ELO 1915L 19" IntelliTouch calibration
peter
Post by peter »
Hello, we are using ELO 1915L 19" IntelliTouch with WTware OS, but the calibration is not prefect. When I press touchscreen, pointer moves correctly. In the middle of the screen the calibration is ok, but on the edges the pointer is shifted by approximately 1 - 1.5cm. Is there any solution, how to refine the calibration? Thanks for your answer.
Re: ELO 1915L 19" IntelliTouch calibration
Not for now. We'll think about it.
