Sound Broken in 5.4.30 for Pi3
J1mbo
Post by J1mbo »
We noticed that RDP audio isn't working with 5.4.30 (was working with Pi3 beta, 5.4.18 based I think). Logs show this:
usbcore: registered new interface driver snd-usb-audio
     hardware.cpp ( 1095): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
     globalConfig.cpp ( 1631): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
 ERROR: Sound card not found. Disable sound.
J1mbo
Re: Sound Broken in 5.4.30 for Pi3
Post by J1mbo »
Here is the (working) log from 5.4.18:
Unpack /bootmedia/packages/pi2-alsa.
[            gm] [   12.454845] modprobe snd-bcm2835.
[            gm] [   12.466010] modprobe snd-usb-audio.
|   0: [ 0]   : control
|  33:        : timer
[        KERNEL] [   12.478037] usbcore: registered new interface driver snd-usb-audio
[            gm] [   12.478336] /dev/snd/pcmC0D1p character device.
[            gm] [   12.478393] /dev/snd/pcmC0D0p character device.
[          pfac] [   12.478449] Run /sbin/rdpsnd sndvol 100 100 50.
[            gm] [   12.478473] /dev/snd/controlC0 character device.
[            gm] [   12.478516] /dev/snd/timer character device.
[          pfac] [   12.478580] Ok, PID 594.
[            gm] [   12.478611] Preconfigure ALSA.
[          pfac] [   12.478676] Run /sbin/rdpsnd 1 0 100 0 -1.
[            gm] [   12.478712] Run '/sbin/rdpsnd sndvol 100 100 50', log '', env '', pid ''.
[          pfac] [   12.478777] Ok, PID 595.
[            gm] [   12.478800] Run sound daemon.
[            gm] [   12.478840] Run '/sbin/rdpsnd 1 0 100 0 -1', log '', env '', pid ''.
[        rdpsnd] [   12.480915] RDP Sound Redirector, WTware v.5.4.18/Pi2.
[        rdpsnd] [   12.484249] Card 'ALSA'/'bcm2835 ALSA'.
[        rdpsnd] [   12.484378] Mixer name: 'Broadcom Mixer'.
[        sndvol] [   12.484447] Card 'ALSA'/'bcm2835 ALSA'.
[        rdpsnd] [   12.484472] Components: ''.
[        sndvol] [   12.484513] Mixer name: 'Broadcom Mixer'.
[        sndvol] [   12.484554] Components: ''.
[        sndvol] [   12.484594] Controls: 6.
[        sndvol] [   12.484634] ALSA: control 'PCM Playback Volume'.
[        sndvol] [   12.484675] ALSA: control 'PCM Playback Switch'.
[        sndvol] [   12.484715] ALSA: control 'PCM Playback Route'.
[        sndvol] [   12.484756] ALSA: control 'IEC958 Playback Default'.
[        sndvol] [   12.484796] ALSA: control 'IEC958 Playback Con Mask'.
[        sndvol] [   12.484837] ALSA: control 'IEC958 Playback PCM Stream'.
[        sndvol] [   12.484877] Inactive control IEC958 Playback PCM Stream'.
[        rdpsnd] [   12.484945] Controls: 6.
[        rdpsnd] [   12.485046] ALSA: control 'PCM Playback Volume'.
[        rdpsnd] [   12.485093] ALSA: control 'PCM Playback Switch'.
[        rdpsnd] [   12.485136] ALSA: control 'PCM Playback Route'.
[        rdpsnd] [   12.485177] ALSA: control 'IEC958 Playback Default'.
[        rdpsnd] [   12.485218] ALSA: control 'IEC958 Playback Con Mask'.
[        rdpsnd] [   12.485258] ALSA: control 'IEC958 Playback PCM Stream'.
[        rdpsnd] [   12.485298] Inactive control IEC958 Playback PCM Stream'.
Onboard sound at RPi should be enabled in config.txt at SD card now.
J1mbo
Post by J1mbo »
Thanks, so it is:
dtparam=audio=on
kmen
Post by kmen »
and the sound option should be on?
sound=on
J1mbo
Post by J1mbo »
Yes. To edit config.txt, you can use a browser, http://[terminal-ip]/
mstorck
Post by mstorck »
I have set
sound=on
in configuration file. I also set
dtparam=audio=on
in config.txt and finally I also set
hdmi_drive=2
in config.txt. But I still have these log entries:
[            gm] [   77.376233] Unpack /bootmedia/packages/pi2-alsa.
[            gm] [   77.426514] modprobe snd-bcm2835.
[            gm] [   77.435422] modprobe snd-usb-audio.
[        KERNEL] [   77.453718] usbcore: registered new interface driver snd-usb-audio
[            gm] [   92.457032]         hardware.cpp ( 1095): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[            gm] [   92.457184]     globalConfig.cpp ( 1624): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[            gm] [   92.457267] ERROR: Sound card not found. Disable sound.
and of course no audio/sound within an RDP session.
I'm running
WTware v.5.4.40/RPi supervisor.
on RPi3.
Another ThinClient OS for RPi has working sound on the same hardware.
Any ideas to get this working with WTware?
Please, send me whole log and all files on SD in zip to aka@pxe.ru
nhelder
Post by nhelder »
Hi, all~
I came across this thread as I was having issues getting audio out of the audio jack for my Pi3 when running WTware.
The eventual combination of settings that did the trick for me, in the config.txt file, were:
# hdmi_drive  result
# 1           Normal DVI mode (No sound)
# 2           Normal HDMI mode (Sound will be sent if supported and enabled)
hdmi_drive=1
# Setting this to 1 pretends that all audio formats are unsupported by the display.
# This means ALSA will default to the analogue audio (headphone) jack.
hdmi_ignore_edid_audio=1
dtparam=audio=on
# Enable improved audio driver
# https://www.raspberrypi.org/forums/viewtopic.php?f=29&t=136445
audio_pwm_mode=2
...just thought I would share for others that might run in to a similar issue.
- Nathan
P.S. For completeness, my config file looks simply like:
server=--new--
graphic=adf
sound=on
sound_rate=44100
sleep=20
connect_timeout=5
connection
