-338| [        initrd] [   10.910309] dhcp: DNS 192.168.10.15.
17-11-30-338| [        initrd] [   10.910377] dhcp: DNS 192.168.10.14.
17-11-30-338| [        initrd] [   10.910445] dhcp: domain udom.internal.com.
17-11-30-338| [        initrd] [   10.910513] TFTP IP 192.168.10.83 already specified.
17-11-30-338| [        initrd] [   10.910582] No boot file from DHCP.
17-11-30-338| [        initrd] [   10.910650] TFTP binary "", configs prefix "", using "/" slash.
17-11-30-338| Send broadcast WTCU discover.
17-11-30-338| [        initrd] [   10.912244] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
17-11-30-338| [          pfac] [   10.912823] Run /sbin/httpd.
17-11-30-338| [          pfac] [   10.912938] Ok, PID 573.
17-11-30-338| [        KERNEL] [   10.925805] random: httpd: uninitialized urandom read (48 bytes read, 114 bits of entropy available)
17-11-30-338| [        initrd] [   11.028210] USB: 0424:9514 Standard Microsystems Corp. SMC9514 Hub.
17-11-30-338| [        initrd] [   11.028353] USB: 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter.
17-11-30-338| [        initrd] [   11.028431] USB: 045e:0797 Microsoft Corp. Optical Mouse 200.
17-11-30-338| [        initrd] [   11.028501] USB: 045e:0752 Microsoft Corp. Wired Keyboard 400.
17-11-30-338| [        initrd] [   11.028572] [TFTP] Download file Everyone/list.wtc from 192.168.10.83.
17-11-30-338| [        initrd] [   11.046997] WTware TFTP v.5.4.46.
17-11-30-338| /--- FILE "/tmp/list.wtc" -----------------------
17-11-30-338| | #
17-11-30-338| | # Include files list.
17-11-30-338| | #
17-11-30-338| | # This way of terminals configuration is meant only for manual
17-11-30-338| | # terminals management. Graphic configurator doesn't read list.wtc,
17-11-30-338| | # doesn't read or edit files from ListIncludes directory. So be careful
17-11-30-338| | # not to configure one terminal in configurator and in list.wtc.
17-11-30-338| | #
17-11-30-338| | # This file uses such syntax:
17-11-30-338| | #
17-11-30-338| | #    01.02.03.04.05.06[([username@][terminalname])] [file [file ...]]] [# note]
17-11-30-338| | #
17-11-30-338| | # Examples:
17-11-30-338| | #
17-11-30-338| | #     02.03.04.05.06.07 file1
17-11-30-338| | #
17-11-30-338| | # It means that terminal with MAC-address 02.03.04.05.06.07
17-11-30-338| | # reads parameters from file ListIncludes/file1.
17-11-30-338| | #
17-11-30-338| | #
17-11-30-338| | #     03.04.05.06.07.08(vasja@) file2
17-11-30-338| | #
17-11-30-338| | # It means that terminal with MAC-address 03.04.05.06.07.08
17-11-30-338| | # reads parameters from file ListIncludes/file2
17-11-30-338| | # and sets user name "vasja" in "Windows login" window.
17-11-30-338| | #
17-11-30-338| | #
17-11-30-338| | #     04.05.06.07.08.09(term5) file6 file7 # John notebook.
17-11-30-338| | #
17-11-30-338| | # It means that terminal with MAC-address 04.05.06.07.08.09
17-11-30-338| | # is named term5, the same as specify clienthostname parameter,
17-11-30-338| | # and it reads parameters from files ListIncludes/file6 and
17-11-30-338| | # ListIncludes/file7.
17-11-30-338| | #
17-11-30-338| | #
17-11-30-338| | # To specify user name using non-latin letters open this file in
17-11-30-338| | # Notepad and save with Encoding: Unicode.
17-11-30-338| | #
17-11-30-338| [        initrd] [   11.050045] [TFTP] Download file Terminals/B8.27.EB.C5.B5.01/config.wtc from 192.168.10.83.
17-11-30-338| /--- FILE "/tmp/config.wtc" -----------------------
17-11-30-338| | template Hash-rdh1
17-11-30-338| | connection rdh1
17-11-30-338| | connection rdh2
17-11-30-338| | next screen
17-11-30-338| [        initrd] [   11.054283] [TFTP] Download file Everyone/all.wtc from 192.168.10.83.
17-11-30-338| /--- FILE "/tmp/all.wtc" -----------------------
17-11-30-338| | server=tcmgr.udom.internal.com;192.168.10.83;
17-11-30-338| [        initrd] [   11.058527] [TFTP] Download file Templates/Hash-rdh1.wtc from 192.168.10.83.
17-11-30-338| /--- FILE "/tmp/tmp.wtc" -----------------------
17-11-30-338| | [BOM]
17-11-30-338| | vnc=on
17-11-30-338| | vnc_password=hex:a4f4fc5d544013bebad15701ecf6fb4c
17-11-30-338| | display=1024x768
17-11-30-338| | skin=pk
17-11-30-338| [        initrd] [   11.061203] [TFTP] Download file Connections/rdh1.wtc from 192.168.10.83.
17-11-30-338| | server=192.168.15.30
17-11-30-338| | domain=udom
17-11-30-338| [        initrd] [   11.069327] [TFTP] Download file Connections/rdh2.wtc from 192.168.10.83.
17-11-30-338| | server=192.168.15.50
17-11-30-338| [        initrd] [   11.073510] [TFTP] Download file Connections/rdh1.wtc from 192.168.10.83.
17-11-30-338| [        initrd] [   11.077401] [TFTP] Download file Connections/rdh2.wtc from 192.168.10.83.
17-11-30-338| /--- FILE "/etc/config.compiled" -----------------------
17-11-30-338| [        initrd] [   11.166024] Hostname: "wtwB827EBC5B501".
17-11-30-338| [         httpd] [   11.414751] HTTP Server, WTware v.5.4.46/RPi
17-11-30-338| Everyone can control terminal by RSH.
17-11-30-338| RSH: listener is active.
17-11-30-338| [            gm] [   11.435210] WTware session manager v.5.4.46/RPi.
17-11-30-338| [            gm] [   11.435280] Add keyboard event1: Microsoft Wired Keyboard 400.
17-11-30-338| [         httpd] [   11.440206] Reread settings.
17-11-30-338| [         httpd] [   11.440277] Everyone can control terminal by HTTP.
17-11-30-338| [            gm] [   11.500063] EV_REL flag found. Add mouse event0: USB Optical Mouse.
17-11-30-338| [            gm] [   11.500135] Display mode: 1024x768, 32 bit, 0 Hz, modeline "", DDC enabled, connector 0.
17-11-30-338| [            gm] [   11.500178] Framebuffer device found.
17-11-30-338| [            gm] [   11.500217] LINELENBYTES 4096
17-11-30-338| [            gm] [   11.500256] VLEN 3145728
17-11-30-338| [            gm] [   11.507031] [TFTP] Download file Graphic/pk/wait.png from 192.168.10.83.
17-11-30-338| [            gm] [   11.540565] /tmp/wait.png: 464x195.
17-11-30-338| [            gm] [   11.548218] [TFTP] Download file Graphic/pk/popup.png from 192.168.10.83.
17-11-30-338| [            gm] [   11.563010] [TFTP] Download file Graphic/pk/menu.png from 192.168.10.83.
17-11-30-338| [        KERNEL] [   11.776368] random: nonblocking pool is initialized
17-11-30-338| [            gm] [   12.598984] /tmp/menu.png: 1024x768.
17-11-30-338| [            gm] [   12.629475] /graphic/winlg.png: 48x48.
17-11-30-338| [            gm] [   12.630492] /graphic/winsm.png: 38x38.
17-11-30-338| [            gm] [   12.630673] Everyone can control terminal by VNC.
17-11-30-338| [            gm] [   12.630757] VNC listener at port 5900.
17-11-30-338| [            gm] [  212.434962] Run '/sbin/resolver 0xe1a380 dns [192.168.15.30]', log '', env '', pid ''.
17-11-30-338| [          pfac] [  212.435114] Run /sbin/resolver 0xe1a380 dns [192.168.15.30].
17-11-30-338| [          pfac] [  212.435705] Ok, PID 582.
17-11-30-338| [          pfac] [  212.439499] Process pid 582 terminated, status 00000000.
17-11-30-338| [            gm] [  212.440103] 192.168.15.30 => 192.168.15.30.
17-11-30-338| [            gm] [  212.440197] Free ram before fork terminal client /sbin/rdpclient (session 1): 920272 Kb.
17-11-30-338| [            gm] [  212.440279] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
17-11-30-338| [          pfac] [  212.440360] Run /sbin/rdpclient 1.
17-11-30-338| [          pfac] [  212.440923] Ok, PID 583.
17-11-30-338| [ rdpclient 583] [  212.979421] RDP Terminal Client, WTware v.5.4.46/RPi, pipe 1, pid 583.
17-11-30-338| [ rdpclient 583] [  212.980130] Make RDP session with 192.168.15.30, port 3389.
17-11-30-338| [ rdpclient 583] [  212.980203]  No username.
17-11-30-338| [ rdpclient 583] [  212.980246]  No password.
17-11-30-338| [ rdpclient 583] [  212.980289]  No PIN.
17-11-30-338| [ rdpclient 583] [  212.980372]  Domain: "udom".
17-11-30-338| [ rdpclient 583] [  212.980411]  No shell.
17-11-30-338| [ rdpclient 583] [  212.980447]  No directory.
17-11-30-338| [ rdpclient 583] [  212.980485]  Window: 1024x768@24.
17-11-30-338| [ rdpclient 583] [  212.980522]  PFlags 0x0000002F.
17-11-30-338| [ rdpclient 583] [  212.980559]  Keyboard 00000409:00000000.
17-11-30-338| [ rdpclient 583] [  212.980596]  My hostname "wtwB827EBC5B501".
17-11-30-338| [ rdpclient 583] [  212.980633] TCP: connecting to 192.168.15.30:3389.
17-11-30-338| [ rdpclient 583] [  212.980923] TCP: connection with 192.168.15.30:3389 established.
17-11-30-338| [ rdpclient 583] [  212.980965] Turn keepalive on.
17-11-30-338| [ rdpclient 583] [  212.981286] Free ram after buffers allocation: 919644 KB.
17-11-30-338| [ rdpclient 583] [  213.006613] Process RDP server certificate.
17-11-30-338| [ rdpclient 583] [  213.006675] RDP5 encryption (X.509).
17-11-30-338| [ rdpclient 583] [  213.398551] 32-bit color.
17-11-30-338| [ rdpclient 583] [  246.305626] errorInfo 0x00000000.
17-11-30-338| [ rdpclient 583] [  246.306683] Receive Disconnect Provider Ultimatum.
17-11-30-338| [            gm] [  246.306774] TSClient gracefully end.
17-11-30-338| [          pfac] [  246.308551] Process pid 583 terminated, status 00000009.
17-11-30-338| [            gm] [  250.087936] Run '/sbin/resolver 0xe1a380 dns [192.168.15.30]', log '', env '', pid ''.
17-11-30-338| [          pfac] [  250.088088] Run /sbin/resolver 0xe1a380 dns [192.168.15.30].
17-11-30-338| [          pfac] [  250.088678] Ok, PID 584.
17-11-30-338| [          pfac] [  250.092422] Process pid 584 terminated, status 00000000.
17-11-30-338| [            gm] [  250.093028] 192.168.15.30 => 192.168.15.30.
17-11-30-338| [            gm] [  250.093148] Free ram before fork terminal client /sbin/rdpclient (session 2): 919852 Kb.
17-11-30-338| [          pfac] [  250.093230] Run /sbin/rdpclient 2.
17-11-30-338| [            gm] [  250.093274] Run '/sbin/rdpclient 2', log '/tmp/rdpclient.out', env '', pid ''.
17-11-30-338| [          pfac] [  250.093878] Ok, PID 585.
17-11-30-338| [ rdpclient 585] [  250.525731] RDP Terminal Client, WTware v.5.4.46/RPi, pipe 2, pid 585.
17-11-30-338| [ rdpclient 585] [  250.526390] Make RDP session with 192.168.15.30, port 3389.
17-11-30-338| [ rdpclient 585] [  250.526445]  No username.
17-11-30-338| [ rdpclient 585] [  250.526485]  No password.
17-11-30-338| [ rdpclient 585] [  250.526525]  No PIN.
17-11-30-338| [ rdpclient 585] [  250.526563]  Domain: "udom".
17-11-30-338| [ rdpclient 585] [  250.526601]  No shell.
17-11-30-338| [ rdpclient 585] [  250.526649]  No directory.
17-11-30-338| [ rdpclient 585] [  250.526686]  Window: 1024x768@24.
17-11-30-338| [ rdpclient 585] [  250.526723]  PFlags 0x0000002F.
17-11-30-338| [ rdpclient 585] [  250.526760]  Keyboard 00000409:00000000.
17-11-30-338| [ rdpclient 585] [  250.526797]  My hostname "wtwB827EBC5B501".
17-11-30-338| [ rdpclient 585] [  250.526833] TCP: connecting to 192.168.15.30:3389.
17-11-30-338| [ rdpclient 585] [  250.528382] TCP: connection with 192.168.15.30:3389 established.
17-11-30-338| [ rdpclient 585] [  250.528421] Turn keepalive on.
17-11-30-338| [ rdpclient 585] [  250.528703] Free ram after buffers allocation: 919852 KB.
17-11-30-338| [ rdpclient 585] [  250.543852] Process RDP server certificate.
17-11-30-338| [ rdpclient 585] [  250.543912] RDP5 encryption (X.509).
17-11-30-338| [ rdpclient 585] [  250.857863] 32-bit color.
17-11-30-338| [ rdpclient 585] [  259.930719] LOGON_EX_LOGONERRORS 0xfffffffe 0x00000023.
17-11-30-338| [ rdpclient 585] [  291.865491] SessionId 0x00000023: udom\testuserb.
17-11-30-338| [            gm] [ 2438.086019] /tmp/popup.png: 200x30.
17-11-30-346| Connection from wtc.exe at 192.168.10.83.
Posted: Tue Sep 27, 2016 12:46 pm
I see no errors in log.
Mouse works outside corrupted RDP session, so it's not a hardware problem.
Perhaps, some kind of mouse software or driver for exotic mouse installed on server. Which process do you see in Task Manager running in RDP session just after Login, before you run anything?
Posted: Wed Sep 28, 2016 10:24 am
by Alon
I know it's weird, it happens randomly, while the user is already working, happens like twice a week, doesn't sound too much of a problem but when there are many users it is a pain in the b.
Windows clients are not affected Win CE, Win 98, Xp, 7, 10.
Handles  NPM(K)    PM(K)      WS(K) VM(M)   CPU(s)     Id ProcessName
     85       8     1288       4148    43     0.14   1492 armsvc
    131      11    12608      13956    52     0.33    940 audiodg
    863      45    33228      67852   253    28.00   3040 CcmExec
     38       5     2144       4824    50     0.13   1372 conhost
    701      13     2640       5072    47     0.63    448 csrss
     75       9     1884       4120    40     0.14    500 csrss
    220       9     2140       5364    43     0.72   3108 csrss
     73       7     1568       4340    50     0.08   3912 dwm
    560      40    20048      34600   210     3.42   2836 explorer
      0       0        0         24     0               0 Idle
    156      20    11468      18492    76     0.33   1692 inetinfo
    182      24     8820      16488    90     0.23    876 LogonUI
    937      31     8328      17420    53    40.58    612 lsass
    252      10     3120       6316    33     0.53    620 lsm
    154      17     3624       7848    60     0.08   1876 msdtc
    664      62   147648     177800   442   159.53   2904 MsMpEng
    161      19     4692      14232    90     0.39   1940 nscp
    511      29    69648      77664   632     5.22   3196 powershell
    158       8     1876       5236    61     0.05    792 rdpclip
    271      22    20436      22224   223     0.45   3580 SCNotification
    287      14     5700      11192    45    77.39    604 services
     35       1      540       1256     4     0.09    360 smss
    242      15    27508      22724   548     0.89   1740 SMSvcHost
    445      36    16888      26876   134     3.77   1288 spoolsv
    158      19     6172       9948    42     0.19    380 svchost
    320      26     6644      11992    66     1.11    432 svchost
    428      28     9500      17688    91     4.08    504 svchost
    372      15     5416      10996    55     3.89    716 svchost
    475      41    17892      19176   125     2.27    732 svchost
    352      15     4252       8480    37     3.20    796 svchost
     82       6     1960       4868    26     1.52    916 svchost
    454      23    17308      18068    75    25.58    948 svchost
   3181      59    68672      87488   274   233.48   1008 svchost
    306      33     6704      11624    52     0.63   1144 svchost
    266      18     4268       9544    51     0.44   1360 svchost
    102      17     4824       9584    40     0.20   1608 svchost
    160      15     4684       9240    72     0.16   1644 svchost
     64       7     1532       4176    25     0.17   1720 svchost
     61       7     1392       4004    25     0.05   1980 svchost
    364      20     9908      17272    67     1.86   2456 svchost
    113      14     2208       5832    33     0.09   2492 svchost
    542       0      124        300     3    22.20      4 System
     93       8     1956       5532    31     0.06   1752 taskeng
     94       8     2128       5680    51     0.08   2800 taskeng
    243      23     7152      11612   122     0.23   2976 taskhost
    128      11     2856       8880    87     2.52   3492 taskmgr
    197      22     9184      14888    74     0.17   2008 w3dbsmgr
     87      10     1748       4832    44     0.17    508 wininit
     82       6     1764       4752    24     0.20    540 winlogon
    124       9     2480       6064    31     0.42   2912 winlogon
    161      17     7104      12076    61     0.20   1216 WmiPrvSE
    130      12     7032      11972    60     3.34   2348 WmiPrvSE
    317      16     6280      12252    54     0.42   2396 WmiPrvSE
    433      25    20764      29632    97    42.31   2440 WmiPrvSE
    141      13     4972      11852    56     0.69   2788 WmiPrvSE
    127      10     2968       6700    31     0.03   2948 WmiPrvSE
Posted: Thu Sep 29, 2016 9:21 am
Process list is taken inside wtware rdp session? Looks good, I don't see wrong process.
Can you test recent freerdp? In freerdp, input go through "fast path" by default while wtware and AFAIK rdesktop use original rdp method. If freerdp will work, I'll switch wtware to "fast path" too.
Posted: Wed Oct 05, 2016 9:59 am
by Alon
Yes, single user logged in.
I would love to, do you have a beta with "fast path"? i could try it on a couple of clients.
thank you.
Posted: Fri Oct 07, 2016 2:02 pm
You wrote, that you experience the same on thinstation linux with rdesktop v1.7.1. Could you try it with recent FreeRDP ?
Posted: Thu Nov 03, 2016 12:32 pm
by Alon
The problem is that I cannot change the client , it was built using TSOmatic (web wizard), so I cannot change what is built in the image.
I was hoping i could do beta test of WtWare with fast path FreeRdp.
Thank you
Posted: Thu Nov 03, 2016 3:25 pm
I can not run FreeRDP inside wtware, we use our own RDP client. And implementing "fast-path" input in wtware is too hard just for testing. I'm not sure that it will help, and it's a lot of coding. Sorry, I have no solution :(
Posted: Mon Nov 28, 2016 2:56 pm
by Alon
Since v5.4.56 my test users have not reported this problem since upgrading (~17/11).
Thank you.
