How to change IP setting & TFTP server remotely ?
nicodep
Post by nicodep »
Hi Aka,
I test your wtware solution with PI3 and it's fantastic !
Question : how to change remotely PI3 tcp IP from IP static to DHCP, and modify TFTP server IP ?
I can accces localy via DEL touch ... but remotely ?
Thk
Re: How to change IP setting & TFTP server remotely ?
Sorry, there is no access to these settings.
nicodep
Post by nicodep »
Hi Aka,
Same question because i have now 80 PI3 in different shop and we change local router
I need to change remotely PI3 IP TCP config from static to DHCP ?
No way :( The same problem will be with updating to newer wtware version.
Write 80 new SD cards and ask users to replace.
J1mbo
Post by J1mbo »
Worth noting that network boot is now working, so new SD cards are not needed anymore (once RPi firmware is updated though).
nicodep
Post by nicodep »
J1mbo wrote:Worth noting that network boot is now working, so new SD cards are not needed anymore (once RPi firmware is updated though).
Hi J1mbo, can you explain your solution ?
for info, i can't add parameter on each shop because the dhcp is inside the router
J1mbo
Post by J1mbo »
I would configure the router for DHCP relay in that case to your central location.
